I don't know of a link, but there surely are some -- maybe as little Excel spreadsheet bits. I'm a little foggy as to why you want the amp to see a flat impedance curve, though ..
You might try a more general search spec, like "loudspeaker crossover calculator".
The word "crossover" by itself unfortunately brings up an avalanche of car adverts.
Cheers
Cheers
Thank you very much guys, this is what I was looking for.
Now I need a set of 1,4", a guy in Germany makes cool wood horns
http://www.lm-h.bplaced.net/index.php/en/shop-eng/product/view/2/1
I don' t know very well horns but they look well made, no?
What do you think about this 2" FaitalPro HF200 compression driver?
Not very powerful but for a Hi-Fi system this is not a problem, the price is soft (200 Euros).
FaitalPRO | HF Drivers | HF200
HF200 and HF14x ( x varies) are both 1.4 " drivers.
HF200 is 50.8 mm (2 in) Throat Diameter.
The HF2xy are actually 1.4" drivers with an adaptor in front. The advantage over the HF14x drivers is that you can mount them on a 2" horn without needing to buy an external adaptor. The disadvantage is that they are less "beefy" than the usual 2" drivers that usually have larger diaphragms. But for home listening a 1.4" driver is often a good compromise because they deliver enough SPL for a home situation and often have better HF extension than 2" models.
Charles (using HF146 on XT1464)
Do you mean that FaitalPro HF14x use the same mounting holes than HF20x?
Anyway I use a tweeter from 7000Hz - 8000Hz
At least the 90 degrees mounting holes are placed on the same 102 mm diameter circle for both drivers:
FaitalPRO | HF Drivers | HF140
Charles
Charles
Material shouldn't matter too much, it is a preference maybe (looks). The horn has to support the weight of the driver. Aluminium rings easier, but if the ringing isn't dampend when screwed to a frontpanel, you can always apply some dampening material on the back. So, choose based on horn design not material
About evaluating a horn design: Smoother change in the mouth to front panel is better (less sound diffracted / reflected back to throat). Avoid horns with abrupt changes in throat area, so avoid diffraction slot designs and try to match exit angle of the driver to the horn throat. Less reflections in the throat. All this is to eliminate "horn honk".
Constant Directivity horn gets you similar on axis and off axis response which means the power response will be nice and sweet spot will be larger.
Still, some people like old horns which are not constant directivity, and have weird shapes, diffraction slots, bad mounths and still couldn't be happier So, especially big horns are largely a visual and emotional thing.
For hifi use, I'd go with a constant directivity horn with OS profile. See the ATH4 thread, there is a free tool there that you can use to design a horn that has a shape and size you like, and be able to simulate it (mind you size and shape relate to the complete speaker system design). It looks like it is easy to outperform any commercial horns with aid of the Mabats software and insane DIY skills But, you could just buy some nice aluminium or plastic horns with very little money and get on with it. Have fun!
THanks tmuikku, very interesting.
For instance Faital Pro HF200, Faital Pro HFM200, and the new Eminence N320T look good, those compression drivers caught my attention.
https://faitalpro.com/en/products/HF_Drivers/product_details/datasheet.php?id=502030150
https://faitalpro.com/en/products/HF_Drivers/product_details/datasheet.php?id=502030090
https://www.eminence.com/pdf/N320T8.pdf
Do you have other affordable models for me and what do you think about my selection?
- Compression driver with horn, help!
