DC Cathodyne not balanced
The circuit show near 2V difference between outputs, why?
  • Op Point xperiment.asc
  • 12AX7.txt
Moderator
Joined 2011
Equal load impedances should give equal outputs.
Hopefully C1 is connected properly, unlike on your schematic.
Check the resistor tolerances, the imbalance difference is around 5%.
Unless you use 1% or better resistors, this amount of imbalance is expected.
1. Is your filament elevated?
Too much voltage from the cathode to the filament? That causes leakage current from the cathode to the filament. Unbalanced signal.
A filament winding that is center tapped to ground, or that has 100 Ohm resistors from each winding end to ground, is not elevated. Leakage current.
Un-balanced signal.
A filament winding that is center tapped to a +DC voltage, or that has 100 Ohm resistors from each winding to a +DC voltage, is elevated.
Little or no leakage current. Balanced signal.
2. A 5% plate load resistor that is 2.5% High, and the other 5% plate load resistor that is 2.5% Low, will cause a 5% signal difference, push versus pull.
3. A gassy 12AU7 will have grid current (current that un-balances the circuit).
It's not a sim error. Not connecting C1 causes ripple on the B+. The anode output of the cathodyne has low PSRR so the ripple is added to the signal. The cathode output has high PSRR so doesn't see the ripple. If you connect C1 in the sim the outputs are the same as they should be.
Reactions: 1 user
Moderator
Joined 2011
Yes, if you actually do not have C1 connected for the sim, that will cause an error due to unwanted effects from R3,
which among other things, makes the plate resistor larger, and hence the plate output voltage larger.
Even if it is connected, the test frequency must be high enough so the impedance of C1 is very low to ground,
in order to avoid this effect.
Recalling an article interview with David Hafler and this issue in one of the amps, his explanation for a circuit adjustment was that the unbypassed cathode load resistor created degenerative FB that created the signal gain differential at the cathode. If memory serves correctly. Searching for the mag. it's in.
The plate and cathode signal currents are the same, so equal loading gives equal outputs.
Sure the output impedances at the plate and cathode are different, but that doesn't matter with equal loads.
However, if there is significant capacitive loading, the unequal Routs will cause an imbalance at very high frequencies.
Perhaps Hafler was discussing why the cathodyne does not have the imbalance problem of the "cathode-coupled phase inverter",
which does have an inherent output imbalance, due to the finite impedance of the CCS (or resistor) to ground.
With a perfect (infinite impedance) CCS, it too would have perfect balance. Of course, the correct fix is to drive it balanced.
Then it would have perfect output balance, by virtue of the symmetry.
Reactions: 1 users
Cathodyne:
1. The Main current is from the cathode to the plate. Ic = Ip
Matched cathode and plate resistors gives exactly the same signal voltage amplitude (discounting extremely high frequencies, where capacitive current is a factor.
At most audio frequencies, all is well.
2. Any form of grid current Robs current from the Main current path. In that case Ic is not equal to Ip.
The signal voltage amplitudes are not matched. Not good.
3. Any form of cathode to filament Leakage current (DC or Signal), Robs current from the Main current path. In that case Ic is not equal to Ip.
Some simulation programs work well for case 1. above.
Many do not work well for cases 2. and 3. above, they do not have the factors in the program.
There, I said it.
Of course leaving C1 disconnected was the real cause of your problem.
But do not overlook the potential problems of 2. and 3. in a real circuit.
Reactions: 1 user
Stupid of me! ... Now the outputs are perfectly equal.
Another day, another lesson...
Thank you very much to all.
You shouldn't be very concerned about a bit of unbalanced output. If you are running a PP amp in class A, the two different signals are summed in the transformer 100% of the time so you get the equivalent of power out that is slightly under the 2x the highest half. Example, 8 + 7.9 = 15.9 .... It's the same in class AB operation as there is no time when there is not at least 1 of the tubes that is conducting, and for most of the time of the cycle both do unless you are very deep into the AB biasing. Unless you have a very large imbalance, there would be no time when both tubes are in cutoff at the same time. If you don't like the idea of a tube crossing into the cutoff zone, don't run an amp biased for AB operation. In the end it takes a very large deviation from balanced operation to have any audible affect and that would be a serious component issue to be addressed. You would notice it as a channel to channel power imbalance. So according to the theory that if both load resistors are equal, then there has to be balance, it matters not if the tube ages until its own operation is compromised enough to start clipping early at high volume levels.
Reactions: 1 user
Concertina stages with equal plate load resistors and equal grid resistors, Rg, are balanced even with old aged tubes . . .
As long as the tube is Not Gassy; and as long as the filament to cathode leakage has Not degraded with age.
Caution: Some brand new tubes can have gas, and some brand new tubes can have filament to cathode leakage.
The Quality of Your Parts May Vary (QYPMV)
Reactions: 1 user
