you can create a rule file for udev that will (re)start camilladsp when your soundcard is detected.
If you run without -w then CamillaDSP should exit if the soundcard disappears. Is that what happens?
Then udev is the way to start it again when the USB device reconnects. There is a guide here: GitHub - HEnquist/camilladsp-config: Help for setting up CamillaDSP, example config files etc
Cool - I was thinking I'd have to research how to do this, but I now realise it's the optional step 5 in the guide that @HenrikEnquist has just reminded me about. I remember dismissing that as not relevant before - ha!you can create a rule file for udev that will (re)start camilladsp when your soundcard is detected.
Thanks for the information. Am I right in thinking that step 5 is an alternative to having the service start automatically at boot? So the last part of step 4 should be omitted - or revoked?
I don't see -w in my current setup (see below) but CamillaDSP doesn't exit when I turn off the soundcard. Usually the last line in the log is "Pausing processing, module: camillalib::countertimer" which occurs one minute after the music stops. Am I missing something else?
Code:
ubuntu@ubuntu:/usr/local/etc/camilladsp/logs$ cat /etc/systemd/system/camilladsp.service
[Unit]
Description=CamillaDSP Daemon
After=syslog.target
StartLimitIntervalSec=10
StartLimitBurst=10
[Service]
Type=simple
ExecStart=/bin/bash -c '/usr/local/bin/camilladsp -a0.0.0.0 -p5000 -g-30 --logfile /usr/local/etc/camilladsp/logs/log$$(date +%%FT%%H%%M).txt -ldebug /usr/local/etc/camilladsp/config192XO.yml'
Restart=always
RestartSec=1
StandardOutput=syslog
StandardError=syslog
SyslogIdentifier=camilladsp
User=root
Group=root
CPUSchedulingPolicy=fifo
CPUSchedulingPriority=10
[Install]
WantedBy=graphical.target
No keep step 4, then you are sure that it starts both on boot and later when you plug in the dac.Thanks for the information. Am I right in thinking that step 5 is an alternative to having the service start automatically at boot? So the last part of step 4 should be omitted - or revoked?
Strange, can you post a hundred lines or so from the log just before that "Pausing processing" message?I don't see -w in my current setup (see below) but CamillaDSP doesn't exit when I turn off the soundcard. Usually the last line in the log is "Pausing processing, module: camillalib::countertimer" which occurs one minute after the music stops. Am I missing something else?
Here's the last 100 or so lines:
On boot with the soundcard switched off, the status of CamillaDSP is as follows:
The status after stopping the process look like this.
Presumably this behaviour is caused by wrapping the CamillaDSP process in the bash instruction, and that's why the automatic stop when the card is switched off doesn't work correctly with this arrangement.
Code:
Dec 04 14:29:38.816 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:29:48.839 DEBG Current buffer level: 8277.051063829787, corrected capture rate: 99.99778645833334%, module: camillalib::audiodevice
Dec 04 14:29:48.839 DEBG Playback buffer level: 8277.051063829787, signal rms: [-70.566605, -71.06026, -80.44419, -1000.0, -1000.0, -1000.0, -67.566605, -68.06026], module: camillalib::alsadevice
Dec 04 14:29:48.840 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:29:58.868 DEBG Current buffer level: 8270.527659574467, corrected capture rate: 99.99796875%, module: camillalib::audiodevice
Dec 04 14:29:58.868 DEBG Playback buffer level: 8270.527659574467, signal rms: [-69.63881, -70.03242, -65.47233, -1000.0, -1000.0, -1000.0, -66.63881, -67.03242], module: camillalib::alsadevice
Dec 04 14:29:58.868 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:30:08.892 DEBG Current buffer level: 8384.817021276596, corrected capture rate: 99.995%, module: camillalib::audiodevice
Dec 04 14:30:08.892 DEBG Playback buffer level: 8384.817021276596, signal rms: [-73.57623, -73.429596, -59.834476, -1000.0, -1000.0, -1000.0, -70.57623, -70.429596], module: camillalib::alsadevice
Dec 04 14:30:08.893 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:30:18.923 DEBG Current buffer level: 8226.208510638298, corrected capture rate: 99.99911458333334%, module: camillalib::audiodevice
Dec 04 14:30:18.923 DEBG Playback buffer level: 8226.208510638298, signal rms: [-72.255615, -72.36938, -55.446606, -1000.0, -1000.0, -1000.0, -69.255615, -69.36938], module: camillalib::alsadevice
Dec 04 14:30:18.924 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:30:28.947 DEBG Current buffer level: 8170.663829787234, corrected capture rate: 100.00057291666667%, module: camillalib::audiodevice
Dec 04 14:30:28.948 DEBG Playback buffer level: 8170.663829787234, signal rms: [-74.179146, -74.223015, -51.42643, -1000.0, -1000.0, -1000.0, -71.17915, -71.223015], module: camillalib::alsadevice
Dec 04 14:30:28.948 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:30:38.974 DEBG Current buffer level: 8144.36170212766, corrected capture rate: 100.00125%, module: camillalib::audiodevice
Dec 04 14:30:38.975 DEBG Playback buffer level: 8144.36170212766, signal rms: [-68.51964, -69.95149, -75.785385, -1000.0, -1000.0, -1000.0, -65.51964, -66.95149], module: camillalib::alsadevice
Dec 04 14:30:38.975 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:30:49.004 DEBG Current buffer level: 8112.28085106383, corrected capture rate: 100.00208333333333%, module: camillalib::audiodevice
Dec 04 14:30:49.005 DEBG Playback buffer level: 8112.28085106383, signal rms: [-67.1199, -66.799034, -53.290672, -1000.0, -1000.0, -1000.0, -64.1199, -63.799034], module: camillalib::alsadevice
Dec 04 14:30:49.005 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:30:59.028 DEBG Current buffer level: 8383.68085106383, corrected capture rate: 99.99502604166666%, module: camillalib::audiodevice
Dec 04 14:30:59.029 DEBG Playback buffer level: 8383.68085106383, signal rms: [-63.494972, -64.01632, -56.67466, -1000.0, -1000.0, -1000.0, -60.494972, -61.01632], module: camillalib::alsadevice
Dec 04 14:30:59.029 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:31:09.055 DEBG Current buffer level: 8380.6, corrected capture rate: 99.99510416666666%, module: camillalib::audiodevice
Dec 04 14:31:09.055 DEBG Playback buffer level: 8380.6, signal rms: [-65.44601, -65.00579, -69.60248, -1000.0, -1000.0, -1000.0, -62.446007, -62.005787], module: camillalib::alsadevice
Dec 04 14:31:09.055 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:31:19.083 DEBG Current buffer level: 8256.531914893618, corrected capture rate: 99.99833333333333%, module: camillalib::audiodevice
Dec 04 14:31:19.084 DEBG Playback buffer level: 8256.531914893618, signal rms: [-65.193985, -67.24884, -80.84584, -1000.0, -1000.0, -1000.0, -62.19399, -64.24884], module: camillalib::alsadevice
Dec 04 14:31:19.084 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:31:29.108 DEBG Current buffer level: 8289.548936170213, corrected capture rate: 99.99747395833334%, module: camillalib::audiodevice
Dec 04 14:31:29.108 DEBG Playback buffer level: 8289.548936170213, signal rms: [-71.472015, -73.32894, -62.04386, -1000.0, -1000.0, -1000.0, -68.472015, -70.32894], module: camillalib::alsadevice
Dec 04 14:31:29.109 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:31:39.134 DEBG Current buffer level: 8323.808510638299, corrected capture rate: 99.99658854166667%, module: camillalib::audiodevice
Dec 04 14:31:39.135 DEBG Playback buffer level: 8323.808510638299, signal rms: [-68.97286, -70.2642, -59.807327, -1000.0, -1000.0, -1000.0, -65.97287, -67.26419], module: camillalib::alsadevice
Dec 04 14:31:39.135 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:31:49.163 DEBG Current buffer level: 8339.131914893616, corrected capture rate: 99.996171875%, module: camillalib::audiodevice
Dec 04 14:31:49.163 DEBG Playback buffer level: 8339.131914893616, signal rms: [-69.543045, -69.314545, -55.428116, -1000.0, -1000.0, -1000.0, -66.543045, -66.314545], module: camillalib::alsadevice
Dec 04 14:31:49.164 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:31:59.191 DEBG Current buffer level: 8262.863829787235, corrected capture rate: 99.99817708333333%, module: camillalib::audiodevice
Dec 04 14:31:59.191 DEBG Playback buffer level: 8262.863829787235, signal rms: [-67.57445, -67.09417, -55.40222, -1000.0, -1000.0, -1000.0, -64.57445, -64.09417], module: camillalib::alsadevice
Dec 04 14:31:59.192 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:32:09.216 DEBG Current buffer level: 8093.008510638298, corrected capture rate: 100.002578125%, module: camillalib::audiodevice
Dec 04 14:32:09.216 DEBG Playback buffer level: 8093.008510638298, signal rms: [-69.4351, -68.844025, -53.3089, -1000.0, -1000.0, -1000.0, -66.4351, -65.844025], module: camillalib::alsadevice
Dec 04 14:32:09.217 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:32:19.243 DEBG Current buffer level: 8212.31914893617, corrected capture rate: 99.99947916666667%, module: camillalib::audiodevice
Dec 04 14:32:19.243 DEBG Playback buffer level: 8212.31914893617, signal rms: [-91.59779, -91.592415, -96.41742, -1000.0, -1000.0, -1000.0, -88.59779, -88.592415], module: camillalib::alsadevice
Dec 04 14:32:19.244 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:32:29.267 DEBG Current buffer level: 8418.178723404255, corrected capture rate: 99.99411458333334%, module: camillalib::audiodevice
Dec 04 14:32:29.267 DEBG Playback buffer level: 8418.178723404255, signal rms: [-76.72301, -74.11307, -79.08968, -1000.0, -1000.0, -1000.0, -73.72301, -71.11307], module: camillalib::alsadevice
Dec 04 14:32:29.268 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:32:39.295 DEBG Current buffer level: 8183.374468085106, corrected capture rate: 100.000234375%, module: camillalib::audiodevice
Dec 04 14:32:39.295 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:32:39.296 DEBG Playback buffer level: 8183.374468085106, signal rms: [-74.045006, -73.28632, -88.89401, -1000.0, -1000.0, -1000.0, -71.045006, -70.28632], module: camillalib::alsadevice
Dec 04 14:32:49.323 DEBG Current buffer level: 8198.744680851063, corrected capture rate: 99.99984375%, module: camillalib::audiodevice
Dec 04 14:32:49.324 DEBG Playback buffer level: 8198.744680851063, signal rms: [-64.42517, -67.1523, -73.56127, -1000.0, -1000.0, -1000.0, -61.425167, -64.1523], module: camillalib::alsadevice
Dec 04 14:32:49.324 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:32:59.351 DEBG Current buffer level: 8181.365957446808, corrected capture rate: 100.00028645833335%, module: camillalib::audiodevice
Dec 04 14:32:59.351 DEBG Playback buffer level: 8181.365957446808, signal rms: [-61.36722, -60.88153, -51.19739, -1000.0, -1000.0, -1000.0, -58.367218, -57.881527], module: camillalib::alsadevice
Dec 04 14:32:59.352 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:33:09.376 DEBG Current buffer level: 8176.11914893617, corrected capture rate: 100.00041666666665%, module: camillalib::audiodevice
Dec 04 14:33:09.377 DEBG Playback buffer level: 8176.11914893617, signal rms: [-68.161224, -71.92634, -55.709793, -1000.0, -1000.0, -1000.0, -65.161224, -68.92634], module: camillalib::alsadevice
Dec 04 14:33:09.377 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:33:19.403 DEBG Current buffer level: 8219.306382978724, corrected capture rate: 99.999296875%, module: camillalib::audiodevice
Dec 04 14:33:19.403 DEBG Playback buffer level: 8219.306382978724, signal rms: [-67.621414, -68.066734, -57.99472, -1000.0, -1000.0, -1000.0, -64.621414, -65.066734], module: camillalib::alsadevice
Dec 04 14:33:19.404 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:33:29.431 DEBG Current buffer level: 8266.012765957446, corrected capture rate: 99.99807291666667%, module: camillalib::audiodevice
Dec 04 14:33:29.432 DEBG Playback buffer level: 8266.012765957446, signal rms: [-68.78098, -67.6311, -53.654095, -1000.0, -1000.0, -1000.0, -65.78099, -64.6311], module: camillalib::alsadevice
Dec 04 14:33:29.432 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:33:39.452 DEBG Current buffer level: 8250.017021276595, corrected capture rate: 99.99848958333334%, module: camillalib::audiodevice
Dec 04 14:33:39.452 DEBG Playback buffer level: 8250.017021276595, signal rms: [-75.032585, -73.64041, -61.186462, -1000.0, -1000.0, -1000.0, -72.032585, -70.64041], module: camillalib::alsadevice
Dec 04 14:33:39.452 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:33:49.484 DEBG Current buffer level: 8209.417021276597, corrected capture rate: 99.99955729166666%, module: camillalib::audiodevice
Dec 04 14:33:49.485 DEBG Playback buffer level: 8209.417021276597, signal rms: [-93.933266, -93.48645, -97.74402, -1000.0, -1000.0, -1000.0, -90.933266, -90.48645], module: camillalib::alsadevice
Dec 04 14:33:49.485 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:33:59.510 DEBG Current buffer level: 8269.978723404256, corrected capture rate: 99.99799479166667%, module: camillalib::audiodevice
Dec 04 14:33:59.510 DEBG Playback buffer level: 8269.978723404256, signal rms: [-1989.4194, -1991.273, -1960.1956, -1000.0, -1000.0, -1000.0, -1986.4194, -1988.2728], module: camillalib::alsadevice
Dec 04 14:33:59.511 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:34:09.535 DEBG Current buffer level: 8327.32340425532, corrected capture rate: 99.99648437500001%, module: camillalib::audiodevice
Dec 04 14:34:09.535 DEBG Playback buffer level: 8327.32340425532, signal rms: [-73.371185, -76.32583, -75.240486, -1000.0, -1000.0, -1000.0, -70.371185, -73.32583], module: camillalib::alsadevice
Dec 04 14:34:09.536 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:34:19.563 DEBG Current buffer level: 8336.455319148936, corrected capture rate: 99.99625%, module: camillalib::audiodevice
Dec 04 14:34:19.564 DEBG Playback buffer level: 8336.455319148936, signal rms: [-81.0273, -83.39734, -83.77921, -1000.0, -1000.0, -1000.0, -78.0273, -80.39735], module: camillalib::alsadevice
Dec 04 14:34:19.564 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:34:29.591 DEBG Current buffer level: 8362.76170212766, corrected capture rate: 99.99557291666666%, module: camillalib::audiodevice
Dec 04 14:34:29.591 DEBG Playback buffer level: 8362.76170212766, signal rms: [-71.85576, -74.069565, -83.56175, -1000.0, -1000.0, -1000.0, -68.85575, -71.069565], module: camillalib::alsadevice
Dec 04 14:34:29.592 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:34:39.617 DEBG Current buffer level: 8262.212765957447, corrected capture rate: 99.99817708333333%, module: camillalib::audiodevice
Dec 04 14:34:39.618 DEBG Playback buffer level: 8262.212765957447, signal rms: [-68.67537, -70.33035, -66.52031, -1000.0, -1000.0, -1000.0, -65.67537, -67.33035], module: camillalib::alsadevice
Dec 04 14:34:39.618 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:34:49.643 DEBG Current buffer level: 8199.544680851064, corrected capture rate: 99.99981770833334%, module: camillalib::audiodevice
Dec 04 14:34:49.643 DEBG Playback buffer level: 8199.544680851064, signal rms: [-67.475075, -67.44287, -59.103546, -1000.0, -1000.0, -1000.0, -64.475075, -64.44288], module: camillalib::alsadevice
Dec 04 14:34:49.644 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:34:59.671 DEBG Current buffer level: 8202.27659574468, corrected capture rate: 99.99973958333334%, module: camillalib::audiodevice
Dec 04 14:34:59.671 DEBG Playback buffer level: 8202.27659574468, signal rms: [-67.23694, -67.34168, -53.81806, -1000.0, -1000.0, -1000.0, -64.23694, -64.34168], module: camillalib::alsadevice
Dec 04 14:34:59.671 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:35:09.699 DEBG Current buffer level: 8160.75744680851, corrected capture rate: 100.00083333333333%, module: camillalib::audiodevice
Dec 04 14:35:09.699 DEBG Playback buffer level: 8160.75744680851, signal rms: [-71.56711, -72.175186, -75.06999, -1000.0, -1000.0, -1000.0, -68.56711, -69.17518], module: camillalib::alsadevice
Dec 04 14:35:09.700 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:35:19.724 DEBG Current buffer level: 8203.055319148936, corrected capture rate: 99.99971354166667%, module: camillalib::audiodevice
Dec 04 14:35:19.724 DEBG Playback buffer level: 8203.055319148936, signal rms: [-70.76895, -69.07775, -62.652588, -1000.0, -1000.0, -1000.0, -67.76895, -66.07775], module: camillalib::alsadevice
Dec 04 14:35:19.725 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:35:29.752 DEBG Current buffer level: 8212.370212765958, corrected capture rate: 99.99947916666667%, module: camillalib::audiodevice
Dec 04 14:35:29.753 DEBG Playback buffer level: 8212.370212765958, signal rms: [-69.56294, -68.917786, -60.843018, -1000.0, -1000.0, -1000.0, -66.56295, -65.917786], module: camillalib::alsadevice
Dec 04 14:35:29.753 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:35:39.779 DEBG Current buffer level: 8277.025531914893, corrected capture rate: 99.99778645833334%, module: camillalib::audiodevice
Dec 04 14:35:39.779 DEBG Playback buffer level: 8277.025531914893, signal rms: [-73.454865, -74.210594, -75.93198, -1000.0, -1000.0, -1000.0, -70.45486, -71.210594], module: camillalib::alsadevice
Dec 04 14:35:39.780 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:35:49.803 DEBG Current buffer level: 8243.629787234042, corrected capture rate: 99.998671875%, module: camillalib::audiodevice
Dec 04 14:35:49.804 DEBG Playback buffer level: 8243.629787234042, signal rms: [-70.53823, -70.650116, -72.95693, -1000.0, -1000.0, -1000.0, -67.53823, -67.65012], module: camillalib::alsadevice
Dec 04 14:35:49.804 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:35:59.831 DEBG Current buffer level: 8282.629787234042, corrected capture rate: 99.99765625%, module: camillalib::audiodevice
Dec 04 14:35:59.831 DEBG Playback buffer level: 8282.629787234042, signal rms: [-70.87947, -70.98134, -69.35214, -1000.0, -1000.0, -1000.0, -67.87947, -67.981346], module: camillalib::alsadevice
Dec 04 14:35:59.831 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:36:09.859 DEBG Current buffer level: 8303.178723404255, corrected capture rate: 99.99710937500001%, module: camillalib::audiodevice
Dec 04 14:36:09.859 DEBG Playback buffer level: 8303.178723404255, signal rms: [-69.3032, -69.89308, -57.291634, -1000.0, -1000.0, -1000.0, -66.3032, -66.893074], module: camillalib::alsadevice
Dec 04 14:36:09.860 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:36:19.883 DEBG Current buffer level: 8304.6, corrected capture rate: 99.99708333333334%, module: camillalib::audiodevice
Dec 04 14:36:19.884 DEBG Playback buffer level: 8304.6, signal rms: [-65.31761, -65.73705, -65.64932, -1000.0, -1000.0, -1000.0, -62.317616, -62.73705], module: camillalib::alsadevice
Dec 04 14:36:19.884 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:36:29.911 DEBG Current buffer level: 8328.842553191489, corrected capture rate: 99.99645833333334%, module: camillalib::audiodevice
Dec 04 14:36:29.911 DEBG Playback buffer level: 8328.842553191489, signal rms: [-67.10399, -68.079765, -67.55052, -1000.0, -1000.0, -1000.0, -64.104, -65.079765], module: camillalib::alsadevice
Dec 04 14:36:29.912 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:36:39.938 DEBG Current buffer level: 8304.531914893618, corrected capture rate: 99.99708333333334%, module: camillalib::audiodevice
Dec 04 14:36:39.939 DEBG Playback buffer level: 8304.531914893618, signal rms: [-69.435, -70.02112, -56.647335, -1000.0, -1000.0, -1000.0, -66.435, -67.02112], module: camillalib::alsadevice
Dec 04 14:36:39.939 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:36:49.967 DEBG Current buffer level: 8118.485106382978, corrected capture rate: 100.00192708333333%, module: camillalib::audiodevice
Dec 04 14:36:49.967 DEBG Playback buffer level: 8118.485106382978, signal rms: [-67.18216, -66.67953, -70.87157, -1000.0, -1000.0, -1000.0, -64.18216, -63.679527], module: camillalib::alsadevice
Dec 04 14:36:49.967 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:36:59.991 DEBG Current buffer level: 8147.936170212766, corrected capture rate: 100.001171875%, module: camillalib::audiodevice
Dec 04 14:36:59.991 DEBG Playback buffer level: 8147.936170212766, signal rms: [-66.918434, -67.83676, -62.12577, -1000.0, -1000.0, -1000.0, -63.918438, -64.83676], module: camillalib::alsadevice
Dec 04 14:36:59.992 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:37:10.019 DEBG Current buffer level: 8431.672340425532, corrected capture rate: 99.99377604166668%, module: camillalib::audiodevice
Dec 04 14:37:10.019 DEBG Playback buffer level: 8431.672340425532, signal rms: [-68.90728, -69.53847, -62.801598, -1000.0, -1000.0, -1000.0, -65.90728, -66.53846], module: camillalib::alsadevice
Dec 04 14:37:10.019 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:37:20.047 DEBG Current buffer level: 8319.92340425532, corrected capture rate: 99.99669270833334%, module: camillalib::audiodevice
Dec 04 14:37:20.047 DEBG Playback buffer level: 8319.92340425532, signal rms: [-63.80102, -66.11208, -68.286896, -1000.0, -1000.0, -1000.0, -60.801018, -63.112083], module: camillalib::alsadevice
Dec 04 14:37:20.047 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:37:30.067 DEBG Current buffer level: 8219.974468085107, corrected capture rate: 99.999296875%, module: camillalib::audiodevice
Dec 04 14:37:30.067 DEBG Playback buffer level: 8219.974468085107, signal rms: [-68.94049, -69.36469, -61.269974, -1000.0, -1000.0, -1000.0, -65.94049, -66.36469], module: camillalib::alsadevice
Dec 04 14:37:30.067 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:37:40.099 DEBG Current buffer level: 8268.56170212766, corrected capture rate: 99.99802083333333%, module: camillalib::audiodevice
Dec 04 14:37:40.099 DEBG Playback buffer level: 8268.56170212766, signal rms: [-60.99232, -62.002544, -60.178566, -1000.0, -1000.0, -1000.0, -57.99232, -59.00254], module: camillalib::alsadevice
Dec 04 14:37:40.100 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:37:50.128 DEBG Current buffer level: 8284.080851063829, corrected capture rate: 99.99760416666666%, module: camillalib::audiodevice
Dec 04 14:37:50.128 DEBG Playback buffer level: 8284.080851063829, signal rms: [-64.57363, -64.29564, -61.9141, -1000.0, -1000.0, -1000.0, -61.573635, -61.29564], module: camillalib::alsadevice
Dec 04 14:37:50.128 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:38:00.151 DEBG Current buffer level: 8320.868085106384, corrected capture rate: 99.99666666666667%, module: camillalib::audiodevice
Dec 04 14:38:00.152 DEBG Playback buffer level: 8320.868085106384, signal rms: [-64.147095, -66.135414, -61.47777, -1000.0, -1000.0, -1000.0, -61.147095, -63.135414], module: camillalib::alsadevice
Dec 04 14:38:00.152 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:38:10.178 DEBG Current buffer level: 8368.123404255319, corrected capture rate: 99.99541666666667%, module: camillalib::audiodevice
Dec 04 14:38:10.179 DEBG Playback buffer level: 8368.123404255319, signal rms: [-70.84712, -72.1228, -59.83445, -1000.0, -1000.0, -1000.0, -67.84712, -69.1228], module: camillalib::alsadevice
Dec 04 14:38:10.179 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:38:20.207 DEBG Current buffer level: 8073.11914893617, corrected capture rate: 100.00309895833333%, module: camillalib::audiodevice
Dec 04 14:38:20.208 DEBG Playback buffer level: 8073.11914893617, signal rms: [-71.686676, -71.224556, -60.07631, -1000.0, -1000.0, -1000.0, -68.68667, -68.224556], module: camillalib::alsadevice
Dec 04 14:38:20.208 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:38:30.235 DEBG Current buffer level: 8097.731914893617, corrected capture rate: 100.00247395833333%, module: camillalib::audiodevice
Dec 04 14:38:30.235 DEBG Playback buffer level: 8097.731914893617, signal rms: [-123.05232, -116.06475, -95.14322, -1000.0, -1000.0, -1000.0, -120.05232, -113.06476], module: camillalib::alsadevice
Dec 04 14:38:30.236 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:38:40.259 DEBG Current buffer level: 8373.174468085106, corrected capture rate: 99.99528645833334%, module: camillalib::audiodevice
Dec 04 14:38:40.259 DEBG Playback buffer level: 8373.174468085106, signal rms: [-72.55752, -70.343956, -52.614193, -1000.0, -1000.0, -1000.0, -69.55752, -67.343956], module: camillalib::alsadevice
Dec 04 14:38:40.259 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:38:50.287 DEBG Current buffer level: 8324.217021276596, corrected capture rate: 99.9965625%, module: camillalib::audiodevice
Dec 04 14:38:50.287 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:38:50.287 DEBG Playback buffer level: 8324.217021276596, signal rms: [-69.77758, -68.42096, -59.022903, -1000.0, -1000.0, -1000.0, -66.77758, -65.42096], module: camillalib::alsadevice
Dec 04 14:39:00.315 DEBG Current buffer level: 8122.621276595744, corrected capture rate: 100.00182291666665%, module: camillalib::audiodevice
Dec 04 14:39:00.316 DEBG Playback buffer level: 8122.621276595744, signal rms: [-66.714264, -68.0518, -57.819324, -1000.0, -1000.0, -1000.0, -63.714264, -65.0518], module: camillalib::alsadevice
Dec 04 14:39:00.316 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:39:10.339 DEBG Current buffer level: 8158.195744680851, corrected capture rate: 100.00088541666668%, module: camillalib::audiodevice
Dec 04 14:39:10.339 DEBG Playback buffer level: 8158.195744680851, signal rms: [-68.36601, -67.50307, -56.30753, -1000.0, -1000.0, -1000.0, -65.36601, -64.50307], module: camillalib::alsadevice
Dec 04 14:39:10.340 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:39:20.366 DEBG Current buffer level: 8278.889361702128, corrected capture rate: 99.99776041666667%, module: camillalib::audiodevice
Dec 04 14:39:20.367 DEBG Playback buffer level: 8278.889361702128, signal rms: [-67.992905, -65.31749, -63.804756, -1000.0, -1000.0, -1000.0, -64.9929, -62.31749], module: camillalib::alsadevice
Dec 04 14:39:20.367 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:39:30.395 DEBG Current buffer level: 8283.51914893617, corrected capture rate: 99.99763020833333%, module: camillalib::audiodevice
Dec 04 14:39:30.395 DEBG Playback buffer level: 8283.51914893617, signal rms: [-68.59489, -68.08551, -55.187225, -1000.0, -1000.0, -1000.0, -65.59488, -65.08551], module: camillalib::alsadevice
Dec 04 14:39:30.396 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:39:40.419 DEBG Current buffer level: 8252.11914893617, corrected capture rate: 99.99843750000001%, module: camillalib::audiodevice
Dec 04 14:39:40.420 DEBG Playback buffer level: 8252.11914893617, signal rms: [-66.59489, -67.32049, -54.18987, -1000.0, -1000.0, -1000.0, -63.594887, -64.32048], module: camillalib::alsadevice
Dec 04 14:39:40.420 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:39:50.447 DEBG Current buffer level: 8308.51489361702, corrected capture rate: 99.99697916666666%, module: camillalib::audiodevice
Dec 04 14:39:50.447 DEBG Playback buffer level: 8308.51489361702, signal rms: [-72.46712, -72.11795, -52.91863, -1000.0, -1000.0, -1000.0, -69.46712, -69.11795], module: camillalib::alsadevice
