Class D Amp Photo Gallery
Disabled Account
Joined 2008
High power and battery power isn't the best mix.
Also, batteries normaly have a pretty high Zout at high frequencys, making them everything but ideal for audio, and absolutely not for class-D.
I agree, it's important to use a "stiff" low output Z power supply for Class D amps.
What SMPS are you using and how large capacitor bank?
What about rail pumping?
BTW: Instead of using the Class D photogallery as a show place you should open a thread about the amp in the Class D forum or in the Marketplace.
Stein
Reactions: 1 user
Joined 2007
.... I'm using a 64V 1.2 kWh custom pouch cell lithium ion pack that has a 50A BMS, I'm sure without the BMS it could push a terifying amount of current. The bus capacitors on the amps handle the high frequencies. Its for portable stuff I currently have 6 channels of TPA3521 (parts shortages prevented TPA3255) running on it using a buck converter.
What is the Zout vs frequency? And how does the noise spectrum look?? Normally lithium batteries Will have quite high levels of noise.
One of my amp.
Reactions: 1 users
Starkrimson Ultra Build.
First pic is in an old amp case. The other two are in the custom Modushop case.
I have now made my Starkrimson to be dual mono with the addition of a second power supply. I have also installed the rail capacitor upgrade on top of each module. It has made a nice improvement to the sound, more than I expected. I have also attached a pic of the rear of the case showing the WBT0703 binding posts.
Reactions: 3 users
XH-M542 TPA3116 Mono block with front opAmp NE5532 , help advice using smps psu or dual psu per Chanel L&R “CRC psu - MC psu Rot Eliot? ….
Nice, regarding the PSU, I would go for 2 Single rail with LLC circuit. (one per module)
I am testing some PSU with my PA5 (TPA3255 amp.) but it gives some idea :
Max VDC for The TPA3116 is 26V.
If you are looking for a very good PSU, I will for :
1) https://www.audiophonics.fr/fr/alim...-dalimentation-decoupage-300w-24v-p-6196.html
2) https://recom-power.com/en/products/ac-dc-power-supplies/ac-dc-off-board/rec-p-RACM230-24SG.html?1
The Connex uses zero-voltage switching half bridge resonant topology , it is a nice Audio PSU (see my thread with the PA5).
The RACM230-24 uses an Active LLC PFC controller and works nice too but is less Powerful.
Thanks for advice 🙏🙏🙏
Thanks for sharing.
