Printed_circuit_board
Cheapest_printed_circuit_board, Fr4, with SMD components, made from 150 dpi jpeg image ( low resolution - more than good, the pcb quality)
Printed_circuit_board_PCB, on FR4 support, painted with transparent soldering flux.
Cheapest printed circuit board on FR4 support painted with transparent soldering flux.
Double layer PCB,on FR4 support, with over 99% layer synchronizing.
Below it is the BOTTOM layer.
Double sided PCB (Bottom layer)
TOP LAYER of above PCB
Cheapest printed circuit board on FR4 support, painted with transparent soldering flux.
TINNED Double layer PCB, on FR4 support, with both sides SILKSCREEN (components mask) - TOP LAYER
Layers synchronizing = over 99,5% )
TINNED Double layer PCB, on FR4 support, with both sides SILKSCREEN (components mask) - BOTTOM LAYER
Printed circuit boards
Cheap printed circuit board (PCB)
Silkscreen ( Components mask ) - for FREE
Printed circuit board of above silkscreen components mask.
Cheapest printed circuit boards on FR4 support.
It is offered for FREE :
-Painting with transparent soldering flux
-SILKSCREEN ( components mask)
-Drilling
-Drilling
The silkscreen ( components mask of above pcb's ) can be seen in below photo.
I wish to all members of diyaudio.com forum, a better New Year 2014 !
How much for 1 pcb, including shipping to Spain - Europe?
TINNED printed circuit board on XPC support ) thick 1 mm - copper 18 um
Advantages ( than FR4 )
-lower cost;
-better drilling and cutting;
-tinning is better ( more sticky and more uniform ) ;
-more accurate traces and pad's ( in special for pcb's done it from .jpg with low resolution <600 dpi
-lower cost;
- Vendor's Bazaar
- Cheap printed circuit boards starting with 0,0375 Euro / cm2