Dec 04 14:39:50.448 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:40:00.475 DEBG Current buffer level: 8258.693617021276, corrected capture rate: 99.99828125%, module: camillalib::audiodevice
Dec 04 14:40:00.475 DEBG Playback buffer level: 8258.693617021276, signal rms: [-69.00733, -71.94205, -61.909412, -1000.0, -1000.0, -1000.0, -66.00733, -68.94205], module: camillalib::alsadevice
Dec 04 14:40:00.475 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:40:10.500 DEBG Current buffer level: 8268.212765957447, corrected capture rate: 99.99802083333333%, module: camillalib::audiodevice
Dec 04 14:40:10.501 DEBG Playback buffer level: 8268.212765957447, signal rms: [-66.35637, -68.53048, -63.424458, -1000.0, -1000.0, -1000.0, -63.35637, -65.53048], module: camillalib::alsadevice
Dec 04 14:40:10.501 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:40:20.527 DEBG Current buffer level: 8302.953191489361, corrected capture rate: 99.99713541666667%, module: camillalib::audiodevice
Dec 04 14:40:20.527 DEBG Playback buffer level: 8302.953191489361, signal rms: [-64.84224, -63.84846, -56.99095, -1000.0, -1000.0, -1000.0, -61.84224, -60.848465], module: camillalib::alsadevice
Dec 04 14:40:20.528 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:40:30.554 DEBG Current buffer level: 8334.43829787234, corrected capture rate: 99.99630208333333%, module: camillalib::audiodevice
Dec 04 14:40:30.555 DEBG Playback buffer level: 8334.43829787234, signal rms: [-73.21127, -72.63782, -65.37657, -1000.0, -1000.0, -1000.0, -70.211266, -69.63782], module: camillalib::alsadevice
Dec 04 14:40:30.555 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:40:40.584 DEBG Current buffer level: 8127.808510638298, corrected capture rate: 100.00169270833332%, module: camillalib::audiodevice
Dec 04 14:40:40.585 DEBG Playback buffer level: 8127.808510638298, signal rms: [-74.54616, -73.97162, -67.57892, -1000.0, -1000.0, -1000.0, -71.54616, -70.97162], module: camillalib::alsadevice
Dec 04 14:40:40.585 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:40:50.608 DEBG Current buffer level: 8161.672340425532, corrected capture rate: 100.00080729166667%, module: camillalib::audiodevice
Dec 04 14:40:50.608 DEBG Playback buffer level: 8161.672340425532, signal rms: [-68.56751, -68.944016, -64.39758, -1000.0, -1000.0, -1000.0, -65.56752, -65.944016], module: camillalib::alsadevice
Dec 04 14:40:50.609 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:41:00.634 DEBG Current buffer level: 8336.404255319148, corrected capture rate: 99.99625%, module: camillalib::audiodevice
Dec 04 14:41:00.635 DEBG Playback buffer level: 8336.404255319148, signal rms: [-65.66636, -65.98721, -56.40834, -1000.0, -1000.0, -1000.0, -62.66636, -62.98721], module: camillalib::alsadevice
Dec 04 14:41:00.635 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:41:10.663 DEBG Current buffer level: 8219.625531914893, corrected capture rate: 99.999296875%, module: camillalib::audiodevice
Dec 04 14:41:10.663 DEBG Playback buffer level: 8219.625531914893, signal rms: [-64.47585, -65.45045, -54.73986, -1000.0, -1000.0, -1000.0, -61.47585, -62.45045], module: camillalib::alsadevice
Dec 04 14:41:10.663 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:41:20.687 DEBG Current buffer level: 8220.67659574468, corrected capture rate: 99.99927083333333%, module: camillalib::audiodevice
Dec 04 14:41:20.688 DEBG Playback buffer level: 8220.67659574468, signal rms: [-65.626785, -64.30825, -56.345936, -1000.0, -1000.0, -1000.0, -62.626785, -61.308247], module: camillalib::alsadevice
Dec 04 14:41:20.688 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:41:30.715 DEBG Current buffer level: 8261.987234042554, corrected capture rate: 99.99820312499999%, module: camillalib::audiodevice
Dec 04 14:41:30.715 DEBG Playback buffer level: 8261.987234042554, signal rms: [-69.41967, -68.99968, -55.824814, -1000.0, -1000.0, -1000.0, -66.41967, -65.99968], module: camillalib::alsadevice
Dec 04 14:41:30.716 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:41:40.744 DEBG Current buffer level: 8319.774468085106, corrected capture rate: 99.99669270833334%, module: camillalib::audiodevice
Dec 04 14:41:40.744 DEBG Playback buffer level: 8319.774468085106, signal rms: [-77.35436, -75.27365, -59.751686, -1000.0, -1000.0, -1000.0, -74.35436, -72.27365], module: camillalib::alsadevice
Dec 04 14:41:40.744 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:41:50.768 DEBG Current buffer level: 8355.208510638298, corrected capture rate: 99.99575520833334%, module: camillalib::audiodevice
Dec 04 14:41:50.768 DEBG Playback buffer level: 8355.208510638298, signal rms: [-63.955017, -64.52352, -50.813637, -1000.0, -1000.0, -1000.0, -60.955013, -61.52352], module: camillalib::alsadevice
Dec 04 14:41:50.769 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:42:00.795 DEBG Current buffer level: 8364.136170212765, corrected capture rate: 99.99552083333333%, module: camillalib::audiodevice
Dec 04 14:42:00.796 DEBG Playback buffer level: 8364.136170212765, signal rms: [-73.705124, -71.83798, -61.99724, -1000.0, -1000.0, -1000.0, -70.705124, -68.837975], module: camillalib::alsadevice
Dec 04 14:42:00.796 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:42:10.823 DEBG Current buffer level: 8251.710638297873, corrected capture rate: 99.99846354166667%, module: camillalib::audiodevice
Dec 04 14:42:10.823 DEBG Playback buffer level: 8251.710638297873, signal rms: [-69.792595, -70.26129, -56.973667, -1000.0, -1000.0, -1000.0, -66.792595, -67.26129], module: camillalib::alsadevice
Dec 04 14:42:10.824 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:42:20.851 DEBG Current buffer level: 8133.736170212766, corrected capture rate: 100.00153645833333%, module: camillalib::audiodevice
Dec 04 14:42:20.851 DEBG Playback buffer level: 8133.736170212766, signal rms: [-68.68067, -70.33804, -67.40034, -1000.0, -1000.0, -1000.0, -65.68067, -67.33804], module: camillalib::alsadevice
Dec 04 14:42:20.851 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:42:30.876 DEBG Current buffer level: 8169.876595744681, corrected capture rate: 100.00059895833333%, module: camillalib::audiodevice
Dec 04 14:42:30.876 DEBG Playback buffer level: 8169.876595744681, signal rms: [-63.49661, -61.40217, -64.66607, -1000.0, -1000.0, -1000.0, -60.496613, -58.40217], module: camillalib::alsadevice
Dec 04 14:42:30.876 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:42:40.903 DEBG Current buffer level: 8362.578723404255, corrected capture rate: 99.99557291666666%, module: camillalib::audiodevice
Dec 04 14:42:40.903 DEBG Playback buffer level: 8362.578723404255, signal rms: [-69.16121, -69.428604, -73.23663, -1000.0, -1000.0, -1000.0, -66.16121, -66.428604], module: camillalib::alsadevice
Dec 04 14:42:40.904 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:42:50.931 DEBG Current buffer level: 8250.55744680851, corrected capture rate: 99.99848958333334%, module: camillalib::audiodevice
Dec 04 14:42:50.931 DEBG Playback buffer level: 8250.55744680851, signal rms: [-67.28163, -68.300125, -70.3721, -1000.0, -1000.0, -1000.0, -64.28163, -65.30013], module: camillalib::alsadevice
Dec 04 14:42:50.931 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:43:00.954 DEBG Current buffer level: 8184.948936170213, corrected capture rate: 100.00020833333335%, module: camillalib::audiodevice
Dec 04 14:43:00.955 DEBG Playback buffer level: 8184.948936170213, signal rms: [-70.41643, -70.59189, -81.6256, -1000.0, -1000.0, -1000.0, -67.41643, -67.59189], module: camillalib::alsadevice
Dec 04 14:43:00.955 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:43:10.982 DEBG Current buffer level: 8214.595744680852, corrected capture rate: 99.99942708333333%, module: camillalib::audiodevice
Dec 04 14:43:10.983 DEBG Playback buffer level: 8214.595744680852, signal rms: [-78.95559, -78.30536, -96.47418, -1000.0, -1000.0, -1000.0, -75.95559, -75.30536], module: camillalib::alsadevice
Dec 04 14:43:10.983 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:43:21.011 DEBG Current buffer level: 8268.36170212766, corrected capture rate: 99.99802083333333%, module: camillalib::audiodevice
Dec 04 14:43:21.011 DEBG Playback buffer level: 8268.36170212766, signal rms: [-67.63721, -66.50582, -58.64057, -1000.0, -1000.0, -1000.0, -64.63721, -63.505825], module: camillalib::alsadevice
Dec 04 14:43:21.011 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:43:31.035 DEBG Current buffer level: 8265.178723404255, corrected capture rate: 99.99809895833334%, module: camillalib::audiodevice
Dec 04 14:43:31.035 DEBG Playback buffer level: 8265.178723404255, signal rms: [-70.29337, -65.45338, -58.663784, -1000.0, -1000.0, -1000.0, -67.29338, -62.453377], module: camillalib::alsadevice
Dec 04 14:43:31.035 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:43:41.063 DEBG Current buffer level: 8260.527659574467, corrected capture rate: 99.99822916666666%, module: camillalib::audiodevice
Dec 04 14:43:41.063 DEBG Playback buffer level: 8260.527659574467, signal rms: [-66.018845, -65.88882, -63.565872, -1000.0, -1000.0, -1000.0, -63.018845, -62.888813], module: camillalib::alsadevice
Dec 04 14:43:41.063 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:43:51.093 DEBG Current buffer level: 8301.468085106382, corrected capture rate: 99.99716145833332%, module: camillalib::audiodevice
Dec 04 14:43:51.093 DEBG Playback buffer level: 8301.468085106382, signal rms: [-67.58729, -68.378456, -62.193634, -1000.0, -1000.0, -1000.0, -64.58729, -65.37845], module: camillalib::alsadevice
Dec 04 14:43:51.094 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:44:01.111 DEBG Current buffer level: 8267.651063829788, corrected capture rate: 99.998046875%, module: camillalib::audiodevice
Dec 04 14:44:01.111 DEBG Playback buffer level: 8267.651063829788, signal rms: [-69.58911, -69.364395, -57.894737, -1000.0, -1000.0, -1000.0, -66.58911, -66.364395], module: camillalib::alsadevice
Dec 04 14:44:01.111 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:44:11.144 DEBG Current buffer level: 8343.885106382979, corrected capture rate: 99.99606770833334%, module: camillalib::audiodevice
Dec 04 14:44:11.145 DEBG Playback buffer level: 8343.885106382979, signal rms: [-68.307526, -66.71867, -57.877293, -1000.0, -1000.0, -1000.0, -65.307526, -63.718674], module: camillalib::alsadevice
Dec 04 14:44:11.145 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:44:21.172 DEBG Current buffer level: 8395.285106382978, corrected capture rate: 99.99471354166667%, module: camillalib::audiodevice
Dec 04 14:44:21.172 DEBG Playback buffer level: 8395.285106382978, signal rms: [-64.398964, -64.157135, -65.90968, -1000.0, -1000.0, -1000.0, -61.39896, -61.15713], module: camillalib::alsadevice
Dec 04 14:44:21.172 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:44:31.199 DEBG Current buffer level: 8234.263829787234, corrected capture rate: 99.99890624999999%, module: camillalib::audiodevice
Dec 04 14:44:31.199 DEBG Playback buffer level: 8234.263829787234, signal rms: [-66.04635, -66.17721, -52.032185, -1000.0, -1000.0, -1000.0, -63.046345, -63.177216], module: camillalib::alsadevice
Dec 04 14:44:31.200 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:44:41.225 DEBG Current buffer level: 8100.697872340425, corrected capture rate: 100.00239583333332%, module: camillalib::audiodevice
Dec 04 14:44:41.225 DEBG Playback buffer level: 8100.697872340425, signal rms: [-62.13221, -60.87051, -63.138176, -1000.0, -1000.0, -1000.0, -59.13221, -57.870514], module: camillalib::alsadevice
Dec 04 14:44:41.225 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:44:51.251 DEBG Current buffer level: 8100.272340425532, corrected capture rate: 100.00239583333332%, module: camillalib::audiodevice
Dec 04 14:44:51.251 DEBG Playback buffer level: 8100.272340425532, signal rms: [-63.306637, -64.58448, -61.548695, -1000.0, -1000.0, -1000.0, -60.306633, -61.58448], module: camillalib::alsadevice
Dec 04 14:44:51.252 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:45:01.276 DEBG Current buffer level: 8235.8, corrected capture rate: 99.99888020833333%, module: camillalib::audiodevice
Dec 04 14:45:01.277 DEBG Playback buffer level: 8235.8, signal rms: [-61.01306, -60.874405, -75.407295, -1000.0, -1000.0, -1000.0, -58.01306, -57.87441], module: camillalib::alsadevice
Dec 04 14:45:01.277 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:45:11.303 DEBG Current buffer level: 8415.038297872341, corrected capture rate: 99.99419270833333%, module: camillalib::audiodevice
Dec 04 14:45:11.303 DEBG Playback buffer level: 8415.038297872341, signal rms: [-63.827568, -66.675705, -56.23008, -1000.0, -1000.0, -1000.0, -60.827568, -63.675697], module: camillalib::alsadevice
Dec 04 14:45:11.303 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:45:21.331 DEBG Current buffer level: 8201.068085106383, corrected capture rate: 99.99976562500001%, module: camillalib::audiodevice
Dec 04 14:45:21.331 DEBG Playback buffer level: 8201.068085106383, signal rms: [-62.978226, -62.65574, -51.086525, -1000.0, -1000.0, -1000.0, -59.97822, -59.65574], module: camillalib::alsadevice
Dec 04 14:45:21.332 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:45:31.355 DEBG Current buffer level: 8201.165957446809, corrected capture rate: 99.99976562500001%, module: camillalib::audiodevice
Dec 04 14:45:31.356 DEBG Playback buffer level: 8201.165957446809, signal rms: [-64.85862, -66.1677, -64.89213, -1000.0, -1000.0, -1000.0, -61.85862, -63.1677], module: camillalib::alsadevice
Dec 04 14:45:31.356 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:45:41.384 DEBG Current buffer level: 8219.35744680851, corrected capture rate: 99.999296875%, module: camillalib::audiodevice
Dec 04 14:45:41.385 DEBG Playback buffer level: 8219.35744680851, signal rms: [-59.693695, -59.58633, -54.891335, -1000.0, -1000.0, -1000.0, -56.69369, -56.586327], module: camillalib::alsadevice
Dec 04 14:45:41.385 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:45:51.411 DEBG Current buffer level: 8335.429787234043, corrected capture rate: 99.99627604166666%, module: camillalib::audiodevice
Dec 04 14:45:51.412 DEBG Playback buffer level: 8335.429787234043, signal rms: [-64.93267, -65.105736, -70.62797, -1000.0, -1000.0, -1000.0, -61.932674, -62.105736], module: camillalib::alsadevice
Dec 04 14:45:51.412 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:46:01.439 DEBG Current buffer level: 8321.48510638298, corrected capture rate: 99.996640625%, module: camillalib::audiodevice
Dec 04 14:46:01.439 DEBG Playback buffer level: 8321.48510638298, signal rms: [-62.784, -62.546993, -59.486794, -1000.0, -1000.0, -1000.0, -59.783997, -59.546997], module: camillalib::alsadevice
Dec 04 14:46:01.439 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:46:11.459 DEBG Current buffer level: 8372.83829787234, corrected capture rate: 99.9953125%, module: camillalib::audiodevice
Dec 04 14:46:11.459 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:46:11.459 DEBG Playback buffer level: 8372.83829787234, signal rms: [-65.78854, -66.06599, -65.821144, -1000.0, -1000.0, -1000.0, -62.788548, -63.065983], module: camillalib::alsadevice
Dec 04 14:46:21.490 DEBG Current buffer level: 8312.651063829788, corrected capture rate: 99.996875%, module: camillalib::audiodevice
Dec 04 14:46:21.491 DEBG Playback buffer level: 8312.651063829788, signal rms: [-68.11782, -68.28967, -80.71623, -1000.0, -1000.0, -1000.0, -65.11782, -65.28968], module: camillalib::alsadevice
Dec 04 14:46:21.491 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:46:31.519 DEBG Current buffer level: 8164.04255319149, corrected capture rate: 100.00072916666667%, module: camillalib::audiodevice
Dec 04 14:46:31.519 DEBG Playback buffer level: 8164.04255319149, signal rms: [-65.14868, -64.66618, -62.340515, -1000.0, -1000.0, -1000.0, -62.14868, -61.666183], module: camillalib::alsadevice
Dec 04 14:46:31.520 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:46:41.547 DEBG Current buffer level: 8206.170212765957, corrected capture rate: 99.99963541666666%, module: camillalib::audiodevice
Dec 04 14:46:41.547 DEBG Playback buffer level: 8206.170212765957, signal rms: [-66.7839, -70.45352, -66.63296, -1000.0, -1000.0, -1000.0, -63.783894, -67.45352], module: camillalib::alsadevice
Dec 04 14:46:41.548 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:46:51.570 DEBG Current buffer level: 8189.387234042553, corrected capture rate: 100.000078125%, module: camillalib::audiodevice
Dec 04 14:46:51.571 DEBG Playback buffer level: 8189.387234042553, signal rms: [-69.613045, -68.46236, -65.41346, -1000.0, -1000.0, -1000.0, -66.61304, -65.46236], module: camillalib::alsadevice
Dec 04 14:46:51.571 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:47:01.599 DEBG Current buffer level: 8274.123404255319, corrected capture rate: 99.99786458333332%, module: camillalib::audiodevice
Dec 04 14:47:01.599 DEBG Playback buffer level: 8274.123404255319, signal rms: [-64.76434, -66.00571, -66.310486, -1000.0, -1000.0, -1000.0, -61.764343, -63.00571], module: camillalib::alsadevice
Dec 04 14:47:01.600 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:47:11.624 DEBG Current buffer level: 8208.353191489361, corrected capture rate: 99.99958333333333%, module: camillalib::audiodevice
Dec 04 14:47:11.625 DEBG Playback buffer level: 8208.353191489361, signal rms: [-68.85224, -68.486336, -68.38405, -1000.0, -1000.0, -1000.0, -65.85225, -65.48634], module: camillalib::alsadevice
Dec 04 14:47:11.625 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:47:21.651 DEBG Current buffer level: 8291.421276595745, corrected capture rate: 99.997421875%, module: camillalib::audiodevice
Dec 04 14:47:21.652 DEBG Playback buffer level: 8291.421276595745, signal rms: [-68.67381, -69.75847, -66.20528, -1000.0, -1000.0, -1000.0, -65.67381, -66.75847], module: camillalib::alsadevice
Dec 04 14:47:21.652 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:47:31.680 DEBG Current buffer level: 8264.191489361701, corrected capture rate: 99.998125%, module: camillalib::audiodevice
Dec 04 14:47:31.680 DEBG Playback buffer level: 8264.191489361701, signal rms: [-67.391785, -66.84048, -57.35716, -1000.0, -1000.0, -1000.0, -64.39178, -63.840477], module: camillalib::alsadevice
Dec 04 14:47:31.681 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:47:41.703 DEBG Current buffer level: 8243.255319148937, corrected capture rate: 99.998671875%, module: camillalib::audiodevice
Dec 04 14:47:41.704 DEBG Playback buffer level: 8243.255319148937, signal rms: [-86.01424, -85.49195, -80.251884, -1000.0, -1000.0, -1000.0, -83.01423, -82.49195], module: camillalib::alsadevice
Dec 04 14:47:41.704 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:47:51.732 DEBG Current buffer level: 8249.893617021276, corrected capture rate: 99.998515625%, module: camillalib::audiodevice
Dec 04 14:47:51.733 DEBG Playback buffer level: 8249.893617021276, signal rms: [-120.14565, -118.3118, -104.20802, -1000.0, -1000.0, -1000.0, -117.14565, -115.3118], module: camillalib::alsadevice
Dec 04 14:47:51.733 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:48:01.760 DEBG Current buffer level: 8341.131914893616, corrected capture rate: 99.99611979166667%, module: camillalib::audiodevice
Dec 04 14:48:01.760 DEBG Playback buffer level: 8341.131914893616, signal rms: [-68.407234, -68.815605, -77.41012, -1000.0, -1000.0, -1000.0, -65.407234, -65.81561], module: camillalib::alsadevice
Dec 04 14:48:01.760 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:48:11.788 DEBG Current buffer level: 8334.434042553192, corrected capture rate: 99.99630208333333%, module: camillalib::audiodevice
Dec 04 14:48:11.789 DEBG Playback buffer level: 8334.434042553192, signal rms: [-70.87297, -72.437065, -90.93868, -1000.0, -1000.0, -1000.0, -67.87297, -69.43706], module: camillalib::alsadevice
Dec 04 14:48:11.789 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:48:21.816 DEBG Current buffer level: 8151.927659574468, corrected capture rate: 100.00106770833332%, module: camillalib::audiodevice
Dec 04 14:48:21.816 DEBG Playback buffer level: 8151.927659574468, signal rms: [-83.35845, -79.765656, -73.21603, -1000.0, -1000.0, -1000.0, -80.358444, -76.765656], module: camillalib::alsadevice
Dec 04 14:48:21.817 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:48:31.840 DEBG Current buffer level: 8114.812765957447, corrected capture rate: 100.00203125%, module: camillalib::audiodevice
Dec 04 14:48:31.841 DEBG Playback buffer level: 8114.812765957447, signal rms: [-67.02067, -68.23366, -72.57679, -1000.0, -1000.0, -1000.0, -64.020676, -65.23366], module: camillalib::alsadevice
Dec 04 14:48:31.841 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:48:41.865 DEBG Current buffer level: 8428.936170212766, corrected capture rate: 99.99385416666667%, module: camillalib::audiodevice
Dec 04 14:48:41.865 DEBG Playback buffer level: 8428.936170212766, signal rms: [-67.309296, -65.46807, -65.99465, -1000.0, -1000.0, -1000.0, -64.3093, -62.46807], module: camillalib::alsadevice
Dec 04 14:48:41.866 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:48:51.895 DEBG Current buffer level: 8329.165957446809, corrected capture rate: 99.99643229166666%, module: camillalib::audiodevice
Dec 04 14:48:51.895 DEBG Playback buffer level: 8329.165957446809, signal rms: [-69.64743, -68.91684, -61.057735, -1000.0, -1000.0, -1000.0, -66.64743, -65.91684], module: camillalib::alsadevice
Dec 04 14:48:51.895 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:49:01.919 DEBG Current buffer level: 8216.95744680851, corrected capture rate: 99.999375%, module: camillalib::audiodevice
Dec 04 14:49:01.919 DEBG Playback buffer level: 8216.95744680851, signal rms: [-65.38009, -63.132027, -68.54425, -1000.0, -1000.0, -1000.0, -62.38009, -60.13203], module: camillalib::alsadevice
Dec 04 14:49:01.919 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:49:11.947 DEBG Current buffer level: 8149.548936170213, corrected capture rate: 100.00111979166665%, module: camillalib::audiodevice
Dec 04 14:49:11.947 DEBG Playback buffer level: 8149.548936170213, signal rms: [-67.76765, -65.829185, -69.19419, -1000.0, -1000.0, -1000.0, -64.76765, -62.829185], module: camillalib::alsadevice
Dec 04 14:49:11.948 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:49:21.973 DEBG Current buffer level: 8171.859574468085, corrected capture rate: 100.000546875%, module: camillalib::audiodevice
Dec 04 14:49:21.973 DEBG Playback buffer level: 8171.859574468085, signal rms: [-67.12135, -66.47638, -73.24929, -1000.0, -1000.0, -1000.0, -64.12135, -63.476376], module: camillalib::alsadevice
Dec 04 14:49:21.973 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:49:31.999 DEBG Current buffer level: 8196.774468085106, corrected capture rate: 99.99989583333333%, module: camillalib::audiodevice
Dec 04 14:49:31.999 DEBG Playback buffer level: 8196.774468085106, signal rms: [-70.80509, -70.56824, -62.52912, -1000.0, -1000.0, -1000.0, -67.80509, -67.56824], module: camillalib::alsadevice
Dec 04 14:49:31.999 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:49:42.027 DEBG Current buffer level: 8281.27659574468, corrected capture rate: 99.99768229166666%, module: camillalib::audiodevice
Dec 04 14:49:42.027 DEBG Playback buffer level: 8281.27659574468, signal rms: [-67.51148, -66.41805, -76.838715, -1000.0, -1000.0, -1000.0, -64.51148, -63.41805], module: camillalib::alsadevice
Dec 04 14:49:42.028 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:49:52.056 DEBG Current buffer level: 8313.170212765957, corrected capture rate: 99.99684895833333%, module: camillalib::audiodevice
Dec 04 14:49:52.056 DEBG Playback buffer level: 8313.170212765957, signal rms: [-62.85238, -62.090508, -53.000034, -1000.0, -1000.0, -1000.0, -59.85238, -59.090504], module: camillalib::alsadevice
Dec 04 14:49:52.057 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:50:02.079 DEBG Current buffer level: 8360.565957446808, corrected capture rate: 99.995625%, module: camillalib::audiodevice
Dec 04 14:50:02.079 DEBG Playback buffer level: 8360.565957446808, signal rms: [-69.94112, -70.996254, -65.71856, -1000.0, -1000.0, -1000.0, -66.94112, -67.99625], module: camillalib::alsadevice
Dec 04 14:50:02.080 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:50:12.107 DEBG Current buffer level: 8428.404255319148, corrected capture rate: 99.99385416666667%, module: camillalib::audiodevice
Dec 04 14:50:12.107 DEBG Playback buffer level: 8428.404255319148, signal rms: [-63.84651, -62.90243, -68.88421, -1000.0, -1000.0, -1000.0, -60.846516, -59.902428], module: camillalib::alsadevice
Dec 04 14:50:12.107 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:50:22.134 DEBG Current buffer level: 8151.034042553191, corrected capture rate: 100.00106770833332%, module: camillalib::audiodevice
Dec 04 14:50:22.135 DEBG Playback buffer level: 8151.034042553191, signal rms: [-66.70762, -65.23522, -59.33256, -1000.0, -1000.0, -1000.0, -63.70762, -62.23522], module: camillalib::alsadevice
Dec 04 14:50:22.135 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:50:32.164 DEBG Current buffer level: 8188.770212765958, corrected capture rate: 100.00010416666667%, module: camillalib::audiodevice
Dec 04 14:50:32.164 DEBG Playback buffer level: 8188.770212765958, signal rms: [-70.11563, -66.15868, -74.700226, -1000.0, -1000.0, -1000.0, -67.11564, -63.158684], module: camillalib::alsadevice
Dec 04 14:50:32.165 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:50:42.188 DEBG Current buffer level: 8184.68085106383, corrected capture rate: 100.00020833333335%, module: camillalib::audiodevice
Dec 04 14:50:42.188 DEBG Playback buffer level: 8184.68085106383, signal rms: [-66.63819, -66.23444, -65.16105, -1000.0, -1000.0, -1000.0, -63.63819, -63.23444], module: camillalib::alsadevice
Dec 04 14:50:42.189 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:50:52.215 DEBG Current buffer level: 8212.51489361702, corrected capture rate: 99.99947916666667%, module: camillalib::audiodevice
Dec 04 14:50:52.215 DEBG Playback buffer level: 8212.51489361702, signal rms: [-70.07058, -70.25832, -71.873215, -1000.0, -1000.0, -1000.0, -67.07059, -67.25833], module: camillalib::alsadevice
Dec 04 14:50:52.216 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:51:02.243 DEBG Current buffer level: 8180.527659574468, corrected capture rate: 100.0003125%, module: camillalib::audiodevice
Dec 04 14:51:02.244 DEBG Playback buffer level: 8180.527659574468, signal rms: [-71.73755, -73.79493, -86.12564, -1000.0, -1000.0, -1000.0, -68.73755, -70.79494], module: camillalib::alsadevice
Dec 04 14:51:02.244 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:51:12.266 DEBG Current buffer level: 8257.548936170213, corrected capture rate: 99.99830729166666%, module: camillalib::audiodevice
Dec 04 14:51:12.267 DEBG Playback buffer level: 8257.548936170213, signal rms: [-67.397194, -67.33574, -68.011536, -1000.0, -1000.0, -1000.0, -64.397194, -64.33574], module: camillalib::alsadevice
Dec 04 14:51:12.267 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:51:22.295 DEBG Current buffer level: 8340.6, corrected capture rate: 99.99614583333334%, module: camillalib::audiodevice
