• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
CDROM control KITs VFD version
In this picture (attached) you show a cable. You say, "make a cable like this." Okay, but it looks like the cable is soldered. I'm asking, can't you use a connector on those pins?
I'm making a distinction between this cable
and
the separate PCB you show in the other picture.
and
Hi lestertrad
Yes,the cable is soldered.On the picture,
It's the one I made before.Now I get the separate PCB for Double 7PIN to Single 14PIN.The separate PCB is the connector~
Huang
Re: Does CD player need to be grounded ?
lestertrad said:
Wonderful.
Now I need to wait and see if kit works better.
Right now it is not working very well.
Does CD player need to be grounded ? I think that may be my problem.
Does anyone else have an answer?
TIA to all.
Hi
what is the new problem you get from the controller~?
Will reply you later,I have to go to sleep now~
sincerely
Huang
Problem with CD-ROM kit
Lots of times I have noise. Sometimes read problems. But when I touch the outside of the CD drive, problem goes away. No more noise.
CD drive is sitting on top of old cassette player. When I pick it up, it makes noise or stops playing. This is why I ask about possible ground (earth) problem.
When I have time I will try connecting a ground wire.
Hope you had a good sleep! ;-D
Re: Problem with CD-ROM kit
Hi lestertrad
This is the new problem I never got.Have you try another CD drive?And the problem still happen?
Sincerely
Huang
I have four CD drives:
- Goldstar CRD-8240B April 1998
- Acer 640-172 Feb. 1999
- Goldstar CED 8080B June 2000 (CD/RW)
- Plextor PX760A Feb. 2006 (CD/DVD/RW)
and it has happened with most of them.
When I have time I will do a better test and report to you.
Hi lestertrad
Very strange.Very sorry for the problem.I can send you one more mainboard to make sure if the problem on the mainboard.Waiting for your depth test~
Huang
PROBLEM SOLVED!
Slowgay, I must apologize. The problem was not with the kit at all - it was with my cable!
I made a new digital cable to go from the CD drive to the DAC and now everything is fine: No noise, and I can even pick up the CD drive while operating and it still works fine.
The problem was a bad connection in my cable. So, when I touched or moved the CD drive, noise was caused.
It was not a problem with the kit or with grounding!
Again I am very sorry!
Now playing with new cable and Plextor 760A drive and the sound is wonderful!
Thanks again for such a fine kit
Lester
Re: PROBLEM SOLVED!
Lester
Hi Lester
Never mind.Thank you for you telling this~.😀 I'm happy as you after I get this new from you.And now holp you have a good time to DIY~
Sincerely
Huang
