Design of my 120 Watt amplfier
I have not found a way to test the real amplifier to prove the IV limiter actually works as well as the simulation model predicts. have you?
I have. I used a DC load as a load. I tried 2 situations:
- changing the input voltage of the output stage with a constant load (just as in the simulation). The DC load was a resistive load.
- changing the load conditions, by pulsing the DC load. The DC load was a changing current source.
Real world measurements where very close to the simulated results. It is very important to have good models of the transistors. I've got mine from ltwiki.org and they seem very accurate to me.
If the prot Q is thermally coupled to the output devices/heatsink, then you can make use of the changing Vbe due to temperature to change the limiting condition depending on the temperature of the surroundings. i.e. more current passes without limiting when Qprot temp is low and less current when high temp.
I did a quick simulation of how the VI limiter reacts to temperature. Very nice, as maximum current drops with temperature rise :)
I did 30mins on it last night.
Had to add .include models because none of the transistors were included, not even the 1n4148.
eventually it recognised my .include, but still missing models.
So changed Q4 to bc550Cc, Q3 remained, Q1 & 2 to mjl1302c
and it ran.
But Ir11 ~84A
Q4 Vbe ~2V i.e. worse than hard on and still allows each output to pass ~41A.
Q3 Vbe ~1V
What am I doing wrong?
Can you explain what V3 pulse is doing?