Dec 04 14:51:22.295 DEBG Playback buffer level: 8340.6, signal rms: [-69.14687, -68.938866, -66.43768, -1000.0, -1000.0, -1000.0, -66.146866, -65.938866], module: camillalib::alsadevice
Dec 04 14:51:22.296 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:51:32.323 DEBG Current buffer level: 8238.595744680852, corrected capture rate: 99.99880208333335%, module: camillalib::audiodevice
Dec 04 14:51:32.324 DEBG Playback buffer level: 8238.595744680852, signal rms: [-68.551254, -67.83761, -61.480957, -1000.0, -1000.0, -1000.0, -65.551254, -64.83761], module: camillalib::alsadevice
Dec 04 14:51:32.324 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:51:42.348 DEBG Current buffer level: 8283.451063829787, corrected capture rate: 99.99763020833333%, module: camillalib::audiodevice
Dec 04 14:51:42.349 DEBG Playback buffer level: 8283.451063829787, signal rms: [-67.84288, -68.07564, -65.941574, -1000.0, -1000.0, -1000.0, -64.84288, -65.07564], module: camillalib::alsadevice
Dec 04 14:51:42.349 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:51:52.375 DEBG Current buffer level: 8301.574468085106, corrected capture rate: 99.99716145833332%, module: camillalib::audiodevice
Dec 04 14:51:52.375 DEBG Playback buffer level: 8301.574468085106, signal rms: [-64.43745, -63.82914, -58.90393, -1000.0, -1000.0, -1000.0, -61.43745, -60.82914], module: camillalib::alsadevice
Dec 04 14:51:52.376 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:52:02.403 DEBG Current buffer level: 8367.029787234043, corrected capture rate: 99.99544270833334%, module: camillalib::audiodevice
Dec 04 14:52:02.403 DEBG Playback buffer level: 8367.029787234043, signal rms: [-61.073715, -61.215706, -71.18987, -1000.0, -1000.0, -1000.0, -58.07371, -58.215706], module: camillalib::alsadevice
Dec 04 14:52:02.403 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:52:12.424 DEBG Current buffer level: 8311.165957446809, corrected capture rate: 99.99690104166666%, module: camillalib::audiodevice
Dec 04 14:52:12.424 DEBG Playback buffer level: 8311.165957446809, signal rms: [-63.208344, -63.206123, -57.29301, -1000.0, -1000.0, -1000.0, -60.20834, -60.206127], module: camillalib::alsadevice
Dec 04 14:52:12.424 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:52:22.455 DEBG Current buffer level: 8096.931914893617, corrected capture rate: 100.0025%, module: camillalib::audiodevice
Dec 04 14:52:22.456 DEBG Playback buffer level: 8096.931914893617, signal rms: [-66.827255, -66.973114, -69.52148, -1000.0, -1000.0, -1000.0, -63.827255, -63.973114], module: camillalib::alsadevice
Dec 04 14:52:22.456 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:52:32.483 DEBG Current buffer level: 8169.561702127659, corrected capture rate: 100.00059895833333%, module: camillalib::audiodevice
Dec 04 14:52:32.483 DEBG Playback buffer level: 8169.561702127659, signal rms: [-64.14728, -63.992035, -60.490204, -1000.0, -1000.0, -1000.0, -61.147285, -60.99203], module: camillalib::alsadevice
Dec 04 14:52:32.484 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:52:42.504 DEBG Current buffer level: 8436.753191489363, corrected capture rate: 99.99364583333333%, module: camillalib::audiodevice
Dec 04 14:52:42.504 DEBG Playback buffer level: 8436.753191489363, signal rms: [-68.83314, -67.00061, -68.85121, -1000.0, -1000.0, -1000.0, -65.83314, -64.00061], module: camillalib::alsadevice
Dec 04 14:52:42.504 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:52:52.534 DEBG Current buffer level: 8291.217021276596, corrected capture rate: 99.997421875%, module: camillalib::audiodevice
Dec 04 14:52:52.535 DEBG Playback buffer level: 8291.217021276596, signal rms: [-69.227745, -69.26087, -64.40759, -1000.0, -1000.0, -1000.0, -66.227745, -66.26088], module: camillalib::alsadevice
Dec 04 14:52:52.535 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:53:02.563 DEBG Current buffer level: 8246.829787234043, corrected capture rate: 99.99859375%, module: camillalib::audiodevice
Dec 04 14:53:02.563 DEBG Playback buffer level: 8246.829787234043, signal rms: [-103.63318, -102.39366, -101.92369, -1000.0, -1000.0, -1000.0, -100.63317, -99.39368], module: camillalib::alsadevice
Dec 04 14:53:02.564 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:53:12.588 DEBG Current buffer level: 8211.157446808511, corrected capture rate: 99.99950520833333%, module: camillalib::audiodevice
Dec 04 14:53:12.588 DEBG Playback buffer level: 8211.157446808511, signal rms: [-69.22264, -69.78861, -64.128975, -1000.0, -1000.0, -1000.0, -66.22264, -66.78861], module: camillalib::alsadevice
Dec 04 14:53:12.588 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:53:22.615 DEBG Current buffer level: 8239.92340425532, corrected capture rate: 99.99877604166667%, module: camillalib::audiodevice
Dec 04 14:53:22.615 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:53:22.616 DEBG Playback buffer level: 8239.92340425532, signal rms: [-65.69182, -63.547447, -61.75496, -1000.0, -1000.0, -1000.0, -62.69181, -60.547447], module: camillalib::alsadevice
Dec 04 14:53:32.643 DEBG Current buffer level: 8278.685106382978, corrected capture rate: 99.99776041666667%, module: camillalib::audiodevice
Dec 04 14:53:32.643 DEBG Playback buffer level: 8278.685106382978, signal rms: [-60.719994, -59.66929, -56.49589, -1000.0, -1000.0, -1000.0, -57.719997, -56.66929], module: camillalib::alsadevice
Dec 04 14:53:32.643 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:53:42.667 DEBG Current buffer level: 8315.434042553192, corrected capture rate: 99.996796875%, module: camillalib::audiodevice
Dec 04 14:53:42.668 DEBG Playback buffer level: 8315.434042553192, signal rms: [-69.88923, -68.05959, -60.322002, -1000.0, -1000.0, -1000.0, -66.88922, -65.05959], module: camillalib::alsadevice
Dec 04 14:53:42.668 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:53:52.694 DEBG Current buffer level: 8282.43829787234, corrected capture rate: 99.99765625%, module: camillalib::audiodevice
Dec 04 14:53:52.695 DEBG Playback buffer level: 8282.43829787234, signal rms: [-70.78024, -72.15575, -64.69379, -1000.0, -1000.0, -1000.0, -67.780235, -69.15574], module: camillalib::alsadevice
Dec 04 14:53:52.695 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:54:02.723 DEBG Current buffer level: 8071.795744680851, corrected capture rate: 100.00315104166665%, module: camillalib::audiodevice
Dec 04 14:54:02.723 DEBG Playback buffer level: 8071.795744680851, signal rms: [-66.75579, -65.32231, -66.390144, -1000.0, -1000.0, -1000.0, -63.75579, -62.32231], module: camillalib::alsadevice
Dec 04 14:54:02.724 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:54:12.751 DEBG Current buffer level: 8217.591489361703, corrected capture rate: 99.99934895833333%, module: camillalib::audiodevice
Dec 04 14:54:12.751 DEBG Playback buffer level: 8217.591489361703, signal rms: [-68.351456, -67.800186, -62.90561, -1000.0, -1000.0, -1000.0, -65.351456, -64.800186], module: camillalib::alsadevice
Dec 04 14:54:12.751 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:54:22.775 DEBG Current buffer level: 8361.774468085106, corrected capture rate: 99.99559895833333%, module: camillalib::audiodevice
Dec 04 14:54:22.776 DEBG Playback buffer level: 8361.774468085106, signal rms: [-63.842644, -63.60296, -54.318146, -1000.0, -1000.0, -1000.0, -60.842648, -60.60296], module: camillalib::alsadevice
Dec 04 14:54:22.776 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:54:32.802 DEBG Current buffer level: 8260.08510638298, corrected capture rate: 99.99822916666666%, module: camillalib::audiodevice
Dec 04 14:54:32.803 DEBG Playback buffer level: 8260.08510638298, signal rms: [-71.42981, -69.5571, -64.74768, -1000.0, -1000.0, -1000.0, -68.4298, -66.5571], module: camillalib::alsadevice
Dec 04 14:54:32.803 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:54:42.831 DEBG Current buffer level: 8143.36170212766, corrected capture rate: 100.00127604166667%, module: camillalib::audiodevice
Dec 04 14:54:42.832 DEBG Playback buffer level: 8143.36170212766, signal rms: [-68.106575, -73.205795, -62.327797, -1000.0, -1000.0, -1000.0, -65.106575, -70.205795], module: camillalib::alsadevice
Dec 04 14:54:42.832 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:54:52.859 DEBG Current buffer level: 8124.863829787234, corrected capture rate: 100.00177083333332%, module: camillalib::audiodevice
Dec 04 14:54:52.859 DEBG Playback buffer level: 8124.863829787234, signal rms: [-71.73232, -72.77217, -61.2681, -1000.0, -1000.0, -1000.0, -68.73232, -69.77217], module: camillalib::alsadevice
Dec 04 14:54:52.860 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:55:02.884 DEBG Current buffer level: 8292.07659574468, corrected capture rate: 99.99739583333334%, module: camillalib::audiodevice
Dec 04 14:55:02.885 DEBG Playback buffer level: 8292.07659574468, signal rms: [-70.39947, -71.11191, -65.857574, -1000.0, -1000.0, -1000.0, -67.39946, -68.11191], module: camillalib::alsadevice
Dec 04 14:55:02.885 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:55:12.906 DEBG Current buffer level: 8359.714893617022, corrected capture rate: 99.99565104166666%, module: camillalib::audiodevice
Dec 04 14:55:12.907 DEBG Playback buffer level: 8359.714893617022, signal rms: [-66.84572, -64.86999, -61.71934, -1000.0, -1000.0, -1000.0, -63.84572, -61.869984], module: camillalib::alsadevice
Dec 04 14:55:12.907 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:55:22.940 DEBG Current buffer level: 8156.663829787234, corrected capture rate: 100.0009375%, module: camillalib::audiodevice
Dec 04 14:55:22.941 DEBG Playback buffer level: 8156.663829787234, signal rms: [-70.02354, -72.01503, -67.98324, -1000.0, -1000.0, -1000.0, -67.02354, -69.01503], module: camillalib::alsadevice
Dec 04 14:55:22.941 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:55:32.964 DEBG Current buffer level: 8219.340425531915, corrected capture rate: 99.999296875%, module: camillalib::audiodevice
Dec 04 14:55:32.965 DEBG Playback buffer level: 8219.340425531915, signal rms: [-72.77935, -72.68434, -69.491356, -1000.0, -1000.0, -1000.0, -69.77935, -69.68434], module: camillalib::alsadevice
Dec 04 14:55:32.965 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:55:42.991 DEBG Current buffer level: 8221.029787234043, corrected capture rate: 99.99924479166667%, module: camillalib::audiodevice
Dec 04 14:55:42.992 DEBG Playback buffer level: 8221.029787234043, signal rms: [-73.32417, -71.32426, -64.78678, -1000.0, -1000.0, -1000.0, -70.32417, -68.32426], module: camillalib::alsadevice
Dec 04 14:55:42.992 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:55:53.020 DEBG Current buffer level: 8301.234042553191, corrected capture rate: 99.99716145833332%, module: camillalib::audiodevice
Dec 04 14:55:53.021 DEBG Playback buffer level: 8301.234042553191, signal rms: [-71.064026, -69.63281, -59.510994, -1000.0, -1000.0, -1000.0, -68.064026, -66.63281], module: camillalib::alsadevice
Dec 04 14:55:53.021 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:56:03.042 DEBG Current buffer level: 8277.83829787234, corrected capture rate: 99.99778645833334%, module: camillalib::audiodevice
Dec 04 14:56:03.043 DEBG Playback buffer level: 8277.83829787234, signal rms: [-69.21541, -69.851, -62.839706, -1000.0, -1000.0, -1000.0, -66.215416, -66.851], module: camillalib::alsadevice
Dec 04 14:56:03.043 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:56:13.071 DEBG Current buffer level: 8353.910638297872, corrected capture rate: 99.99580729166667%, module: camillalib::audiodevice
Dec 04 14:56:13.071 DEBG Playback buffer level: 8353.910638297872, signal rms: [-73.83225, -75.58598, -66.72389, -1000.0, -1000.0, -1000.0, -70.83225, -72.58598], module: camillalib::alsadevice
Dec 04 14:56:13.071 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:56:23.099 DEBG Current buffer level: 8308.208510638298, corrected capture rate: 99.99697916666666%, module: camillalib::audiodevice
Dec 04 14:56:23.099 DEBG Playback buffer level: 8308.208510638298, signal rms: [-66.48811, -67.84623, -63.93474, -1000.0, -1000.0, -1000.0, -63.488117, -64.84622], module: camillalib::alsadevice
Dec 04 14:56:23.099 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:56:33.127 DEBG Current buffer level: 8259.936170212766, corrected capture rate: 99.99825520833333%, module: camillalib::audiodevice
Dec 04 14:56:33.128 DEBG Playback buffer level: 8259.936170212766, signal rms: [-64.0777, -69.57277, -68.435905, -1000.0, -1000.0, -1000.0, -61.077698, -66.57277], module: camillalib::alsadevice
Dec 04 14:56:33.128 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:56:43.148 DEBG Current buffer level: 8116.948936170213, corrected capture rate: 100.00197916666667%, module: camillalib::audiodevice
Dec 04 14:56:43.149 DEBG Playback buffer level: 8116.948936170213, signal rms: [-71.39987, -67.49869, -66.39906, -1000.0, -1000.0, -1000.0, -68.39987, -64.49869], module: camillalib::alsadevice
Dec 04 14:56:43.149 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:56:53.179 DEBG Current buffer level: 8141.5787234042555, corrected capture rate: 100.001328125%, module: camillalib::audiodevice
Dec 04 14:56:53.180 DEBG Playback buffer level: 8141.5787234042555, signal rms: [-67.44529, -69.531624, -58.49803, -1000.0, -1000.0, -1000.0, -64.4453, -66.53163], module: camillalib::alsadevice
Dec 04 14:56:53.180 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:57:03.204 DEBG Current buffer level: 8359.787234042553, corrected capture rate: 99.99565104166666%, module: camillalib::audiodevice
Dec 04 14:57:03.204 DEBG Playback buffer level: 8359.787234042553, signal rms: [-121.33526, -121.98455, -103.14101, -1000.0, -1000.0, -1000.0, -118.33526, -118.98454], module: camillalib::alsadevice
Dec 04 14:57:03.204 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:57:13.228 DEBG Current buffer level: 8260.093617021277, corrected capture rate: 99.99822916666666%, module: camillalib::audiodevice
Dec 04 14:57:13.228 DEBG Playback buffer level: 8260.093617021277, signal rms: [-76.87911, -75.23025, -64.80041, -1000.0, -1000.0, -1000.0, -73.87911, -72.23024], module: camillalib::alsadevice
Dec 04 14:57:13.228 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:57:23.258 DEBG Current buffer level: 8243.2, corrected capture rate: 99.998671875%, module: camillalib::audiodevice
Dec 04 14:57:23.259 DEBG Playback buffer level: 8243.2, signal rms: [-62.79995, -62.07196, -61.39153, -1000.0, -1000.0, -1000.0, -59.79995, -59.07196], module: camillalib::alsadevice
Dec 04 14:57:23.259 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:57:33.287 DEBG Current buffer level: 8221.72340425532, corrected capture rate: 99.99924479166667%, module: camillalib::audiodevice
Dec 04 14:57:33.287 DEBG Playback buffer level: 8221.72340425532, signal rms: [-65.96721, -66.61749, -59.044262, -1000.0, -1000.0, -1000.0, -62.967205, -63.617496], module: camillalib::alsadevice
Dec 04 14:57:33.287 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:57:43.311 DEBG Current buffer level: 8296.621276595744, corrected capture rate: 99.99729166666667%, module: camillalib::audiodevice
Dec 04 14:57:43.312 DEBG Playback buffer level: 8296.621276595744, signal rms: [-67.57928, -68.24572, -62.904037, -1000.0, -1000.0, -1000.0, -64.579285, -65.24573], module: camillalib::alsadevice
Dec 04 14:57:43.312 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:57:53.338 DEBG Current buffer level: 8284.978723404256, corrected capture rate: 99.99760416666666%, module: camillalib::audiodevice
Dec 04 14:57:53.339 DEBG Playback buffer level: 8284.978723404256, signal rms: [-69.028275, -68.96417, -59.56327, -1000.0, -1000.0, -1000.0, -66.028275, -65.96418], module: camillalib::alsadevice
Dec 04 14:57:53.339 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:58:03.367 DEBG Current buffer level: 8236.982978723405, corrected capture rate: 99.99885416666666%, module: camillalib::audiodevice
Dec 04 14:58:03.367 DEBG Playback buffer level: 8236.982978723405, signal rms: [-60.28767, -59.76925, -64.701706, -1000.0, -1000.0, -1000.0, -57.28767, -56.769253], module: camillalib::alsadevice
Dec 04 14:58:03.367 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:58:13.386 DEBG Current buffer level: 8282.463829787233, corrected capture rate: 99.99765625%, module: camillalib::audiodevice
Dec 04 14:58:13.387 DEBG Playback buffer level: 8282.463829787233, signal rms: [-67.23349, -66.30292, -72.125275, -1000.0, -1000.0, -1000.0, -64.23349, -63.302917], module: camillalib::alsadevice
Dec 04 14:58:13.387 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:58:23.419 DEBG Current buffer level: 8359.446808510638, corrected capture rate: 99.99565104166666%, module: camillalib::audiodevice
Dec 04 14:58:23.420 DEBG Playback buffer level: 8359.446808510638, signal rms: [-65.031746, -64.11431, -59.35021, -1000.0, -1000.0, -1000.0, -62.031746, -61.11431], module: camillalib::alsadevice
Dec 04 14:58:23.420 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:58:33.447 DEBG Current buffer level: 8166.727659574468, corrected capture rate: 100.00067708333333%, module: camillalib::audiodevice
Dec 04 14:58:33.447 DEBG Playback buffer level: 8166.727659574468, signal rms: [-61.684166, -61.83472, -64.24819, -1000.0, -1000.0, -1000.0, -58.684166, -58.834724], module: camillalib::alsadevice
Dec 04 14:58:33.447 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:58:43.476 DEBG Current buffer level: 8057.076595744681, corrected capture rate: 100.003515625%, module: camillalib::audiodevice
Dec 04 14:58:43.476 DEBG Playback buffer level: 8057.076595744681, signal rms: [-68.69979, -67.29882, -67.33165, -1000.0, -1000.0, -1000.0, -65.69979, -64.29881], module: camillalib::alsadevice
Dec 04 14:58:43.476 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:58:53.499 DEBG Current buffer level: 8244.893617021276, corrected capture rate: 99.99864583333333%, module: camillalib::audiodevice
Dec 04 14:58:53.500 DEBG Playback buffer level: 8244.893617021276, signal rms: [-68.95877, -68.79989, -70.811295, -1000.0, -1000.0, -1000.0, -65.95877, -65.79989], module: camillalib::alsadevice
Dec 04 14:58:53.500 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:59:03.528 DEBG Current buffer level: 8351.510638297872, corrected capture rate: 99.995859375%, module: camillalib::audiodevice
Dec 04 14:59:03.529 DEBG Playback buffer level: 8351.510638297872, signal rms: [-62.733078, -62.20306, -62.24834, -1000.0, -1000.0, -1000.0, -59.733078, -59.203056], module: camillalib::alsadevice
Dec 04 14:59:03.529 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:59:13.554 DEBG Current buffer level: 8224.668085106383, corrected capture rate: 99.99916666666667%, module: camillalib::audiodevice
Dec 04 14:59:13.555 DEBG Playback buffer level: 8224.668085106383, signal rms: [-61.86389, -62.212524, -62.964054, -1000.0, -1000.0, -1000.0, -58.863888, -59.21253], module: camillalib::alsadevice
Dec 04 14:59:13.555 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:59:23.579 DEBG Current buffer level: 8168.123404255319, corrected capture rate: 100.000625%, module: camillalib::audiodevice
Dec 04 14:59:23.580 DEBG Playback buffer level: 8168.123404255319, signal rms: [-66.90969, -66.03594, -65.076225, -1000.0, -1000.0, -1000.0, -63.909687, -63.035942], module: camillalib::alsadevice
Dec 04 14:59:23.580 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:59:33.607 DEBG Current buffer level: 8225.36170212766, corrected capture rate: 99.99914062500001%, module: camillalib::audiodevice
Dec 04 14:59:33.607 DEBG Playback buffer level: 8225.36170212766, signal rms: [-70.6111, -69.68193, -68.69712, -1000.0, -1000.0, -1000.0, -67.6111, -66.68193], module: camillalib::alsadevice
Dec 04 14:59:33.607 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:59:43.635 DEBG Current buffer level: 8259.157446808511, corrected capture rate: 99.99825520833333%, module: camillalib::audiodevice
Dec 04 14:59:43.635 DEBG Playback buffer level: 8259.157446808511, signal rms: [-65.0831, -64.62287, -65.23391, -1000.0, -1000.0, -1000.0, -62.0831, -61.62288], module: camillalib::alsadevice
Dec 04 14:59:43.636 DEBG SetSpeed message received, module: camilladsp
Dec 04 14:59:53.661 DEBG Current buffer level: 8290.56170212766, corrected capture rate: 99.99744791666667%, module: camillalib::audiodevice
Dec 04 14:59:53.661 DEBG Playback buffer level: 8290.56170212766, signal rms: [-66.22867, -65.37408, -61.191868, -1000.0, -1000.0, -1000.0, -63.22867, -62.374077], module: camillalib::alsadevice
Dec 04 14:59:53.661 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:00:03.687 DEBG Current buffer level: 8286.727659574468, corrected capture rate: 99.99755208333333%, module: camillalib::audiodevice
Dec 04 15:00:03.687 DEBG Playback buffer level: 8286.727659574468, signal rms: [-67.10641, -66.474945, -68.35931, -1000.0, -1000.0, -1000.0, -64.10641, -63.474953], module: camillalib::alsadevice
Dec 04 15:00:03.688 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:00:13.712 DEBG Current buffer level: 8307.991489361702, corrected capture rate: 99.99700520833333%, module: camillalib::audiodevice
Dec 04 15:00:13.713 DEBG Playback buffer level: 8307.991489361702, signal rms: [-69.19789, -66.79897, -62.88862, -1000.0, -1000.0, -1000.0, -66.19789, -63.798977], module: camillalib::alsadevice
Dec 04 15:00:13.713 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:00:23.739 DEBG Current buffer level: 8376.012765957446, corrected capture rate: 99.99520833333332%, module: camillalib::audiodevice
Dec 04 15:00:23.740 DEBG Playback buffer level: 8376.012765957446, signal rms: [-63.013428, -64.185425, -54.36183, -1000.0, -1000.0, -1000.0, -60.013428, -61.185425], module: camillalib::alsadevice
Dec 04 15:00:23.740 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:00:33.767 DEBG Current buffer level: 8321.153191489362, corrected capture rate: 99.996640625%, module: camillalib::audiodevice
Dec 04 15:00:33.767 DEBG Playback buffer level: 8321.153191489362, signal rms: [-63.864906, -64.31878, -66.33172, -1000.0, -1000.0, -1000.0, -60.864906, -61.318783], module: camillalib::alsadevice
Dec 04 15:00:33.768 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:00:43.796 DEBG Current buffer level: 8215.791489361702, corrected capture rate: 99.99940104166667%, module: camillalib::audiodevice
Dec 04 15:00:43.796 DEBG Playback buffer level: 8215.791489361702, signal rms: [-66.198395, -66.41148, -59.03589, -1000.0, -1000.0, -1000.0, -63.198395, -63.41148], module: camillalib::alsadevice
Dec 04 15:00:43.796 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:00:53.823 DEBG Current buffer level: 8147.472340425532, corrected capture rate: 100.001171875%, module: camillalib::audiodevice
Dec 04 15:00:53.823 DEBG Playback buffer level: 8147.472340425532, signal rms: [-63.90123, -63.752514, -62.892006, -1000.0, -1000.0, -1000.0, -60.90123, -60.75251], module: camillalib::alsadevice
Dec 04 15:00:53.823 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:01:03.848 DEBG Current buffer level: 8204.31914893617, corrected capture rate: 99.99968750000001%, module: camillalib::audiodevice
Dec 04 15:01:03.848 DEBG Playback buffer level: 8204.31914893617, signal rms: [-74.87494, -74.492294, -68.10704, -1000.0, -1000.0, -1000.0, -71.87494, -71.492294], module: camillalib::alsadevice
Dec 04 15:01:03.849 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:01:13.875 DEBG Current buffer level: 8438.906382978723, corrected capture rate: 99.99359375%, module: camillalib::audiodevice
Dec 04 15:01:13.875 DEBG Playback buffer level: 8438.906382978723, signal rms: [-128.94673, -129.65039, -124.72961, -1000.0, -1000.0, -1000.0, -125.94673, -126.65038], module: camillalib::alsadevice
Dec 04 15:01:13.876 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:01:23.904 DEBG Current buffer level: 8190.438297872341, corrected capture rate: 100.00005208333333%, module: camillalib::audiodevice
Dec 04 15:01:23.905 DEBG Playback buffer level: 8190.438297872341, signal rms: [-73.09556, -72.32636, -85.798706, -1000.0, -1000.0, -1000.0, -70.09555, -69.32636], module: camillalib::alsadevice
Dec 04 15:01:23.905 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:01:33.928 DEBG Current buffer level: 8206.893617021276, corrected capture rate: 99.99963541666666%, module: camillalib::audiodevice
Dec 04 15:01:33.929 DEBG Playback buffer level: 8206.893617021276, signal rms: [-65.15626, -65.29692, -66.30199, -1000.0, -1000.0, -1000.0, -62.15626, -62.29692], module: camillalib::alsadevice
Dec 04 15:01:33.929 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:01:43.955 DEBG Current buffer level: 8241.944680851064, corrected capture rate: 99.99872395833333%, module: camillalib::audiodevice
Dec 04 15:01:43.955 DEBG Playback buffer level: 8241.944680851064, signal rms: [-60.551716, -60.15619, -52.828907, -1000.0, -1000.0, -1000.0, -57.551712, -57.156185], module: camillalib::alsadevice
Dec 04 15:01:43.956 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:01:53.983 DEBG Current buffer level: 8268.44255319149, corrected capture rate: 99.99802083333333%, module: camillalib::audiodevice
Dec 04 15:01:53.984 DEBG Playback buffer level: 8268.44255319149, signal rms: [-63.703163, -63.873238, -72.16984, -1000.0, -1000.0, -1000.0, -60.703167, -60.873238], module: camillalib::alsadevice
Dec 04 15:01:53.984 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:02:04.008 DEBG Current buffer level: 8327.344680851063, corrected capture rate: 99.99648437500001%, module: camillalib::audiodevice
Dec 04 15:02:04.008 DEBG Playback buffer level: 8327.344680851063, signal rms: [-61.667896, -61.425495, -53.40316, -1000.0, -1000.0, -1000.0, -58.667892, -58.4255], module: camillalib::alsadevice
Dec 04 15:02:04.008 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:02:14.035 DEBG Current buffer level: 8307.255319148937, corrected capture rate: 99.99700520833333%, module: camillalib::audiodevice
Dec 04 15:02:14.035 DEBG Playback buffer level: 8307.255319148937, signal rms: [-64.662796, -64.65404, -66.14142, -1000.0, -1000.0, -1000.0, -61.662804, -61.654037], module: camillalib::alsadevice
Dec 04 15:02:14.035 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:02:24.063 DEBG Current buffer level: 8252.651063829788, corrected capture rate: 99.99843750000001%, module: camillalib::audiodevice
Dec 04 15:02:24.064 DEBG Playback buffer level: 8252.651063829788, signal rms: [-67.1791, -66.62231, -56.604042, -1000.0, -1000.0, -1000.0, -64.1791, -63.622307], module: camillalib::alsadevice
Dec 04 15:02:24.064 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:02:34.088 DEBG Current buffer level: 8239.6, corrected capture rate: 99.99877604166667%, module: camillalib::audiodevice
Dec 04 15:02:34.089 DEBG Playback buffer level: 8239.6, signal rms: [-64.66718, -65.85368, -73.07878, -1000.0, -1000.0, -1000.0, -61.66718, -62.853683], module: camillalib::alsadevice
Dec 04 15:02:34.089 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:02:44.115 DEBG Current buffer level: 8171.795744680851, corrected capture rate: 100.000546875%, module: camillalib::audiodevice
