After having heard improvements in clarity after "treating" CDs with my old head demagnatiser (I no longer own a tape deck.) I decided to build a motorised solution inspired by the commercial CD clarifier.
A surplus CD motor, a self gripping spindle from a broken lap top CD drive, transformer, push down toggle and some caps and bridge wee glued and cable tied into a plastic box. The results are good!!!!
Here are some pics.
Here are some pics.
Shoog said:What the physical principle on which your CD clarifier works ?
Shoog
Ooooooh, enjoy picking at scabs, do we?
For enquiring minds:
Apparatus and method for reducing electronic relaxation noise present information recording medium
and
Information recording disc demagnetization apparatus
Hope this helps
James
and
Hope this helps
James
I like the work on the aparatus, and I also find the patent interesting. However an aparatus doesn't require you to prove its effectiveness to apply for a patent (or am I wrong).
Has it been demonstrated scientifically that CD's become magnitised and that this has an effect on the "tone" ? Can anyone point me to a paper on the proven principle. I am genuinely interested, and hence my restraint in my original statement.
Shoog
Shoog
No scientific clue......
Heard the Bedini years ago and tried my old head demag thingy and heard the same kind of difference.
Just decided to make it more user friendly.....
The difference is varied depending on discs treated (play times maybe) but afeter reading the patent notes I am going to treat discs upside down (mag field will then be closer to label side) and hear what happens....
This audio game is just bizarre.....
Shoog said:I like the work on the aparatus, and I also find the patent interesting. However an aparatus doesn't require you to prove its effectiveness to apply for a patent (or am I wrong).
You are not wrong. Not only that, but it doesn't have to actually work for a patent to be granted. There's patents on all kinds of outrageous nonsense.
I am sure that some of you will also need this Intelligent Chip CD upgrade with a valid scientific explanation of it's operation. .
Best regards,
Jaka Racman
Best regards,
Jaka Racman
Bill Fitzpatrick said:I filed a patent on the inclined plane last year. It was rejected.
So now we know why you have been so grumpy!
Since when is the reflective layer magnetic? I mean, any more so than I am.
I read the article on the chip thing. Not at all enlightening as to how a magnetic clarifier would work as they are using entirely different principles. Not entirely convinced by the scientific babble about the chip, I understand the principles he is describing - but in relation to a CD I think hes pulling our legs.
The real problem with verifying the worth of any of these devises is that audio memory is so short term. Simple taking the CD out of the CD player, having just listened to it, and "clarifying it", and then popping it back in - the chances of really remembering the difference is tiny, if it at all subtle. The user expectation of an improvement is likely to swamp any actual change.
Shoog
Shoog
SY - thats a very disturbing avatar you have switched to - can you change it back
I agree! Is that Michael Jackson in his latest transformation?
Cheers
Shoog said:SY - thats a very disturbing avatar you have switched to - can you change it back.
Shoog
Cheers
At least two people don't like it. That's enough reason to keep it.
- Digital Source
- DIY CD Clarifier (pics)
