Hello guys!
Having a BIIISE I want to order the legato, hermes(amanero) cronus and rhea (49mhz pair).
Now my questions are :
for stacking b3se to legato the headers are already included or have to buy them apart?
same question for the reclocker, does the hermes already have the header for interfacing amanero? also does the cronus have the 4 ufls to connect it to b3se or I have to order them apart?
want to make the order today and I am a little impatient
thanks
thanks
I included a pair of male/female headers for each (all) positions to accommodate different stacking options.
All ufl positions on the Cronus are pre-populated.
The Buffalo3se does not come with the ufls populated, except for the mck ufl. I can optionally permitting these if needed.
I already have the ufls on the b3se.Since I am not at home right now I can't check to see if I have the headers between the b3se and the legato or is legato coming with them?
I'll send you a pm with what I want to buy if that's ok with you.
Thanks!
Thanks!
I'm using two Teleporters and a meter of CAT5 between a SACD player and my B2. Any opinions on whether there would be any advantage to using a Cronus to reclock things after the Teleporter at the DAC end?
Only if your SACD player can slave to an external master clock. 🙂 Otherwise I would not.
The teleporters are a great idea though. 🙂
Thanks Russ. I guess I overlooked that part of the design concept when I posted the question. The Teleporters do indeed work well for this application.
Are there any benefits on using double shielded cable for a 10-15cm long u.fl-u.fl connection or is enough the single shielded one ?
For example hirose U.FL-2LP-066 series is 1.32mm diameter and double shielded, being the only one double shielded from them.
Instead the U.FL-2LP-088 series is 1.37mm single shielded but with lower attenuation, ~1-1.3dBm lower than U.FL-2LP-066.
Another option is the U.FL-2LP-04 with 0.81mm diameter single shielded and with an attenuation of ~2.6-3.8 dBm higher than U.FL-2LP-066, this being the cheapest solution.
Which one should I get for my needs and the best performance ?
I ask all this because I want to take the right decision when ordering these pricey little cables!
I have only ever used the single shielded type - they seem to be perfectly adequate for the task. That does not mean the double shielded aren't better, but I have never had the need to use them.
So Cronus is up and running for a while now. And I'm happy with the result so far (hope the soon to arrive Placid brings some more improvement). I'm using a headless MacMini with Audirvana and the IOS app. I find using the MacMini a bit devious. So I had a look at the Auralic Aries. The Aries comes in two versions. The expensive one with Femto clocks and a "high-end" power supply. The cheap version without Femto clocks and a cheap power supply.
Because I re-clock the incoming signal with Cronus, is it any use to buy the Aries with Femto clocks? (I can replace the PSU from the cheaper Aries for something better)
The clocks in the host won't matter a bit. As long as it is reliable and capable - that is all you need. 🙂
Hmm still problems I'm afraid... I have distorted sound on the left channel...
Any advise what to do?
Is there an adapter (if it exists) for to connect Cronus to 2 x BIIISE boards with ufl connectors?
Had some more time to try some possibility's. I have distortion on the left channel only when upsampling to 352-384 ( using power of 2).
I also think this sudden distortion could be the reason both left channels of my power amps failed. (I'm bi amping). Repaired one amp, the other needs more attention 😕
Only when upsampling?
Did you try native 352,8 kHz pcm?
You can download some here:
High Resolution Music DOWNLOAD services .:. FLAC in free TEST BENCH
No, have not tried native 352.8. I will download and try.
The problem with the left channel came very unexpected.
I had everything going well for a couple of day except I had
some distortion now and than but only for a very short time.
I was listening to music a bit louder than usual when suddenly I got
very loud distortion over both channels. I turned everything off and on again.
Both my amp (left channel only) had failed. After repairing one amp I found
out that the left channel still gave distortion while the right channel was functioning normal. Tried my cd player which was functioning normal on both channels. This means my pre amp is also okay. So I started to try my Buffalo IIISE at 44.1 to 384. It functioned allright until I went past 192...
- More Vendors...
- Twisted Pear
- Cronus - It's about time.