Dec 04 15:02:44.115 DEBG Playback buffer level: 8171.795744680851, signal rms: [-64.80126, -64.149254, -68.349556, -1000.0, -1000.0, -1000.0, -61.801258, -61.149258], module: camillalib::alsadevice
Dec 04 15:02:44.116 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:02:54.143 DEBG Current buffer level: 8164.574468085107, corrected capture rate: 100.00072916666667%, module: camillalib::audiodevice
Dec 04 15:02:54.143 DEBG Playback buffer level: 8164.574468085107, signal rms: [-66.991196, -64.504654, -69.0181, -1000.0, -1000.0, -1000.0, -63.9912, -61.50466], module: camillalib::alsadevice
Dec 04 15:02:54.144 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:03:04.168 DEBG Current buffer level: 8413.2, corrected capture rate: 99.99424479166666%, module: camillalib::audiodevice
Dec 04 15:03:04.169 DEBG Playback buffer level: 8413.2, signal rms: [-65.882095, -64.824425, -66.90019, -1000.0, -1000.0, -1000.0, -62.882095, -61.82442], module: camillalib::alsadevice
Dec 04 15:03:04.169 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:03:14.196 DEBG Current buffer level: 8225.072340425531, corrected capture rate: 99.99914062500001%, module: camillalib::audiodevice
Dec 04 15:03:14.196 DEBG Playback buffer level: 8225.072340425531, signal rms: [-68.02385, -68.90524, -72.00416, -1000.0, -1000.0, -1000.0, -65.02385, -65.905235], module: camillalib::alsadevice
Dec 04 15:03:14.196 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:03:24.223 DEBG Current buffer level: 8171.28085106383, corrected capture rate: 100.000546875%, module: camillalib::audiodevice
Dec 04 15:03:24.223 DEBG Playback buffer level: 8171.28085106383, signal rms: [-66.00782, -67.03732, -67.058044, -1000.0, -1000.0, -1000.0, -63.007816, -64.037315], module: camillalib::alsadevice
Dec 04 15:03:24.224 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:03:34.251 DEBG Current buffer level: 8157.851063829788, corrected capture rate: 100.00091145833335%, module: camillalib::audiodevice
Dec 04 15:03:34.251 DEBG Playback buffer level: 8157.851063829788, signal rms: [-65.20242, -65.18181, -65.948166, -1000.0, -1000.0, -1000.0, -62.20242, -62.181812], module: camillalib::alsadevice
Dec 04 15:03:34.251 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:03:44.275 DEBG Current buffer level: 8234.331914893617, corrected capture rate: 99.99890624999999%, module: camillalib::audiodevice
Dec 04 15:03:44.276 DEBG Playback buffer level: 8234.331914893617, signal rms: [-63.653275, -63.467007, -67.749626, -1000.0, -1000.0, -1000.0, -60.65327, -60.467003], module: camillalib::alsadevice
Dec 04 15:03:44.276 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:03:54.303 DEBG Current buffer level: 8245.272340425532, corrected capture rate: 99.99861979166667%, module: camillalib::audiodevice
Dec 04 15:03:54.303 DEBG Playback buffer level: 8245.272340425532, signal rms: [-72.37195, -71.41587, -76.830246, -1000.0, -1000.0, -1000.0, -69.37195, -68.41587], module: camillalib::alsadevice
Dec 04 15:03:54.303 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:04:04.332 DEBG Current buffer level: 8300.51489361702, corrected capture rate: 99.9971875%, module: camillalib::audiodevice
Dec 04 15:04:04.333 DEBG Playback buffer level: 8300.51489361702, signal rms: [-67.6833, -66.97395, -63.227097, -1000.0, -1000.0, -1000.0, -64.6833, -63.973953], module: camillalib::alsadevice
Dec 04 15:04:04.333 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:04:14.355 DEBG Current buffer level: 8308.446808510638, corrected capture rate: 99.99697916666666%, module: camillalib::audiodevice
Dec 04 15:04:14.355 DEBG Playback buffer level: 8308.446808510638, signal rms: [-67.960785, -66.078255, -85.191376, -1000.0, -1000.0, -1000.0, -64.960785, -63.078255], module: camillalib::alsadevice
Dec 04 15:04:14.355 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:04:24.383 DEBG Current buffer level: 8323.187234042553, corrected capture rate: 99.99658854166667%, module: camillalib::audiodevice
Dec 04 15:04:24.384 DEBG Playback buffer level: 8323.187234042553, signal rms: [-106.693054, -106.23147, -97.84389, -1000.0, -1000.0, -1000.0, -103.693054, -103.23147], module: camillalib::alsadevice
Dec 04 15:04:24.384 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:04:34.410 DEBG Current buffer level: 8319.306382978724, corrected capture rate: 99.99669270833334%, module: camillalib::audiodevice
Dec 04 15:04:34.411 DEBG Playback buffer level: 8319.306382978724, signal rms: [-71.23843, -74.50958, -61.13337, -1000.0, -1000.0, -1000.0, -68.238434, -71.50958], module: camillalib::alsadevice
Dec 04 15:04:34.411 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:04:44.439 DEBG Current buffer level: 8233.740425531914, corrected capture rate: 99.99893229166666%, module: camillalib::audiodevice
Dec 04 15:04:44.439 DEBG Playback buffer level: 8233.740425531914, signal rms: [-73.81864, -70.660965, -67.08737, -1000.0, -1000.0, -1000.0, -70.81864, -67.660965], module: camillalib::alsadevice
Dec 04 15:04:44.440 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:04:54.462 DEBG Current buffer level: 8122.706382978723, corrected capture rate: 100.00182291666665%, module: camillalib::audiodevice
Dec 04 15:04:54.463 DEBG Playback buffer level: 8122.706382978723, signal rms: [-68.256805, -67.17197, -53.30095, -1000.0, -1000.0, -1000.0, -65.25681, -64.17197], module: camillalib::alsadevice
Dec 04 15:04:54.463 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:05:04.491 DEBG Current buffer level: 8137.387234042553, corrected capture rate: 100.00143229166667%, module: camillalib::audiodevice
Dec 04 15:05:04.492 DEBG Playback buffer level: 8137.387234042553, signal rms: [-73.55166, -70.49492, -72.43557, -1000.0, -1000.0, -1000.0, -70.55166, -67.49492], module: camillalib::alsadevice
Dec 04 15:05:04.492 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:05:14.516 DEBG Current buffer level: 8415.991489361702, corrected capture rate: 99.99419270833333%, module: camillalib::audiodevice
Dec 04 15:05:14.517 DEBG Playback buffer level: 8415.991489361702, signal rms: [-65.557434, -65.18752, -58.734436, -1000.0, -1000.0, -1000.0, -62.557434, -62.18752], module: camillalib::alsadevice
Dec 04 15:05:14.517 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:05:24.544 DEBG Current buffer level: 8262.629787234042, corrected capture rate: 99.99817708333333%, module: camillalib::audiodevice
Dec 04 15:05:24.544 DEBG Playback buffer level: 8262.629787234042, signal rms: [-68.186676, -66.25913, -70.27906, -1000.0, -1000.0, -1000.0, -65.186676, -63.25913], module: camillalib::alsadevice
Dec 04 15:05:24.544 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:05:34.572 DEBG Current buffer level: 8237.965957446808, corrected capture rate: 99.998828125%, module: camillalib::audiodevice
Dec 04 15:05:34.572 DEBG Playback buffer level: 8237.965957446808, signal rms: [-71.1636, -71.65912, -64.34585, -1000.0, -1000.0, -1000.0, -68.1636, -68.65912], module: camillalib::alsadevice
Dec 04 15:05:34.572 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:05:44.599 DEBG Current buffer level: 8187.804255319149, corrected capture rate: 100.00013020833333%, module: camillalib::audiodevice
Dec 04 15:05:44.599 DEBG Playback buffer level: 8187.804255319149, signal rms: [-72.845825, -68.131035, -67.763916, -1000.0, -1000.0, -1000.0, -69.845825, -65.131035], module: camillalib::alsadevice
Dec 04 15:05:44.600 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:05:54.623 DEBG Current buffer level: 8213.702127659575, corrected capture rate: 99.999453125%, module: camillalib::audiodevice
Dec 04 15:05:54.624 DEBG Playback buffer level: 8213.702127659575, signal rms: [-73.12568, -72.68921, -74.48248, -1000.0, -1000.0, -1000.0, -70.12568, -69.68921], module: camillalib::alsadevice
Dec 04 15:05:54.624 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:06:04.650 DEBG Current buffer level: 8241.668085106383, corrected capture rate: 99.99872395833333%, module: camillalib::audiodevice
Dec 04 15:06:04.651 DEBG Playback buffer level: 8241.668085106383, signal rms: [-63.02163, -63.11164, -59.159958, -1000.0, -1000.0, -1000.0, -60.02163, -60.11164], module: camillalib::alsadevice
Dec 04 15:06:04.651 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:06:14.679 DEBG Current buffer level: 8285.408510638297, corrected capture rate: 99.997578125%, module: camillalib::audiodevice
Dec 04 15:06:14.680 DEBG Playback buffer level: 8285.408510638297, signal rms: [-69.90059, -74.39208, -76.58287, -1000.0, -1000.0, -1000.0, -66.90059, -71.392075], module: camillalib::alsadevice
Dec 04 15:06:14.680 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:06:24.703 DEBG Current buffer level: 8259.570212765957, corrected capture rate: 99.99825520833333%, module: camillalib::audiodevice
Dec 04 15:06:24.703 DEBG Playback buffer level: 8259.570212765957, signal rms: [-70.51408, -68.346115, -60.14654, -1000.0, -1000.0, -1000.0, -67.514084, -65.346115], module: camillalib::alsadevice
Dec 04 15:06:24.704 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:06:34.731 DEBG Current buffer level: 8256.123404255319, corrected capture rate: 99.99833333333333%, module: camillalib::audiodevice
Dec 04 15:06:34.731 DEBG Playback buffer level: 8256.123404255319, signal rms: [-68.88108, -69.52727, -67.85025, -1000.0, -1000.0, -1000.0, -65.88108, -66.52726], module: camillalib::alsadevice
Dec 04 15:06:34.731 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:06:44.759 DEBG Current buffer level: 8257.404255319148, corrected capture rate: 99.99830729166666%, module: camillalib::audiodevice
Dec 04 15:06:44.759 DEBG Playback buffer level: 8257.404255319148, signal rms: [-69.89932, -69.91243, -64.249825, -1000.0, -1000.0, -1000.0, -66.89932, -66.91243], module: camillalib::alsadevice
Dec 04 15:06:44.760 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:06:54.783 DEBG Current buffer level: 8293.808510638299, corrected capture rate: 99.99736979166667%, module: camillalib::audiodevice
Dec 04 15:06:54.783 DEBG Playback buffer level: 8293.808510638299, signal rms: [-73.21235, -70.552765, -61.13925, -1000.0, -1000.0, -1000.0, -70.21235, -67.552765], module: camillalib::alsadevice
Dec 04 15:06:54.784 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:07:04.811 DEBG Current buffer level: 8282.655319148937, corrected capture rate: 99.99765625%, module: camillalib::audiodevice
Dec 04 15:07:04.811 DEBG Playback buffer level: 8282.655319148937, signal rms: [-69.98413, -67.857666, -59.82017, -1000.0, -1000.0, -1000.0, -66.98413, -64.857666], module: camillalib::alsadevice
Dec 04 15:07:04.811 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:07:14.839 DEBG Current buffer level: 8252.297872340425, corrected capture rate: 99.99843750000001%, module: camillalib::audiodevice
Dec 04 15:07:14.839 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:07:14.839 DEBG Playback buffer level: 8252.297872340425, signal rms: [-69.086624, -69.85267, -54.657944, -1000.0, -1000.0, -1000.0, -66.086624, -66.85266], module: camillalib::alsadevice
Dec 04 15:07:24.868 DEBG Current buffer level: 8108.770212765958, corrected capture rate: 100.0021875%, module: camillalib::audiodevice
Dec 04 15:07:24.868 DEBG Playback buffer level: 8108.770212765958, signal rms: [-64.74861, -64.84616, -58.458782, -1000.0, -1000.0, -1000.0, -61.748615, -61.846157], module: camillalib::alsadevice
Dec 04 15:07:24.869 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:07:34.892 DEBG Current buffer level: 8225.710638297873, corrected capture rate: 99.99914062500001%, module: camillalib::audiodevice
Dec 04 15:07:34.893 DEBG Playback buffer level: 8225.710638297873, signal rms: [-62.809387, -64.5061, -48.387695, -1000.0, -1000.0, -1000.0, -59.809387, -61.506104], module: camillalib::alsadevice
Dec 04 15:07:34.893 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:07:44.919 DEBG Current buffer level: 8423.782978723404, corrected capture rate: 99.993984375%, module: camillalib::audiodevice
Dec 04 15:07:44.919 DEBG Playback buffer level: 8423.782978723404, signal rms: [-61.47941, -62.4786, -56.307835, -1000.0, -1000.0, -1000.0, -58.47941, -59.478603], module: camillalib::alsadevice
Dec 04 15:07:44.920 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:07:54.947 DEBG Current buffer level: 8267.753191489363, corrected capture rate: 99.998046875%, module: camillalib::audiodevice
Dec 04 15:07:54.948 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:07:54.948 DEBG Playback buffer level: 8267.753191489363, signal rms: [-78.22676, -73.8886, -83.51859, -1000.0, -1000.0, -1000.0, -75.22676, -70.8886], module: camillalib::alsadevice
Dec 04 15:08:04.972 DEBG Current buffer level: 8220.744680851063, corrected capture rate: 99.99927083333333%, module: camillalib::audiodevice
Dec 04 15:08:04.973 DEBG Playback buffer level: 8220.744680851063, signal rms: [-69.393776, -67.203285, -70.67706, -1000.0, -1000.0, -1000.0, -66.393776, -64.20328], module: camillalib::alsadevice
Dec 04 15:08:04.973 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:08:14.998 DEBG Current buffer level: 8250.834042553191, corrected capture rate: 99.99848958333334%, module: camillalib::audiodevice
Dec 04 15:08:14.999 DEBG Playback buffer level: 8250.834042553191, signal rms: [-70.58868, -70.07562, -60.653526, -1000.0, -1000.0, -1000.0, -67.58867, -67.07562], module: camillalib::alsadevice
Dec 04 15:08:14.999 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:08:25.027 DEBG Current buffer level: 8334.651063829788, corrected capture rate: 99.99630208333333%, module: camillalib::audiodevice
Dec 04 15:08:25.028 DEBG Playback buffer level: 8334.651063829788, signal rms: [-68.30446, -65.74541, -56.80136, -1000.0, -1000.0, -1000.0, -65.30446, -62.745415], module: camillalib::alsadevice
Dec 04 15:08:25.028 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:08:35.051 DEBG Current buffer level: 8296.170212765957, corrected capture rate: 99.99729166666667%, module: camillalib::audiodevice
Dec 04 15:08:35.052 DEBG Playback buffer level: 8296.170212765957, signal rms: [-68.65951, -69.6741, -70.13864, -1000.0, -1000.0, -1000.0, -65.6595, -66.67411], module: camillalib::alsadevice
Dec 04 15:08:35.052 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:08:45.079 DEBG Current buffer level: 8301.765957446809, corrected capture rate: 99.99716145833332%, module: camillalib::audiodevice
Dec 04 15:08:45.079 DEBG Playback buffer level: 8301.765957446809, signal rms: [-67.510666, -67.01512, -58.70862, -1000.0, -1000.0, -1000.0, -64.510666, -64.01512], module: camillalib::alsadevice
Dec 04 15:08:45.080 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:08:55.107 DEBG Current buffer level: 8320.451063829787, corrected capture rate: 99.99666666666667%, module: camillalib::audiodevice
Dec 04 15:08:55.107 DEBG Playback buffer level: 8320.451063829787, signal rms: [-61.475674, -64.265526, -54.237617, -1000.0, -1000.0, -1000.0, -58.475677, -61.265522], module: camillalib::alsadevice
Dec 04 15:08:55.108 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:09:05.135 DEBG Current buffer level: 8142.991489361702, corrected capture rate: 100.00130208333333%, module: camillalib::audiodevice
Dec 04 15:09:05.135 DEBG Playback buffer level: 8142.991489361702, signal rms: [-62.713657, -64.091736, -56.672398, -1000.0, -1000.0, -1000.0, -59.713654, -61.091732], module: camillalib::alsadevice
Dec 04 15:09:05.136 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:09:15.160 DEBG Current buffer level: 8097.75744680851, corrected capture rate: 100.00247395833333%, module: camillalib::audiodevice
Dec 04 15:09:15.160 DEBG Playback buffer level: 8097.75744680851, signal rms: [-62.471596, -63.32209, -54.13462, -1000.0, -1000.0, -1000.0, -59.471592, -60.322094], module: camillalib::alsadevice
Dec 04 15:09:15.160 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:09:25.187 DEBG Current buffer level: 8296.387234042553, corrected capture rate: 99.99729166666667%, module: camillalib::audiodevice
Dec 04 15:09:25.187 DEBG Playback buffer level: 8296.387234042553, signal rms: [-59.98484, -59.70349, -60.123943, -1000.0, -1000.0, -1000.0, -56.984844, -56.703495], module: camillalib::alsadevice
Dec 04 15:09:25.187 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:09:35.215 DEBG Current buffer level: 8350.591489361703, corrected capture rate: 99.99588541666667%, module: camillalib::audiodevice
Dec 04 15:09:35.215 DEBG Playback buffer level: 8350.591489361703, signal rms: [-63.12483, -63.127357, -52.892056, -1000.0, -1000.0, -1000.0, -60.124832, -60.127357], module: camillalib::alsadevice
Dec 04 15:09:35.215 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:09:45.236 DEBG Current buffer level: 8133.136170212766, corrected capture rate: 100.00153645833333%, module: camillalib::audiodevice
Dec 04 15:09:45.237 DEBG Playback buffer level: 8133.136170212766, signal rms: [-64.90649, -64.24219, -51.788563, -1000.0, -1000.0, -1000.0, -61.906487, -61.242195], module: camillalib::alsadevice
Dec 04 15:09:45.237 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:09:55.267 DEBG Current buffer level: 8144.017021276596, corrected capture rate: 100.00125%, module: camillalib::audiodevice
Dec 04 15:09:55.267 DEBG Playback buffer level: 8144.017021276596, signal rms: [-63.34476, -63.567738, -57.530693, -1000.0, -1000.0, -1000.0, -60.344765, -60.567738], module: camillalib::alsadevice
Dec 04 15:09:55.268 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:10:05.295 DEBG Current buffer level: 8167.140425531915, corrected capture rate: 100.00065104166667%, module: camillalib::audiodevice
Dec 04 15:10:05.295 DEBG Playback buffer level: 8167.140425531915, signal rms: [-60.404163, -60.40691, -64.76208, -1000.0, -1000.0, -1000.0, -57.404167, -57.406906], module: camillalib::alsadevice
Dec 04 15:10:05.295 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:10:15.320 DEBG Current buffer level: 8372.008510638298, corrected capture rate: 99.9953125%, module: camillalib::audiodevice
Dec 04 15:10:15.321 DEBG Playback buffer level: 8372.008510638298, signal rms: [-71.26146, -71.038925, -58.932133, -1000.0, -1000.0, -1000.0, -68.26147, -68.038925], module: camillalib::alsadevice
Dec 04 15:10:15.321 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:10:25.347 DEBG Current buffer level: 8287.88085106383, corrected capture rate: 99.99752604166666%, module: camillalib::audiodevice
Dec 04 15:10:25.348 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:10:25.348 DEBG Playback buffer level: 8287.88085106383, signal rms: [-72.49108, -71.9382, -61.750965, -1000.0, -1000.0, -1000.0, -69.49107, -68.9382], module: camillalib::alsadevice
Dec 04 15:10:35.375 DEBG Current buffer level: 8296.012765957446, corrected capture rate: 99.99729166666667%, module: camillalib::audiodevice
Dec 04 15:10:35.375 DEBG Playback buffer level: 8296.012765957446, signal rms: [-64.1696, -66.83414, -64.44483, -1000.0, -1000.0, -1000.0, -61.169605, -63.834145], module: camillalib::alsadevice
Dec 04 15:10:35.376 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:10:45.399 DEBG Current buffer level: 8306.608510638298, corrected capture rate: 99.99703125%, module: camillalib::audiodevice
Dec 04 15:10:45.399 DEBG Playback buffer level: 8306.608510638298, signal rms: [-77.498085, -78.982544, -72.19656, -1000.0, -1000.0, -1000.0, -74.498085, -75.982544], module: camillalib::alsadevice
Dec 04 15:10:45.400 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:10:55.427 DEBG Current buffer level: 8266.127659574468, corrected capture rate: 99.99807291666667%, module: camillalib::audiodevice
Dec 04 15:10:55.427 DEBG Playback buffer level: 8266.127659574468, signal rms: [-70.52363, -73.48551, -84.36638, -1000.0, -1000.0, -1000.0, -67.52363, -70.48552], module: camillalib::alsadevice
Dec 04 15:10:55.428 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:11:05.455 DEBG Current buffer level: 8274.63829787234, corrected capture rate: 99.99786458333332%, module: camillalib::audiodevice
Dec 04 15:11:05.456 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:11:05.456 DEBG Playback buffer level: 8274.63829787234, signal rms: [-97.740845, -99.75045, -87.07779, -1000.0, -1000.0, -1000.0, -94.74084, -96.75045], module: camillalib::alsadevice
Dec 04 15:11:15.475 DEBG Current buffer level: 8358.148936170213, corrected capture rate: 99.99567708333333%, module: camillalib::audiodevice
Dec 04 15:11:15.475 DEBG Playback buffer level: 8358.148936170213, signal rms: [-72.64133, -72.35924, -74.83023, -1000.0, -1000.0, -1000.0, -69.64133, -69.35924], module: camillalib::alsadevice
Dec 04 15:11:15.475 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:11:25.507 DEBG Current buffer level: 8230.778723404255, corrected capture rate: 99.99901041666666%, module: camillalib::audiodevice
Dec 04 15:11:25.507 DEBG Playback buffer level: 8230.778723404255, signal rms: [-65.27263, -66.41386, -55.894615, -1000.0, -1000.0, -1000.0, -62.27263, -63.413857], module: camillalib::alsadevice
Dec 04 15:11:25.507 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:11:35.536 DEBG Current buffer level: 8104.9106382978725, corrected capture rate: 100.00229166666668%, module: camillalib::audiodevice
Dec 04 15:11:35.536 DEBG Playback buffer level: 8104.9106382978725, signal rms: [-66.01218, -63.723404, -70.15033, -1000.0, -1000.0, -1000.0, -63.012177, -60.7234], module: camillalib::alsadevice
Dec 04 15:11:35.537 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:11:45.558 DEBG Current buffer level: 8181.574468085107, corrected capture rate: 100.00028645833335%, module: camillalib::audiodevice
Dec 04 15:11:45.558 DEBG Playback buffer level: 8181.574468085107, signal rms: [-65.34059, -65.09082, -42.98685, -1000.0, -1000.0, -1000.0, -62.34059, -62.090816], module: camillalib::alsadevice
Dec 04 15:11:45.559 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:11:55.587 DEBG Current buffer level: 8452.425531914894, corrected capture rate: 99.99322916666667%, module: camillalib::audiodevice
Dec 04 15:11:55.588 DEBG Playback buffer level: 8452.425531914894, signal rms: [-66.4954, -66.82814, -67.00838, -1000.0, -1000.0, -1000.0, -63.4954, -63.828133], module: camillalib::alsadevice
Dec 04 15:11:55.588 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:12:05.614 DEBG Current buffer level: 8275.021276595744, corrected capture rate: 99.99783854166667%, module: camillalib::audiodevice
Dec 04 15:12:05.615 DEBG Playback buffer level: 8275.021276595744, signal rms: [-67.198235, -67.81818, -55.464855, -1000.0, -1000.0, -1000.0, -64.198235, -64.81818], module: camillalib::alsadevice
Dec 04 15:12:05.615 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:12:15.639 DEBG Current buffer level: 8245.595744680852, corrected capture rate: 99.99861979166667%, module: camillalib::audiodevice
Dec 04 15:12:15.639 DEBG Playback buffer level: 8245.595744680852, signal rms: [-65.113365, -63.99397, -43.219673, -1000.0, -1000.0, -1000.0, -62.113373, -60.993973], module: camillalib::alsadevice
Dec 04 15:12:15.639 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:12:25.667 DEBG Current buffer level: 8243.778723404255, corrected capture rate: 99.998671875%, module: camillalib::audiodevice
Dec 04 15:12:25.668 DEBG Playback buffer level: 8243.778723404255, signal rms: [-69.521225, -67.95509, -67.45676, -1000.0, -1000.0, -1000.0, -66.521225, -64.95509], module: camillalib::alsadevice
Dec 04 15:12:25.669 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:12:35.695 DEBG Current buffer level: 8231.897872340425, corrected capture rate: 99.998984375%, module: camillalib::audiodevice
Dec 04 15:12:35.695 DEBG Playback buffer level: 8231.897872340425, signal rms: [-63.21585, -62.940628, -64.74396, -1000.0, -1000.0, -1000.0, -60.21585, -59.940628], module: camillalib::alsadevice
Dec 04 15:12:35.696 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:12:45.720 DEBG Current buffer level: 8299.178723404255, corrected capture rate: 99.99721354166667%, module: camillalib::audiodevice
Dec 04 15:12:45.721 DEBG Playback buffer level: 8299.178723404255, signal rms: [-60.21194, -60.174175, -72.80887, -1000.0, -1000.0, -1000.0, -57.211937, -57.17417], module: camillalib::alsadevice
Dec 04 15:12:45.721 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:12:55.747 DEBG Current buffer level: 8356.829787234043, corrected capture rate: 99.99572916666666%, module: camillalib::audiodevice
Dec 04 15:12:55.747 DEBG Playback buffer level: 8356.829787234043, signal rms: [-71.34892, -71.15762, -69.935074, -1000.0, -1000.0, -1000.0, -68.34892, -68.15763], module: camillalib::alsadevice
Dec 04 15:12:55.748 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:13:05.774 DEBG Current buffer level: 8173.629787234043, corrected capture rate: 100.00049479166665%, module: camillalib::audiodevice
Dec 04 15:13:05.775 DEBG Playback buffer level: 8173.629787234043, signal rms: [-66.06871, -66.17971, -67.5048, -1000.0, -1000.0, -1000.0, -63.068703, -63.179707], module: camillalib::alsadevice
Dec 04 15:13:05.775 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:13:15.803 DEBG Current buffer level: 8082.297872340426, corrected capture rate: 100.00286458333333%, module: camillalib::audiodevice
Dec 04 15:13:15.803 DEBG Playback buffer level: 8082.297872340426, signal rms: [-66.93126, -67.59328, -63.520157, -1000.0, -1000.0, -1000.0, -63.93126, -64.593285], module: camillalib::alsadevice
Dec 04 15:13:15.803 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:13:25.828 DEBG Current buffer level: 8170.514893617022, corrected capture rate: 100.00057291666667%, module: camillalib::audiodevice
Dec 04 15:13:25.828 DEBG Playback buffer level: 8170.514893617022, signal rms: [-63.66375, -62.131157, -45.618904, -1000.0, -1000.0, -1000.0, -60.66375, -59.131157], module: camillalib::alsadevice
Dec 04 15:13:25.828 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:13:35.853 DEBG Current buffer level: 8364, corrected capture rate: 99.99552083333333%, module: camillalib::audiodevice
Dec 04 15:13:35.854 DEBG Playback buffer level: 8364, signal rms: [-64.26103, -62.84253, -66.55941, -1000.0, -1000.0, -1000.0, -61.261032, -59.842533], module: camillalib::alsadevice
Dec 04 15:13:35.854 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:13:45.881 DEBG Current buffer level: 8305.455319148936, corrected capture rate: 99.99705729166666%, module: camillalib::audiodevice
Dec 04 15:13:45.881 DEBG Playback buffer level: 8305.455319148936, signal rms: [-66.768524, -65.23111, -66.16761, -1000.0, -1000.0, -1000.0, -63.76853, -62.23111], module: camillalib::alsadevice
Dec 04 15:13:45.882 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:13:55.912 DEBG Current buffer level: 8122.072340425532, corrected capture rate: 100.00182291666665%, module: camillalib::audiodevice
Dec 04 15:13:55.912 DEBG Playback buffer level: 8122.072340425532, signal rms: [-58.842896, -63.515778, -80.59132, -1000.0, -1000.0, -1000.0, -55.842896, -60.515778], module: camillalib::alsadevice
Dec 04 15:13:55.913 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:14:05.935 DEBG Current buffer level: 8178.017021276596, corrected capture rate: 100.00036458333332%, module: camillalib::audiodevice
