Did I kill my Philips CD-60?
I replaced C2521 47uF. The machine doesn't seem to recognize a disc has been inserted.
When I press Power+Play+Stop, I get
00 00 P 1.07
When I press
the display goes to 00 01 and the laser bobs up and down. I don't detect a red light from the laser.
I replaced it because my unit had a problem, and I had read that this cap causes trouble.
The original blue cap had the gray stripe closer to the edge of the PCB, so I oriented the new cap's green stripe the same way.
@bajjisw The unit made a whistling-whining noise, a steady tone of about 600Hz, which could be heard over the music. I was told it might have had something to do with "wobble frequency".
@wheijke I will certainly check that later today.
Please read the entire service manual. I've generally found them to be well written and useful.
Does it have debug flowcharts? The one I used had to be done in sequence.
It may be that the combination of mounting and tilting the unit as in the picture makes the CDM mechanism level.
@bajjisw I have been through the entire SM, numerous times. The Fault Finding Tree calls for Service Positions 0, 1, 2, and 3, yet nowhere does it depict them.
I have attached a section of the Tree. The remainder of the tests require two Philips Test Discs, which cost $200 and $250.
I have also attached a portion of the SM from a different machine, which would be more helpful to someone at my level.
@electron-ic I will get a digital multimeter, then I'm sure I will have some questions for you!🙂
