hi sir mile
share PCB please
i want test your amp again
thanks
This is same circuit, amp must work on old pcb.
nice pcb, but still can't find the iron powder..... ooooo i,m so frustasion😱100nF/100V and two 0R1/2W instead 0R1/5W was add with litle pcb change.
Dear Mile,
Nice to see that you are working on the new PCB. But I still see there's no space for a heatsink on outputs.
When I turn off D200, it will give me a funny noise (like a siren going from high to low frequency) until rail caps discharge. Any suggestions please ?
Outputs and heatsink are on botom side of pcb, use speaker protect with NE555.
For power resistor (2k2/2W - 10r/2W - 0r1/5W) can I use coil resistor ?
You can use any kind of resistors.
Sir Mile,
How about these type for the O/C protect, are they suitable for D200?
Regards!
0,033R can be use with IRFB4227, but 0,005R can be use only in O/C protect with LM311 comparator ( D500 O/C circuit ).
at last my D200 is singing.... using coil from computer psu and not hot just warm, i,m HAPPY now... YESSSS 😎
Nice work, coil isn't rewind?
Hello,
what is the brand of the 0.47µF and 0.22µF capacitors?
Because my seller don't sell WIMA capacitors.
Scuse my Frenchy English 😀
yes sir, the coil is not rewind, i have 1mm wire, how many turn should i wrap the core ofthis kind ? Regards.Nice work, coil isn't rewind?
( sorry, i,m using google translate to wrote)😀
What is rail voltage on your amp?
Hi mile,
did you check D200 @75V rail??
is it start(oscillate)@very low signal input without noise???
feedback resistor 4k7 hot???
MANOJ
MANOJ
Hi mile,
MANOJ
This D200 work at +/-80V rail, only 2k2/2W and TIP31C are hot.
It start at very low input signal without any audable noise.
Hi mile,
actually Mackie SRM450 using 4k7/2W series with 47K/0.25W for feedback and it will HOT little @35 degree.
MANOJ
MANOJ
Hi mile,
MANOJ
For me over 60 degree is warm and over 90 degree is hot.
just for testing i'm using 42v dc. 🙂What is rail voltage on your amp?
my caps 0,47uF and 0,22uF with no brand, i think from china.Hello,
- Class D
- Class D Amp with LM566, LM393 and 2XIRF530
