cyrus 2
Hi
I have a mission cyrus 2 amp which blew a capacitor last
night.
Do you know what type of capacitor i should get to
replace it as i would love to keep my cyrus.
The numbering on the capacitor seems to be of no use
to the staff at the local maplins.
+ 470 / 50 - T8 EKM
If anyone knows what type of capacitor i should replace with would be great
thanks
tim
pics
Thanks so much
here are some photos
This is one of the preamp (phono only) psu caps. They usually blew much earlier, because Mission used a not reliable series perhaps. I changed many of them already in the late eighties and early nineties. They also usually break (not necessary explode, but get leaky, loose capacity, and start to "modulate" the voltage...) just by age, not by any other cause. So you may be lucky here, although it is difficult to say without having the item on my desk.
So in any case: Remove the remains (not easy...) and solder in a new cap with the already mentioned values (better would be 470µF / 63V but htese do not fir perhaps). Do not forget the polarity. Then power up the amp (with the power amps fuses removed!) and check the voltages before (at the caps or the diodes) and after the regulators.
very good, even the older ones.
I have a Cyrus Two with PSX. Sounds superb for the second hand price I paid.
Although my line level only Cyrus8 is better, but does not have phono.
Oh, I wish someone would post a Cyrus Two schematic.
That should be an easy fix.
The sound of the Cyrus 2 is good, the nice punchy bass is the best aspect. The sound can be a little on the bright side but if you like a detailed sound it's good.
The Cyrus 1 and Cyrus 2 are very similar indeed. I repaired a friends Cyrus 2 a while ago and bought the service manual from Cyrus, not that cheap and not a brilliant document either :whazzat:
polarity
thanks so much for the help
So I unsolder the capacitor, Go to maplins and ask for one with these specs 470µF / 63V
Resolder ( will the polarity be marked on the circuit board ).
You mentioned checking the voltage after soldering Is there any particular voltage i should be reading .
sorry Its been years since i looked at a circuit and kinda lost
I'll see if i can get the capacitors today one spare incase the other goes and i need a voltage meter also.
Am just concerned about getting the polarity right , is there a sure fire way of knowing if i dont see any markings.
thanks
Make sure Maplin's sell you a cap with the same pin pitch.
I think there is a + sign on the silk screen, but it's possible there isn't. If you remove the cap then post up on here which number it is on the board (e.g. C102) then I can look at my manual and see where it is in the circuit and tell you which way round it needs to go. But please don't bother me if there is a + on the silk screen as I will have to move a load of stuff to get to the manual :cannotbe:
Re: polarity
thanks
From your photo, you have one of the earlier Cyrus 2s with the non-metalic case. The capacitor which has failed is C64 and the +ve leg is the one which is nearest to the edge of the pcb, i.e. it is the opposite way round to the adjacent similar capacitor C63. The board is marked with a (+) to show the correct orientation.
I would sugest that you replace both C64 and C63. Ideally you should use some new insulation pads for the output transistors when you reassemble the amp unless you leave them connected to the heatsink and remove the heatsink along with the pcb. If you choose the latter option take care not to put any strain on the output transistor legs or solder pads.
Does anyone know the replacement Power transistors for a 1988 cyrus 2? Are there any other replacement Nos. available for this? My C2 is rated 150watts say a label on the casing. Any help would be appreciated.
The Nos> on the power transistor on my set is C8834 and the Driver ones are 243 and 253. The tech at Cyrus UK has not heard of power transistor C8834..
thanks & kind regards to all.
Henry: 😕
The early Cyrus 2 has two TO220 devices per rail, inhouse marked as PT7. The later Cyrus 2 has one TO247 device per rail, inhouse marked as PT77.
The drivers in both cases are MJE devices. I replaced them with MFE340/MJE350 without issue.
Cyrus want a silly price for new output devices. I would use TIP41C (or B if you're brave) for the TO220 devices, and TIP35C (or B if you're brave) for the TO247 as an easy substitute.
