dac I/V convertion with very low distortion
I stumbled upon something really strange. I don't understand this circuit, but it seems to perform very well. It's similar to the Leach moving coil head amp, but the capacitors that grounded the bases have been removed. I don't think I can call this a grounded base amplifier any more. The whole thing floats. I set the current generator to -6.2mA output and what happens is that the power supply just shifts without disturbing the current flows in the transistors. What's really weird is that distortion is extremely low. It's something like five or six zeros, then a number. S/N is about -130dB or more. Go figure, I don't understand it. So, this circuit doesn't seem to care about the DC offset from the current generator.
I have now put the Santos I/U into my system as phono MC pre-pre. Noise is very low and gain is good. As MM stage i use my House RIAA, i called it that way because it should never leave the house as other stages do.
Impressions are very favorable. I have heard and made many transimpedance stages like the Nobrainer, Rosi, The Grail, Aquox and even a balanced version that was the MPP2010.
Usually they major in what is known as "PRAT factor", that is power, rhythm, attack.
They can sound a little over damped and not as fluid as a Fet or tube stage though.
This Santos I/U is different from all transimpedance stages i heard, no, make that from all stages i heard. At first it struck me that the sound was not harsh or sharp at all but still very transparent and open. That comes with a lot of air and liquidity. It resolves tiny details but does not give an analytic impression. The sound stage has an enormous size. The most iintriquing ability is to sound tonally correct but also light and fast on the feet. Tonal colors are fleshed out but do not give the impression to be from " material".
It is rather a see through quality that lets the tone exist without any obvious encavement and without boundary. Lighter then air, more like light but curiously not slim or threadbare. I would say it sounds simply very natural. We can expect some surprises.
  • Santos I:U in system.jpg
Ok. now you make me with more desire to construct my one. 🙂
But i have so many circuits that i dont know were to start.
I think im going to try first my original circuit.
One thing that you should try, is replacing the input transistors with the nxp BISS, maybe you get a surprise, this are very good at low input impedance. and i bet that the Rbb are very low.
Or leave as it is, if you like the end result 😉
Joachim, which version did you build?
