CFH7 Amp
The supply is fine, but seeing the output spectrum with the input shorted may give us a clue where to look next.
Here is the FFT with a shorted input.
...It is a clear audible hum... It isn't a power supply problem...
The intention for the dedicated input ground is to provide the input section the cleanest reference, direct from the main PSU ground.
In the CFH9 PCB I see the C14 and C16 terminated to the input side ground. These capacitors are decouplers, doing a dirty job of cleaning the VAS/Input supply off some ripple. They do not suck/absorb the ripple current, they pass it to ground and get a tiny bit charged while doing that.
Ideally that ripple current flows to any connected ground without problem if the trace was a superconductor, but in our case it is a very not-superconducting copper, having still some minute resistance. Now add with it the 10R to the ohm's law equation (ignoring 0.7V clamp by the two anti-parallel diodes). If there is any current into any resistance there shall be born a Voltage. This voltage pollutes the input ground with its most fundamental component, i.e. the 50Hz(or 60Hz) ripple. Obvious in the spectrum traces.
IME, the solution is to route all the decouple capacitors (even the small ones) to the PSU side ground and keep the input-feed ground for only input.
:2c:
:2c:
Very good catch!
In any case the VAS current decoupling capacitors aren't these,those are for input decoupling .
Thanks Shaan!
Hello Idefixes.
Take a look. I tried to illustrate the effect as simply as I could.
Showing only the positive half, the negative is the same, only opposite polarity.
V1 is our positive supply at 50V.
V2 induces a 100mV sawtooth wave over V1, making the voltage on the left of R1 a sum of V1 and V2. Almost simulating typical rectified PSU output.
C1 simulates C14 in CFH9 PCB.
l1 simulates input segment current draw (2mA is a typical value).
R2 simulates the 10R resistor of the diode+resistor network (diodes not drawn as not necessary for the purpose here).
The green trace shows the ripple current flowing through C1 (C14 in CFH9). Remember that this current also flows through R2 to ground.
The red trace shows voltage at right side of R2 (Point A in the last pic I uploaded). This voltage is a direct result of the ripple current flowing through R2. This is the problem because this exact sawtooth voltage is the "ground" presented to the input stage and it shows a 60mV amplitude while it should be a straight line (i.e. 0V AC).
The input does not care what the problem is, it will take this voltage as part of input signal (even when input pins are shorted) and amplify it according to the amplifier's gain. As a result it finds its way to output.
Hello Idefixes.
Hi shaan thanks for explanation. All routing job after CFH9 my SR60 layout under (red tracks) C2 isn't solder for separated ground. What i can say is that the major parts of layout i can see on diyaudio doesn't care from as all ground are together even Peeceebee v1.1 is routed that way....my verstatil (VSSA with BJT output) too but silent dead....
Marc
...What i can say is that the major parts of layout i can see on diyaudio doesn't care from as all ground are together even Peeceebee v1.1 is routed that way....my verstatil (VSSA with BJT output) too but silent dead...
Of course.
Terminating all ground paths in a single point on amplifier PCB is great for reducing chance of supply noise getting into signal if thick power cables are used and cable length is kept to a minimum.
But providing the input ground directly from PSU ground is a step further and eliminates all possibilities of anything from the supply rails getting into signal ground. This is why V2 has it and it is more immune to supply rail noises than V1.1 even if thin and long cables are used.
Happy building.
CFH9
Let's go to see what we have up to now.
1)Tracing the signal gnd network.
Probe between A,B points.
2)Measuring the same points A,B
Hello Idefixes.
Shaan - makes a lot of sense. I have just realized that all the rails decoupling is connected to the signal ground here - this is definitely a mistake.
Guys, only the input resistor and feedback resistor can be connected there for the ground lift to work properly. Also - in CFA designs, the feedback network is rather low-inpedance, so in CFA front-ends I either don't use the lifted ground, or use a rather low-ohm resistor (4.7...2.2 ohm).
