Current drive for Loudspeakers
That is on my list of things to try. Do you think it practical to develop a box to implement the idea you describe? You could use the box with any generic amp to make it force current.
Transforming any generic (voltage) amp to a current amp using an additional box
involved many risks.
I think a dedicated current output amp is more safe particularly as you need bandwidth extended to DC.
What maximal "power" would you need for an 8 Ohm load ?
50-75 watts at 8 ohms for most speakers. 2A RMS will drive most speakers to Xmax in free air at Fs. For the big speakers, 48V rms and 4A rms is required.
Very few to no speakers are 8 ohms at Fs. My monster speaker is 12 -14 ohms at Fs. 14 ohms at small signal and 12 ohms at Xmax.
High efficiency speakers can be hundreds of ohms at Fs.
It is better to specify max Vrms and max Irms. The small amp should be 24V rms and 2A rms.
It could happen this way
I think if you really look closely, then current drive could be very exciting from a performance point of view, but as it's a paradigm shift I have big doubts of how to make it commercially fly.
It would be simple: Someone starts producing new active speakers and their exceptionally clean sound will be praised everywhere. Someone else does reverse engineering and notices that surprisingly the amplifiers got current feedback, making them transconductance amplifiers instead of voltage amplifiers. Soon after other companies will start producing as great sounding active speakers.
Hi
you can laugh of this setup,
I am listening to the music from a few months with 98 Ohm resistors series with 4 Ohm 91dB speaker. It was the experiment but survived from this time.
The result is velvet, smooth highs, but with lots of the details and sound richness. Beautiful voices, horns, saxs, trumpets, etc. SQ.
Negative impact on bass driver damping is hard to hear.
I can recommend to experiment with similar solutions to have current drive with voltage drive.
The speakers are Saba Acoustic monitors 80, the amp JVC A-X9.
Similar improvment I marked with Yamaha A-1 amp.
And now you do not need to care about extra low resistance speaker cables😉
JVC A-X9...love the amp, I used to have one!
Now I am using NIKKO Alpha 230 for similar experiments. I never went so high with resistor impedance...maybe I will try it too. Or use variable resistor or half of L-pad. (I do have real transconductance amplifier LM1875 based in other system and that is great sounding amp)
Current drive is no laughing matter!
