DIY D1 I/V STAGE
sources are down ( to negative ) and drains are up ( to positive ) ;
I never look at symbols in schematic , mostly because I just can't remember what's source and what's drain on them ...... :rofl:
so - those details - mistakenly reversed symbols , reversed caps and zeners - I usually can't spot them
Please check the datasheet of the dac.
measure dc at the source of t1a/b and/or the output pins of the dac. should be the same.
How is it all wired up?: cdplayer/i2s signal -> reciever/dac -> i/v?
regards
Output pins DAC & source of t1a/b both channels -0.740VDC, so it's the same in DAC like in the I/V.
Is wired: PC usb // HiFace usb receiver s/pdif output // CS8414 receiver PCM1704 DAC SE.
Thks for help.
before connecting D1 to PCM - you need to set P1 to have approx. 0V at I/V input , measuring against gnd
then you connect D1 to PCM , power up everything and do fine setting after some time ( when everything is in temp. equilibrium .
simple as that .
if something is not working - something is dead .
either PCM or D1 .
edit :
schematic with approx. voltages attached ; what is important is just red 0V value ;
all other voltages approximately , and valid only for troubleshooting purpose
simple as that .
either PCM or D1 .
edit :
While adjust DAC I measured I/V:
Left channel
R6 // Drain T1 // C3 14.20V
R5 // Gate T1 // C2 // P1 3.45V
C5 // Source T2 // R4 10.77V
R2 // Source T1 0 V
Right channel
R6 // Drain T1 // C3 14.17V
C5 // Source T2 // R4 10.74V
R2 // Source T1 0 V
Are the measurements right?
After 9 days of extensive listening sessions I can conclude that sounds a lot better CS8414+DF1704+PCM1704+D1 I/V NP than BII+Legato in single end & balanced mode vs single end mode PCM1704+NP D1 I/V, details:
CS8414+DF1704+PCM1704 with Erno Borbely series regulators (one +5V (CS8414+DF1704 & two +-5V for PCM1704, NP D1 I/V LM317+LM337 for +-30V
BII+Legato with Salas regs V1.2R for BII, Salas reg V1.0 remote sense for Legato & set of 3 Trident regs for BII
I use Sony Vaio laptop like source, both share USB 2.0 HiFace with Salas 1.0 remote sense reg
N.B. Erno Borbely adviced me that PCM1704 sounds better than BII, next step I will change Legato I/V for Classic Pass Labs D1 I/V with an ESS Dac designed by Owen (opc)
