DIY D1 I/V STAGE
it's hard to say that Papa B. isn't shunt aficionado , when he made one of most brute shunt regs around :clown:
anyway - whatever you change - you must recheck that important point .
if you have no intention to use proper shunt instead of dreky LMs - at least put proper cap multipliers between them and D1 ;
The PCM1704 was used for the 24/96 update. The PCM63 was only 20 bits.
I still like the PCM63 sonics and the guys who designed both like the 63 better for some internal reason. The 1704 had less current swing hence the use of two.
Wayne - just curious ......
you use 1704 instead of 63 from sonic , or availability reasons ?
Just curious too 😉
Would it also apply to pcm 1794 in the same way?
Manu
dont forget bleeder resistors to ground at the outputs to shunt any dc leakage from the caps. i would say by the look of your schematic there above, that they are the unmarked resistors from each output to starground
