Hi Andrea, received the package you sent.
Fantastic! I can now have music! The Amanero module you sent works perfectly - both channels, PCM and DSD (in linux). Not tested Windows - I don't normally use Windows, anyway. Shall do more testing this weekend.
Tried the standby modified PIC you sent me (57a) - the function is worse than my existing version (56c):
Power Button switched on in DAC: standby mode
Power button on remote switched on: DAC relay turns on and DAC powers up but no LCD backlight
Power button on remote switched off: DAC remains on (relay does not switch off) and LCD remains off
I did not try the flat cable and standard PIC without standby.
I would very much like to put the DAC from powered on to standby (switch the relay on and off using the remote). This should be possible?
Shall send you a separate email.
please add your problem or correct the problem info
This is the current list:
1) smoothquark [SOLVED]
problem: with USB input DSD plays fine but PCM is completely silent, right channel does not run on USB input but coax all ok
solution: Amanero has been changed
2) judo [PARTIAL SOLVED]
problem: USB input work only at 44KHz in KS, ASIO OK
solution: using ASIO driven all ok, still problem in KS and DS probably Windows Vista not compatible with Amonero driver, still to check.
3) misterwolf [OPEN]
problem: no lock over 96 KHz also after some modification
solution: to check
4) masterkey [SOLVED] [waiting the confirm]
problem: no work with usb input but work good with coax and optical input
solution: masterley will receive a new DAC module
5) misterwolf , Halook [SOLVED]
problem: spdif does not work with some non standard sources
solution: eliminate the 75ohm and add a 1uF capacitor after the input transformer (cut the pcb jump).
6) MattMax - [tested ?]
probem: tweeters of my loudspeakers emit a hissing sound when the DAC is on mute
solution: see point 2, apply #1586 and add a caps to filter high freq. on DAC output
7) Erlend Sæterdal [ tested ?]
problem: More than 11 mv offset with OPA 1612
solution: have you tested different op-amp ? have you apply the mod. #1586 ?
8) bertchai [tested ?]
problem: using Mac 0.5s at the beginning of the song is missing/silent
solution: try the version with automute delay reduced, post #1724
9) Claudio52 [DAC OK - TEST IN PROGRESS ON AMP]
problem: noise on output
solution: DAC all ok on measurements, he are testing the amplifier
10) Some [SOLVED]
problem: Amanero USB module not recognized from PC
solution: the USB pins on pcb touch the DAC shield, so cut this
11) Some [SOLVED]
problem: lcd wrong characters
solution: change the flat cable or solder the wires
12) Many [SOLVED]
problem: firmware update
solution: the best method is to use the Pickit2 available on Ebay shop and Amazon, there are some cheaper clone
13) Many [SOLVED]
problem: little oscillation on power supply shunt
solution: follow post #1586 and #1626
solution: to check
10) Some [SOLVED]
11) Some [SOLVED]
12) Many [SOLVED]
13) Many [SOLVED]
I have wrote the 57a standby version without test it because I have sent my DAC module to masterkey to replace original with problems.
I should receive another DAC module from Quanghao very soon so I will resolve the bug on the firmware 57a standby.
If possible buy a Pic kit 2 or clone to update the firmware when it will be ready.
Thanks. Yes, planning to buy a pic kit soon. I would like to "play" with the firmware too. Would also like to get triggers working - my only reason now to use my preamp is for the triggers.
The save function store input, filter configuration and volume on PIC non-volatile memory.
The Phase control & filter band doesn't work on mine. I don't know the firmware version, mine is from the latest batch sent by Quanghao.
Also, the shunt is still hot. According to Quanghao he has applied the mod. Is this normal ?
Quanghao, I am still waiting my dac, you always tell me that you´re going to send it but never happens.
I send you private messages and don´t answer.
I am bored. 😡
I am bored. 😡
I am bored. 😡
Incredible, Quanghao you are really quick, half an hour later appears the dac in my house. jajaja Thanks.
Looks good.
Could you make some photos of regulators and check the firmware at the switch-on ?
I have the 56 A version is this ok ?
Anyway I listened to DSD last Night and the difference between DSD and Wave files is huge.
A analog stage is not necessary at all. 100 ohm I/V resistors and direct to poweramp works just fine.
Yes, 56A or 57A are ok
Better without 100 ohm I/V
but do you drive the ampl. as balanced or un-balanced ?
Unbalanced but Balanced in few days.
Do I need series caps in Voltage mode ?
I will receive LL 1684 in this week . I will use Balanced out off the transformer. Can I use your schematic at the input off the 1684 ?
In any mode is necessary a cap to eliminate the DC on ES9018 output.
Yes, you can use my schematic with LL1684.
1) judo [PARTIAL SOLVED]
2) misterwolf [OPEN]
solution: to check
3) smoothquark [SOLVED]
solution: masterley have received a new DAC module
6) MattMax - [SOLVED ?]
7) Erlend Sæterdal [ SOLVED ?]
8) bertchai [ SOLVED ?]
9) Claudio52 [SOLVED]
10) Some [SOLVED]
11) Some [SOLVED]
12) Many [SOLVED]
13) Many [SOLVED]
So now the problem is only the lock over 96KHz with some sources ?
solution: to check
10) Some [SOLVED]
11) Some [SOLVED]
12) Many [SOLVED]
13) Many [SOLVED]
Hi
Mine dac cant lock to above 96k on spdif .
My source is a squeezebox touch incl plugin to 192k play back.
When playing via usb fron the squeezebox then the dac locks ok to 192khz.
Ps. The same plug in on the squeezebox enables bith 192k and usb play back
By the way... This DAC is so good in sound quality. This DAC is the best DAC i ever have owned.. Thank you very much to Audiodesignguide "Andrea" and Quang Hao for designing this unique product.
Br
Caad
Br
Caad
SPDIF input over 96KHz
ES9018 chip is able to accept 192KHz on spdif input but the ES9018 want 3.3V TTL level input so we have used the circuit suggested by ESS to convert the low level spdif to 3.3V TTL.
This circuit load the spdif source with the standard 75 ohm.
Have you made some modifications ? These should be make as progressive steps after a test ?
1) remove the pcb jump and insert the 1uF or 2uF after the spdif transformer
2) remove the 75 ohm input resistance after spdif transformer
3) ac bypass the ground of the primary and secondary of the spdif transformer with 0.1uF
4) eliminate the spdif transformer
Someone can modify this list on the experience made and report the max frequency obtain.
Hi
Caad
Quanghao, Andrea - I am delighted with the DAC since replacing the Amanero. Need to test more this weekend. By the way, is there a schematic for my standby modified controller? I am wondering whether I can somehow piggy back a 12V trigger to activate my power amps? I realise I may require another 12V transformer. Also need a way to power off the relay so that standby works properly.
- More Vendors...
- Quanghao Audio Design
- DAC-END R (ES9018) full assembled board
