It looks like just about everything in the chassis department is sold out. When do you plan do restock? Thanks.
Your answer was posted recently. It seems like there is a new shipment arriving every 3-4 months.
Thanks for your interest. About 2 months.
mounting screws and standoffs
Hi there,
I am building an F5T v2 and have the PCBs from the store. I am getting my parts together now and plan on buying a 5u chassis when available.
I'm not sure what screws for the mosfets and standoffs for the front end I need.😕😕😕
Here are my questions:
1. What thread length do I need for the brass hex M3 male x M3 female standoffs for the above chassis?
2. What is an appropriate body length for the above standoff?
3. What thread length M3 socket head screws do I need to secure the F/E to the standoffs (I guess it'll need to be maybe 2 or 3mm longer than the body length of the standoff)?
4. What thread length screws do i need to secure the mosfets to the chassis through the washer and mosfet?
Appreciate any help.
thanks
cd
Hi there,
thanks
cd
The easy solution is to buy the Premium back panel and PCB / Transistor / Diode mounting parts kit for the Deluxe Chassis - Accessories & Spare Parts - Chassis It's a good deal for quality parts that you know will fit. Next time that's what I am going to do.
It found that the mounting holes are tapped 5-6 mm deep. From there you can figure out how long you need to make the screws - enough to pass through parts and washers and give ~4 mm of engagement.
For standoffs, all they need to do is allow the leads and solder on the bottom of the board to clear the chassis. I use 1/4". Remember to allow for the board thickness when figuring screw length - 10-12 mm is where I come out.
For the mosfets, add 4 mm to the device, isolator and washer thicknesses. Another option I like (learned from AndrewT) is to use 20 mm screws so they are maximally engaged with the tapped threads. Use a nut on the screw to apply the pressure to hold the devices in place.
Bob,
I was reading your post263 and thinking to myself that much extra thinking is avoided by using the "too long" all thread screw and a nut.
I got to the end and smiled (a lot).
Bob, Thanks very much. I think I too will buy that back panel parts package if it's in stock when I begin the build.
The 5-6mm deep mounting holes I think is what I was after and hadn't thought about the solder on the bottom of the PCB. So thank you for bringing that to my attention to.
Andrew, I like to give credit for ideas that are not my own.
Thanks for passing that (and others) on.
It looks like most of the full width chassis are out of stock. Is there any estimate on when they will stocked once again? I am getting prepared to build a pair of F5T v3.
Thanks.
Thanks.
Any time frame on the 4u and 5u cases?
Thanks,
Vince
Hey Vince 🙂 They are now in stock (in a slightly different configuration) but aren't public yet because I need to update the product information. We updated the back panel to allow much more flexibility for XLR, RCA, dual XLR and RCA, and combinations. I'll try to get them online ASAP!
Ok, done - they are now here:
Full width with 40mm Heatsinks - Chassis
Any questions feel free to ask. I am currently away on holiday, apologies for the slow updates.
Hi there,
Anyone bought the Deluxe 5U V2? Mine came only with a bag of about 6-8 screws taped to the perforated base plate. One needs way more than that to assemble the enclosure. And no rubber feet either. Did you guys get them or do I need to buy my own? I sent an email to the store helpdesk last week and I am still waiting on a definitive answer so I thought I would ask here 🙂
Thank you
kj
Thank you
kj
Hi there,
Thank you
kj
I got the 5U Deluxe today and the hardware kit is missing too. 🙁
Hi there,
Thank you
kj
Hi KJ123,
The Helpdesk did receive your email last Aug 10 and requested you to allow us to refer your case. Apologies that we couldn't get back to you sooner. We are now working on sending you replacements. Please email the Helpdesk if you have further questions. Thanks.
Hi JERICOH,
I'm sorry that you didn't receive the correct screws as well. We are working on sending you replacements. Please email the Helpdesk if you have any other concerns. Thanks.
Is there a European warehouse?
Thanks 🙂
\\\Jens
Hi Jens,
The diyAudio EU warehouse is temporarily closed but we do have plans to restock it in the near future to cater to our EU customers.
At the moment, however, all orders are shipped from the USA warehouse.
- The diyAudio Store
- Chassis Discussion
