Destroyer x Amplifier...Dx amp...my amplifier
Carlos,
I just got a report from the hospital... it reads:
"Uncle Charlie (aka TC) was here briefly for a check-up... and he did check-up alright - not a single nurse went unchecked.
It seems that (despite not being authorized to do so) TC went around with a soldering iron trying to improve all medical equipment he could get his hands on. Truth be told, now all the beeping has a much better bottom end.
We hope we will not see him until his daughter graduates."
Thanks for being you Carlos - your friends are wishing you a speedy recovery and many years of happy amplifier building.
Unbeliavable that you have discovered!
I really love nurses.
regards,
Carlos
Want to be 20 again ?
Hi Carlos, the body heals faster with a positive attitude. It's been proved in the laboratory ! That's why they say that 'happy' patients overcome their ailments easier and faster than others. Look up Genome theory. Your cells react to your state of mind ! I think you don't have a problem with that ! If there is a problem , just bring along a few nurses ! 😀
But seriously here is something you can read about. It is supposedly a very old concoction but should be safe for anybody. Me and many of my friends take this and it's done wonders for us ! It's not taken 365 days a year but at least for 2 to 3 months continuously at first. Then you can take it off and on for a week at a time to keep the arteries clean . Is there proof ? Look at the angiogram.
In addition I have friends with stents and additional artery blocks who took it and when they went for their tests the docs were amazed that the other blocks had almost completely gone ! One doc said, "continue to take that juice you are taking, it's working very well for you "! When the arteries get clean a whole lot of OTHER ailments also go away.
Ask your doc ( if you can take it ...you should be able to...) and then watch yourself live happily for another 25 years ! 😉
EVERYONE should try it , never know what problems it will fix in your system !
You don't have to believe in it. Just try it for a month at least ! It uses garlic but doesn't smell of garlic. This is because the lime kills the garlic smell.
We don't make it like it's described as we think it might kill some chemicals in the garlic by simmering for 30 minutes. Some friends simmer it for 5 mins on very low heat to kill any bacteria in the water.
But here is our method which seems to work for us :
1 inch ginger , cleaned and roughly chopped
4 or 5 garlic cloves crushed
1 whole lime with skin ( seeds removed) chopped into 8 pieces
50 ml water
50 ml Apple Cider Vinegar ( best if it is 'unfiltered' like Braggs)
beat up very well in a blender ( about 2 to 3 minutes)
Pour into a clean thick cloth or fine sieve and squeeze out the liquid. Add some more water ( about 15 ml ) to the blender and get out remaining mixture and sieve it also.
Add some honey to this, which is 1/3 the volume of this extract.
Pour into a clean sterilized glass bottle and shake well. Store in the refrigerator. Take 15 to 30 ml each time before food.
You could simmer it for 5 to 10 minutes or so to kill bacteria ! This mix is more dilute than the original recipe and so you need to take a little more volume wise.
Remember to use Organic garlic or "non-irradiated" garlic . Radiation kills the potency of the garlic. If the garlic comes from China it is surely irradiated , done to increase the shelf life !
I actually scrape off the skin of the lime and add it to the mixture before beating it up. US labs claim that the skin of lime contains chemicals 10,000 times more potent than chemotherapy. So any 'budding' cancer cells might get killed ! Any proof it works ? No. But what the heck, why not ! It tastes good . 🙂
Those who become 20 again please report back !! 😀
( Note: The potency of the mixture diminishes rapidly with time. That's because the chemicals in garlic keep changing structure with time . That's why you need to refrigerate it , to keep it working longer. However never make too much . Just enough to last 'at the most' 4 days ! Fresh is always BEST ! )
Garlic , the miracle medicine ?
I have here a book about all the discoveries about garlic from labs around the globe. One interesting one is that if Garlic is 'fully crushed' and kept for over 1 hour the chemicals in the small cells mix and produce the worlds 'most potent natural antibiotic' . Also supposed to be 'broad spectrum (?)' meaning it can be effective for a much larger range of issues than synthetically produced antibiotics.
It remains in this 'antibiotic form' from 1 to 3 hours after crushing it. After that it slowly changes in structure and becomes less effective as an antibiotic !
You can take it anytime, can't over medicate yourself or have any side effects unless you are allergic to it. But people with major stomach ailments better talk to a doc. It could burn damaged stomach linings. Done properly, it can also heal them !
It's taken ( 1 crushed clove ) mixed with 1 tsp of honey. You can mix it with food or add a sufficient quantity of water ( 1/ 2 to 1 full glass of water ) and drink it ALONG with food ! The water reduces it's concentration and makes it less difficult for some people as it mixes with the food in the stomach.
Drink the juice of 1/2 a 'lime' after the meal. It will kill any smell of garlic ! Swirl it around your mouth before swallowing.
