changes in 25.05:
2025-05-17 beta version 25.05-b171807 (x86_64, x86_64-rt & i486) changes:
you can update throught the development page:
http://<ip-address or hostname>/cgi-bin/Devel
- LMS update to 9.0.3 (Git commit 91f363b on May 13th, 2025)
- Kernel update to 6.12.28
- Other component updates
- Some bug fixes
Yes, I have something like this :Any issues in the logs?
22:06:09.0103] Slim::Networking:😀iscovery:😛layers::_players_error (144) Unable to get players: 404 Not Found
[25-05-19 22:07:09.0151] Slim::Networking:😀iscovery:😛layers::_players_error (144) Unable to get players: 404 Not Found
[25-05-19 22:08:08.0257] Slim::Networking:😀iscovery:😛layers::_players_error (144) Unable to get players: 404 Not Found
[25-05-19 22:09:06.0060] Slim::Networking:😀iscovery:😛layers::_players_error (144) Unable to get players: 404 Not Found
Tryed to restart Daphile, useless
After that I swithed off, wait 1 min and switched On again and working fine ...
I am using Daphile RT version
I'm using Daphile now for 8+ years and I like it very, VERY much. from 2023 I use a Singxer SU-6 and a standard USB output from my server. This is really making a difference!
Way better then the Jcat USB card with or without special supply,
Better then an SPDIF output (either AES/EBU or optical) from the server.
I have tried all kind of solutions, using special windows hard and software, dedicated ROON server, Rasberry PI etc. As soon as you enter the Singxer into the equasion, HiFi stops being HiFi and music live is playing. Hard to describe but worth the 700 euro investment!
Is there any way to change the filenaming format of CDs ripped by Daphile? Perhaps a way to change the configuration for the command passed to the ripping routine? The default is not the way I want it.
Also: I tried to get the scanner to ignore .cue files but this setting didn't have any effect: Settings>Advancd Media Server Settings>Advanced>File Types>Disabled Playlist File Extensions, set to "cue" (with no parentheses) and saved and restarted.
Hmm. Maybe I forgot to hit "apply...." I'll try it again.
Anybody have any luck with this?
Same issue here following upgrade with Daphile RT. When I boot up Daphile, I can connect to it for about a minute until it loses the network connection. 🙁
It is something wrong with the last release of Daphile RT ( 25.05 ). If upgrade, problems with boot partition will show up. If not with boot, then with DAC connection And a fresh install never succeed ...
@lorde73 - the latest Daphile upgrade to RT 25.05 didn't work for me. I reverted back to the previous version of Daphile which worked fine. The latest version boots up, then after a minute (or less) the network connection drops.
Since the prior version works fine for me, I'll just stay with that for now.
- PC Based
- Daphile - Audiophile Music Server & Player OS
