Sorry, platter, stock OL with their mat, i will test the Rega one i have and post the differences.......M
Hugh, lots of subjects in there!
The PTA is an Origin Live arm as well, i believe they make excellent kit.
The RTA is my own concept, it was all Carlos fault really, he had done LC and it seemed obvious to me that the vertical motion should be taken on the carriage not by moving the whole set of rails, Carlo thought it unlikely, i didn't know it was difficult so i had a go, i did dozens of experiments, i used to record them methodically but no more, if it seems better it becomes the current arm.
Carlo has now done an excellent version, far better built than mine where he keeps the paralelogram almost flat, its all on the LTA thread.
Then several people encouraged me to measure things, i resisted for a while but when i started it was a great benefit and i had often fooled myself by thinking if i thought it was a good idea and worked hard at it, it must be an improvement and often listened and believed it when measurements showed otherwise.
I am now at a point where the consistency of the apparatus is a limiting factor, i can measure the same thing twice and not get the same answer....
I did test rega and ol mats earlier, no mat was poor but the other two varied, one better sometimes the other at other times.
With measurements done my way you only see the dominant result, so one artefact can hide another, so you have to remove the first to reveal the other..
Anyway, other subjects, under my plinth is a sand box, this is in my view the separation level, vibration coming up is supposed to die in the sand box and any going down is supposed to be absorbed there as well. so my construction is to try and get vibrations caused by the sylus out through light stiff parts to the arm base and into the sand box.
Oh, and the rails are polished stainless tubes, also 95% sand filled, i tried foam rubber, blu tack and sand to get to there.
M
