CSS FR125S Cabinet
also don't overlook Planet10's Fonken - the bass response never ceases to amaze the non-initiated "OK, where are you hiding the woofers?"
With only a minor change to the size of port slots, this design will also work with Fostex FE127; I spent a couple of hours last night listening to a pair. It's certainly a matter of personal preference that I always gravitate back to either this driver or the FE126 in a BLH.
my subwoofer has XLR high pass outputs, is there a way of connecting this to my speakers (when i finish them)?
or can i make a seperate high pass filter (that i can plug in and unplug) around 80Hz so that i can integrate it into my subwoofer?
(p.s. my subwoofer is a Tannoy TS8)
planet10 said:
Use 1 pr and separate them.
dave
Why do you separate them?
The capacitance has to be very low to start with as those cat5 cables have to be able to carry very high MHz frequency signals and by separating them you actually increase the inductive impedance which usually affects the highs more than the capacitance.
I was thinking of running one terminal to one polarity pair pole and the other to the other one. That' would be four conductors per speaker terminal and the other four for for the other and each pair will be feeding both terminals and all four pairs will be in parallel. This will give the lowest inductive impedance.
Because it sounds better?
You just described Chris' previous speaker cable. I brought over my single separated pair for comparison. I was not allowed to take mine home.
2 wires. Separated. I know it is a lot of work to peel them apart, but it is worth it.
dave
planet10 said:
13 litres seems to be a sweet spot. Works for BR, aperiodic & sealed. MiniOs are 13 l. I've yet to draw up a more typical (and simplier0 shelf port or plumbing pipe port version.
dave
Hmmm...
I'll have to play with this 13L sim in BBL6 both sealed & BR. Would it be a safe assumption that the aperiodic curves would fall between the first two?
Why do you think that is?
dave
How far apart are they separated and what do you use to keep them separated?
Because that's what my ears said.
I took a piece of packing tape, and taped it sticky side up on the floor. I ran one strand about a 1/2" from one edge, and then another strand about a 1/2" from the other. I made sure they were not perfectly parallel -- in this case a bit sloppy is good. I then put a piece of packing tape sticky side down over the works. Then for toughness i added one more layer of packing tape on either side.
I'd take a picture but i have to make a new set.
dave
"my subwoofer has XLR high pass outputs, is there a way of connecting this to my speakers (when i finish them)?
(p.s. my subwoofer is a Tannoy TS8)"
Anyone?
XLR is line-level, so you'll need an amp after them. This is possible if you have separable pre- and power-amp stages.
Edit: I don't think passive high-pass is such a good idea with FR125S. If you have an AV-receiver, it should have optional active high pass for all speakers.
Bas Horneman said:
Why is that?
A passive 1st order highpass at ~80Hz on speaker level will need pretty big caps and these going to be pretty expansive and BIG, unless you ecxept cheap elcos in your signal path. Also IMO it is going to need an Impedance Equalization Circuit (a zobel network in paralell to the speaker to flatten the impedance peak around fb) for the xo to work properly. This IEC again will need some big inductors and caps.
best, LC
Bas Horneman said:
The sub amplifier has already done that at line level.
But I thought there might be some reason other than cost/complexity and efficiency which are seldom reasons for diy'ers to do things otherwise 😉
Best,
bas
Hi
Well, depends on the diy'er, but effciency will get a very high rating from most fullrangers.
There might be a diy way to adress this on line level, for folks like me who don't really like the idea of using commercial active subs (as they mostly have bad amps or are very expansive).
On t-linesspeakers is a article on a diy passive line level xo - PLLXO - you will need a second poweramp for the bass section then, but it's a more diy'fish way than some commercial active sub...
best, LC
