I'd choose the ES9018 I suggested above.
Use a good power supply for both boards. Try not to use internal USB supplies.
You mean ES9018K2M, not ES9018 that costs 55$ only the chip!!
i can't find designs of ES9018K2M and the datasheet is empty
http://popcornhour.hu/media/news/a-500_pro/es9018k2m.pdf
Where can i find the chip itself?
How about the board below?
ES9018K2M XMOS DSD DXD 384kHz USB DAC with Bit-perfect volume control and SPDIF input - DIYINHK
DIYinHK makes good PCBs/Kits for the money. The design is much better than the cheaper (ready assembled) ES9018K2M DACs seen on ebay. It offers some hardware-hacking options, too, like separate analogue regulator ports for L and R, and access to control registers via I2C.
This board also allows you to use the ES9018K2M hardware volume control (you need to add a microcontroller or Arduino to use it). The cheap ebay DACs do not appear to give a connector for I2C, so no access to the hardware volume -- beware!
The ES9018K2M is a much better DAC than the ES9023 (etc). It includes the mighty ES9018 modulator and DSP functions.
The DIYinHKit's board seems to be one-way solution. Isn't it?
So to be the project completed only a well stabilized supply is missing
Rod's comments are quite correct, particularly on that ES9018K2M board available on eBay, or not going the ES9023 path.
Perhaps there's someone on this forum that tried the ES9018K2M ebay board, and can comment on the results. I would love to hear them too. There's very little or no information on how to control the whole thing using that board, like volume, settings, etc.
OTOS the DIYinHK Kit will need other parts to work as it should, and would probably make your USB board unnecessary, as you should have to get DIYinHK's, which is much better. Price for kit is quite a deal too.
Being able to use external linear supplies is very good too, sound quality wise. Of course that might increase the final cost, but it all depends on how much you want to spend.
Pity your USB board's manufacturer does not offer any DAC to mate it with. That should be the best option.
DIYinHKit says:
*The single ES9018K2M DAC PCB can be used individually with only 3 wire I2S signal connected from Raspberry Pi, BeagleBone Black, cm6631a, amanero etc.
I think they will combined nicely!
Also i believe that power supply is the half of quality of every device analog or not
Thanks both for your help
It's certainly worth a try.
Look at the new very low noise regulators from LT and AD, the linear ones.
LT has a very good reputation about regulators
But there is a drawback, they have short time time of production
In about 10years will be obsolete
I may try one of ultra low noise if the packaging isn't smaller than SOIC
What does than mean in 10 years will be obsolete?
Regulators don't go obsolete: as long as specs are good, or better than others, that's what's important.
Even if a better one is released 5 years from now, or three, that doesn't make others obsolete.
I suppose i didn't use the correct word, my wrong
I mean out of production not antique!! It have happened twice that, i couldnt find a specific switch mode LT regulator on production
What if i use all power supplies floating? Away from common ground
Will that helps somehow?
Hi. My pc does not recognize the cm6631A device. Usb port shows an error when I plugged the usb cable of cm6631A. I have windows 10 and a gigabyte motherboard GA-970A
This is the Windows message. I tried with 3 different pcs and the same message. 2 in win10 and 1 in win7Did you contact the manufacturer for a Windows 10 driver?
How can I do this? My pc does not recognize the cm6631A card to do soDid you upgrade the 6631 driver to windows 10? You need to.
This site downloads you a driverdoc to scan your pc and recommend you the drivers for unknown devices, I suppose.
Have you tried this driver?
Hi-Fi CM6631A 192KHZ 24bit USB 2.0 to Coaxial Optical SPDIF Convertor DAC Board
Scroll down to the driver to download.
This are the people that designed the 6631. Contact them on where to find the driver for Windows 10.
https://www.cmedia.com.tw/support
I have put this driver for the first time. Maybe something wrong with the device or with the usb power or with some ground connection or I don't know what else...Have you tried this driver?
Send from Huawei Mate8
- Digital Line Level
- CM6631 USB audio interface ... any good?