Dec 04 15:14:05.935 DEBG Playback buffer level: 8178.017021276596, signal rms: [-81.141594, -83.78663, -68.0606, -1000.0, -1000.0, -1000.0, -78.1416, -80.78663], module: camillalib::alsadevice
Dec 04 15:14:05.935 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:14:15.962 DEBG Current buffer level: 8253.95744680851, corrected capture rate: 99.99841145833334%, module: camillalib::audiodevice
Dec 04 15:14:15.963 DEBG Playback buffer level: 8253.95744680851, signal rms: [-66.474754, -67.23223, -55.211136, -1000.0, -1000.0, -1000.0, -63.474754, -64.23223], module: camillalib::alsadevice
Dec 04 15:14:15.963 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:14:25.991 DEBG Current buffer level: 8228.038297872341, corrected capture rate: 99.99906250000001%, module: camillalib::audiodevice
Dec 04 15:14:25.991 DEBG Playback buffer level: 8228.038297872341, signal rms: [-73.6493, -74.56689, -72.8369, -1000.0, -1000.0, -1000.0, -70.64929, -71.56688], module: camillalib::alsadevice
Dec 04 15:14:25.992 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:14:36.016 DEBG Current buffer level: 8237.536170212767, corrected capture rate: 99.998828125%, module: camillalib::audiodevice
Dec 04 15:14:36.017 DEBG Playback buffer level: 8237.536170212767, signal rms: [-67.25022, -67.208435, -75.8763, -1000.0, -1000.0, -1000.0, -64.25022, -64.208435], module: camillalib::alsadevice
Dec 04 15:14:36.017 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:14:46.043 DEBG Current buffer level: 8258.72340425532, corrected capture rate: 99.99828125%, module: camillalib::audiodevice
Dec 04 15:14:46.044 DEBG Playback buffer level: 8258.72340425532, signal rms: [-65.32501, -64.7056, -67.34214, -1000.0, -1000.0, -1000.0, -62.325016, -61.705605], module: camillalib::alsadevice
Dec 04 15:14:46.044 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:14:56.071 DEBG Current buffer level: 8270.182978723404, corrected capture rate: 99.99796875%, module: camillalib::audiodevice
Dec 04 15:14:56.072 DEBG Playback buffer level: 8270.182978723404, signal rms: [-67.901306, -66.958496, -69.37222, -1000.0, -1000.0, -1000.0, -64.901306, -63.958504], module: camillalib::alsadevice
Dec 04 15:14:56.072 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:15:06.095 DEBG Current buffer level: 8280.208510638298, corrected capture rate: 99.99770833333334%, module: camillalib::audiodevice
Dec 04 15:15:06.095 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:15:06.095 DEBG Playback buffer level: 8280.208510638298, signal rms: [-67.822426, -67.78209, -62.922863, -1000.0, -1000.0, -1000.0, -64.82242, -64.78209], module: camillalib::alsadevice
Dec 04 15:15:16.120 DEBG Current buffer level: 8340.612765957447, corrected capture rate: 99.99614583333334%, module: camillalib::audiodevice
Dec 04 15:15:16.120 DEBG Playback buffer level: 8340.612765957447, signal rms: [-70.32239, -69.891525, -69.979675, -1000.0, -1000.0, -1000.0, -67.32238, -66.891525], module: camillalib::alsadevice
Dec 04 15:15:16.120 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:15:26.152 DEBG Current buffer level: 8340.540425531915, corrected capture rate: 99.99614583333334%, module: camillalib::audiodevice
Dec 04 15:15:26.152 DEBG Playback buffer level: 8340.540425531915, signal rms: [-68.237885, -69.34604, -87.31633, -1000.0, -1000.0, -1000.0, -65.23788, -66.34604], module: camillalib::alsadevice
Dec 04 15:15:26.152 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:15:36.178 DEBG Current buffer level: 8375.153191489362, corrected capture rate: 99.995234375%, module: camillalib::audiodevice
Dec 04 15:15:36.179 DEBG Playback buffer level: 8375.153191489362, signal rms: [-73.81387, -73.835, -89.075745, -1000.0, -1000.0, -1000.0, -70.81388, -70.83501], module: camillalib::alsadevice
Dec 04 15:15:36.179 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:15:46.200 DEBG Current buffer level: 8168.336170212766, corrected capture rate: 100.000625%, module: camillalib::audiodevice
Dec 04 15:15:46.201 DEBG Playback buffer level: 8168.336170212766, signal rms: [-77.337814, -73.15586, -88.10653, -1000.0, -1000.0, -1000.0, -74.337814, -70.15586], module: camillalib::alsadevice
Dec 04 15:15:46.201 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:15:56.231 DEBG Current buffer level: 8156.931914893617, corrected capture rate: 100.0009375%, module: camillalib::audiodevice
Dec 04 15:15:56.232 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:15:56.232 DEBG Playback buffer level: 8156.931914893617, signal rms: [-69.09431, -70.47598, -67.147385, -1000.0, -1000.0, -1000.0, -66.094315, -67.475975], module: camillalib::alsadevice
Dec 04 15:16:06.258 DEBG Current buffer level: 8168.208510638298, corrected capture rate: 100.000625%, module: camillalib::audiodevice
Dec 04 15:16:06.259 DEBG Playback buffer level: 8168.208510638298, signal rms: [-69.02179, -70.315445, -67.79085, -1000.0, -1000.0, -1000.0, -66.02179, -67.31544], module: camillalib::alsadevice
Dec 04 15:16:06.259 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:16:16.284 DEBG Current buffer level: 8223.744680851063, corrected capture rate: 99.99919270833333%, module: camillalib::audiodevice
Dec 04 15:16:16.284 DEBG Playback buffer level: 8223.744680851063, signal rms: [-71.27358, -72.610245, -64.61922, -1000.0, -1000.0, -1000.0, -68.273575, -69.610245], module: camillalib::alsadevice
Dec 04 15:16:16.284 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:16:26.311 DEBG Current buffer level: 8241.314893617022, corrected capture rate: 99.99872395833333%, module: camillalib::audiodevice
Dec 04 15:16:26.311 DEBG Playback buffer level: 8241.314893617022, signal rms: [-67.82466, -69.07024, -56.83571, -1000.0, -1000.0, -1000.0, -64.82466, -66.07024], module: camillalib::alsadevice
Dec 04 15:16:26.312 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:16:36.340 DEBG Current buffer level: 8249.468085106382, corrected capture rate: 99.998515625%, module: camillalib::audiodevice
Dec 04 15:16:36.340 DEBG Playback buffer level: 8249.468085106382, signal rms: [-71.09214, -71.95503, -68.378174, -1000.0, -1000.0, -1000.0, -68.09214, -68.95503], module: camillalib::alsadevice
Dec 04 15:16:36.340 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:16:46.365 DEBG Current buffer level: 8196.744680851063, corrected capture rate: 99.99989583333333%, module: camillalib::audiodevice
Dec 04 15:16:46.365 DEBG Playback buffer level: 8196.744680851063, signal rms: [-70.23577, -71.622284, -71.070175, -1000.0, -1000.0, -1000.0, -67.23577, -68.622284], module: camillalib::alsadevice
Dec 04 15:16:46.365 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:16:56.391 DEBG Current buffer level: 8244.289361702127, corrected capture rate: 99.99864583333333%, module: camillalib::audiodevice
Dec 04 15:16:56.392 DEBG Playback buffer level: 8244.289361702127, signal rms: [-71.72514, -72.528336, -70.455284, -1000.0, -1000.0, -1000.0, -68.72514, -69.528336], module: camillalib::alsadevice
Dec 04 15:16:56.392 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:17:06.419 DEBG Current buffer level: 8265.272340425532, corrected capture rate: 99.99809895833334%, module: camillalib::audiodevice
Dec 04 15:17:06.419 DEBG Playback buffer level: 8265.272340425532, signal rms: [-68.267105, -69.86143, -58.861557, -1000.0, -1000.0, -1000.0, -65.267105, -66.86143], module: camillalib::alsadevice
Dec 04 15:17:06.420 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:17:16.444 DEBG Current buffer level: 8338.595744680852, corrected capture rate: 99.99619791666666%, module: camillalib::audiodevice
Dec 04 15:17:16.444 DEBG Playback buffer level: 8338.595744680852, signal rms: [-70.841125, -71.60988, -67.3696, -1000.0, -1000.0, -1000.0, -67.84112, -68.60988], module: camillalib::alsadevice
Dec 04 15:17:16.445 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:17:26.471 DEBG Current buffer level: 8307.787234042553, corrected capture rate: 99.99700520833333%, module: camillalib::audiodevice
Dec 04 15:17:26.472 DEBG Playback buffer level: 8307.787234042553, signal rms: [-68.50303, -65.298065, -54.555737, -1000.0, -1000.0, -1000.0, -65.50303, -62.298065], module: camillalib::alsadevice
Dec 04 15:17:26.472 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:17:36.499 DEBG Current buffer level: 8343.004255319149, corrected capture rate: 99.99606770833334%, module: camillalib::audiodevice
Dec 04 15:17:36.499 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:17:36.500 DEBG Playback buffer level: 8343.004255319149, signal rms: [-67.3107, -65.703705, -70.75441, -1000.0, -1000.0, -1000.0, -64.31069, -62.703705], module: camillalib::alsadevice
Dec 04 15:17:46.520 DEBG Current buffer level: 8316.821276595745, corrected capture rate: 99.99677083333334%, module: camillalib::audiodevice
Dec 04 15:17:46.520 DEBG Playback buffer level: 8316.821276595745, signal rms: [-69.12442, -70.14528, -71.87025, -1000.0, -1000.0, -1000.0, -66.12443, -67.14528], module: camillalib::alsadevice
Dec 04 15:17:46.521 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:17:56.551 DEBG Current buffer level: 8143.736170212766, corrected capture rate: 100.00127604166667%, module: camillalib::audiodevice
Dec 04 15:17:56.551 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:17:56.552 DEBG Playback buffer level: 8143.736170212766, signal rms: [-63.118347, -63.458923, -72.81963, -1000.0, -1000.0, -1000.0, -60.118347, -60.458923], module: camillalib::alsadevice
Dec 04 15:18:06.579 DEBG Current buffer level: 8142.9106382978725, corrected capture rate: 100.00130208333333%, module: camillalib::audiodevice
Dec 04 15:18:06.579 DEBG Playback buffer level: 8142.9106382978725, signal rms: [-71.62143, -72.69891, -69.38611, -1000.0, -1000.0, -1000.0, -68.62143, -69.69892], module: camillalib::alsadevice
Dec 04 15:18:06.579 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:18:16.604 DEBG Current buffer level: 8365.046808510639, corrected capture rate: 99.99549479166666%, module: camillalib::audiodevice
Dec 04 15:18:16.605 DEBG Playback buffer level: 8365.046808510639, signal rms: [-63.773174, -64.601234, -68.97242, -1000.0, -1000.0, -1000.0, -60.77318, -61.60124], module: camillalib::alsadevice
Dec 04 15:18:16.605 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:18:26.631 DEBG Current buffer level: 8312.825531914894, corrected capture rate: 99.996875%, module: camillalib::audiodevice
Dec 04 15:18:26.631 DEBG Playback buffer level: 8312.825531914894, signal rms: [-71.50727, -72.73434, -50.909096, -1000.0, -1000.0, -1000.0, -68.50727, -69.73434], module: camillalib::alsadevice
Dec 04 15:18:26.632 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:18:36.659 DEBG Current buffer level: 8213.706382978724, corrected capture rate: 99.999453125%, module: camillalib::audiodevice
Dec 04 15:18:36.659 DEBG Playback buffer level: 8213.706382978724, signal rms: [-65.06804, -65.305565, -71.827866, -1000.0, -1000.0, -1000.0, -62.06804, -62.305565], module: camillalib::alsadevice
Dec 04 15:18:36.660 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:18:46.687 DEBG Current buffer level: 8269.655319148937, corrected capture rate: 99.99799479166667%, module: camillalib::audiodevice
Dec 04 15:18:46.687 DEBG Playback buffer level: 8269.655319148937, signal rms: [-68.34046, -68.91615, -52.86762, -1000.0, -1000.0, -1000.0, -65.34046, -65.916145], module: camillalib::alsadevice
Dec 04 15:18:46.687 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:18:56.712 DEBG Current buffer level: 8248.051063829787, corrected capture rate: 99.99854166666667%, module: camillalib::audiodevice
Dec 04 15:18:56.713 DEBG Playback buffer level: 8248.051063829787, signal rms: [-59.086792, -60.191326, -69.669945, -1000.0, -1000.0, -1000.0, -56.08679, -57.19133], module: camillalib::alsadevice
Dec 04 15:18:56.713 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:19:06.739 DEBG Current buffer level: 8283.182978723404, corrected capture rate: 99.99763020833333%, module: camillalib::audiodevice
Dec 04 15:19:06.739 DEBG Playback buffer level: 8283.182978723404, signal rms: [-64.33009, -64.280235, -49.196564, -1000.0, -1000.0, -1000.0, -61.3301, -61.280235], module: camillalib::alsadevice
Dec 04 15:19:06.739 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:19:16.766 DEBG Current buffer level: 8290.872340425532, corrected capture rate: 99.99744791666667%, module: camillalib::audiodevice
Dec 04 15:19:16.767 DEBG Playback buffer level: 8290.872340425532, signal rms: [-62.775993, -63.46365, -44.410435, -1000.0, -1000.0, -1000.0, -59.775997, -60.463646], module: camillalib::alsadevice
Dec 04 15:19:16.767 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:19:26.792 DEBG Current buffer level: 8345.60425531915, corrected capture rate: 99.996015625%, module: camillalib::audiodevice
Dec 04 15:19:26.792 DEBG Playback buffer level: 8345.60425531915, signal rms: [-63.363205, -64.1314, -44.9716, -1000.0, -1000.0, -1000.0, -60.363205, -61.131397], module: camillalib::alsadevice
Dec 04 15:19:26.792 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:19:36.819 DEBG Current buffer level: 8123.944680851064, corrected capture rate: 100.001796875%, module: camillalib::audiodevice
Dec 04 15:19:36.819 DEBG Playback buffer level: 8123.944680851064, signal rms: [-65.53741, -67.98396, -47.90424, -1000.0, -1000.0, -1000.0, -62.537407, -64.98397], module: camillalib::alsadevice
Dec 04 15:19:36.820 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:19:46.847 DEBG Current buffer level: 8078.617021276596, corrected capture rate: 100.00296875000001%, module: camillalib::audiodevice
Dec 04 15:19:46.847 DEBG Playback buffer level: 8078.617021276596, signal rms: [-66.99967, -69.48874, -51.395264, -1000.0, -1000.0, -1000.0, -63.999672, -66.48874], module: camillalib::alsadevice
Dec 04 15:19:46.848 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:19:56.872 DEBG Current buffer level: 8371.60425531915, corrected capture rate: 99.99533854166667%, module: camillalib::audiodevice
Dec 04 15:19:56.873 DEBG Playback buffer level: 8371.60425531915, signal rms: [-63.825687, -69.003456, -56.71659, -1000.0, -1000.0, -1000.0, -60.825687, -66.003456], module: camillalib::alsadevice
Dec 04 15:19:56.873 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:20:06.899 DEBG Current buffer level: 8287.072340425531, corrected capture rate: 99.99752604166666%, module: camillalib::audiodevice
Dec 04 15:20:06.899 DEBG Playback buffer level: 8287.072340425531, signal rms: [-67.37958, -68.41882, -52.123093, -1000.0, -1000.0, -1000.0, -64.37957, -65.41882], module: camillalib::alsadevice
Dec 04 15:20:06.899 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:20:16.923 DEBG Current buffer level: 8154.872340425532, corrected capture rate: 100.00098958333335%, module: camillalib::audiodevice
Dec 04 15:20:16.923 DEBG Playback buffer level: 8154.872340425532, signal rms: [-73.96264, -72.65262, -59.608196, -1000.0, -1000.0, -1000.0, -70.96265, -69.65262], module: camillalib::alsadevice
Dec 04 15:20:16.923 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:20:26.955 DEBG Current buffer level: 8167.876595744681, corrected capture rate: 100.00065104166667%, module: camillalib::audiodevice
Dec 04 15:20:26.955 DEBG Playback buffer level: 8167.876595744681, signal rms: [-69.63848, -69.764694, -56.609226, -1000.0, -1000.0, -1000.0, -66.63848, -66.764694], module: camillalib::alsadevice
Dec 04 15:20:26.955 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:20:36.980 DEBG Current buffer level: 8166.446808510638, corrected capture rate: 100.00067708333333%, module: camillalib::audiodevice
Dec 04 15:20:36.981 DEBG Playback buffer level: 8166.446808510638, signal rms: [-67.71499, -68.42326, -55.203575, -1000.0, -1000.0, -1000.0, -64.71499, -65.42326], module: camillalib::alsadevice
Dec 04 15:20:36.981 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:20:47.007 DEBG Current buffer level: 8183.336170212766, corrected capture rate: 100.000234375%, module: camillalib::audiodevice
Dec 04 15:20:47.007 DEBG Playback buffer level: 8183.336170212766, signal rms: [-69.982025, -69.043884, -51.310635, -1000.0, -1000.0, -1000.0, -66.982025, -66.043884], module: camillalib::alsadevice
Dec 04 15:20:47.007 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:20:57.031 DEBG Current buffer level: 8431, corrected capture rate: 99.99377604166668%, module: camillalib::audiodevice
Dec 04 15:20:57.032 DEBG Playback buffer level: 8431, signal rms: [-63.36302, -63.230278, -54.81195, -1000.0, -1000.0, -1000.0, -60.363026, -60.230274], module: camillalib::alsadevice
Dec 04 15:20:57.032 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:21:07.059 DEBG Current buffer level: 8254.553191489362, corrected capture rate: 99.99838541666666%, module: camillalib::audiodevice
Dec 04 15:21:07.060 DEBG Playback buffer level: 8254.553191489362, signal rms: [-67.35917, -66.2535, -52.917465, -1000.0, -1000.0, -1000.0, -64.35916, -63.2535], module: camillalib::alsadevice
Dec 04 15:21:07.060 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:21:17.086 DEBG Current buffer level: 8251.672340425532, corrected capture rate: 99.99846354166667%, module: camillalib::audiodevice
Dec 04 15:21:17.086 DEBG Playback buffer level: 8251.672340425532, signal rms: [-63.34311, -63.50593, -53.857574, -1000.0, -1000.0, -1000.0, -60.343113, -60.505928], module: camillalib::alsadevice
Dec 04 15:21:17.087 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:21:27.115 DEBG Current buffer level: 8287.008510638298, corrected capture rate: 99.99752604166666%, module: camillalib::audiodevice
Dec 04 15:21:27.116 DEBG Playback buffer level: 8287.008510638298, signal rms: [-63.50613, -64.28696, -58.961082, -1000.0, -1000.0, -1000.0, -60.506134, -61.286957], module: camillalib::alsadevice
Dec 04 15:21:27.116 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:21:37.135 DEBG Current buffer level: 8268.817021276596, corrected capture rate: 99.99802083333333%, module: camillalib::audiodevice
Dec 04 15:21:37.135 DEBG Playback buffer level: 8268.817021276596, signal rms: [-68.920586, -69.050705, -56.619392, -1000.0, -1000.0, -1000.0, -65.92059, -66.050705], module: camillalib::alsadevice
Dec 04 15:21:37.135 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:21:47.167 DEBG Current buffer level: 8316.553191489362, corrected capture rate: 99.99677083333334%, module: camillalib::audiodevice
Dec 04 15:21:47.167 DEBG Playback buffer level: 8316.553191489362, signal rms: [-63.990158, -62.398865, -56.243134, -1000.0, -1000.0, -1000.0, -60.990158, -59.39886], module: camillalib::alsadevice
Dec 04 15:21:47.167 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:21:57.195 DEBG Current buffer level: 8384.92340425532, corrected capture rate: 99.995%, module: camillalib::audiodevice
Dec 04 15:21:57.196 DEBG Playback buffer level: 8384.92340425532, signal rms: [-66.205, -64.40686, -59.235615, -1000.0, -1000.0, -1000.0, -63.204998, -61.40686], module: camillalib::alsadevice
Dec 04 15:21:57.196 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:22:07.223 DEBG Current buffer level: 8086.178723404255, corrected capture rate: 100.00276041666667%, module: camillalib::audiodevice
Dec 04 15:22:07.223 DEBG Playback buffer level: 8086.178723404255, signal rms: [-66.66587, -67.23878, -59.399742, -1000.0, -1000.0, -1000.0, -63.66588, -64.23877], module: camillalib::alsadevice
Dec 04 15:22:07.223 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:22:17.248 DEBG Current buffer level: 8128.012765957446, corrected capture rate: 100.00166666666668%, module: camillalib::audiodevice
Dec 04 15:22:17.249 DEBG Playback buffer level: 8128.012765957446, signal rms: [-65.36652, -66.91296, -60.710873, -1000.0, -1000.0, -1000.0, -62.366524, -63.91296], module: camillalib::alsadevice
Dec 04 15:22:17.249 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:22:27.275 DEBG Current buffer level: 8110.497872340426, corrected capture rate: 100.00213541666668%, module: camillalib::audiodevice
Dec 04 15:22:27.276 DEBG Playback buffer level: 8110.497872340426, signal rms: [-64.95319, -64.071976, -62.53662, -1000.0, -1000.0, -1000.0, -61.953194, -61.07197], module: camillalib::alsadevice
Dec 04 15:22:27.276 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:22:37.300 DEBG Current buffer level: 8396.919148936171, corrected capture rate: 99.9946875%, module: camillalib::audiodevice
Dec 04 15:22:37.301 DEBG Playback buffer level: 8396.919148936171, signal rms: [-63.158894, -63.31696, -46.617706, -1000.0, -1000.0, -1000.0, -60.158897, -60.31696], module: camillalib::alsadevice
Dec 04 15:22:37.301 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:22:47.328 DEBG Current buffer level: 8358.008510638298, corrected capture rate: 99.99567708333333%, module: camillalib::audiodevice
Dec 04 15:22:47.329 DEBG Playback buffer level: 8358.008510638298, signal rms: [-62.761375, -62.628918, -58.96502, -1000.0, -1000.0, -1000.0, -59.761375, -59.628914], module: camillalib::alsadevice
Dec 04 15:22:47.329 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:22:57.356 DEBG Current buffer level: 8230.097872340426, corrected capture rate: 99.99901041666666%, module: camillalib::audiodevice
Dec 04 15:22:57.356 DEBG Playback buffer level: 8230.097872340426, signal rms: [-66.537834, -68.45832, -47.410713, -1000.0, -1000.0, -1000.0, -63.53783, -65.45832], module: camillalib::alsadevice
Dec 04 15:22:57.356 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:23:07.383 DEBG Current buffer level: 8284.136170212765, corrected capture rate: 99.99760416666666%, module: camillalib::audiodevice
Dec 04 15:23:07.383 DEBG Playback buffer level: 8284.136170212765, signal rms: [-76.337006, -73.069084, -66.05555, -1000.0, -1000.0, -1000.0, -73.337006, -70.069084], module: camillalib::alsadevice
Dec 04 15:23:07.383 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:23:17.402 DEBG Current buffer level: 8267.391489361702, corrected capture rate: 99.998046875%, module: camillalib::audiodevice
Dec 04 15:23:17.403 DEBG Playback buffer level: 8267.391489361702, signal rms: [-75.99461, -85.19897, -81.37152, -1000.0, -1000.0, -1000.0, -72.994606, -82.19896], module: camillalib::alsadevice
Dec 04 15:23:17.403 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:23:27.434 DEBG Current buffer level: 8260.846808510638, corrected capture rate: 99.99822916666666%, module: camillalib::audiodevice
Dec 04 15:23:27.435 DEBG Playback buffer level: 8260.846808510638, signal rms: [-75.200775, -73.95778, -80.200714, -1000.0, -1000.0, -1000.0, -72.200775, -70.95778], module: camillalib::alsadevice
Dec 04 15:23:27.435 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:23:37.463 DEBG Current buffer level: 8305.446808510638, corrected capture rate: 99.99705729166666%, module: camillalib::audiodevice
Dec 04 15:23:37.463 DEBG Playback buffer level: 8305.446808510638, signal rms: [-62.724552, -63.92894, -60.215374, -1000.0, -1000.0, -1000.0, -59.72455, -60.928936], module: camillalib::alsadevice
Dec 04 15:23:37.464 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:23:47.487 DEBG Current buffer level: 8281.92340425532, corrected capture rate: 99.99768229166666%, module: camillalib::audiodevice
Dec 04 15:23:47.488 DEBG Playback buffer level: 8281.92340425532, signal rms: [-65.06275, -65.10217, -86.42267, -1000.0, -1000.0, -1000.0, -62.062756, -62.102173], module: camillalib::alsadevice
Dec 04 15:23:47.488 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:23:57.516 DEBG Current buffer level: 8256.863829787235, corrected capture rate: 99.99833333333333%, module: camillalib::audiodevice
Dec 04 15:23:57.516 DEBG Playback buffer level: 8256.863829787235, signal rms: [-67.35402, -68.22613, -52.157, -1000.0, -1000.0, -1000.0, -64.35402, -65.22613], module: camillalib::alsadevice
Dec 04 15:23:57.517 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:24:07.543 DEBG Current buffer level: 8050.093617021276, corrected capture rate: 100.00369791666665%, module: camillalib::audiodevice
Dec 04 15:24:07.543 DEBG Playback buffer level: 8050.093617021276, signal rms: [-62.018623, -63.023834, -86.65665, -1000.0, -1000.0, -1000.0, -59.018623, -60.023834], module: camillalib::alsadevice
Dec 04 15:24:07.543 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:24:17.564 DEBG Current buffer level: 8215.374468085107, corrected capture rate: 99.99940104166667%, module: camillalib::audiodevice
Dec 04 15:24:17.564 DEBG Playback buffer level: 8215.374468085107, signal rms: [-67.51318, -67.26517, -48.96391, -1000.0, -1000.0, -1000.0, -64.513176, -64.26517], module: camillalib::alsadevice
Dec 04 15:24:17.564 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:24:27.594 DEBG Current buffer level: 8387.859574468084, corrected capture rate: 99.994921875%, module: camillalib::audiodevice
Dec 04 15:24:27.595 DEBG Playback buffer level: 8387.859574468084, signal rms: [-63.749344, -65.19008, -59.207996, -1000.0, -1000.0, -1000.0, -60.74934, -62.19008], module: camillalib::alsadevice
Dec 04 15:24:27.595 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:24:37.623 DEBG Current buffer level: 8263.812765957447, corrected capture rate: 99.99815104166667%, module: camillalib::audiodevice
Dec 04 15:24:37.624 DEBG Playback buffer level: 8263.812765957447, signal rms: [-71.592, -71.92695, -66.45504, -1000.0, -1000.0, -1000.0, -68.592, -68.926956], module: camillalib::alsadevice
Dec 04 15:24:37.624 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:24:47.651 DEBG Current buffer level: 8156.2, corrected capture rate: 100.0009375%, module: camillalib::audiodevice
Dec 04 15:24:47.651 DEBG Playback buffer level: 8156.2, signal rms: [-69.53534, -70.122406, -52.3293, -1000.0, -1000.0, -1000.0, -66.53534, -67.122406], module: camillalib::alsadevice
Dec 04 15:24:47.652 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:24:57.675 DEBG Current buffer level: 8153.272340425532, corrected capture rate: 100.001015625%, module: camillalib::audiodevice
Dec 04 15:24:57.676 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:24:57.676 DEBG Playback buffer level: 8153.272340425532, signal rms: [-65.79248, -66.43189, -69.6407, -1000.0, -1000.0, -1000.0, -62.792477, -63.43189], module: camillalib::alsadevice
Dec 04 15:25:07.703 DEBG Current buffer level: 8208.804255319148, corrected capture rate: 99.99958333333333%, module: camillalib::audiodevice
Dec 04 15:25:07.703 DEBG Playback buffer level: 8208.804255319148, signal rms: [-62.81765, -63.708908, -49.319607, -1000.0, -1000.0, -1000.0, -59.81765, -60.708908], module: camillalib::alsadevice
Dec 04 15:25:07.703 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:25:17.731 DEBG Current buffer level: 8232.659574468085, corrected capture rate: 99.99895833333333%, module: camillalib::audiodevice
Dec 04 15:25:17.731 DEBG Playback buffer level: 8232.659574468085, signal rms: [-62.971466, -64.28344, -60.038334, -1000.0, -1000.0, -1000.0, -59.97147, -61.28344], module: camillalib::alsadevice
Dec 04 15:25:17.731 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:25:27.756 DEBG Current buffer level: 8229.92340425532, corrected capture rate: 99.99903645833334%, module: camillalib::audiodevice
