Chip Amp Photo Gallery
lm3886
It's a Mullard C280 Polyester film cap.
Capacitors don't "add" anything they are passive.
Frank
If the cap and circuit trace has a resonance in the audible band it can "add" a coloration to the signal. More often a passive cap would be used to "remove" a portion of the signal however a poorly designed circuit will create a tank and appear to "add" something.
I don't think that was his intent with the striped cap but a blanket statement could confuse the less experienced.
Finally built it up -- took me half passed forever to build the enclosure, but my audiosector.com kit is finally up and making noise. Here's the imgur gallery.
The transformer is an Antek 200VA transformer (AS-2224) and the kit is the LM3875 'Classic Kit' from Peter Daniels.
I used wood for the side rails and L-shaped aluminum brackets mounted on there. The chips are mounted to a U-shaped bracket; that bracket is mounted to the back and bottom (with silicone grease of course).
I'd never cut aluminum before and found it surprisingly easy to cut with a bi-metal blade in a jigsaw. In retrospect, I shouldn't have used wood for the rails as there's no room for expansion -- but I had absolute zero faith in my ability to machine, tap, and line up aluminum. Besides that, I'm quite happy with the results!
The switch in the back isn't working and a replacement is on the way. Now, off to build up my Mesmerized DCB1 buffer and a proper media console to sit it all on.
A tip:
With that thick front panel (>4mm) you do not need to drill the mounting holes through the plate. Drill carefully from back side of the plate with a 2.5mm drill and only to about 3mm depth, not completely through the plate.
Then use stainless steel M3 screws and screw them directly to the 2.5mm hole, use oil as lubricant when screwing (and there is nothing perverted in this as my late dance teacher would have said) and you have nice attachment for the panel from the back side invisible to the front - which is nice...
A tip:
Thanks, but I like the screws up front. Also far easier for me to drill and align 2 holes coming in from the front. I was having trouble drilling through two plates and having them both match enough for me to tap. This thread from Peter Daniel's was helping a great deal during the build.
