DAC-END R (ES9018) full assembled board - version 2
I did my own transformer PCB, fully compatible with the DAC 120/240V switch. Fully dual mono with separate digital section transformer. Here in Quebec, Canada AC main voltage is 120V. With the Telema transformers I used (25VA per channel), 18V secondaries was giving a too high secondary voltageat 21Vac instead of 18Vac. Using the 15Vac model gave me a nice 17.8Vac. Next update, replacing the I/V resistors with Caddock MK132 😉
The Rhopoint seems indeed to be the ultimate I/V resistor but where can I buy it?
Hi All!
Below is a list of DAC and you have received your list that I will post next.
A - List shipment:
1. Adveza (numbertracking: 374009606, date: 30/05/2014)
2. Eboz (numbertracking: 804910636802, date: 31/5/2014)
3. Dudek1 (numbertracking: 374009521, date: 28/05/2014)
4. Rowli (numbertracking: 374009597, date: 30/05/2014)
5. Serge58 (numbertracking: CP110116519VN, date: 28/05/2014)
6. Axeexa (numbertracking: 374009518, date: 28/05/2014)
7. Papapew (numbertracking: 805621177790, date: 30/05/2014)
8. Sandor (numbertracking: 374009699, date: 3/06/2014)
9. Gradozelo (numbertracking: 374009760, date: 5/06/2014)
10. NickF (numbertracking: 874588049772, date: 12/06/2014)
11. PeterKD (numbertracking: 374009929, date: 16/06/2014)
12. Vmoreau (numbertracking: ………., date: 1/7/2014)
13. Jokari69 (numbertracking: ………., date: 1/7/2014)
14. Mas Penk (numbertracking: 374009378; date: 26/05/2014)
15. Danielkol (numbertracking: CP 110116765VN, date: 31/05/2014)
16. Danny_66 (numbertracking: 374009685, date: 3/06/2014)
17. Brgds (numbertracking: 374009455, date: 26/05/2014)
18. Anjogi (numbertracking: 374009464, date: 26/05/2014)
19. Frankwilker (numbertracking: 374009328, date: 19/05/2014)
20. Ervstill (numbertracking: 374009504, date: 28/05/2014)
21. ClaudioM (numbertracking: 374009610, date: 30/05/2014)
22. Xtomm (numbertracking: 374009314, date: 19/05/2014)
23. Corpius (numbertracking: 374009402, date: 22/05/2014)
24. Ardahan (numbertracking: 374009331, date: 19/05/2014)
25. Johnnyti (numbertracking: CP 110116767VN, date: 19/05/2014)
26. Algar_mi (numbertracking: 804910636798, date: 31/05/2014)
27. Enigmapb (numbertracking: 804910636787, date: 31/05/2014)
B – List unshipment:
1. Msaywitz (Dac full with LL1864; waiting transformer LL1864)
2. Jonh Fara (Dac full with LL1864; waiting transformer LL1864)
3. Boudy (Dac full)
4. Blackberry (Dac full)
5. Jacky Joachim
6. Claudio52 (out put stage + 2 transformer)
7. Erlend Seaterdal (out put stage)
8. RRedline (out put stage)
9. Gjorgji (out put stage + 2 transformer)
10. Ylaw (out put stage)
11. Gde3 (out put stage + USB)
12. NKL
13. Ceausuc (USB)
thanks all!
quanghao
Thanks Quanghao,
I'm on the next "wish list":drink: - in the meantime be good to read some listening impressions from those who have received the DAC😎
Hi All!
A - List shipment:
3. Boudy (Dac full)
5. Jacky Joachim
12. NKL
13. Ceausuc (USB)
thanks all!
quanghao
Here the transformer PCB layout... One bottom layer only, a few link and that fits my limitation of 6x9 PCB material I had. End up with a 3'' x 9'' PCB. Three screw mounting holes match existing DAC chassis original mounting holes. I needed to drill four more holes, one in each corner because I was limited to 3x9 PCB size. A custom commercial PCB could match all standard chassis holes but I couldn't...
Hi QuangHao,
I am not on the list B " unshipment "! Forgot me to you?
Thank you for indicating me the rates of shipping for France for a complete kit.
I shall add 40 $ for the aluminum remote control and $80 for the assembly, the tests, the maintenance.
I have déja paid:
12/02/2014 450 USD Paypal 8BP45637JJ042905B
12/03/2014 450 USD Paypal 81W16224XK553972P
I am impatient to listen to the result of this excellent work!
