I have a very loud cd and I'm sure it's either overloading the output of the Tent XO3 on the transport or overloading the input of my da converter. Can any of you digital heads give any comment on this? (Jocko your the input output king)?
Cheers George
Cheers George
CDs data cannot exceed the range 0000 to FFFF.
Many newer CDs are heavily compressed and have many samples at the limit values.
Some DAC digital filters cannot cope with signals too close to full volume as they produce interpolated samples beyond the limits.
Some badly designed filters even go unstable when thet get internal overflows in the maths.
You could rip the cd to a PC and using software like goldwave or audacity reduce the volume by 3dB say and burn a CDR with the quieter version to try.
georgehifi said:I have a very loud cd and I'm sure it's either overloading the output of the Tent XO3 on the transport or overloading the input of my da converter. Can any of you digital heads give any comment on this? (Jocko your the input output king)?
Cheers George
The value of the sample in the digital domain has no bearing on the amplitude of its physical representation.
I cannot recall the month and year of publication, but Elektor had published a clipping circuit which indicated that many CDs produced exceeded the input limit of DACs.
Elso Kwak said:The digital filter from Sony; CXD1244 clips on the ringing of a 0dB square wave.......
Your ears would, too, if you listened to that sort of thing. Fortunately there aren't that many 0 dB square waves in music.
I_F
No - but many that hit 0000 and FFFF quite often.
I even know one that is regarded as audiophile by some demonstarators !! 😱
Charles
I_F
jean-paul said:
I am glad musicians do not create such sounds.
Come on, have you heard Brittney sing?
Samuel Jayaraj said:I cannot recall the month and year of publication, but Elektor had published a clipping circuit which indicated that many CDs produced exceeded the input limit of DACs.
I have never seen a DAC chip that cannot handle all posssible 16 bit data codes. If there is sucha thing it is seriously flawed.
There are some "audiophile" commercial CD players with outputs much higher than the red book standard 2V rms. Magazine reviewers always seem to fall for "louder is better"
A preamplifier with +5V powered cmos analogue switches is going to clip at these high levels. Some are high enough to overload switches running on +/- 5V
Britney can't sing
This was posted elsewhere..
http://www.mindspring.com/~mrichter/dynamics/dynamics.htm
davidsrsb said:CDs data cannot exceed the range 0000 to FFFF.
When we were setting up our first all-digital domain production suite a CD certain to have a high average level - something by Slipknot - caused panic when the board meters gave all indications of input overload. They locked at one value and didn't budge. The sound was awful, from an analogue mindset it gave every indication of clipping. Checked the analogue output of the digital console: yep, clipped waveform. The CD player fed the board AES-EBU, so furiously re-read the console manual. Nothing wrong. Checked the analogue output of the CD player: clipped waveforms. Second player, same thing. Eventually we came to realize the CD was mastered clipped. This wasn't a clipper/processor, this was straight-out back-to-back zener consistently shear the tops off dead flat. Welcome to the new artistic sensibilites.
Let me shed a bit more light on this, the cd that i'm talking about is the new Jackson Brown (The Naked Ride Home) it is by far the loudest cd in the 1000 odd that I have.
Now it seems that it only sounds distorted on my separate transport (Tent XO clocked) and separate D/A converter A3.24 Musical Fidelity. For some reason the same cd does not sound this distorted on stand alone players, this led me to belive that the sending/recieving components of separate transport/ da converters may have a limit to what they can handle compared to stand alone players.
Cheers George
Cheers George
The tx/rx section is digital. It's levels are fixed and cannot vary in response to the value of the transmitted data. You need to look to the I/V stage and beyond.
georgehifi said:Let me shed a bit more light on this, the cd that i'm talking about is the new Jackson Brown (The Naked Ride Home) it is by far the loudest cd in the 1000 odd that I have.
Cheers George
Has this got copy protection? This can cause excessive jitter which may make your DAC lose lock
It could also be transport read errors, try EAC on a PC and see if it complains about reading tyhe disk.
It's not one of those Sony copy protected cd's they sound ugly as well, this this a Warner/Elektra disc but it does have a strange imprint in the centre that I've never seen (D.A.T.A. IFPL 311) whatever that means.
How can 1 cd stand out as twice the output level as anything else I have. I'd understand if it were Deep Purple, or something like that, but Jackson Browne, give me a break.
Cheers George
Cheers George
You would be surprised of what modern industry is capable off. I wouldn’t blame the artists. Try importing some tracks from different cd's in a waveform viewer like Cooledit or Audition. Far too many are compressed and hard limited and make all the dynamics disappear. Look at post #7 here which is not at all an exception these days. It's a big shame.
/Hugo
/Hugo
An interesting thing is that this disc is the only one that will be read by a cd player that I have here that has a very very weak laser, it will not read the TOC never mind play any of the discs I have except for this very loud one. What do you guys make of that.
Cheers George
Cheers George
- Digital Source
- Can over loud cd's overload dacs ? (Jocko?)
