CM6631 USB audio interface ... any good?
I did not receive any drivers from the seller. I don't know who the seller is. There are thousands of sellers on Ali, communication with them is impossible. They themselves don't know what they are selling. I downloaded the driver from the Internet, all working good.
Reactions: Roppu
Thank you (spasiba?) 790.
It is unbelievable. I can't find the old drivers. I downloaded them from the link the eBay seller gave me. It is the Weilang Dac7 but I bought it some 10 years ago.
I only can find these ones on my PC and they look being for up to Win 8. And yes, your ones are much more recent as mine are ver. 7. I will test them as soon as I can plug the DAC again.
I uploaded them just for you to have a look
Reactions: 790
@Roppu Grazie 😉 Yes, I have already installed it and it does not change the definition of the device as a Speaker (Installation of program from this pack is impossible on my Win10). I know that only reflashing will help me, but this is too much of a risk for such a minor change. SPDIF-out in my CM6631A works well now for hi-res stereo and I have another device for multi-channel movies.
I know how to use SPDIFer-plugin in foobar2000 for multi-channel AC3/DTS in bitstream mode via this 6631A, but the multi-channel music that I need does not exist 🙂 (I have 2 samples of Bjork in 5.1 (Dolby and DTS-96/24), if you wanna check it)
Reactions: Roppu
After 6 years, I built an amplifier again using a CM6631A module. I will describe some of my experiences, I think it will be useful for others as well.
-Flashtool 2.1.0.9 runs on Windows 10.
-If the fw upgrade process stops during upgrade and the CM6631A no longer works, you can still repair it using the free Zladig program, you will need to install a driver for it as a libusb-win32 device using Zladig. Flashtool can then write new firmware to the device. This happened with me once. https://zadig.akeo.ie/
Steps for successful firmware update:
-Plug-in the CM6631A, select the proper device (there can be more than one on the list, check for 0D8C... on the list), then press erase.
-Important, be sure to remove, than re-plug the CM6631A before trying to upload the new firmware.
-Select the proper USB device (there can be more than one on the list, check for 0D8C... on the list) then load your firmware.
-Re-connect after firmware update.
I uploaded the files to keep them available.
I also uploaded my own firmware file, I use it with PCM5102A DAC in 3-wire I2S mode. (for 45/49MHz crystal pair CM6631A's, 32bit / 384k mode)
hi:
Burned the firmware you provided, SPDIF output has 384k samples but no data. Can you provide a SPDIF 384k working firmware!