Dec 04 15:25:27.757 DEBG Playback buffer level: 8229.92340425532, signal rms: [-67.90683, -69.723175, -70.3714, -1000.0, -1000.0, -1000.0, -64.90683, -66.723175], module: camillalib::alsadevice
Dec 04 15:25:27.757 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:25:37.782 DEBG Current buffer level: 8206.83829787234, corrected capture rate: 99.99963541666666%, module: camillalib::audiodevice
Dec 04 15:25:37.783 DEBG Playback buffer level: 8206.83829787234, signal rms: [-60.73507, -61.763374, -48.511616, -1000.0, -1000.0, -1000.0, -57.73507, -58.763374], module: camillalib::alsadevice
Dec 04 15:25:37.783 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:25:47.811 DEBG Current buffer level: 8221.08510638298, corrected capture rate: 99.99924479166667%, module: camillalib::audiodevice
Dec 04 15:25:47.811 DEBG Playback buffer level: 8221.08510638298, signal rms: [-63.086845, -62.488266, -66.33323, -1000.0, -1000.0, -1000.0, -60.086845, -59.488262], module: camillalib::alsadevice
Dec 04 15:25:47.811 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:25:57.835 DEBG Current buffer level: 8246.038297872341, corrected capture rate: 99.99859375%, module: camillalib::audiodevice
Dec 04 15:25:57.835 DEBG Playback buffer level: 8246.038297872341, signal rms: [-60.87795, -61.508385, -52.461205, -1000.0, -1000.0, -1000.0, -57.877945, -58.508385], module: camillalib::alsadevice
Dec 04 15:25:57.835 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:26:07.862 DEBG Current buffer level: 8365.617021276596, corrected capture rate: 99.99549479166666%, module: camillalib::audiodevice
Dec 04 15:26:07.862 DEBG Playback buffer level: 8365.617021276596, signal rms: [-62.942577, -64.8894, -59.175907, -1000.0, -1000.0, -1000.0, -59.94258, -61.8894], module: camillalib::alsadevice
Dec 04 15:26:07.863 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:26:17.891 DEBG Current buffer level: 8351.16170212766, corrected capture rate: 99.995859375%, module: camillalib::audiodevice
Dec 04 15:26:17.891 DEBG Playback buffer level: 8351.16170212766, signal rms: [-62.550335, -62.85896, -70.32548, -1000.0, -1000.0, -1000.0, -59.55033, -59.858955], module: camillalib::alsadevice
Dec 04 15:26:17.891 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:26:27.915 DEBG Current buffer level: 8306.378723404256, corrected capture rate: 99.99703125%, module: camillalib::audiodevice
Dec 04 15:26:27.915 DEBG Playback buffer level: 8306.378723404256, signal rms: [-63.14188, -63.500526, -49.547493, -1000.0, -1000.0, -1000.0, -60.141876, -60.500526], module: camillalib::alsadevice
Dec 04 15:26:27.916 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:26:37.942 DEBG Current buffer level: 8395.489361702128, corrected capture rate: 99.99471354166667%, module: camillalib::audiodevice
Dec 04 15:26:37.943 DEBG Playback buffer level: 8395.489361702128, signal rms: [-61.898933, -63.290474, -49.28625, -1000.0, -1000.0, -1000.0, -58.898933, -60.29047], module: camillalib::alsadevice
Dec 04 15:26:37.943 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:26:47.971 DEBG Current buffer level: 8200.79574468085, corrected capture rate: 99.99979166666667%, module: camillalib::audiodevice
Dec 04 15:26:47.971 DEBG Playback buffer level: 8200.79574468085, signal rms: [-61.830994, -62.269226, -54.030495, -1000.0, -1000.0, -1000.0, -58.83099, -59.269226], module: camillalib::alsadevice
Dec 04 15:26:47.971 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:26:57.999 DEBG Current buffer level: 8202.970212765957, corrected capture rate: 99.99973958333334%, module: camillalib::audiodevice
Dec 04 15:26:57.999 DEBG Playback buffer level: 8202.970212765957, signal rms: [-64.97859, -65.31335, -56.77894, -1000.0, -1000.0, -1000.0, -61.97859, -62.313343], module: camillalib::alsadevice
Dec 04 15:26:58.000 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:27:08.023 DEBG Current buffer level: 8189.582978723404, corrected capture rate: 100.000078125%, module: camillalib::audiodevice
Dec 04 15:27:08.024 DEBG Playback buffer level: 8189.582978723404, signal rms: [-67.2816, -66.70665, -54.991077, -1000.0, -1000.0, -1000.0, -64.28161, -63.70665], module: camillalib::alsadevice
Dec 04 15:27:08.024 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:27:18.051 DEBG Current buffer level: 8247.446808510638, corrected capture rate: 99.99856770833333%, module: camillalib::audiodevice
Dec 04 15:27:18.051 DEBG Playback buffer level: 8247.446808510638, signal rms: [-65.77286, -64.78598, -48.882454, -1000.0, -1000.0, -1000.0, -62.77286, -61.785973], module: camillalib::alsadevice
Dec 04 15:27:18.052 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:27:28.079 DEBG Current buffer level: 8231.021276595744, corrected capture rate: 99.998984375%, module: camillalib::audiodevice
Dec 04 15:27:28.079 DEBG Playback buffer level: 8231.021276595744, signal rms: [-104.30415, -103.69038, -88.69285, -1000.0, -1000.0, -1000.0, -101.30415, -100.69038], module: camillalib::alsadevice
Dec 04 15:27:28.080 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:27:38.104 DEBG Current buffer level: 8233.16170212766, corrected capture rate: 99.99893229166666%, module: camillalib::audiodevice
Dec 04 15:27:38.104 DEBG Playback buffer level: 8233.16170212766, signal rms: [-100.59104, -104.03787, -85.26437, -1000.0, -1000.0, -1000.0, -97.591034, -101.03787], module: camillalib::alsadevice
Dec 04 15:27:38.105 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:27:48.131 DEBG Current buffer level: 8316.314893617022, corrected capture rate: 99.99677083333334%, module: camillalib::audiodevice
Dec 04 15:27:48.131 DEBG Playback buffer level: 8316.314893617022, signal rms: [-78.36711, -77.28708, -72.318565, -1000.0, -1000.0, -1000.0, -75.36711, -74.28708], module: camillalib::alsadevice
Dec 04 15:27:48.131 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:27:58.159 DEBG Current buffer level: 8281.131914893616, corrected capture rate: 99.99768229166666%, module: camillalib::audiodevice
Dec 04 15:27:58.159 DEBG Playback buffer level: 8281.131914893616, signal rms: [-70.426285, -71.57831, -57.27429, -1000.0, -1000.0, -1000.0, -67.426285, -68.57831], module: camillalib::alsadevice
Dec 04 15:27:58.159 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:28:08.183 DEBG Current buffer level: 8349.080851063829, corrected capture rate: 99.99591145833332%, module: camillalib::audiodevice
Dec 04 15:28:08.183 DEBG Playback buffer level: 8349.080851063829, signal rms: [-67.99716, -67.80245, -63.566853, -1000.0, -1000.0, -1000.0, -64.99717, -64.80245], module: camillalib::alsadevice
Dec 04 15:28:08.183 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:28:18.211 DEBG Current buffer level: 8270.67659574468, corrected capture rate: 99.99796875%, module: camillalib::audiodevice
Dec 04 15:28:18.211 DEBG Playback buffer level: 8270.67659574468, signal rms: [-70.003654, -70.95285, -67.762634, -1000.0, -1000.0, -1000.0, -67.003654, -67.95285], module: camillalib::alsadevice
Dec 04 15:28:18.212 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:28:28.239 DEBG Current buffer level: 8142.668085106383, corrected capture rate: 100.00130208333333%, module: camillalib::audiodevice
Dec 04 15:28:28.239 DEBG Playback buffer level: 8142.668085106383, signal rms: [-67.11879, -68.84967, -59.733284, -1000.0, -1000.0, -1000.0, -64.11879, -65.84967], module: camillalib::alsadevice
Dec 04 15:28:28.239 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:28:38.267 DEBG Current buffer level: 8095.561702127659, corrected capture rate: 100.00252604166666%, module: camillalib::audiodevice
Dec 04 15:28:38.268 DEBG Playback buffer level: 8095.561702127659, signal rms: [-66.598, -73.039635, -58.878532, -1000.0, -1000.0, -1000.0, -63.598003, -70.039635], module: camillalib::alsadevice
Dec 04 15:28:38.268 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:28:48.292 DEBG Current buffer level: 8197.748936170212, corrected capture rate: 99.99986979166667%, module: camillalib::audiodevice
Dec 04 15:28:48.293 DEBG Playback buffer level: 8197.748936170212, signal rms: [-71.82633, -75.079994, -66.146225, -1000.0, -1000.0, -1000.0, -68.82633, -72.079994], module: camillalib::alsadevice
Dec 04 15:28:48.293 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:28:58.319 DEBG Current buffer level: 8423.68085106383, corrected capture rate: 99.993984375%, module: camillalib::audiodevice
Dec 04 15:28:58.319 DEBG Playback buffer level: 8423.68085106383, signal rms: [-65.01842, -68.46185, -49.636703, -1000.0, -1000.0, -1000.0, -62.018417, -65.46185], module: camillalib::alsadevice
Dec 04 15:28:58.319 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:29:08.347 DEBG Current buffer level: 8247.595744680852, corrected capture rate: 99.99856770833333%, module: camillalib::audiodevice
Dec 04 15:29:08.347 DEBG Playback buffer level: 8247.595744680852, signal rms: [-69.51938, -70.05639, -57.628292, -1000.0, -1000.0, -1000.0, -66.51938, -67.05639], module: camillalib::alsadevice
Dec 04 15:29:08.347 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:29:18.372 DEBG Current buffer level: 8179.2, corrected capture rate: 100.00033854166665%, module: camillalib::audiodevice
Dec 04 15:29:18.373 DEBG Playback buffer level: 8179.2, signal rms: [-73.28088, -74.912094, -73.67944, -1000.0, -1000.0, -1000.0, -70.28089, -71.912094], module: camillalib::alsadevice
Dec 04 15:29:18.373 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:29:28.399 DEBG Current buffer level: 8144.948936170213, corrected capture rate: 100.00125%, module: camillalib::audiodevice
Dec 04 15:29:28.399 DEBG Playback buffer level: 8144.948936170213, signal rms: [-79.22872, -76.00723, -86.155136, -1000.0, -1000.0, -1000.0, -76.22872, -73.00723], module: camillalib::alsadevice
Dec 04 15:29:28.399 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:29:38.427 DEBG Current buffer level: 8153.570212765958, corrected capture rate: 100.001015625%, module: camillalib::audiodevice
Dec 04 15:29:38.427 DEBG Playback buffer level: 8153.570212765958, signal rms: [-74.29333, -79.215324, -78.85567, -1000.0, -1000.0, -1000.0, -71.29333, -76.215324], module: camillalib::alsadevice
Dec 04 15:29:38.428 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:29:48.452 DEBG Current buffer level: 8257.804255319148, corrected capture rate: 99.99830729166666%, module: camillalib::audiodevice
Dec 04 15:29:48.453 DEBG Playback buffer level: 8257.804255319148, signal rms: [-74.911674, -75.65263, -62.996254, -1000.0, -1000.0, -1000.0, -71.911674, -72.65263], module: camillalib::alsadevice
Dec 04 15:29:48.453 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:29:58.479 DEBG Current buffer level: 8259.685106382978, corrected capture rate: 99.99825520833333%, module: camillalib::audiodevice
Dec 04 15:29:58.479 DEBG Playback buffer level: 8259.685106382978, signal rms: [-68.37598, -70.01855, -59.213585, -1000.0, -1000.0, -1000.0, -65.375984, -67.01854], module: camillalib::alsadevice
Dec 04 15:29:58.480 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:30:08.507 DEBG Current buffer level: 8267.919148936171, corrected capture rate: 99.998046875%, module: camillalib::audiodevice
Dec 04 15:30:08.507 DEBG Playback buffer level: 8267.919148936171, signal rms: [-68.442856, -71.20925, -62.01094, -1000.0, -1000.0, -1000.0, -65.442856, -68.20925], module: camillalib::alsadevice
Dec 04 15:30:08.508 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:30:18.527 DEBG Current buffer level: 8314.348936170212, corrected capture rate: 99.99682291666666%, module: camillalib::audiodevice
Dec 04 15:30:18.528 DEBG Playback buffer level: 8314.348936170212, signal rms: [-71.37126, -71.59334, -53.59596, -1000.0, -1000.0, -1000.0, -68.37126, -68.59334], module: camillalib::alsadevice
Dec 04 15:30:18.528 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:30:28.559 DEBG Current buffer level: 8300.897872340425, corrected capture rate: 99.9971875%, module: camillalib::audiodevice
Dec 04 15:30:28.560 DEBG Playback buffer level: 8300.897872340425, signal rms: [-68.06548, -68.688614, -62.644997, -1000.0, -1000.0, -1000.0, -65.06548, -65.688614], module: camillalib::alsadevice
Dec 04 15:30:28.560 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:30:38.587 DEBG Current buffer level: 8285.885106382979, corrected capture rate: 99.997578125%, module: camillalib::audiodevice
Dec 04 15:30:38.587 DEBG Playback buffer level: 8285.885106382979, signal rms: [-66.062256, -66.41919, -65.710846, -1000.0, -1000.0, -1000.0, -63.062256, -63.419186], module: camillalib::alsadevice
Dec 04 15:30:38.588 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:30:48.612 DEBG Current buffer level: 8311.148936170213, corrected capture rate: 99.99690104166666%, module: camillalib::audiodevice
Dec 04 15:30:48.613 DEBG Playback buffer level: 8311.148936170213, signal rms: [-75.869644, -75.71728, -83.325035, -1000.0, -1000.0, -1000.0, -72.869644, -72.71728], module: camillalib::alsadevice
Dec 04 15:30:48.613 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:30:58.639 DEBG Current buffer level: 8321.8, corrected capture rate: 99.996640625%, module: camillalib::audiodevice
Dec 04 15:30:58.639 DEBG Playback buffer level: 8321.8, signal rms: [-74.34979, -73.978645, -83.21405, -1000.0, -1000.0, -1000.0, -71.34979, -70.97865], module: camillalib::alsadevice
Dec 04 15:30:58.640 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:31:08.667 DEBG Current buffer level: 8216.127659574468, corrected capture rate: 99.999375%, module: camillalib::audiodevice
Dec 04 15:31:08.667 DEBG Playback buffer level: 8216.127659574468, signal rms: [-69.4711, -68.626434, -63.80068, -1000.0, -1000.0, -1000.0, -66.4711, -65.626434], module: camillalib::alsadevice
Dec 04 15:31:08.668 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:31:18.695 DEBG Current buffer level: 8193.931914893617, corrected capture rate: 99.99997395833333%, module: camillalib::audiodevice
Dec 04 15:31:18.695 DEBG Playback buffer level: 8193.931914893617, signal rms: [-69.59276, -70.127625, -64.77634, -1000.0, -1000.0, -1000.0, -66.592766, -67.127625], module: camillalib::alsadevice
Dec 04 15:31:18.696 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:31:28.720 DEBG Current buffer level: 8190.902127659574, corrected capture rate: 100.00005208333333%, module: camillalib::audiodevice
Dec 04 15:31:28.721 DEBG Playback buffer level: 8190.902127659574, signal rms: [-78.59231, -81.18494, -71.8797, -1000.0, -1000.0, -1000.0, -75.59231, -78.184944], module: camillalib::alsadevice
Dec 04 15:31:28.721 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:31:38.746 DEBG Current buffer level: 8270.834042553191, corrected capture rate: 99.99796875%, module: camillalib::audiodevice
Dec 04 15:31:38.747 DEBG Playback buffer level: 8270.834042553191, signal rms: [-77.10807, -78.09186, -62.75974, -1000.0, -1000.0, -1000.0, -74.10807, -75.09186], module: camillalib::alsadevice
Dec 04 15:31:38.747 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:31:48.775 DEBG Current buffer level: 8200.293617021276, corrected capture rate: 99.99979166666667%, module: camillalib::audiodevice
Dec 04 15:31:48.775 DEBG Playback buffer level: 8200.293617021276, signal rms: [-65.86903, -66.47307, -70.69924, -1000.0, -1000.0, -1000.0, -62.869034, -63.473072], module: camillalib::alsadevice
Dec 04 15:31:48.775 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:31:58.799 DEBG Current buffer level: 8234.953191489361, corrected capture rate: 99.99890624999999%, module: camillalib::audiodevice
Dec 04 15:31:58.800 DEBG Playback buffer level: 8234.953191489361, signal rms: [-64.73434, -70.62047, -65.10056, -1000.0, -1000.0, -1000.0, -61.734337, -67.62047], module: camillalib::alsadevice
Dec 04 15:31:58.800 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:32:08.828 DEBG Current buffer level: 8270.778723404255, corrected capture rate: 99.99796875%, module: camillalib::audiodevice
Dec 04 15:32:08.828 DEBG Playback buffer level: 8270.778723404255, signal rms: [-65.420525, -66.13114, -56.865463, -1000.0, -1000.0, -1000.0, -62.420532, -63.13114], module: camillalib::alsadevice
Dec 04 15:32:08.829 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:32:18.855 DEBG Current buffer level: 8329.246808510637, corrected capture rate: 99.99643229166666%, module: camillalib::audiodevice
Dec 04 15:32:18.855 DEBG Playback buffer level: 8329.246808510637, signal rms: [-82.709915, -81.74559, -75.64341, -1000.0, -1000.0, -1000.0, -79.709915, -78.74558], module: camillalib::alsadevice
Dec 04 15:32:18.855 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:32:28.879 DEBG Current buffer level: 8309.668085106383, corrected capture rate: 99.996953125%, module: camillalib::audiodevice
Dec 04 15:32:28.880 DEBG Playback buffer level: 8309.668085106383, signal rms: [-65.69411, -66.550255, -49.648766, -1000.0, -1000.0, -1000.0, -62.6941, -63.55026], module: camillalib::alsadevice
Dec 04 15:32:28.880 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:32:38.905 DEBG Current buffer level: 8307.497872340426, corrected capture rate: 99.99700520833333%, module: camillalib::audiodevice
Dec 04 15:32:38.905 DEBG Playback buffer level: 8307.497872340426, signal rms: [-70.023834, -70.86747, -67.44035, -1000.0, -1000.0, -1000.0, -67.02384, -67.86747], module: camillalib::alsadevice
Dec 04 15:32:38.905 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:32:48.932 DEBG Current buffer level: 8060.646808510638, corrected capture rate: 100.0034375%, module: camillalib::audiodevice
Dec 04 15:32:48.932 DEBG Playback buffer level: 8060.646808510638, signal rms: [-90.75307, -91.11174, -79.53797, -1000.0, -1000.0, -1000.0, -87.75307, -88.11173], module: camillalib::alsadevice
Dec 04 15:32:48.933 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:32:58.959 DEBG Current buffer level: 8287.370212765958, corrected capture rate: 99.99752604166666%, module: camillalib::audiodevice
Dec 04 15:32:58.960 DEBG Playback buffer level: 8287.370212765958, signal rms: [-124.43736, -122.87277, -106.584274, -1000.0, -1000.0, -1000.0, -121.43736, -119.87277], module: camillalib::alsadevice
Dec 04 15:32:58.960 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:33:08.987 DEBG Current buffer level: 8418.736170212766, corrected capture rate: 99.99411458333334%, module: camillalib::audiodevice
Dec 04 15:33:08.987 DEBG Playback buffer level: 8418.736170212766, signal rms: [-92.7126, -96.49494, -77.64891, -1000.0, -1000.0, -1000.0, -89.7126, -93.49494], module: camillalib::alsadevice
Dec 04 15:33:08.987 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:33:19.014 DEBG Current buffer level: 8145.374468085106, corrected capture rate: 100.00122395833333%, module: camillalib::audiodevice
Dec 04 15:33:19.015 DEBG Playback buffer level: 8145.374468085106, signal rms: [-80.66178, -80.22009, -87.191696, -1000.0, -1000.0, -1000.0, -77.66179, -77.22009], module: camillalib::alsadevice
Dec 04 15:33:19.015 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:33:29.044 DEBG Current buffer level: 8147.063829787234, corrected capture rate: 100.001171875%, module: camillalib::audiodevice
Dec 04 15:33:29.045 DEBG Playback buffer level: 8147.063829787234, signal rms: [-91.33441, -87.40152, -82.76044, -1000.0, -1000.0, -1000.0, -88.33442, -84.40152], module: camillalib::alsadevice
Dec 04 15:33:29.045 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:33:39.067 DEBG Current buffer level: 8119.059574468085, corrected capture rate: 100.00190104166666%, module: camillalib::audiodevice
Dec 04 15:33:39.067 DEBG Playback buffer level: 8119.059574468085, signal rms: [-75.123665, -74.8192, -62.518074, -1000.0, -1000.0, -1000.0, -72.12366, -71.8192], module: camillalib::alsadevice
Dec 04 15:33:39.067 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:33:49.095 DEBG Current buffer level: 8287.089361702128, corrected capture rate: 99.99752604166666%, module: camillalib::audiodevice
Dec 04 15:33:49.095 DEBG Playback buffer level: 8287.089361702128, signal rms: [-85.22569, -86.24696, -84.49532, -1000.0, -1000.0, -1000.0, -82.22569, -83.24696], module: camillalib::alsadevice
Dec 04 15:33:49.096 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:33:59.124 DEBG Current buffer level: 8302.765957446809, corrected capture rate: 99.99713541666667%, module: camillalib::audiodevice
Dec 04 15:33:59.124 DEBG Playback buffer level: 8302.765957446809, signal rms: [-66.92053, -66.3826, -77.4679, -1000.0, -1000.0, -1000.0, -63.920525, -63.3826], module: camillalib::alsadevice
Dec 04 15:33:59.125 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:34:09.148 DEBG Current buffer level: 8217.302127659574, corrected capture rate: 99.99934895833333%, module: camillalib::audiodevice
Dec 04 15:34:09.148 DEBG Playback buffer level: 8217.302127659574, signal rms: [-66.55512, -66.27353, -82.38133, -1000.0, -1000.0, -1000.0, -63.555122, -63.273537], module: camillalib::alsadevice
Dec 04 15:34:09.148 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:34:19.174 DEBG Current buffer level: 8321.88085106383, corrected capture rate: 99.996640625%, module: camillalib::audiodevice
Dec 04 15:34:19.175 DEBG Playback buffer level: 8321.88085106383, signal rms: [-84.081436, -82.19388, -64.91289, -1000.0, -1000.0, -1000.0, -81.081436, -79.19388], module: camillalib::alsadevice
Dec 04 15:34:19.175 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:34:29.204 DEBG Current buffer level: 8275.44255319149, corrected capture rate: 99.99783854166667%, module: camillalib::audiodevice
Dec 04 15:34:29.205 DEBG Playback buffer level: 8275.44255319149, signal rms: [-74.745674, -72.51433, -56.443497, -1000.0, -1000.0, -1000.0, -71.745674, -69.51432], module: camillalib::alsadevice
Dec 04 15:34:29.205 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:34:39.228 DEBG Current buffer level: 8305.663829787234, corrected capture rate: 99.99705729166666%, module: camillalib::audiodevice
Dec 04 15:34:39.228 DEBG Playback buffer level: 8305.663829787234, signal rms: [-71.14594, -70.38571, -51.57395, -1000.0, -1000.0, -1000.0, -68.14595, -67.38571], module: camillalib::alsadevice
Dec 04 15:34:39.229 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:34:49.255 DEBG Current buffer level: 8388.297872340425, corrected capture rate: 99.99489583333333%, module: camillalib::audiodevice
Dec 04 15:34:49.255 DEBG Playback buffer level: 8388.297872340425, signal rms: [-68.15284, -67.5104, -56.37209, -1000.0, -1000.0, -1000.0, -65.15284, -64.51041], module: camillalib::alsadevice
Dec 04 15:34:49.256 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:34:59.283 DEBG Current buffer level: 8262.536170212767, corrected capture rate: 99.99817708333333%, module: camillalib::audiodevice
Dec 04 15:34:59.284 DEBG Playback buffer level: 8262.536170212767, signal rms: [-77.22154, -73.266136, -63.992027, -1000.0, -1000.0, -1000.0, -74.22154, -70.266136], module: camillalib::alsadevice
Dec 04 15:34:59.284 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:35:04.256 DEBG parsed command: Ok(GetMute), module: camillalib::socketserver
Dec 04 15:35:09.311 DEBG Current buffer level: 8108.4595744680855, corrected capture rate: 100.0021875%, module: camillalib::audiodevice
Dec 04 15:35:09.315 DEBG Playback buffer level: 8108.4595744680855, signal rms: [-1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0], module: camillalib::alsadevice
Dec 04 15:35:09.316 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:35:19.336 DEBG Current buffer level: 8337.897872340425, corrected capture rate: 99.99622395833333%, module: camillalib::audiodevice
Dec 04 15:35:19.337 DEBG Playback buffer level: 8337.897872340425, signal rms: [-1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0], module: camillalib::alsadevice
Dec 04 15:35:19.337 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:35:29.362 DEBG Current buffer level: 8388.046808510639, corrected capture rate: 99.99489583333333%, module: camillalib::audiodevice
Dec 04 15:35:29.363 DEBG Playback buffer level: 8388.046808510639, signal rms: [-1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0], module: camillalib::alsadevice
Dec 04 15:35:29.363 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:35:39.388 DEBG Current buffer level: 8411.770212765958, corrected capture rate: 99.994296875%, module: camillalib::audiodevice
Dec 04 15:35:39.388 DEBG Playback buffer level: 8411.770212765958, signal rms: [-1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0], module: camillalib::alsadevice
Dec 04 15:35:39.388 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:35:49.414 DEBG Current buffer level: 8438.63404255319, corrected capture rate: 99.99359375%, module: camillalib::audiodevice
Dec 04 15:35:49.415 DEBG Playback buffer level: 8438.63404255319, signal rms: [-1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0], module: camillalib::alsadevice
Dec 04 15:35:49.415 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:35:59.443 DEBG Current buffer level: 8165.88085106383, corrected capture rate: 100.000703125%, module: camillalib::audiodevice
Dec 04 15:35:59.444 DEBG Playback buffer level: 8165.88085106383, signal rms: [-1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0], module: camillalib::alsadevice
Dec 04 15:35:59.444 DEBG SetSpeed message received, module: camilladsp
Dec 04 15:36:04.384 DEBG Pausing processing, module: camillalib::countertimer
On boot with the soundcard switched off, the status of CamillaDSP is as follows:
Code:
● camilladsp.service - CamillaDSP Daemon
Loaded: loaded (/etc/systemd/system/camilladsp.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) since Sun 2021-12-05 07:40:14 UTC; 304ms ago
Process: 2571 ExecStart=/bin/bash -c /usr/local/bin/camilladsp -a0.0.0.0 -p5000 -g-30 --logfile /usr/local/etc/camilladsp/logs/log$$(date +%FT%H%M).txt -ldebug /usr/local/etc/camilladsp/co>
Main PID: 2571 (code=exited, status=0/SUCCESS)
CPU: 46ms
Code:
ubuntu@ubuntu:~$ sudo systemctl stop camilladsp
ubuntu@ubuntu:~$ sudo systemctl status camilladsp
○ camilladsp.service - CamillaDSP Daemon
Active: inactive (dead) since Sun 2021-12-05 07:42:42 UTC; 2s ago
Process: 3528 ExecStart=/bin/bash -c /usr/local/bin/camilladsp -a0.0.0.0 -p5000 -g-30 --logfile /usr/local/etc/camilladsp/logs/log$$(date +%FT%H%M).txt -ldebug /usr/local/etc/camilladsp/co>
Main PID: 3528 (code=exited, status=0/SUCCESS)
CPU: 48ms
Iff you didn't already, ignore my speculation about the cause for CamillaDSP not stopping when the soundcard is turned off. I got the same behaviour with the standard Unit file - that is, the CamillaDSP service remains active even though the soundcard is switched off.
Positive thing to report is that the step 5 udev instruction works fine. So if I stop the CamillaDSP process manually, then turning the soundcard on restarts the CamillaDSP process correctly.
So just the automatic stopping to resolve.
There should be a playback error after the device disappears. Try disabling pausing on silence, that should force it to continue writing samples to the DAC. And that should trigger the error you need.
Does the log show that captured samples are zero for a while before the courtertimer error? Perhaps the capture thread keeps sending zeros? I do not know what the capture device is in this setup.
