Cheapest PCB's ( with FREE tinning , FREE drilling)
Below pcb's have been manufactured for our forum friend - "KVP" - from Belgium
Thank you.
I would like to thank our dear member msdesigner to make it possible to get those 2 boards at a very reasonable price. Very helpful throughout the complete process.
Cheapest PRINTED-CIRCUIT-BOARDS, with FREE TINNING and FREE SILKSCREEN (mask components)
Below is the SILKSCREEN of board (TOP layer)
Below is the BOTTOM layer ( with tinned traces and pad's) , of above posted board.
Below is the BOTTOM layer ( with tinned traces and pad's).
Top layer ( tinned traces + silkscreen ) of the pcb posted on 3rd June.
Cheapest DOUBLE LAYER, PRINTED-CIRCUIT-BOARDS on FR4 support, with FREE tinning and FREE drilling.
Below it's the TOP layer of big size board with 274x146 mm.
Below it's the BOTTOM layer of big size board with 274x146 mm.
CUTTING ON EDGES = FREE
The boards can not be panelized (more boards/sheet) .
For small boards (under 50x50mm ) the max. quantity / board type ( model), could be 6 pcs.
Beginning with 20 July 2015, the printed circuit boards, could be manufactured on (THINNER) FR4, as follow:
1.SINGLE SIDE ............ start with 0,0285 EURO/cm2
- support thickness = 0,5 mm
- copper thickness =18 um
2.DOUBLE SIDE.................start with 0,0553 EURO/cm2
- support thickness = 1 mm
- copper thickness =18 um / each side
RED pcb's , on FR4 with 0,5 mm thickness.
Available colors ( paint ) : RED , WHITE
Available soon: GREEN, BLUE, BLACK, ORANGE
Painting is applied for FREE only for 0,5 mm support , to opposite layer of traces.
Below can be seen the tinned traces layer of pcb silkscreen posted on 16 July.
Below it's the BOTTOM layer ( of above posted board)
- Vendor's Bazaar
- Cheap printed circuit boards starting with 0,0375 Euro / cm2
