Well, Apples DACs are pretty decent.
Ken Rockwell tested them all:
iPhone 5 Audio Quality Measurements
Only
// PSKEY_HOSTIO_MAP_SCO_PCM
&01ab = 0001// True
PCM pin must be pull-up...strange, but works.
Hmm, i can't get any digital data out of my module..
"PCM pin must be pull-up" means SPI/PCM select pin?
yes, I have also spent weeks trying to get the pcm interface working. After having read all possible documents mainly from chinese sites, and tried many configurations, I am also stuck.
I hope that one day someone comes with some functional pskeys for the digital audio IF of the csr8645 module.
wchpikus said, it is working with the 8645 as well, but no luck yet. The other thing, USB-Audio, isn't working as well atm. (Which did month ago when having it just wired-connected to anything)
USB-Link works, so you can program the module via PCTools without the programmer, but no Audio..
I have bad news.
I had dump for this, but it was done time ego, so tomorrow i will try find this dump on work pc.. I spend some time to find this and try to configure for spdif, but i do not remember how to do this
But nothing lose, i find this dump.
This chip was pure (no configure) so i put this to box and do not use anymore
Offcorse i tryed setup i2s, so no possible now to recover dump from chip.
Please, forgive me, i promise to find this
Ok, so
Dump is here:
https://drive.google.com/folderview?id=0B6L6UWHrZEEKRjlYS0lseEhLazg&usp=sharing
SCR8670, You can setup csr8645 the same, I have to check it.
Connection:
Mobilephone=>bluethooth=>csr8670=>spdif=>74HC157=>AK4113=>is2(master, left jus.)=>PCM5102A=>analog.
Sampling spdif 48KHz.
Dump is here:
Connection:
Thanks mate, but this is still a 8670.
The dump is from your 8645 module?
On the 8670, I2S is working as well.
Edit:
So maybe this is the magic:
Edit:
Code:
// PSKEY_PCM_CONFIG32
&01b3 = 0080 0900
// PSKEY_USE_OLD_BCSP_LE
&01b4 = 0000
// PSKEY_PCM_FORMAT
&01b6 = 006c
// PSKEY_CODEC_OUT_GAIN
&01b7 = 0007
// PSKEY_CODEC_IN_GAIN
&01b8 = 0108
Ok, so my opinion:
&01ab = 0001// True
// PSKEY_HOSTIO_MAP_SCO_CODEC
&01b0 = 0000// False
// PSKEY_HOSTIO_MAP_SCO_PCM_SLOT
&01bd = 0000
&01bd = 0000
// PSKEY_PCM_FORMAT
&01b6 = 006c
&01b3 = 0080 0900
&01ab = 0001// True
&01bd = 0000
&01bd = 0000
// PSKEY_PCM_FORMAT
&01b6 = 006c
&01b3 = 0080 0900
// PSKEY_HOSTIO_MAP_SCO_PCM &01ab = 0001// True -enable stream to pcm
// PSKEY_HOSTIO_MAP_SCO_CODEC &01b0 = 0000// False - disable use codek
// PSKEY_HOSTIO_MAP_SCO_PCM_SLOT &01bd = 0000 - route to pcm0
// PSKEY_PCM_FORMAT &01b6 = 006c - format pcm (bitrate)
// PSKEY_PCM_CONFIG32 &01b3 = 0080 0900 - master,slave,left,rigth justified
But 8670 still stream to spdif
Now i try setup this to 8645
How does master+slave+left+right+justified works? This makes no sense.
If you not setup master, you do not get data and sw from chip..the clock is necessary, but when you setup master, that's should works (in theory).
Isn't the PCM output on 8645 PCM1 rather than PCM0?
On the pskey are visible two pcm
About pskey 35 and 36
This is keys to setup pcm also, but in datasheet are 11 words, in 8646 only 10.
This was divide ( first are in 35, second in 36).
You can there also setup i2s, but documents are not corresponding to 8645 keys...
I changed there also something, but no have note what.
from my trials, the 3rd word of pskey 35 seems to be related to volume attenuation.
I thought I might purchase a cs8645 bases bluetooth - spdif bridge device to read its pskeys ( see this blog for device insight Aptx Bluetooth 4.0 music receiver )
I wonder what role does the 128kbits flash device play in my module or the one (which might even be bigger) on the above link.
- Digital Line Level
- CSR8645 Bluetooth 4.0 AAC APT-X Module / Baseboard