Those who are feeling rusty and 'old' MUST try this ! It's easy. You need to do it continuously at least 2 weeks or more to see any benefits ! It's been very helpful for a lot of people here!
See what it does to your Libido ! 🙂
We have these things you told me and i gonna prepare the formula
If depends on happyness...natural happyness..then i gonna heal very fast.
In the reality i have not more pain in my left arm...maybe something blocked that vanishes...well...will continue measuring nurses at the hospital.🙂
Thank you Ashok.....good words, great ideas....very brazilian style medicine you told me..... our indians use to teach us this stuff.
- Simon!...good to see you...already answered your comments in facebook dear Simon.
regards,
Carlos
I am proud to say the third batch of Brazilian Dx Super A pcboards
Already finished..not more available!
300 hundred kits playing nice sound in Brazil...people use to say no one can beat..... i use to agreed, but i know someone that have beat.
Hugh Dean....this one can do it even better..... sadly i perceive he is not in very good shape..i am feeling that down here...... very sad to see Hugh with disease.
Yes Simon....can beat the Blame... despite Dx Blame still a very good amplifier...but i could make it a little bit better, the bass in this one is stronger..also very high frequencies are awesome..... but i have perceived it is more critical to part values and need some tuning to overcome the Dx Blame ST....it is not all units that beat the Dx Blame...we have to tune it.... it is less "plug and play" then the Dx Blame .
Juan Vargas still have pcboards...he is protecting the stuff....people from Asia ask him and he is not providing to Asia due to copies..... this way he still have some samples of blue pboards..... the best pcboard is that blue one you see...the one made by Juan.... technically the best one in layout design related to attention on details related to coupling and heat....or lack of coupling in between components and less heat effects.
To the ones uses high power...or low impedance ...i do suggest to lift drivers from the main heatsink and provide them with small heatsinks with these components stand up ... this amplifier can go above 250 watts RMS easy..so.... you must take care related the heat generated that can produce annoying results if your heatsink goes operating with temperatures higher than 70 degrées celsius.
regards,
Carlos
..... it is a very flavoursome and invigorating thing...........
I will let you know as soon as I break into a run up the stairs again.
John
Yes, it does taste quite nice and does NOT have a strong garlic smell which many are afraid off !
When the arteries start clearing , a whole range of subtle improvements start taking place. You must give it time. I'd say things get noticeable within a month.
Energy levels do go up. For it to work really well you need some exercise too. Say at least 30 mins normal walk a day would be good.
But I will NOT be surprised to see you running up the stairs eventually ! I can do it now ! I couldn't for a few years.......in between !
Mr. Ashok you are a life saver. I,ve been using this recipe of yours along with some things Mrt.carlos suggested I try..Today my blood pressure reading was 105_62_ pulse 95..WOW
This is the best reading I,ve ever had in many many years..Thank You And Mr. Carlos
May as well tell you about Cinnamon and honey !
According to old texts , if you take 1 level teaspoon of cinnamon powder mixed with 1 tsp of honey ( tastes quite nice !) daily before ( any ) meal , they claim you can 'never' get a heart attack or a stroke due to clotted red blood cells. It supposedly prevents red cells from sticking to each other and so can't block clogged arteries.
In another part of the text it said " It will make you feel like a 20 year old " !
I've been taking it off and on for quite some time.
Hi Evette,
I believe all ancient systems of medication using natural material are based on sound principles 'given to us by someone' who knew all about it. This kind of knowledge should be free and spread as much as one can. I'm sure it was widespread in the olden times. We just lost it because of our 'modern scientific approach'.
Luckily some of it still floats around among some groups of people who , because of the Net, are able to talk about it and suggest it to those who might benefit from it.
As long as it uses natural materials and is safe there should be no harm trying it out. It either works or doesn't . No need to wait another 100 years to get confirmation from a 'modern corporate (!) laboratory'.
Look at 'turmeric'. It's a natural material used in Asian food for thousands of years on a daily basis. It is also used for medicinal applications and can do wonders for stomach ailments. Now the West has tried to 'patent' it ! For what ? Monetary Greed ! What a shame. Knowledge MUST be FREE. It doesn't belong to anyone ....it belongs to ALL. 😉
Hello folks.
I am really interested into building this amplifier, but I cannot find any PCB files or gerber files to make the PCB myself.
Also it is so confusing to find the last version, reading hundreds of posts is not good.
At least there must be a location to store the final versions, and why there is no PCB files?
How I can order the PCBs?
No pcboards available - no gerbers available
This is a DIY circuit, schematic, layout and instructions posted here:
Greg's Web Site
There are Chinese available pcboards in the internet..they are not mine, they have not permission and we will not help piracy.
If you want to give us the pleasure to see you building by yourself, then take a chair and be our host.
Greg Erskine (gerskine in our forum) made something alike... try to find his circuit around..maybe you gonna have pcboards for his circuit.
regards,
Carlos
