Collaborative Tapped horn project
cowanaudio said:
>What about the 18LW1400's you used OB? They might make a nice TH driver.
Fs=25Hz, X-max=9mm No go for TH.
Look for Fs=~1.2-1.6 Fc
My 18Sound databook says 31Hz, that's why I suggested it.
There are a heap of 18" pro drivers with Fs circa 30Hz so it seems they're in the right range. Lots have similar Xmax to the 18LW1400
You're right Brett
The first generation of 18LW1400 had an Fs of 25Hz, they are now 31Hz as you pointed out.
I have some 15LW1401 lying around that model very well in a Tapped Horn. The model shows performance similar to the Danley TH115, but it goes a bit lower, and in a slightly larger box. This is a project for a rainy day.
Just for fun have a look at this driver in a 2.8M horn 400-3000cm^2. 40-240Hz BW I like it how there are no large out of band peaks. This should be an easy box to use.
Cheers
William Cowan
I can't find any information on the Peerless 830564. Has this model been superseded or obsolete?
Also, any thoughts on any Eminence drivers?
Kappalite 3015LF
0.39 Qts
42Hz Fs
9.5mm Xmax
Kilomax Pro 15A
0.39 Qts
41Hz Fs
8mm Xmax
Kilomax Pro 18A
0.56 Qts
33Hz Fs
10mm Xmax
4015LF
0.50 Qts
42Hz Fs
9mm Xmax
4018LF
0.35 Qts (a bit low)
32Hz Fs
8mm Xmax
G'day Martin
The Peerless 830564 is an XLS 12" driver designed for Automotive subwoofer applications. It has dual 4R voicecoils Fs=48.8 Qms=8.06, Qes=0.66 Vas=20.4, Re=1.2 with coils in Parallel, Bl=9.3 Sd=466 Le=0.9mH
It doesn't seem much good for any domestic application, except for in a Tapped Horn, where it appears almost Ideal.
I'm not sure why but it doesn't seem very widely available.
Solen sell the 830877 (Fs=35Hz) which would probably be worth doing a model for. You might be able to ask them if they can get the 830564 in for you.
Cheers
William Cowan
G'day again
The 830877 actually appears to work very well in a 4-5M long tapped horn. Have a look at 5M long 150-1500cm^2. 300 liters internal volume 25Hz at 130dB when firing from a corner.
Almost double the size of my little 30Hz horn, but it goes nearly 10Hz lower.
I've got too many boxes I want to try!
Cheers
William Cowan
Now that I've had a chance to play with hornresp, I'll answer some of my own questions 🙂
dwk123 said:
a) Has anyone modeled up something with the Pyle Pro PPA 12?
Doesn't look good. I suspect BL is too low. Even in a 4+m horn, not much below 40Hz.
b) Is the TB W8-740C a non-starter? I see it's been mentioned a couple times, but I don't remember an actual sim for it. Fs does look a bit low for a 30Hz unit, unfortunately.
I started nooding with the TB driver and got something promising, and then found sabbelbacke's post back on page 27. My model looks very similar to his but scaled way up to a ~25Hz horn. It has a very small x-section and mouth and I *think* I can fold it down into ~150 L or so. ~95dB/W, and hits xmax at ~30Hz with 25V.
So, the next question is how to deal with the large spikes out of the passband? Notch filters? Brickwall FIR filters? (I guess I'm assuming they are real rather than modelling artifacts)
Another W8-740c iteration. Slightly smaller throat and moved the driver up 50cm from the throat. Makes for an incredibly flat passband, but you deal with a knee at the end rather than the usual dip/peak. May or may not be easier to deal with.
Greets!
Hmm, maybe not the best choice, but where size isn't an issue (~33 ft^3 gross if I did the math right), this looks OK for a quick first pass and since it's under-damped can be shrunk some:
GM
Volvotreter said:
Do'nt you think the size of the throat might be a little too small? This is a compression ration of approx. 7:1! I'm not an expert on this matter, however my stomach tells me that not to exceed 3:1 may be 4:1.
Yes, I'm concerned that the specific size I've modeled is too small. However, the Fitzmaurice Tubas that use this driver also have very small throats, so there is evidence the driver can handle it. Certainly, given it's appallling efficiency, it's required to get any decent output from this driver.
I'll have to pull up my Tuba plans and see how tight a throat Bill uses.
judtoff said:
This is interesting, I have one of those Tang Bands, and was planning on doing a 35Hz Tapped Horn.
I couldn't really get a 35Hz version to work with the TB, but if you start with sabbelbacke's version from a couple pages back you should be ok.
My ~25 hz versions look to be foldable into a package 6'x18"x9" or so, which IMHO is pretty small for the performance. I haven't really had a chance to sit down and draw things accurately though, so I'm not 100% sure it's going to work.
Do you have a link to the Fitzmaurice Tubas?
www.billfitzmaurice.com
look at the autotuba and table tuba
Thanks for the help. I was looking around and found an interesting fold pattern.
With the TB W8 It would be tuned to about 30 Hz or so. Do you think it would stand up to a 5:1 compression ratio?
And Bills horns look nice, any links to some DIY versions or plans?(free ones preferably)
G'day judtoff
That is an elegant folding scheme. In practice there is actually little need to angle the internal baffles, just step the areas to approximate the desired expansion.
5:1 is too much for any driver I've seen or know of. Even the beefy Lab12 driver would fall apart above 3:1.
Bills horns are well executed compromised front loaded bass horns, but for the volume and mouth size, a well designed Tapped Horn will always work better (flatter, lower, louder). A Tapped horn is uncanny in it's ability to work really well with a very small mouth and total volume.
Cheers
William Cowan
Checking my plans for the Table Tuba, it looks like it runs right around 3:1. I'll play around with my model and see how I can rebalance things.
judtoff - William is spot on. For a given size, a tapped horn will outperform a Tuba if we're only worried about use as a sub. The 'problem' with Bills Tubas is that they're wider band devices, and the sub frequencies are at the lower-efficiency end of their passband. For example, the Table Tuba holds ~95dB efficiency down to 30 Hz, but needs 9 cu ft. My models show a tapped horn holding 95dB down to 25Hz in about half that size.
BTW - your folding scheme is similar to what I'm looking at, although I have one more fold and some changes since I need the mouth halfway down the cabinet. Your diagram should work fine as long as the dimensions are right.