Thanks for the replies. I did that, and here's the entire log of starting CamillaDSP, playing something briefly, stopping the music and then turning off the soundcard. The output is the same if I turn off the soundcard before pausing the music:
Code:
Dec 05 13:08:24.206 DEBG Read config file Some("/usr/local/etc/camilladsp/config192XO.yml"), module: camilladsp
Dec 05 13:08:24.208 DEBG Config is valid, module: camilladsp
Dec 05 13:08:24.208 DEBG Start websocket server on 0.0.0.0:5000, module: camillalib::socketserver
Dec 05 13:08:24.208 DEBG Wait for config, module: camilladsp
Dec 05 13:08:24.208 DEBG Config ready, module: camilladsp
Dec 05 13:08:24.208 DEBG Build new pipeline, module: camillalib::filters
Dec 05 13:08:24.208 DEBG Using channels [true, true], module: camilladsp
Dec 05 13:08:24.209 DEBG Build from config, module: camillalib::filters
Dec 05 13:08:24.209 DEBG Buffer frames 16384, module: camillalib::alsadevice
Dec 05 13:08:24.209 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.9981505111904521 b1=-1.9963010223809041 b2=0.9981505111904521, module: camillalib::biquad
Dec 05 13:08:24.209 DEBG a1=-1.838334102564905 a2=0.8504587169940455 b0=1 b1=-1.838334102564905 b2=0.8504587169940455, module: camillalib::biquad
Dec 05 13:08:24.209 DEBG a1=-1.9967604006840272 a2=0.996765639706586 b0=1 b1=-1.9967604006840272 b2=0.996765639706586, module: camillalib::biquad
Dec 05 13:08:24.210 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.9981505111904521 b1=-1.9963010223809041 b2=0.9981505111904521, module: camillalib::biquad
Dec 05 13:08:24.210 DEBG a1=-1.838334102564905 a2=0.8504587169940455 b0=1 b1=-1.838334102564905 b2=0.8504587169940455, module: camillalib::biquad
Dec 05 13:08:24.210 DEBG a1=-1.9967604006840272 a2=0.996765639706586 b0=1 b1=-1.9967604006840272 b2=0.996765639706586, module: camillalib::biquad
Dec 05 13:08:24.210 DEBG Build from config, module: camillalib::filters
Dec 05 13:08:24.210 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.0000017103058908716714 b1=0.0000034206117817433428 b2=0.0000017103058908716714, module: camillalib::biquad
Dec 05 13:08:24.211 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.0000017103058908716714 b1=0.0000034206117817433428 b2=0.0000017103058908716714, module: camillalib::biquad
Dec 05 13:08:24.211 DEBG Building delay filter 'sub-align' with delay 528 samples, module: camillalib::basicfilters
Dec 05 13:08:24.211 DEBG a1=-1.838334102564905 a2=0.8504587169940455 b0=1 b1=-1.838334102564905 b2=0.8504587169940455, module: camillalib::biquad
Dec 05 13:08:24.211 DEBG a1=-1.9967604006840272 a2=0.996765639706586 b0=1 b1=-1.9967604006840272 b2=0.996765639706586, module: camillalib::biquad
Dec 05 13:08:24.211 DEBG Build from config, module: camillalib::filters
Dec 05 13:08:24.211 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.9981505111904521 b1=-1.9963010223809041 b2=0.9981505111904521, module: camillalib::biquad
Dec 05 13:08:24.212 DEBG a1=-1.838334102564905 a2=0.8504587169940455 b0=1 b1=-1.838334102564905 b2=0.8504587169940455, module: camillalib::biquad
Dec 05 13:08:24.212 DEBG a1=-1.9967604006840272 a2=0.996765639706586 b0=1 b1=-1.9967604006840272 b2=0.996765639706586, module: camillalib::biquad
Dec 05 13:08:24.212 DEBG Build from config, module: camillalib::filters
Dec 05 13:08:24.212 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.9981505111904521 b1=-1.9963010223809041 b2=0.9981505111904521, module: camillalib::biquad
Dec 05 13:08:24.213 DEBG build filters, waiting to start processing loop, module: camillalib::processing
Dec 05 13:08:24.213 DEBG Playback: supported channels, min: 8, max: 8, list: [8], module: camillalib::alsadevice
Dec 05 13:08:24.213 DEBG Playback: setting channels to 8, module: camillalib::alsadevice
Dec 05 13:08:24.213 DEBG Playback: supported samplerates: Discrete([44100, 48000, 88200, 96000, 176400, 192000]), module: camillalib::alsadevice
Dec 05 13:08:24.213 DEBG Playback: setting rate to 192000, module: camillalib::alsadevice
Dec 05 13:08:24.213 DEBG Playback: supported sample formats: [S32LE], module: camillalib::alsadevice
Dec 05 13:08:24.213 DEBG Playback: setting format to S32LE, module: camillalib::alsadevice
Dec 05 13:08:24.214 DEBG Capture: supported channels, min: 1, max: 32, list: [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32], module: camillalib::alsadevice
Dec 05 13:08:24.214 DEBG Capture: setting channels to 2, module: camillalib::alsadevice
Dec 05 13:08:24.214 DEBG Capture: supported samplerates: Range(8000, 192000), module: camillalib::alsadevice
Dec 05 13:08:24.214 DEBG Capture: setting rate to 192000, module: camillalib::alsadevice
Dec 05 13:08:24.214 DEBG Capture: supported sample formats: [S16LE, S24LE, S24LE3, S32LE, FLOAT32LE], module: camillalib::alsadevice
Dec 05 13:08:24.214 DEBG Capture: setting format to S32LE, module: camillalib::alsadevice
Dec 05 13:08:24.214 DEBG Opening audio device "hw:CARD=Loopback,DEV=0" with parameters: HwParams { channels: Ok(2), rate: "Ok(192000) Hz", format: Ok(S32LE), access: Ok(RWInterleaved), period_size: "Ok(4096) frames", buffer_size: "Ok(32768) frames" }, SwParams(avail_min: Ok(4096) frames, start_threshold: Ok(0) frames, stop_threshold: Ok(32768) frames), module: camillalib::alsadevice
Dec 05 13:08:24.215 DEBG Audio device "hw:CARD=Loopback,DEV=0" successfully opened, module: camillalib::alsadevice
Dec 05 13:08:24.215 DEBG Capture thread ready to start, module: camilladsp
Dec 05 13:08:24.217 DEBG Opening audio device "hw:CARD=Pro53791076,DEV=0" with parameters: HwParams { channels: Ok(8), rate: "Ok(192000) Hz", format: Ok(S32LE), access: Ok(RWInterleaved), period_size: "Ok(2048) frames", buffer_size: "Ok(16384) frames" }, SwParams(avail_min: Ok(2048) frames, start_threshold: Ok(6144) frames, stop_threshold: Ok(16384) frames), module: camillalib::alsadevice
Dec 05 13:08:24.218 DEBG Audio device "hw:CARD=Pro53791076,DEV=0" successfully opened, module: camillalib::alsadevice
Dec 05 13:08:24.218 DEBG Playback thread ready to start, module: camilladsp
Dec 05 13:08:24.218 DEBG Both capture and playback ready, release barrier, module: camilladsp
Dec 05 13:08:24.218 DEBG Supervisor loop starts now!, module: camilladsp
Dec 05 13:08:24.218 DEBG Processing loop starts now!, module: camillalib::processing
Dec 05 13:08:24.218 DEBG Starting captureloop, module: camillalib::alsadevice
Dec 05 13:08:24.218 DEBG Starting playback loop, module: camillalib::alsadevice
Dec 05 13:08:24.219 INFO Capture device supports rate adjust, module: camillalib::alsadevice
Dec 05 13:08:24.219 DEBG Starting capture, module: camillalib::alsadevice
Dec 05 13:08:24.274 INFO Starting playback from Prepared state, module: camillalib::alsadevice
Dec 05 13:08:34.262 DEBG Current buffer level: 8664.587234042554, corrected capture rate: 99.98770833333333%, module: camillalib::audiodevice
Dec 05 13:08:34.262 DEBG Playback buffer level: 8664.587234042554, signal rms: [-110.27775, -113.691055, -84.68483, -1000.0, -1000.0, -1000.0, -107.277756, -110.691055], module: camillalib::alsadevice
Dec 05 13:08:34.262 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:08:44.286 DEBG Current buffer level: 8532.089361702128, corrected capture rate: 99.99114583333333%, module: camillalib::audiodevice
Dec 05 13:08:44.286 DEBG Playback buffer level: 8532.089361702128, signal rms: [-76.47536, -79.138275, -79.05725, -1000.0, -1000.0, -1000.0, -73.47536, -76.138275], module: camillalib::alsadevice
Dec 05 13:08:44.286 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:08:54.313 DEBG Current buffer level: 8307.978723404256, corrected capture rate: 99.99700520833333%, module: camillalib::audiodevice
Dec 05 13:08:54.313 DEBG Playback buffer level: 8307.978723404256, signal rms: [-74.107635, -76.90206, -78.68676, -1000.0, -1000.0, -1000.0, -71.10763, -73.90206], module: camillalib::alsadevice
Dec 05 13:08:54.313 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:09:04.342 DEBG Current buffer level: 8311.961702127659, corrected capture rate: 99.99690104166666%, module: camillalib::audiodevice
Dec 05 13:09:04.342 DEBG Playback buffer level: 8311.961702127659, signal rms: [-72.34924, -73.69501, -81.23915, -1000.0, -1000.0, -1000.0, -69.34924, -70.69501], module: camillalib::alsadevice
Dec 05 13:09:04.342 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:09:14.369 DEBG Current buffer level: 8222.595744680852, corrected capture rate: 99.99921875%, module: camillalib::audiodevice
Dec 05 13:09:14.369 DEBG Playback buffer level: 8222.595744680852, signal rms: [-75.86743, -75.21328, -92.487564, -1000.0, -1000.0, -1000.0, -72.86743, -72.21328], module: camillalib::alsadevice
Dec 05 13:09:14.369 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:09:24.393 DEBG Current buffer level: 8094.791489361702, corrected capture rate: 100.00255208333333%, module: camillalib::audiodevice
Dec 05 13:09:24.394 DEBG Playback buffer level: 8094.791489361702, signal rms: [-63.007526, -63.425865, -69.44794, -1000.0, -1000.0, -1000.0, -60.007523, -60.425865], module: camillalib::alsadevice
Dec 05 13:09:24.394 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:09:34.421 DEBG Current buffer level: 8241.863829787235, corrected capture rate: 99.99872395833333%, module: camillalib::audiodevice
Dec 05 13:09:34.422 DEBG Playback buffer level: 8241.863829787235, signal rms: [-72.08405, -73.44277, -88.808105, -1000.0, -1000.0, -1000.0, -69.08405, -70.44277], module: camillalib::alsadevice
Dec 05 13:09:34.422 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:09:44.445 DEBG Current buffer level: 8368.425531914894, corrected capture rate: 99.99541666666667%, module: camillalib::audiodevice
Dec 05 13:09:44.446 DEBG Playback buffer level: 8368.425531914894, signal rms: [-59.623417, -61.152336, -67.194725, -1000.0, -1000.0, -1000.0, -56.623417, -58.152336], module: camillalib::alsadevice
Dec 05 13:09:44.446 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:09:54.474 DEBG Current buffer level: 8138.821276595745, corrected capture rate: 100.00140625%, module: camillalib::audiodevice
Dec 05 13:09:54.474 DEBG Playback buffer level: 8138.821276595745, signal rms: [-86.190346, -89.759285, -84.00142, -1000.0, -1000.0, -1000.0, -83.190346, -86.75928], module: camillalib::alsadevice
Dec 05 13:09:54.474 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:10:04.502 DEBG Current buffer level: 8091.663829787234, corrected capture rate: 100.00263020833333%, module: camillalib::audiodevice
Dec 05 13:10:04.502 DEBG Playback buffer level: 8091.663829787234, signal rms: [-75.0626, -76.60127, -76.828636, -1000.0, -1000.0, -1000.0, -72.0626, -73.60127], module: camillalib::alsadevice
Dec 05 13:10:04.503 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:10:14.526 DEBG Current buffer level: 8209.089361702128, corrected capture rate: 99.99955729166666%, module: camillalib::audiodevice
Dec 05 13:10:14.526 DEBG Playback buffer level: 8209.089361702128, signal rms: [-66.098755, -67.74266, -72.06389, -1000.0, -1000.0, -1000.0, -63.098755, -64.74266], module: camillalib::alsadevice
Dec 05 13:10:14.527 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:10:24.552 DEBG Current buffer level: 8379.272340425532, corrected capture rate: 99.99513020833334%, module: camillalib::audiodevice
Dec 05 13:10:24.552 DEBG Playback buffer level: 8379.272340425532, signal rms: [-64.36162, -64.47984, -68.047585, -1000.0, -1000.0, -1000.0, -61.361614, -61.47985], module: camillalib::alsadevice
Dec 05 13:10:24.553 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:10:34.581 DEBG Current buffer level: 8173.96170212766, corrected capture rate: 100.00049479166665%, module: camillalib::audiodevice
Dec 05 13:10:34.581 DEBG Playback buffer level: 8173.96170212766, signal rms: [-74.31973, -74.480064, -71.86853, -1000.0, -1000.0, -1000.0, -71.31974, -71.480064], module: camillalib::alsadevice
Dec 05 13:10:34.582 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:10:44.609 DEBG Current buffer level: 8091.744680851064, corrected capture rate: 100.00263020833333%, module: camillalib::audiodevice
Dec 05 13:10:44.609 DEBG Playback buffer level: 8091.744680851064, signal rms: [-73.350464, -74.54742, -75.5413, -1000.0, -1000.0, -1000.0, -70.350464, -71.54742], module: camillalib::alsadevice
Dec 05 13:10:44.609 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:10:54.633 DEBG Current buffer level: 8288.531914893618, corrected capture rate: 99.99749999999999%, module: camillalib::audiodevice
Dec 05 13:10:54.633 DEBG Playback buffer level: 8288.531914893618, signal rms: [-65.89242, -66.94081, -72.39604, -1000.0, -1000.0, -1000.0, -62.892418, -63.94081], module: camillalib::alsadevice
Dec 05 13:10:54.633 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:11:04.661 DEBG Current buffer level: 8343.208510638298, corrected capture rate: 99.99606770833334%, module: camillalib::audiodevice
Dec 05 13:11:04.661 DEBG Playback buffer level: 8343.208510638298, signal rms: [-78.436165, -79.679405, -77.66727, -1000.0, -1000.0, -1000.0, -75.436165, -76.67941], module: camillalib::alsadevice
Dec 05 13:11:04.661 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:11:14.689 DEBG Current buffer level: 8154.787234042553, corrected capture rate: 100.00098958333335%, module: camillalib::audiodevice
Dec 05 13:11:14.689 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:11:14.690 DEBG Playback buffer level: 8154.787234042553, signal rms: [-67.25345, -68.75156, -66.362305, -1000.0, -1000.0, -1000.0, -64.25345, -65.75156], module: camillalib::alsadevice
Dec 05 13:11:24.713 DEBG Current buffer level: 8170.706382978723, corrected capture rate: 100.00057291666667%, module: camillalib::audiodevice
Dec 05 13:11:24.714 DEBG Playback buffer level: 8170.706382978723, signal rms: [-58.80312, -63.210377, -66.57036, -1000.0, -1000.0, -1000.0, -55.803116, -60.210377], module: camillalib::alsadevice
Dec 05 13:11:24.714 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:11:34.741 DEBG Current buffer level: 8149.96170212766, corrected capture rate: 100.00111979166665%, module: camillalib::audiodevice
Dec 05 13:11:34.742 DEBG Playback buffer level: 8149.96170212766, signal rms: [-69.77944, -69.412735, -81.25354, -1000.0, -1000.0, -1000.0, -66.77944, -66.41274], module: camillalib::alsadevice
Dec 05 13:11:34.742 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:11:44.766 DEBG Current buffer level: 8265.617021276596, corrected capture rate: 99.99809895833334%, module: camillalib::audiodevice
Dec 05 13:11:44.766 DEBG Playback buffer level: 8265.617021276596, signal rms: [-72.83052, -70.48323, -82.51749, -1000.0, -1000.0, -1000.0, -69.83053, -67.48322], module: camillalib::alsadevice
Dec 05 13:11:44.766 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:11:54.793 DEBG Current buffer level: 8321.608510638298, corrected capture rate: 99.996640625%, module: camillalib::audiodevice
Dec 05 13:11:54.793 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:11:54.794 DEBG Playback buffer level: 8321.608510638298, signal rms: [-50.793644, -51.370777, -62.166374, -1000.0, -1000.0, -1000.0, -47.793648, -48.370777], module: camillalib::alsadevice
Dec 05 13:11:55.292 DEBG parsed command: Ok(GetMute), module: camillalib::socketserver
Dec 05 13:12:04.821 DEBG Current buffer level: 8286.60425531915, corrected capture rate: 99.99755208333333%, module: camillalib::audiodevice
Dec 05 13:12:04.821 DEBG Playback buffer level: 8286.60425531915, signal rms: [-1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0], module: camillalib::alsadevice
Dec 05 13:12:04.821 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:12:04.945 DEBG parsed command: Ok(GetMute), module: camillalib::socketserver
Dec 05 13:12:14.850 DEBG Current buffer level: 8164.689361702128, corrected capture rate: 100.00072916666667%, module: camillalib::audiodevice
Dec 05 13:12:14.850 DEBG Playback buffer level: 8164.689361702128, signal rms: [-72.23075, -71.85733, -90.32845, -1000.0, -1000.0, -1000.0, -69.23075, -68.85733], module: camillalib::alsadevice
Dec 05 13:12:14.850 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:12:24.873 DEBG Current buffer level: 8198.306382978724, corrected capture rate: 99.99984375%, module: camillalib::audiodevice
Dec 05 13:12:24.874 DEBG Playback buffer level: 8198.306382978724, signal rms: [-62.961426, -63.482548, -85.05237, -1000.0, -1000.0, -1000.0, -59.96143, -60.482544], module: camillalib::alsadevice
Dec 05 13:12:24.874 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:12:34.901 DEBG Current buffer level: 8174.2, corrected capture rate: 100.00046875%, module: camillalib::audiodevice
Dec 05 13:12:34.901 DEBG Playback buffer level: 8174.2, signal rms: [-85.32615, -93.40085, -74.46894, -1000.0, -1000.0, -1000.0, -82.32614, -90.40085], module: camillalib::alsadevice
Dec 05 13:12:34.902 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:12:44.929 DEBG Current buffer level: 8228.242553191489, corrected capture rate: 99.99906250000001%, module: camillalib::audiodevice
Dec 05 13:12:44.929 DEBG Playback buffer level: 8228.242553191489, signal rms: [-74.00547, -74.48551, -75.051994, -1000.0, -1000.0, -1000.0, -71.00547, -71.48551], module: camillalib::alsadevice
Dec 05 13:12:44.929 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:12:54.953 DEBG Current buffer level: 8245.242553191489, corrected capture rate: 99.99861979166667%, module: camillalib::audiodevice
Dec 05 13:12:54.954 DEBG Playback buffer level: 8245.242553191489, signal rms: [-63.3731, -67.40431, -91.052765, -1000.0, -1000.0, -1000.0, -60.3731, -64.40431], module: camillalib::alsadevice
Dec 05 13:12:54.954 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:13:04.981 DEBG Current buffer level: 8260.165957446809, corrected capture rate: 99.99822916666666%, module: camillalib::audiodevice
Dec 05 13:13:04.981 DEBG Playback buffer level: 8260.165957446809, signal rms: [-73.124825, -72.69435, -83.59252, -1000.0, -1000.0, -1000.0, -70.124825, -69.69435], module: camillalib::alsadevice
Dec 05 13:13:04.981 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:13:15.009 DEBG Current buffer level: 8259.331914893617, corrected capture rate: 99.99825520833333%, module: camillalib::audiodevice
Dec 05 13:13:15.010 DEBG Playback buffer level: 8259.331914893617, signal rms: [-70.670074, -68.47461, -86.444595, -1000.0, -1000.0, -1000.0, -67.67007, -65.47462], module: camillalib::alsadevice
Dec 05 13:13:15.010 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:13:25.033 DEBG Current buffer level: 8270.106382978724, corrected capture rate: 99.99796875%, module: camillalib::audiodevice
Dec 05 13:13:25.033 DEBG Playback buffer level: 8270.106382978724, signal rms: [-70.21074, -71.00526, -69.239235, -1000.0, -1000.0, -1000.0, -67.21074, -68.00526], module: camillalib::alsadevice
Dec 05 13:13:25.034 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:13:35.061 DEBG Current buffer level: 8295.863829787235, corrected capture rate: 99.99731770833333%, module: camillalib::audiodevice
Dec 05 13:13:35.062 DEBG Playback buffer level: 8295.863829787235, signal rms: [-74.489815, -72.947136, -75.49579, -1000.0, -1000.0, -1000.0, -71.48982, -69.947136], module: camillalib::alsadevice
Dec 05 13:13:35.062 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:13:45.088 DEBG Current buffer level: 8265.263829787234, corrected capture rate: 99.99809895833334%, module: camillalib::audiodevice
Dec 05 13:13:45.089 DEBG Playback buffer level: 8265.263829787234, signal rms: [-61.65463, -65.882355, -65.25466, -1000.0, -1000.0, -1000.0, -58.65463, -62.88235], module: camillalib::alsadevice
Dec 05 13:13:45.089 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:13:55.114 DEBG Current buffer level: 8316.36170212766, corrected capture rate: 99.99677083333334%, module: camillalib::audiodevice
Dec 05 13:13:55.114 DEBG Playback buffer level: 8316.36170212766, signal rms: [-68.839424, -70.435234, -87.45045, -1000.0, -1000.0, -1000.0, -65.83942, -67.435234], module: camillalib::alsadevice
Dec 05 13:13:55.114 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:14:05.142 DEBG Current buffer level: 8255.451063829787, corrected capture rate: 99.998359375%, module: camillalib::audiodevice
Dec 05 13:14:05.142 DEBG Playback buffer level: 8255.451063829787, signal rms: [-57.473137, -57.897285, -84.16397, -1000.0, -1000.0, -1000.0, -54.473137, -54.897285], module: camillalib::alsadevice
Dec 05 13:14:05.143 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:14:15.169 DEBG Current buffer level: 8081.408510638298, corrected capture rate: 100.002890625%, module: camillalib::audiodevice
Dec 05 13:14:15.169 DEBG Playback buffer level: 8081.408510638298, signal rms: [-64.466354, -67.60138, -63.597584, -1000.0, -1000.0, -1000.0, -61.46635, -64.60138], module: camillalib::alsadevice
Dec 05 13:14:15.169 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:14:25.193 DEBG Current buffer level: 8176.204255319149, corrected capture rate: 100.00041666666665%, module: camillalib::audiodevice
Dec 05 13:14:25.194 DEBG Playback buffer level: 8176.204255319149, signal rms: [-68.18207, -70.51583, -91.146965, -1000.0, -1000.0, -1000.0, -65.18207, -67.51583], module: camillalib::alsadevice
Dec 05 13:14:25.195 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:14:35.221 DEBG Current buffer level: 8345.540425531915, corrected capture rate: 99.996015625%, module: camillalib::audiodevice
Dec 05 13:14:35.222 DEBG Playback buffer level: 8345.540425531915, signal rms: [-64.50565, -64.8907, -87.443115, -1000.0, -1000.0, -1000.0, -61.505653, -61.890697], module: camillalib::alsadevice
Dec 05 13:14:35.222 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:14:45.249 DEBG Current buffer level: 8301.812765957447, corrected capture rate: 99.99716145833332%, module: camillalib::audiodevice
Dec 05 13:14:45.249 DEBG Playback buffer level: 8301.812765957447, signal rms: [-62.314125, -62.000587, -84.64279, -1000.0, -1000.0, -1000.0, -59.314125, -59.00059], module: camillalib::alsadevice
Dec 05 13:14:45.249 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:14:55.277 DEBG Current buffer level: 8119.846808510638, corrected capture rate: 100.00190104166666%, module: camillalib::audiodevice
Dec 05 13:14:55.277 DEBG Playback buffer level: 8119.846808510638, signal rms: [-62.313747, -65.45566, -62.85232, -1000.0, -1000.0, -1000.0, -59.313744, -62.455658], module: camillalib::alsadevice
Dec 05 13:14:55.277 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:15:05.301 DEBG Current buffer level: 8136.923404255319, corrected capture rate: 100.00145833333333%, module: camillalib::audiodevice
Dec 05 13:15:05.302 DEBG Playback buffer level: 8136.923404255319, signal rms: [-80.78859, -83.316795, -93.62667, -1000.0, -1000.0, -1000.0, -77.7886, -80.31679], module: camillalib::alsadevice
Dec 05 13:15:05.302 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:15:15.329 DEBG Current buffer level: 8267.144680851065, corrected capture rate: 99.998046875%, module: camillalib::audiodevice
Dec 05 13:15:15.329 DEBG Playback buffer level: 8267.144680851065, signal rms: [-72.96484, -73.632996, -86.86825, -1000.0, -1000.0, -1000.0, -69.96484, -70.633], module: camillalib::alsadevice
Dec 05 13:15:15.329 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:15:25.350 DEBG Current buffer level: 8387.748936170212, corrected capture rate: 99.994921875%, module: camillalib::audiodevice
Dec 05 13:15:25.351 DEBG Playback buffer level: 8387.748936170212, signal rms: [-73.07905, -75.17198, -86.9742, -1000.0, -1000.0, -1000.0, -70.07905, -72.17198], module: camillalib::alsadevice
Dec 05 13:15:25.351 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:15:35.381 DEBG Current buffer level: 8208.182978723404, corrected capture rate: 99.99958333333333%, module: camillalib::audiodevice
Dec 05 13:15:35.382 DEBG Playback buffer level: 8208.182978723404, signal rms: [-62.93842, -64.58548, -75.69142, -1000.0, -1000.0, -1000.0, -59.938416, -61.58548], module: camillalib::alsadevice
Dec 05 13:15:35.382 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:15:45.408 DEBG Current buffer level: 8182.063829787234, corrected capture rate: 100.00026041666668%, module: camillalib::audiodevice
Dec 05 13:15:45.408 DEBG Playback buffer level: 8182.063829787234, signal rms: [-63.563225, -63.327785, -81.629, -1000.0, -1000.0, -1000.0, -60.56322, -60.32778], module: camillalib::alsadevice
Dec 05 13:15:45.409 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:15:55.437 DEBG Current buffer level: 8197.510638297872, corrected capture rate: 99.99986979166667%, module: camillalib::audiodevice
Dec 05 13:15:55.438 DEBG Playback buffer level: 8197.510638297872, signal rms: [-57.321213, -56.98561, -68.61613, -1000.0, -1000.0, -1000.0, -54.321213, -53.98561], module: camillalib::alsadevice
Dec 05 13:15:55.438 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:16:05.462 DEBG Current buffer level: 8142.621276595744, corrected capture rate: 100.00130208333333%, module: camillalib::audiodevice
Dec 05 13:16:05.463 DEBG Playback buffer level: 8142.621276595744, signal rms: [-61.625023, -61.701298, -67.09911, -1000.0, -1000.0, -1000.0, -58.625023, -58.701294], module: camillalib::alsadevice
Dec 05 13:16:05.463 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:16:12.736 DEBG parsed command: Ok(SetConfigName("/usr/local/etc/camilladsp/config192XO.yml")), module: camillalib::socketserver
Dec 05 13:16:12.744 DEBG parsed command: Ok(Reload), module: camillalib::socketserver
Dec 05 13:16:12.770 DEBG Reloading configuration..., module: camilladsp
Dec 05 13:16:12.772 DEBG Reload using config file, module: camilladsp
Dec 05 13:16:12.772 DEBG Devices changed, restart required., module: camilladsp
Dec 05 13:16:12.792 DEBG Exit message received, sending EndOfStream, module: camillalib::alsadevice
Dec 05 13:16:12.808 DEBG Restarting with new config, module: camilladsp
Dec 05 13:16:12.808 DEBG Wait for config, module: camilladsp
Dec 05 13:16:12.809 DEBG Config ready, module: camilladsp
Dec 05 13:16:12.809 DEBG Using channels [true, true], module: camilladsp
Dec 05 13:16:12.809 DEBG Build new pipeline, module: camillalib::filters
Dec 05 13:16:12.809 DEBG Buffer frames 16384, module: camillalib::alsadevice
Dec 05 13:16:12.810 DEBG Build from config, module: camillalib::filters
Dec 05 13:16:12.810 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.9981505111904521 b1=-1.9963010223809041 b2=0.9981505111904521, module: camillalib::biquad
Dec 05 13:16:12.810 DEBG a1=-1.838334102564905 a2=0.8504587169940455 b0=1 b1=-1.838334102564905 b2=0.8504587169940455, module: camillalib::biquad
Dec 05 13:16:12.811 DEBG a1=-1.9967604006840272 a2=0.996765639706586 b0=1 b1=-1.9967604006840272 b2=0.996765639706586, module: camillalib::biquad
Dec 05 13:16:12.811 DEBG Build from config, module: camillalib::filters
Dec 05 13:16:12.811 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.9981505111904521 b1=-1.9963010223809041 b2=0.9981505111904521, module: camillalib::biquad
Dec 05 13:16:12.811 DEBG a1=-1.838334102564905 a2=0.8504587169940455 b0=1 b1=-1.838334102564905 b2=0.8504587169940455, module: camillalib::biquad
Dec 05 13:16:12.812 DEBG a1=-1.9967604006840272 a2=0.996765639706586 b0=1 b1=-1.9967604006840272 b2=0.996765639706586, module: camillalib::biquad
Dec 05 13:16:12.812 DEBG Build from config, module: camillalib::filters
Dec 05 13:16:12.812 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.0000017103058908716714 b1=0.0000034206117817433428 b2=0.0000017103058908716714, module: camillalib::biquad
Dec 05 13:16:12.813 DEBG Building delay filter 'sub-align' with delay 528 samples, module: camillalib::basicfilters
Dec 05 13:16:12.813 DEBG a1=-1.838334102564905 a2=0.8504587169940455 b0=1 b1=-1.838334102564905 b2=0.8504587169940455, module: camillalib::biquad
Dec 05 13:16:12.813 DEBG a1=-1.9967604006840272 a2=0.996765639706586 b0=1 b1=-1.9967604006840272 b2=0.996765639706586, module: camillalib::biquad
Dec 05 13:16:12.813 DEBG Build from config, module: camillalib::filters
Dec 05 13:16:12.813 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.9981505111904521 b1=-1.9963010223809041 b2=0.9981505111904521, module: camillalib::biquad
Dec 05 13:16:12.814 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.9981505111904521 b1=-1.9963010223809041 b2=0.9981505111904521, module: camillalib::biquad
Dec 05 13:16:12.814 DEBG a1=-1.838334102564905 a2=0.8504587169940455 b0=1 b1=-1.838334102564905 b2=0.8504587169940455, module: camillalib::biquad
Dec 05 13:16:12.814 DEBG a1=-1.9967604006840272 a2=0.996765639706586 b0=1 b1=-1.9967604006840272 b2=0.996765639706586, module: camillalib::biquad
Dec 05 13:16:12.814 DEBG Build from config, module: camillalib::filters
Dec 05 13:16:12.815 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.9981505111904521 b1=-1.9963010223809041 b2=0.9981505111904521, module: camillalib::biquad
Dec 05 13:16:12.815 DEBG a1=-1.838334102564905 a2=0.8504587169940455 b0=1 b1=-1.838334102564905 b2=0.8504587169940455, module: camillalib::biquad
Dec 05 13:16:12.815 DEBG a1=-1.9967604006840272 a2=0.996765639706586 b0=1 b1=-1.9967604006840272 b2=0.996765639706586, module: camillalib::biquad
Dec 05 13:16:12.815 DEBG build filters, waiting to start processing loop, module: camillalib::processing
Dec 05 13:16:12.816 DEBG Capture: supported channels, min: 2, max: 2, list: [2], module: camillalib::alsadevice
Dec 05 13:16:12.816 DEBG Capture: setting channels to 2, module: camillalib::alsadevice
Dec 05 13:16:12.816 DEBG Capture: supported samplerates: Discrete([192000]), module: camillalib::alsadevice
Dec 05 13:16:12.816 DEBG Capture: setting rate to 192000, module: camillalib::alsadevice
Dec 05 13:16:12.816 DEBG Capture: supported sample formats: [S32LE], module: camillalib::alsadevice
Dec 05 13:16:12.817 DEBG Capture: setting format to S32LE, module: camillalib::alsadevice
Dec 05 13:16:12.817 DEBG Playback: supported channels, min: 8, max: 8, list: [8], module: camillalib::alsadevice
Dec 05 13:16:12.817 DEBG Playback: setting channels to 8, module: camillalib::alsadevice
Dec 05 13:16:12.817 DEBG Playback: supported samplerates: Discrete([44100, 48000, 88200, 96000, 176400, 192000]), module: camillalib::alsadevice
Dec 05 13:16:12.817 DEBG Playback: setting rate to 192000, module: camillalib::alsadevice
Dec 05 13:16:12.818 DEBG Playback: supported sample formats: [S32LE], module: camillalib::alsadevice
Dec 05 13:16:12.818 DEBG Playback: setting format to S32LE, module: camillalib::alsadevice
Dec 05 13:16:12.818 DEBG Opening audio device "hw:CARD=Loopback,DEV=0" with parameters: HwParams { channels: Ok(2), rate: "Ok(192000) Hz", format: Ok(S32LE), access: Ok(RWInterleaved), period_size: "Ok(4096) frames", buffer_size: "Ok(32768) frames" }, SwParams(avail_min: Ok(4096) frames, start_threshold: Ok(0) frames, stop_threshold: Ok(32768) frames), module: camillalib::alsadevice
Dec 05 13:16:12.818 DEBG Audio device "hw:CARD=Loopback,DEV=0" successfully opened, module: camillalib::alsadevice
Dec 05 13:16:12.819 DEBG Capture thread ready to start, module: camilladsp
Dec 05 13:16:12.821 DEBG Opening audio device "hw:CARD=Pro53791076,DEV=0" with parameters: HwParams { channels: Ok(8), rate: "Ok(192000) Hz", format: Ok(S32LE), access: Ok(RWInterleaved), period_size: "Ok(2048) frames", buffer_size: "Ok(16384) frames" }, SwParams(avail_min: Ok(2048) frames, start_threshold: Ok(6144) frames, stop_threshold: Ok(16384) frames), module: camillalib::alsadevice
Dec 05 13:16:12.821 DEBG Audio device "hw:CARD=Pro53791076,DEV=0" successfully opened, module: camillalib::alsadevice
Dec 05 13:16:12.822 DEBG Playback thread ready to start, module: camilladsp
Dec 05 13:16:12.822 DEBG Both capture and playback ready, release barrier, module: camilladsp
Dec 05 13:16:12.822 DEBG Supervisor loop starts now!, module: camilladsp
Dec 05 13:16:12.822 DEBG Starting captureloop, module: camillalib::alsadevice
Dec 05 13:16:12.822 DEBG Processing loop starts now!, module: camillalib::processing
Dec 05 13:16:12.822 DEBG Starting playback loop, module: camillalib::alsadevice
Dec 05 13:16:12.822 INFO Capture device supports rate adjust, module: camillalib::alsadevice
Dec 05 13:16:12.823 DEBG Starting capture, module: camillalib::alsadevice
Dec 05 13:16:12.878 INFO Starting playback from Prepared state, module: camillalib::alsadevice
Dec 05 13:16:22.860 DEBG Current buffer level: 8986.268085106383, corrected capture rate: 99.97932291666667%, module: camillalib::audiodevice
Dec 05 13:16:22.861 DEBG Playback buffer level: 8986.268085106383, signal rms: [-70.141136, -70.2751, -72.507805, -1000.0, -1000.0, -1000.0, -67.141136, -67.2751], module: camillalib::alsadevice
Dec 05 13:16:22.861 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:16:32.888 DEBG Current buffer level: 8700.978723404256, corrected capture rate: 99.98677083333334%, module: camillalib::audiodevice
Dec 05 13:16:32.889 DEBG Playback buffer level: 8700.978723404256, signal rms: [-79.94728, -80.83099, -80.26582, -1000.0, -1000.0, -1000.0, -76.94728, -77.83099], module: camillalib::alsadevice
Dec 05 13:16:32.889 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:16:42.916 DEBG Current buffer level: 8487.940425531915, corrected capture rate: 99.99231770833333%, module: camillalib::audiodevice
Dec 05 13:16:42.916 DEBG Playback buffer level: 8487.940425531915, signal rms: [-1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0], module: camillalib::alsadevice
Dec 05 13:16:42.916 DEBG SetSpeed message received, module: camilladsp
Dec 05 13:16:47.609 INFO Playback thread has already stopped., module: camillalib::processing
Here's the status immediately after turning off the soundcard:
Code:
ubuntu@ubuntu:/usr/local/etc/camilladsp$ sudo systemctl status camilladsp
Active: active (running) since Sun 2021-12-05 13:08:24 UTC; 8min ago
Main PID: 5355 (camilladsp)
Tasks: 5 (limit: 9244)
Memory: 2.0M
CPU: 2min 15.029s
CGroup: /system.slice/camilladsp.service
└─5355 /usr/local/bin/camilladsp -a0.0.0.0 -p5000 -g-30 --logfile /usr/local/etc/camilladsp/logs/log.txt -ldebug /usr/local/etc/camilladsp/config192XO.yml
Dec 05 13:08:24 ubuntu systemd[1]: Started CamillaDSP Daemon.
