Hi Jedy,
Send me both files to my e-mail address , I'll study and I will give you an answer as soon I can.
Regards,
Mihai
Dear Mr ...,
I send to you in few time ... thanks for all.
jedy
Double layer pcb ( painted with soldering flux and top silkscreen)
Below it's the BOTTOM layer , of above posted pcb ( + posted photo with components installed , did it for our forum friend "solviken" )
I did not forget your inquiry.
I will study the last file send and I try to give you an answer till the end of this weekend.
Regards,
Mihai
Regards,
Mihai
Do your remember In quote my A75?
Best Regards
Cheapest PRINTED CIRCUIT BOARDS on CEM3 support (professional version ) with FREE TINNING.
The TINNING is FREE , only for CEM3.
The DRILLING is FREE for any support (CEM3 or FR4) , without holes number limits / board.
Cheapest PCB's on FR4 support. ( SINGLE or DOUBLE layer )
DRILLING and PAINTING with SOLDERING FLUX are FREE.
Soldering flux is transparent, rigid and glossy, and helps a lot for better soldering.
I have received also an e-mail from you.
Please resent to my e-mail, also your inqury posted in my thread and of course the PDF file.
Will continue to talk by e-mail.
All the best,
Mihai
All the best,
Mihai
Can you drill several 20 - 32mm holes in PCB for mounting sockets? Board is FR4/2mm, double layer, 290x210mm?
What will be approximate price for such board?
Cheapest PCB's on CEM3 support with SMD components
The PCB shown below is done it from .png image file with very low resolution ( less than 96dpi) , and has a great result, if we took in consideration the file quality.
Cheapest printed circuit boards (PCB's) on CEM3 support)
Cheapest_PCB on CEM3 professional support.
I offer you for free:
-TINNING (only for CEM3 support)
-DRILLING
(Below pcb has 200 x 150 mm)
-DRILLING
-DRILLING
-DRILLING
-DRILLING
-DRILLING
Double layer PCB, on FR4 support, with over 95% ground plane on each side.
The best layer synchronizing (over 99,5%) could be done it from Eagle files.
- Vendor's Bazaar
- Cheap printed circuit boards starting with 0,0375 Euro / cm2
