The problem seems to be related that the router is on a 10.0.0.x network and daphile is on 192.168.0.x network, the router and daphile need to be on the same subnet ie: 10.0.0.x or 192.168.0.x
You will need to change your router to 192.168.0.138 / 255.255.255.0 or change daphile to 10.0.0.x / 255.255.255.0 / Gateway address 10.0.0.138 (where x is a number between 1 and 254 but not 138 because thats the router address)
Use the advice vdi_nenna provided in post #4414 so you don't have two devices with the same IP address.
Example:
Daphile - IP address - 10.0.0.150
Subnet Mask - 255.255.255.0
Gateway Address - 10.0.0.138
Router - IP address - 10.0.0.138
or
Daphile - IP address - 192.168.0.150
Gateway Address - 192.168.0.138
Router - IP address - 192.168.0.138
Also what with the DNS servers and search domain in Daphile they can't be left blank, thanks
No WIFI just Ethernet
Daphile Settings
(please edit with your suggested settings and re post) this way there should be no confusion
IP address: 10.0.0.60
Subnet mask: 255.255.255.0
Router:10.0.0.138
DNS servers: ???????????
Search domains:?????????
PC Settings
IP address: 10.0.0.61
Default gateway: 10.0.0.138
DNS servers
Prefered DNS server ??????
Alternate DNS server: ??????
at this time i am having a break for a few hours from trying to set up Daphile before it end up out the window but when you post the setting both the 10.0.0.138 ones and the 192.168.0.138 i will ping and arp-a and post result.Thank you for your time and patience it is most appreciated and if ever you are out at Parkes NSW i will shout you a drink or three.
Daphile Settings
Router:10.0.0.138
PC Settings
DNS servers
Daphile Settings
Router:10.0.0.138
DNS servers: 1.1.1.1
Search domains: 0.0.0.0
PC Settings
DNS servers
Prefered DNS server 1.1.1.1
Alternate DNS server: 1.0.0.1
If daphile and the Windows PC are not connected to the internet then the DNS server IP addresses are not needed buts its a good idea to add them just in case. We also don't need the router or default gateway IP address for the same reason.
Router:10.0.0.138
PC Settings
DNS servers
Thank you i will get back to you shortly after using those settings, and doing a ping and arp-a and posting the results. If they don't work then maybe a crossover cable or patch cable is needed, WIFI would be so much easier, do you use a USB WIFI adapter and if so what one do you use? Thanks
https://imgbox.com/Z28aS5tgimgbox - fast, simple image host
Okay, something amiss.
Lets try this:
Daphile Settings
Router: leave blank or 0.0.0.0
PC Settings
Default gateway: leave blank
DNS servers
Then from your windows pc from the command prompt, enter PING 10.0.0.60, hit enter.
Lets try this:
Daphile Settings
PC Settings
DNS servers
Finally got it working I could not leave the default gateway blank so used 0.0.0.0 and that did it Iam taking note off thes settings and saving in a hundred different places for safety. One other thing is that I am unable to see my internal music drives D and E so at the moment I have to use my plug in backup USB drives which is less than perfect is there a way to see those drives? Anyway thanks for all your help it means a lot to me and those drinks still stand
Good to see you got it working, sharing your windows pc E and D drives might be a bit more complicated, hopefully other daphile users will provide some guidance. I would simply use USB drives plugged into the daphile computer directly, its just plug and play, this is what I do with my Rpi and volumio.
So I got the drive thing sorted out
Go to storage find the drive with your music
Click on usage select music from drop down list
Go to very bottom of page and click save and restart
And that will make the drive available
You can name the disk whatever you want to make it easier to identify.
I have some other questions for the items user power
It has my CPU set at 1.000 GHz(it is running perfectly fine as is)when it actually runs at 4GHz is this for audio quality in some way? Also
Clock source is TSC is that the beast option from what I have read it seems that it is but it is good to get other options.
Another setting is Hyper threading is it better to disable or not?
Then there is firmware caching should that be enabled and what benefit would it provide versus disadvantages.
Now Enable pci device runtime power management
I could see no real benefit to enabling any of them but if someone has advice on that that would be greatly appreciated.
Once again a big thank you to everyone that helped me get this up and running any tips and tricks for improving the sound (if that’s possible) are very welcome.
One last thing if I insert a formatted USB drive go to system firmware and select that drive from the drop down list can I reinstall to that drive for a backup?
Don’t worry I it’s just the crazy guy who doesn’t go away,
I was thinking about the speed of the cpu and if it’s clock speed is close to the frequencies of the files being played would that have any effect on the quality of the sound, I play a lot of DSD files mainly DSD128 or 5.64 MHz that fits pretty well with 1.4 GHz has anyone tried this and if so what were your thoughts on it.
- PC Based
- Daphile - Audiophile Music Server & Player OS
