DAC-END The best DAC AD1865- UPDAT 2011
Hi Quanghao,
I changed the IRF9610 and the 3 LEDs with a new one.
I measured the voltage on R1 33ohm = 18V.
I have two PCB mounted and the problem is the same in both.
Only 82 V at the output.
What is the correct value to R12 and R4? in Scheme R12 = 270K (1W) R4 = 120K (2W). R12 on the PCB is R8 = 220K (1W) R4 = 180K (2W).
R3 56K in Scheme (5W) PCB (R3 = 180K, R3B = 180K, R3C = 180) Total = 60K.
For 56K (R3 = 180K, R3B = 180K, R3C = 150K) Total = 56K250.
Have you tried the new PCB? I do not understand where the problem is.
Thanks.
hello Quanghao,
I think I found the problem resistor R1 = 33 Ohm, in the two PCBs were cut could not imagine that 2 of 33 ohm resistors Dale new were defective.
On Monday I will see if it works well now I have 33 Ohm resistors. Sorry I bothered by this problem.
Thank you.
hello Guanghao,
the sound is very nice and fairly compensated, thanks to Andrea, and to you for the work you have done.
Just one more question I have installed the 5687 and point B I have 144V. and point P 51V. is that correct?.
without putting the Tubes I have in the point B 260V.
thanks
hello Guanghao,
thanks
no!
if not use LL1660 out put,
So the V at +B 250 to 260V, The vol at Anode at 90 to 100V. thanks
Just finished, to be tested
hi Quanghao, I have not found schematic for your stage iv board, this is one dated 15/9/2011 and has lots of diodes on it which are not speficied. as well as 4 jumper wires.
Can you kindly post a scheuatic for this sshu LL1660 iv stage board. thanks, John
you use 2 jum follow:
jum 6H if you use tube 6Dj8, 6h30
Jum 5687 for 5687 and el82cc, or bandix 6900
thank
