Cheap TPA3118D2 boards, modding them and everything that comes with it
After soldering a gmarsh pcb, a buffer and repairing an amp the 0.8mm conical Weller tip is bigger than the 2.5mm flat tip Ersa 🙂 Sanding is possible indeed, a few times before it gets too short and really should be done after every pcb soldered. Really poor tips, from different sources, local official Weller distributors, not online. Weight of handset is good for me, cable Ersa is a little more flexible. Weller replacement tips are cheaper than Ersa, when looking for smaller tip I bought the Weller, because that seemed convenient, cheap spare parts.
Sanding Weller soldering tips ? Come on guys ! I thought everybody knew that the tip must never be sanded. The thin iron or nickel coating will wear off causing the problems you described. Just clean them with the wet sponge after each use to get rid of the rosin (corrodes the tip) and they will last for years and years. I think it is written in every manual that comes with Weller tools. Common knowledge ... The sponge that is supplied with the tool really has a real function, please try it.
User error big time !
Mmmm, pro tools last forever when used correctly for their intended use. I have 80W Weller irons with a bag of new tips and haven't had to replace the current one in years. I solder a lot and I solder old fashioned lead containing solder of a reputable brand. I had tips failing in the past with my older Weller iron I had then, found the right solder and stayed with that solder ever since.
I don't see any reason to mistreat tools (or any device/equipment for that matter). It always comes back to you either in cost or in dissatisfaction. Resale value of well treated and well maintained stuff is way higher too which opens the way of upgrading to more sophisticated stuff without too much loss.
Do you use the WTCP-S ?
* I see we're amongst the kings of off topic issues 😀
Jean-Paul and others,
Even though a bit off topic I am finding the tool discussion interesting and informative! To me, it's all part of the learning experience. I had no idea some of these de-soldering tools even existed.
To return to the Sanwu tpa3118...I'm wondering if XRK (or someone else even) could take a photo or specifically direct us to the two resistors which change the gain on those boards. For 26dB, I take it they were a 100K and a 20K surface mount type. But I remain foggy on which exact ones they were.
Thanks gentlemen,
Mark
