Replace R23 use 47k instead 10k and you have gain 5X
Thank you so much!!!
hi mr mile
i built irs1500 but my toroid iron powder heated after 15min
i think in d200 heated my toroid core
my core is t-106(yellow)
i did not find other core in my local city
can i turned wires coreless?(on the air)
respectfully
respectfully
hi mr mile
respectfully
Yes you can turn wires coreless.
hi mr mile
respectfully
A city with only 1 type of core available? Impossible! You surely can get an old PC PSU. There is a big ferrite core (EE or EI) in it. With about 2 mm air gap it is much better than the crappy yellow iron powder, or air cored inductor.
Or you can use the core of the High Voltage trafo of any CRT TV or monitor. Etc... there must be some tons of it in any town for free.
Air core is OK for high power only if you use litze wire or you make it very big.
how many turns to get 50uh . and what size of gap is needed sir ??
Approximately L=n*A/h*mu0
A is the core cross-section, h is gap height, mu0 is permeability of vacuum (0.00000125). Everything is in SI unit.
BUT:
You must define saturation current requirement!
Approximately Isat=h*250(A/mm)/n
For example A=200mm^2, 1 mm gap height, 14 turn is about 50 uH, with Isat=17 A.
For 30 A you need h=3 mm and 25 turns, but this gap height has a relatively strong fringing flux, wires have to be kept away from it.
BUT:
thanks paffi
yes . it woks well and it is very powerful
Can you post the pcb from this smps?
thimios, you can find here > Switch Mode Power Supply Circuit SG3525 IR2110 900W SMPS - Electronics Projects Circuits
Quote:
Originally Posted by andrewlebon View Post
Hello apexaudio
greetings nice to see d2000 working can you post pcb if possible
warm regards
Andrew
D2000 is not for DIY.
Hello apexaudio
warm regards
Andrew
- Class D
- Class D Amp with LM566, LM393 and 2XIRF530
