Shaan,we have continuity!
1)I have cut two traces.
2)Now look what is the measurement.(exactly same when testing leads shorted)
3)Tracing between A,B after the modification.
4)>> >> >> >> WITH A SHORTED INP.
Guys sorry but the good news ended here.
Look what output tracing without any signal(shorted inp.)after the modification.
This way but the problem is still here🙁
Can you short the 10R resistor with a wire and then trace the output?
Yes i will try this later,i must eat something😉Can you short the 10R resistor with a wire and then trace the output?
Do you mean that c3,c2 must be on a separate gnd too?
In this particular case, the board is not too long, so connecting them to the "back" of the board is fine. On the longer board it would make sense to connect them together and then make a connector for a separate ground wire.
Have you any new comment for the remaining problem?In this particular case, the board is not too long, so connecting them to the "back" of the board is fine. On the longer board it would make sense to connect them together and then make a connector for a separate ground wire.
Yes, for CFA it most likely will be the best solution.
Jumper the ground lift, as Shaan already recommended 🙂
May be I missed it but can someone kindly link me to the post in this thread where the ground loop problem reportedly occurred without, and was solved with the 10R there?
Thanks in advance. 🙂
Why would one want to take the interference passing through these decoupling capacitors to the Signal wiring?I agree with the way C14/16 are routed i read some advice in this way for decoupling ground return. Even These C14/C16 are not carring high Amp current. 4700uf in OPStage ahave their own return. And even X have no hum in his CFH9 nor in CFH7 that have dirtiest return route.
Marc
It's not just hum that passes through the decoupling capacitors. Any interference on the supply rail will take the decoupling capacitor route, IF the impedance is lower than any alternative.Hi guys,
I went into the lab to try to see what I am getting and why it seems to work. I have been using a cap multiplier all along so I have very little (almost zero) supply rail ripple. This is the Juma's Easy Peasy Cap Mx (IRFP240/9240 and 4700uF with 470uF caps). The amp has no hum. But when I bypassed the Cap Mx and go directly from the CRC PSU (2x9600uF caps per rail), I can hear hum. So this was why I did not hear it. I just did not notice it when I quickly tested before without the Cap Mx.
So in the absence of a solution to this, I would recommend building the very easy to make cap multiplier to temporarily solve the issue. But if you guys can figure out an easy or clever way to remove the hum with some sort of jumper or ground strap that would be great.
The Juma Cap Mx adds 50dB of PSRR, which essentially makes this a non issue. Hope that helps.
All the HF glitches that get onto the supply rail will pass through the decoupling and enter the current route you have provided. The low voltage side of that route MUST be low impedance. Any impedance in that route will generate a voltage. Minimise the impedance as much as possible. This means very short wires/traces to the decoupling ground.
Yes, connecting the low voltage side of the decoupling caps together is better...............This issue can be solved with cutting two tracks and soldering two wire : C14 to C7 and C16 to C6 under board.
In fact all this make sens for further routing job.
Marc
Do that for every decoupling pair.
Then connect all these decoupling low volts wires together to create a low impedance decoupling ground. This is where you connect the PSU zero volts to.
Here is my "opinion".
I think it is better to cross connect each pair of decoupling caps. A short thick route is better than a long wire.
Then connect all the cross connections together with another wide trace. The shorter the better. But preferable to have the highest current connects at one end of the trace and have the lower current connections spread along this trace to the smallest current at the other end.
This should be done at the PCB layout stage.
Then the current routes for each stage should as closely as possible follow the traces that return the current. This is the PCB equivalent to using a close coupled pairs of wires.
Cherry drew an example of this in a paper way back in the 80s, or 90s.
But almost no layout designer follows his advice.
Almost all spread out the Flow and Return traces so that they have BIG LOOP AREA. This is where your interference gets in.
And a big ground loop around the perimeter of a PCB is one of the biggest interference gathering loops one can build in.
the ground lift ( a bad label in my view) reduces interference current in the signal wiring. This is not usually a problem in a mono block. (a real monoblocks, not a dual mono where two amps are inside the same chassis).
The ground lift will probably have no effect in a mono test. Compare it on your work bench using 0r0 to 10r to 100r.
When you go to a multi-channel amplifier, then you find that interference current in the signal wiring increases enough to become easily measurable and often audible.
That's when 0r0 does not work and you need to add in the extra resistance, to reduce the current. Somewhere between 2r and 22r is usually suitable.
A better label for this resistor is "signal wire current attenuator".
One disadvantage to using this extra resistance in the signal return to decoupling ground connection is that it generates a DC voltage when the +ve current is not exactly matched to the -ve current. That DC voltage error is read by the amplifier stages and becomes an output offset.
Do not unbalance the input stage to cancel this "added resistor" offset. Instead balance the +ve and -ve currents so that the DC voltage across the added resistor becomes <<1mVdc.
I have always noticed these amplifiers do not need any 10R in the signal side ground in order to prevent motorboating if a central star ground is used in the main PSU.
Hi Andrew.
In an amplifier with 2K2 input resistor and 47R gain-set resistor is it possible to balance the input and feedback current?
Also, how can the dis-balance be a DC potential when both the 2K2 and 47R resistors are in series with capacitors, passing only AC?
CFH9
Unfortunately the signal gnd network shorting can't solve the problem.
It doesn't make sense if it's shorted or open,TESTED🙁
Tested on a new +/-50v power supply (+/-5mV ripple) with a little better results but the problem is here.
I see better results when resistors(18R/10w) placed in series with the rails.
I assume you are referring back to post633Hi Andrew.
. Could you reword your questions. I don't understand what you are asking.One disadvantage to using this extra resistance in the signal return to decoupling ground connection is that it generates a DC voltage when the +ve current is not exactly matched to the -ve current. That DC voltage error is read by the amplifier stages and becomes an output offset.
I assume you are referring back to post633. Could you reword your questions. I don't understand what you are asking.
Never mind, I got it. 🙂
Interesting.
Can you upload some pictures including the PCB setup, heatsink and signal wires? I am beginning to think we are reaching the PSRR limit of the amplifier, though it looks like it should have better performance.
Yes of cource.🙂Interesting.
- CFH7 Amp
