DAC-END R (ES9018)
and the usb with DAC
Hi All!
Let me give an example of the 32-bit DAC is as follows:
1) DAC module 3 input - DAC32 - basic
2) DAC module + controller + remote 3input
3) DAC module + controller + remote 4 input (USB Amonero)
4) Output stage IV with opamp or wit Tube
Andrea and I have tested USB and find Amno very appropriate for the 9018 chip, as well as the sound quality is very good!
Therefore kit DAC has designed the USB plug straight upward to ensure I2S signal is very short to avoid noise, high efficiency and convenience.
Input connections: SPDIF, AES / EBU, Optical Toslink is the standard, you can buy it and attach.
The new DAC ES9018 module have these features:
- top performance linear pre-regulator
- separated fast shunt for any digital section
- separated fast shunt for any analog channel
- remote volume control
- remote mute control
- remote input control
- remap DAC to share I2S connection with DSD
- Amanero module integrated to have USB input and support 44,88,96,192,384KHz PCM and DSD
- On board reference Crystek oscillator with a jitter of 0.5psec
- 3 spdif input: coax RCA, Toslink optical and AES/EBU
- passive I/V
- optional hi-end differential solid state op-amp
- passive I/V
how much & when will it be available ? thanks
DAC structure and order information
Welcome
This is the entire structure Reference DAC-DAC32, designed by Andrea and Quanghao.
With this structure and production costs will be when you place your order as follows:
1. Minimum of 50 kits.
2. Very good individual components, industrial welding machine, lead-free pewter.
3. Reference the product kit DAC-DAC32: 450 $, including:
1 x Kit DAC
2 x Kit IV
1 x Volum Kit + Remove
All inspection and testing, and then send it to you by FedEx or UPS, I will warranty the kit, 1 for 1 when the errors are.
Note: The kit does not include shipping and connectors: BNC, RCA, Toxlink, Amanero USB.
Would like to invite you to sign up!
Would like to thank all of you!
Quanghao
