A very brave opinion - that is, all DAC, e.g. Mark Levinson etc., are badly made because they use toroids?
George explained it well enough, I have nothing much to add. Could be they were constrained by needing to place the trafo close to sensitive circuitry and therefore the toroid was the better choice, in conjunction with extra mains filtering.
Or it could be they used toroidals for marketing reasons.
Just got my hands on an wooden box I intend to reinforce for dac duty. I plan to use parts from a broken computer power supply for the inlet plug, on/off switch and wiring. Could the spdif selection switch be customized with a different kind of switch than what was provided? I’m thinking of something like a modi 3 here: https://www.schiit.com/products/modi-1 but I’m open to suggestions.
I just want to make sure I’ll have everything I need before I place my digikey order. Thanks for the input!
I'm sure a toggle like that would work fine. Mind - it needs to be a biassed toggle, one that returns to the 'default' position when left alone because its cycling round the available inputs. Did we provide a switch? - I don't remember that!
There's some kind of push button switch and what looks to be some kind of toggle switch with what I received.
Ah yes, I just checked another example of that board we have here. There are two push-button switches - one with a long extension and one without. You need a push-to-connect function and a biassed toggle will do that handsomely.
Thanks, I’ll post the digikey link before ordering if you don’t mind double checking 🙂Ah yes, I just checked another example of that board we have here. There are two push-button switches - one with a long extension and one without. You need a push-to-connect function and a biassed toggle will do that handsomely.
Do you have the pin out for this board? Not sure who the creator is.
I have an annotated photo that another customer sent me which I could forward you by email if you PM me your address.
Thank you for your patience for my barrage of questions as always.I have an annotated photo that another customer sent me which I could forward you by email if you PM me your address.
1) Is the reason the master clock is not required because your dac uses some kind of reclocker?
2) Would an i2s signal directly from a pi to the dac instead of through a spdif board sound better? Is your preference still toslink? The receiver board seems to add 50 picoseconds of jitter regardless of input.
3) If the above is a yes, I’ve located the pin out for my pi2aes hdmi over i2s implementation and am considering using one of these https://www.digikey.ca/en/products/detail/chip-quik-inc/CN0002/5978285 to feed the dac i2s. Do you think it would be a suitable solution?
Bought two of these screens for the spdif board 🙂 https://www.aliexpress.com/item/4001025304341.html?spm=a2g0s.9042311.0.0.4c524c4d364GwU so affordable 🙂
Sorry, it appears I cannot edit my previous post, but it appears I2S over HDMI would require a differential connection and neither the passthrough on the spdif board or the connection on the DAC would allow for that. I guess the only question would be if a raspberry pi board in the same enclosure with i2s connected directly would sound better than through the spdif receiver board with a pi connected via coax/toslink on the other end.Thank you for your patience for my barrage of questions as always.
No, the reason an MCLK isn't required is because there's no digital filter in my DAC. An MCLK in general is needed for enabling clocks to multipliers and adders and other logic. My DAC doesn't have any of that. (Some DACs that do have logic manage to get by with a PLL though in lieu of MCLK. An example is PCM5102)Thank you for your patience for my barrage of questions as always.
I'm not sure 50pS of jitter is a concern with this DAC. The major constraint to SQ is noise from the source and Toslink deals with that very well indeed. If you connect I2S directly you'll lose isolation and likely degrade the sound.
I think I2S over HDMI is an unnecessary complication. Some DACs which are more jitter-sensitive could benefit but I doubt a multibit DAC would. You're correct - I2S over HDMI uses LVDS which is a differential connection so needs interface boards to go back/forth to/from single-ended.
An RPi in the same enclosure as the DAC is probably a bad idea, just because an RPi is a strong EMI aggressor.
Thank you! I’m learning a lot from you! I placed my order at digikey this morning and should have my Akitika Amp done by tomorrow, so sweet music should be filling my house early next week 🙂No, the reason an MCLK isn't required is because there's no digital filter in my DAC. An MCLK in general is needed for enabling clocks to multipliers and adders and other logic. My DAC doesn't have any of that. (Some DACs that do have logic manage to get by with a PLL though in lieu of MCLK. An example is PCM5102)
Akitika amp is one using LM3886s on a fully regulated supply is it? That's one bargain kit, at least that's the impression I've formed.
That’s the one! I’m trying to build my dedicated stereo with some high value parts like your dac!
I look forward to hearing how Celibidache sounds played through Akitika. I was into classAB chipamps for quite a long while but nowadays I'm a confirmed classD maniac.
Amp is up and running, just need to assemble this DAC. Transformer arrived today!
I want to make a few modifications on the spdif board though and it will take a few weeks for the oled screen to arrive. I’m tempted to run it as is lol!
Question, should I be running shielded cable to the RCA plugs? I have some spare cable for that.
I don't bother with shielded cable myself as I keep DAC->RCA wires fairly short (under 15cm). If you go longer then maybe its a good idea.
The S/PDIF board works fine without the screen plugged in.
The transformer I bought from digikey is putting out around 29-30 VAC. Would that be fine for your PSU? I’m seeing around 24.3V DC off the PSU.
Sorry, one more question, do you know where I can buy the tabs that connect the ground to the RCA connectors? These RCA connectors don’t seems to have them.
You're getting 24.3V from the PSU output so it must be working fine. Be careful not to short circuit the output or you'll destroy the regulator, its not protected from shorting at such a high input voltage.
The RCAs we sent you have cube-shaped lugs, that's where we solder the ground wire. Needs a chunky soldering iron as there's quite some volume to heat. I don't know about tabs as they're mechanical things and beyond my limited electronic knowledge 😛
- Vendor's Bazaar
- Celibidache NOS DAC