Thank you
Claude
Hi Quanghao,
It appears somehow I've been dropped from the list.
I have paid for:
.......Option 6 - Complete assembled, tested DAC with discrete output boards
.......Plus - LL1684 transformer output boards with all components except transformers
.......Plus - New style remote
01/20/2014 - $462.50 - First payment for complete DAC plus 2 LL1684 bare boards - Transaction ID # 41F39115K14945800
03/10/2014 - $462.50 - Second payment for complete DAC plus 2 LL1684 bare boards - Transaction ID # 730135631X369413N
04/15/2014 - $60.50 - Added all components for LL1684 boards EXCEPT transformers - Transaction ID # 5P626391J74176147
04/28/2014 - $40 - New style remote - Transaction ID # 4S055591JR439283W
I am still waiting for PM regarding shipping information and cost, then I will send the $80 plus shipping.
Thank you,
Steve
Hi Quanghao.
I'm number 27 on the wish list.
1. atterbud - Option 6 full DAC build with Super I/V output stage in place of standard
2. bsy020 - Option 6 full DAC (standard output) + PCBs for Transformer output
3. Abszero!
4. Gugi 100 (dacboard, output board, chassis)
5. smokingdog
6. feriandas - DAC module + amanero + output stage + transformer + chassis (Complete set: Item 6)
7. ivigueras: 1 + 2 + 3 (DAC, DD output stage, chassis)
8. Djauweh - Option 9 Complete assembled DAC with Lundahl LL1684 output stage
9. audiomusica - Complete set (option 1+2+3+4+5) assuming this makes a complete kit like option 6 but finally assembled on my own.
10. bamarek - option 6 - complete assembled DAC with LL1684
11. Sugden (option 9) Complete assembled DAC with Lundahl LL1684 output stage
12. Nicos - DAC module + amanero + output stage + transformer + chassis (Complete set: Item 6)
13. mjensen (option 9) - complete assembled DAC with Lundahl LL1684 output stage
14.ingemar (option 9)- complete assembled Dac with Lundahl LL1684 output stage(i need to bail out,sorry!!)
15.Gergar- (option 9) - complete Dac with LL1684 + 2 DD output + Op-amp output
16.rolandong-Dac module (assembled & tested with all components) + Amanero module + Aluminum remote
17. Losflacos (Option 9) complete assembled DAC with Lundahl LL1684 output stage, (240VAC) + aluminium remote control
18. picknicker - option 1 + 5: (DAC module assembled and tested with all components + Amanero module) - please also add the metal remote
19. akltam (option 9) complete assembled DAC with Lundahl LL1684 output stage (230V) + remote control
20. Thom - Assembled kit without any output stage (1+3+4+5) + aluminium remote (I will use my own output stage).
21. Alexkosha (option 9) -> complete assembled DAC with Lundahl LL1684 output stage (115V) + Aluminum remote control
22. ruteksen (option 2 + 5) -> output stage + amanero
23. mirza - option 9 completed & assembled DAC with LL 1684 - 230V, aluminium remote controle
24. Artur5 -DAC module + Amanero.
25. Myint67- option 9 complete &assembled dad with ll 1684 -230v aluminium remote control
26. marcus1 (option 9) complete assembled DAC with Lundahl LL1684 output stage (230V)
27. nick696 - (Option 9) complete assembled DAC with Lundahl LL1684 output stage, (240VAC) + aluminium remote control
28. Audioheaven option 1-2-5
29. Erlend Sæterdal : Output stage Only
Hi Quanghao.
3. Abszero!
5. smokingdog
I have opened a new group buy for the new order so please now use it
# http://www.diyaudio.com/forums/quan...full-assembled-board-version-2-group-2-a.html
A - List shipment:
3. Boudy (Dac full)
5. Jacky Joachim
12. NKL
13. Ceausuc (USB)
Quanghao need to verify if Nimes and Apogee must be in this list.
Hi Quanghao,
I have paid for:
Thank you,
Steve
Hi Nimes and Apooge,
I check and pm for you!
Thanks you!
I think you are not using the I/V resistors now
A rotary potentiometer is possible using an encoder, no problem
I will speak with Quanghao about this
Any ideas on how do add a rotary encoder to the version 2 board?
I think i willl add an encoder and a little circuit to "click the buttons" for me.
Audiodesign:It is possible to add some software and use the up, down and some auxiliary input (or the mute pad ) for the encoder?
Best Regards Christian Stille