Dec 05 13:16:47 ubuntu camilladsp[5355]: thread 'AlsaPlayback' panicked at 'called `Result::unwrap()` on an `Err` value: Error("snd_pcm_state", UnsupportedOperation)', /cargo/registry/src/gith>
Dec 05 13:16:47 ubuntu camilladsp[5355]: note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
Can you try just running in a terminal, without writing the log to file with --logfile? Also try without systemd for now. Panic messages don't get written to the log file when you use --logfile to write to a file, and I think there should have been one since it suddenly says "Playback thread has already stopped".
Does it behave the same if you power off the dac as if you disconnect the usb cable?
Finally, please post your config, and the output of "aplay -l" and "arecord -l".
Perhaps this is the cause?
Perhaps the method was called when the device was already gone. Maybe still some issue around the code you patched in the alsa crate? Thanks!
Code:
Thanks for taking the time to check this out. Here's the result of running in the terminal window and then turning off the soundcard while it's playing. I think the error reported in the status report I shared previously that @phofman highlighted is all that the logs show as far as I can see:
Next I tried unplugging the soundcard, with the same results as far as I can tell:
Here's my config file:
Code:
ubuntu@ubuntu:/usr/local/etc/camilladsp/logs$ /usr/local/bin/camilladsp -a0.0.0.0 -p5000 -g-30 -ldebug /usr/local/etc/camilladsp/config192XO.ymlDec 06 07:32:38.318 DEBG Read config file Some("/usr/local/etc/camilladsp/config192XO.yml"), module: camilladsp
Dec 06 07:32:38.320 DEBG Config is valid, module: camilladsp
Dec 06 07:32:38.320 DEBG Start websocket server on 0.0.0.0:5000, module: camillalib::socketserver
Dec 06 07:32:38.321 DEBG Wait for config, module: camilladsp
Dec 06 07:32:38.321 DEBG Config ready, module: camilladsp
Dec 06 07:32:38.322 DEBG Using channels [true, true], module: camilladsp
Dec 06 07:32:38.323 DEBG Buffer frames 16384, module: camillalib::alsadevice
Dec 06 07:32:38.323 DEBG Build new pipeline, module: camillalib::filters
Dec 06 07:32:38.323 DEBG Build from config, module: camillalib::filters
Dec 06 07:32:38.324 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.9981505111904521 b1=-1.9963010223809041 b2=0.9981505111904521, module: camillalib::biquad
Dec 06 07:32:38.325 DEBG a1=-1.838334102564905 a2=0.8504587169940455 b0=1 b1=-1.838334102564905 b2=0.8504587169940455, module: camillalib::biquad
Dec 06 07:32:38.326 DEBG a1=-1.9967604006840272 a2=0.996765639706586 b0=1 b1=-1.9967604006840272 b2=0.996765639706586, module: camillalib::biquad
Dec 06 07:32:38.326 DEBG Build from config, module: camillalib::filters
Dec 06 07:32:38.326 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.9981505111904521 b1=-1.9963010223809041 b2=0.9981505111904521, module: camillalib::biquad
Dec 06 07:32:38.327 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.9981505111904521 b1=-1.9963010223809041 b2=0.9981505111904521, module: camillalib::biquad
Dec 06 07:32:38.327 DEBG a1=-1.838334102564905 a2=0.8504587169940455 b0=1 b1=-1.838334102564905 b2=0.8504587169940455, module: camillalib::biquad
Dec 06 07:32:38.327 DEBG a1=-1.9967604006840272 a2=0.996765639706586 b0=1 b1=-1.9967604006840272 b2=0.996765639706586, module: camillalib::biquad
Dec 06 07:32:38.328 DEBG Build from config, module: camillalib::filters
Dec 06 07:32:38.328 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.0000017103058908716714 b1=0.0000034206117817433428 b2=0.0000017103058908716714, module: camillalib::biquad
Dec 06 07:32:38.329 DEBG Building delay filter 'sub-align' with delay 528 samples, module: camillalib::basicfilters
Dec 06 07:32:38.329 DEBG a1=-1.838334102564905 a2=0.8504587169940455 b0=1 b1=-1.838334102564905 b2=0.8504587169940455, module: camillalib::biquad
Dec 06 07:32:38.330 DEBG a1=-1.9967604006840272 a2=0.996765639706586 b0=1 b1=-1.9967604006840272 b2=0.996765639706586, module: camillalib::biquad
Dec 06 07:32:38.330 DEBG Build from config, module: camillalib::filters
Dec 06 07:32:38.330 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.9981505111904521 b1=-1.9963010223809041 b2=0.9981505111904521, module: camillalib::biquad
Dec 06 07:32:38.331 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.9981505111904521 b1=-1.9963010223809041 b2=0.9981505111904521, module: camillalib::biquad
Dec 06 07:32:38.331 DEBG a1=-1.838334102564905 a2=0.8504587169940455 b0=1 b1=-1.838334102564905 b2=0.8504587169940455, module: camillalib::biquad
Dec 06 07:32:38.331 DEBG a1=-1.9967604006840272 a2=0.996765639706586 b0=1 b1=-1.9967604006840272 b2=0.996765639706586, module: camillalib::biquad
Dec 06 07:32:38.332 DEBG Build from config, module: camillalib::filters
Dec 06 07:32:38.332 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.9981505111904521 b1=-1.9963010223809041 b2=0.9981505111904521, module: camillalib::biquad
Dec 06 07:32:38.332 DEBG a1=-1.838334102564905 a2=0.8504587169940455 b0=1 b1=-1.838334102564905 b2=0.8504587169940455, module: camillalib::biquad
Dec 06 07:32:38.333 DEBG a1=-1.9967604006840272 a2=0.996765639706586 b0=1 b1=-1.9967604006840272 b2=0.996765639706586, module: camillalib::biquad
Dec 06 07:32:38.333 DEBG build filters, waiting to start processing loop, module: camillalib::processing
Dec 06 07:32:38.333 DEBG Capture: supported channels, min: 2, max: 2, list: [2], module: camillalib::alsadevice
Dec 06 07:32:38.334 DEBG Capture: setting channels to 2, module: camillalib::alsadevice
Dec 06 07:32:38.334 DEBG Capture: supported samplerates: Discrete([192000]), module: camillalib::alsadevice
Dec 06 07:32:38.334 DEBG Capture: setting rate to 192000, module: camillalib::alsadevice
Dec 06 07:32:38.335 DEBG Capture: supported sample formats: [S32LE], module: camillalib::alsadevice
Dec 06 07:32:38.335 DEBG Capture: setting format to S32LE, module: camillalib::alsadevice
Dec 06 07:32:38.335 DEBG Playback: supported channels, min: 8, max: 8, list: [8], module: camillalib::alsadevice
Dec 06 07:32:38.336 DEBG Playback: setting channels to 8, module: camillalib::alsadevice
Dec 06 07:32:38.336 DEBG Playback: supported samplerates: Discrete([44100, 48000, 88200, 96000, 176400, 192000]), module: camillalib::alsadevice
Dec 06 07:32:38.336 DEBG Playback: setting rate to 192000, module: camillalib::alsadevice
Dec 06 07:32:38.337 DEBG Playback: supported sample formats: [S32LE], module: camillalib::alsadevice
Dec 06 07:32:38.337 DEBG Playback: setting format to S32LE, module: camillalib::alsadevice
Dec 06 07:32:38.337 DEBG Opening audio device "hw:CARD=Loopback,DEV=0" with parameters: HwParams { channels: Ok(2), rate: "Ok(192000) Hz", format: Ok(S32LE), access: Ok(RWInterleaved), period_size: "Ok(4096) frames", buffer_size: "Ok(32768) frames" }, SwParams(avail_min: Ok(4096) frames, start_threshold: Ok(0) frames, stop_threshold: Ok(32768) frames), module: camillalib::alsadevice
Dec 06 07:32:38.338 DEBG Audio device "hw:CARD=Loopback,DEV=0" successfully opened, module: camillalib::alsadevice
Dec 06 07:32:38.338 DEBG Capture thread ready to start, module: camilladsp
Dec 06 07:32:38.338 DEBG Opening audio device "hw:CARD=Pro53791076,DEV=0" with parameters: HwParams { channels: Ok(8), rate: "Ok(192000) Hz", format: Ok(S32LE), access: Ok(RWInterleaved), period_size: "Ok(2048) frames", buffer_size: "Ok(16384) frames" }, SwParams(avail_min: Ok(2048) frames, start_threshold: Ok(6144) frames, stop_threshold: Ok(16384) frames), module: camillalib::alsadevice
Dec 06 07:32:38.339 DEBG Audio device "hw:CARD=Pro53791076,DEV=0" successfully opened, module: camillalib::alsadevice
Dec 06 07:32:38.339 DEBG Playback thread ready to start, module: camilladsp
Dec 06 07:32:38.339 DEBG Both capture and playback ready, release barrier, module: camilladsp
Dec 06 07:32:38.340 DEBG Supervisor loop starts now!, module: camilladsp
Dec 06 07:32:38.340 DEBG Starting playback loop, module: camillalib::alsadevice
Dec 06 07:32:38.340 DEBG Processing loop starts now!, module: camillalib::processing
Dec 06 07:32:38.341 DEBG Starting captureloop, module: camillalib::alsadevice
Dec 06 07:32:38.341 INFO Capture device supports rate adjust, module: camillalib::alsadevice
Dec 06 07:32:38.341 DEBG Starting capture, module: camillalib::alsadevice
Dec 06 07:32:38.386 INFO Starting playback from Prepared state, module: camillalib::alsadevice
Dec 06 07:32:48.328 DEBG Current buffer level: 8756.162393162393, corrected capture rate: 99.9853125%, module: camillalib::audiodevice
Dec 06 07:32:48.329 DEBG Playback buffer level: 8756.162393162393, signal rms: [-55.341652, -55.341652, -72.3436, -1000.0, -1000.0, -1000.0, -52.341656, -52.341656], module: camillalib::alsadevice
Dec 06 07:32:48.329 DEBG SetSpeed message received, module: camilladsp
Dec 06 07:32:58.357 DEBG Current buffer level: 8736.936170212766, corrected capture rate: 99.98583333333333%, module: camillalib::audiodevice
Dec 06 07:32:58.358 DEBG Playback buffer level: 8736.936170212766, signal rms: [-62.017094, -62.017094, -69.571815, -1000.0, -1000.0, -1000.0, -59.01709, -59.01709], module: camillalib::alsadevice
Dec 06 07:32:58.359 DEBG SetSpeed message received, module: camilladsp
Dec 06 07:33:08.384 DEBG Current buffer level: 8414.285106382978, corrected capture rate: 99.99421875%, module: camillalib::audiodevice
Dec 06 07:33:08.385 DEBG Playback buffer level: 8414.285106382978, signal rms: [-67.25229, -67.25229, -60.430344, -1000.0, -1000.0, -1000.0, -64.25229, -64.25229], module: camillalib::alsadevice
Dec 06 07:33:08.385 DEBG SetSpeed message received, module: camilladsp
Dec 06 07:33:18.409 DEBG Current buffer level: 8280.876595744681, corrected capture rate: 99.99770833333334%, module: camillalib::audiodevice
Dec 06 07:33:18.409 DEBG Playback buffer level: 8280.876595744681, signal rms: [-67.66788, -67.66788, -69.09609, -1000.0, -1000.0, -1000.0, -64.66788, -64.66788], module: camillalib::alsadevice
Dec 06 07:33:18.410 DEBG SetSpeed message received, module: camilladsp
Dec 06 07:33:25.037 DEBG parsed command: Ok(GetMute), module: camillalib::socketserver
Dec 06 07:33:25.038 DEBG parsed command: Ok(GetVolume), module: camillalib::socketserver
Dec 06 07:33:25.045 DEBG parsed command: Ok(SetVolume(-33.0)), module: camillalib::socketserver
Dec 06 07:33:25.057 DEBG a1=-1.8369405783295014 a2=0.8492677266366983 b0=1.0336939398317484 b1=-1.901703123986046 b2=0.8803363324614945, module: camillalib::biquad
Dec 06 07:33:25.057 DEBG a1=-1.9968020843311776 a2=0.9968071895070446 b0=1.0000419563011471 b1=-1.9968019486178439 b2=0.996765368919231, module: camillalib::biquad
Dec 06 07:33:25.058 DEBG a1=-1.8369405783295014 a2=0.8492677266366983 b0=1.0336939398317484 b1=-1.901703123986046 b2=0.8803363324614945, module: camillalib::biquad
Dec 06 07:33:25.058 DEBG a1=-1.9968020843311776 a2=0.9968071895070446 b0=1.0000419563011471 b1=-1.9968019486178439 b2=0.996765368919231, module: camillalib::biquad
Dec 06 07:33:25.059 DEBG a1=-1.8369405783295014 a2=0.8492677266366983 b0=1.0336939398317484 b1=-1.901703123986046 b2=0.8803363324614945, module: camillalib::biquad
Dec 06 07:33:25.060 DEBG a1=-1.9968020843311776 a2=0.9968071895070446 b0=1.0000419563011471 b1=-1.9968019486178439 b2=0.996765368919231, module: camillalib::biquad
Dec 06 07:33:25.061 DEBG a1=-1.8369405783295014 a2=0.8492677266366983 b0=1.0336939398317484 b1=-1.901703123986046 b2=0.8803363324614945, module: camillalib::biquad
Dec 06 07:33:25.062 DEBG a1=-1.9968020843311776 a2=0.9968071895070446 b0=1.0000419563011471 b1=-1.9968019486178439 b2=0.996765368919231, module: camillalib::biquad
Dec 06 07:33:25.063 DEBG a1=-1.8369405783295014 a2=0.8492677266366983 b0=1.0336939398317484 b1=-1.901703123986046 b2=0.8803363324614945, module: camillalib::biquad
Dec 06 07:33:25.063 DEBG a1=-1.9968020843311776 a2=0.9968071895070446 b0=1.0000419563011471 b1=-1.9968019486178439 b2=0.996765368919231, module: camillalib::biquad
Dec 06 07:33:25.103 DEBG a1=-1.8355350040667082 a2=0.8480680194658033 b0=1.0685274431028684 b1=-1.9672510045552176 b2=0.9112565768514447, module: camillalib::biquad
Dec 06 07:33:25.104 DEBG a1=-1.9968432367101128 a2=0.9968482114415093 b0=1.0000839266039652 b1=-1.9968429651699613 b2=0.9967645563776958, module: camillalib::biquad
Dec 06 07:33:25.105 DEBG a1=-1.8355350040667082 a2=0.8480680194658033 b0=1.0685274431028684 b1=-1.9672510045552176 b2=0.9112565768514447, module: camillalib::biquad
Dec 06 07:33:25.106 DEBG a1=-1.9968432367101128 a2=0.9968482114415093 b0=1.0000839266039652 b1=-1.9968429651699613 b2=0.9967645563776958, module: camillalib::biquad
Dec 06 07:33:25.107 DEBG a1=-1.8355350040667082 a2=0.8480680194658033 b0=1.0685274431028684 b1=-1.9672510045552176 b2=0.9112565768514447, module: camillalib::biquad
Dec 06 07:33:25.108 DEBG a1=-1.9968432367101128 a2=0.9968482114415093 b0=1.0000839266039652 b1=-1.9968429651699613 b2=0.9967645563776958, module: camillalib::biquad
Dec 06 07:33:25.109 DEBG a1=-1.8355350040667082 a2=0.8480680194658033 b0=1.0685274431028684 b1=-1.9672510045552176 b2=0.9112565768514447, module: camillalib::biquad
Dec 06 07:33:25.110 DEBG a1=-1.9968432367101128 a2=0.9968482114415093 b0=1.0000839266039652 b1=-1.9968429651699613 b2=0.9967645563776958, module: camillalib::biquad
Dec 06 07:33:25.111 DEBG a1=-1.8355350040667082 a2=0.8480680194658033 b0=1.0685274431028684 b1=-1.9672510045552176 b2=0.9112565768514447, module: camillalib::biquad
Dec 06 07:33:25.111 DEBG a1=-1.9968432367101128 a2=0.9968482114415093 b0=1.0000839266039652 b1=-1.9968429651699613 b2=0.9967645563776958, module: camillalib::biquad
Dec 06 07:33:25.147 DEBG a1=-1.83411745398109 a2=0.8468596968609028 b0=1.1045345439168777 b1=-2.035043847246535 b2=0.94325154620947, module: camillalib::biquad
Dec 06 07:33:25.148 DEBG a1=-1.9968838595222402 a2=0.9968887071409233 b0=1.000125912748603 b1=-1.9968834519675653 b2=0.9967632019469956, module: camillalib::biquad
Dec 06 07:33:25.149 DEBG a1=-1.83411745398109 a2=0.8468596968609028 b0=1.1045345439168777 b1=-2.035043847246535 b2=0.94325154620947, module: camillalib::biquad
Dec 06 07:33:25.150 DEBG a1=-1.9968838595222402 a2=0.9968887071409233 b0=1.000125912748603 b1=-1.9968834519675653 b2=0.9967632019469956, module: camillalib::biquad
Dec 06 07:33:25.151 DEBG a1=-1.83411745398109 a2=0.8468596968609028 b0=1.1045345439168777 b1=-2.035043847246535 b2=0.94325154620947, module: camillalib::biquad
Dec 06 07:33:25.151 DEBG a1=-1.9968838595222402 a2=0.9968887071409233 b0=1.000125912748603 b1=-1.9968834519675653 b2=0.9967632019469956, module: camillalib::biquad
Dec 06 07:33:25.153 DEBG a1=-1.83411745398109 a2=0.8468596968609028 b0=1.1045345439168777 b1=-2.035043847246535 b2=0.94325154620947, module: camillalib::biquad
Dec 06 07:33:25.153 DEBG a1=-1.9968838595222402 a2=0.9968887071409233 b0=1.000125912748603 b1=-1.9968834519675653 b2=0.9967632019469956, module: camillalib::biquad
Dec 06 07:33:25.155 DEBG a1=-1.83411745398109 a2=0.8468596968609028 b0=1.1045345439168777 b1=-2.035043847246535 b2=0.94325154620947, module: camillalib::biquad
Dec 06 07:33:25.155 DEBG a1=-1.9968838595222402 a2=0.9968887071409233 b0=1.000125912748603 b1=-1.9968834519675653 b2=0.9967632019469956, module: camillalib::biquad
Dec 06 07:33:25.187 DEBG a1=-1.8326878340625579 a2=0.8456427169851585 b0=1.1417545386589332 b1=-2.1051577416740463 b2=0.976358085937714, module: camillalib::biquad
Dec 06 07:33:25.187 DEBG a1=-1.996923959455508 a2=0.9969286832085741 b0=1.000167921647199 b1=-1.9969234156078615 b2=0.9967613054090214, module: camillalib::biquad
Dec 06 07:33:25.188 DEBG a1=-1.8326878340625579 a2=0.8456427169851585 b0=1.1417545386589332 b1=-2.1051577416740463 b2=0.976358085937714, module: camillalib::biquad
Dec 06 07:33:25.189 DEBG a1=-1.996923959455508 a2=0.9969286832085741 b0=1.000167921647199 b1=-1.9969234156078615 b2=0.9967613054090214, module: camillalib::biquad
Dec 06 07:33:25.190 DEBG a1=-1.8326878340625579 a2=0.8456427169851585 b0=1.1417545386589332 b1=-2.1051577416740463 b2=0.976358085937714, module: camillalib::biquad
Dec 06 07:33:25.191 DEBG a1=-1.996923959455508 a2=0.9969286832085741 b0=1.000167921647199 b1=-1.9969234156078615 b2=0.9967613054090214, module: camillalib::biquad
Dec 06 07:33:25.192 DEBG a1=-1.8326878340625579 a2=0.8456427169851585 b0=1.1417545386589332 b1=-2.1051577416740463 b2=0.976358085937714, module: camillalib::biquad
Dec 06 07:33:25.192 DEBG a1=-1.996923959455508 a2=0.9969286832085741 b0=1.000167921647199 b1=-1.9969234156078615 b2=0.9967613054090214, module: camillalib::biquad
Dec 06 07:33:25.193 DEBG a1=-1.8326878340625579 a2=0.8456427169851585 b0=1.1417545386589332 b1=-2.1051577416740463 b2=0.976358085937714, module: camillalib::biquad
Dec 06 07:33:25.194 DEBG a1=-1.996923959455508 a2=0.9969286832085741 b0=1.000167921647199 b1=-1.9969234156078615 b2=0.9967613054090214, module: camillalib::biquad
Dec 06 07:33:25.232 DEBG a1=-1.8312460313181862 a2=0.8444170225246738 b0=1.1802285206111651 b1=-2.177672254528314 b2=1.0106147251236366, module: camillalib::biquad
Dec 06 07:33:25.232 DEBG a1=-1.9969635436167783 a2=0.9969681466672777 b0=1.000209960750969 b1=-1.9969628631050405 b2=0.9967588664280463, module: camillalib::biquad
Dec 06 07:33:25.234 DEBG a1=-1.8312460313181862 a2=0.8444170225246738 b0=1.1802285206111651 b1=-2.177672254528314 b2=1.0106147251236366, module: camillalib::biquad
Dec 06 07:33:25.234 DEBG a1=-1.9969635436167783 a2=0.9969681466672777 b0=1.000209960750969 b1=-1.9969628631050405 b2=0.9967588664280463, module: camillalib::biquad
Dec 06 07:33:25.236 DEBG a1=-1.8312460313181862 a2=0.8444170225246738 b0=1.1802285206111651 b1=-2.177672254528314 b2=1.0106147251236366, module: camillalib::biquad
Dec 06 07:33:25.236 DEBG a1=-1.9969635436167783 a2=0.9969681466672777 b0=1.000209960750969 b1=-1.9969628631050405 b2=0.9967588664280463, module: camillalib::biquad
Dec 06 07:33:25.237 DEBG a1=-1.8312460313181862 a2=0.8444170225246738 b0=1.1802285206111651 b1=-2.177672254528314 b2=1.0106147251236366, module: camillalib::biquad
Dec 06 07:33:25.237 DEBG a1=-1.9969635436167783 a2=0.9969681466672777 b0=1.000209960750969 b1=-1.9969628631050405 b2=0.9967588664280463, module: camillalib::biquad
Dec 06 07:33:25.238 DEBG a1=-1.8312460313181862 a2=0.8444170225246738 b0=1.1802285206111651 b1=-2.177672254528314 b2=1.0106147251236366, module: camillalib::biquad
Dec 06 07:33:25.239 DEBG a1=-1.9969635436167783 a2=0.9969681466672777 b0=1.000209960750969 b1=-1.9969628631050405 b2=0.9967588664280463, module: camillalib::biquad
Dec 06 07:33:27.124 DEBG parsed command: Ok(GetMute), module: camillalib::socketserver
Dec 06 07:33:27.125 DEBG parsed command: Ok(GetVolume), module: camillalib::socketserver
Dec 06 07:33:27.130 DEBG parsed command: Ok(SetVolume(-36.0)), module: camillalib::socketserver
Dec 06 07:33:27.151 DEBG a1=-1.829792103309771 a2=0.8431827016028446 b0=1.2199942361347431 b1=-2.252660732954442 b2=1.0460570951127728, module: camillalib::biquad
Dec 06 07:33:27.151 DEBG a1=-1.9970026144406683 a2=0.9970070998834928 b0=1.0002520325670343 b1=-1.9970017968169378 b2=0.9967558849401887, module: camillalib::biquad
Dec 06 07:33:27.152 DEBG a1=-1.829792103309771 a2=0.8431827016028446 b0=1.2199942361347431 b1=-2.252660732954442 b2=1.0460570951127728, module: camillalib::biquad
Dec 06 07:33:27.153 DEBG a1=-1.9970026144406683 a2=0.9970070998834928 b0=1.0002520325670343 b1=-1.9970017968169378 b2=0.9967558849401887, module: camillalib::biquad
Dec 06 07:33:27.154 DEBG a1=-1.829792103309771 a2=0.8431827016028446 b0=1.2199942361347431 b1=-2.252660732954442 b2=1.0460570951127728, module: camillalib::biquad
Dec 06 07:33:27.154 DEBG a1=-1.9970026144406683 a2=0.9970070998834928 b0=1.0002520325670343 b1=-1.9970017968169378 b2=0.9967558849401887, module: camillalib::biquad
Dec 06 07:33:27.155 DEBG a1=-1.829792103309771 a2=0.8431827016028446 b0=1.2199942361347431 b1=-2.252660732954442 b2=1.0460570951127728, module: camillalib::biquad
Dec 06 07:33:27.156 DEBG a1=-1.9970026144406683 a2=0.9970070998834928 b0=1.0002520325670343 b1=-1.9970017968169378 b2=0.9967558849401887, module: camillalib::biquad
Dec 06 07:33:27.156 DEBG a1=-1.829792103309771 a2=0.8431827016028446 b0=1.2199942361347431 b1=-2.252660732954442 b2=1.0460570951127728, module: camillalib::biquad
Dec 06 07:33:27.157 DEBG a1=-1.9970026144406683 a2=0.9970070998834928 b0=1.0002520325670343 b1=-1.9970017968169378 b2=0.9967558849401887, module: camillalib::biquad
Dec 06 07:33:27.193 DEBG a1=-1.8283256253596238 a2=0.8419394337383995 b0=1.2611040659874722 b1=-2.3302242198837853 b2=1.0827339622750887, module: camillalib::biquad
Dec 06 07:33:27.194 DEBG a1=-1.9970411871622964 a2=0.9970455579875492 b0=1.0002941535225418 b1=-1.9970402318562108 b2=0.996752359771093, module: camillalib::biquad
Dec 06 07:33:27.195 DEBG a1=-1.8283256253596238 a2=0.8419394337383995 b0=1.2611040659874722 b1=-2.3302242198837853 b2=1.0827339622750887, module: camillalib::biquad
Dec 06 07:33:27.195 DEBG a1=-1.9970411871622964 a2=0.9970455579875492 b0=1.0002941535225418 b1=-1.9970402318562108 b2=0.996752359771093, module: camillalib::biquad
Dec 06 07:33:27.196 DEBG a1=-1.8283256253596238 a2=0.8419394337383995 b0=1.2611040659874722 b1=-2.3302242198837853 b2=1.0827339622750887, module: camillalib::biquad
Dec 06 07:33:27.196 DEBG a1=-1.9970411871622964 a2=0.9970455579875492 b0=1.0002941535225418 b1=-1.9970402318562108 b2=0.996752359771093, module: camillalib::biquad
Dec 06 07:33:27.197 DEBG a1=-1.8283256253596238 a2=0.8419394337383995 b0=1.2611040659874722 b1=-2.3302242198837853 b2=1.0827339622750887, module: camillalib::biquad
Dec 06 07:33:27.197 DEBG a1=-1.9970411871622964 a2=0.9970455579875492 b0=1.0002941535225418 b1=-1.9970402318562108 b2=0.996752359771093, module: camillalib::biquad
Dec 06 07:33:27.198 DEBG a1=-1.8283256253596238 a2=0.8419394337383995 b0=1.2611040659874722 b1=-2.3302242198837853 b2=1.0827339622750887, module: camillalib::biquad
Dec 06 07:33:27.199 DEBG a1=-1.9970411871622964 a2=0.9970455579875492 b0=1.0002941535225418 b1=-1.9970402318562108 b2=0.996752359771093, module: camillalib::biquad
Dec 06 07:33:27.235 DEBG a1=-1.8268466708656201 a2=0.8406873220519451 b0=1.3035982344030141 b1=-2.410440935749532 b2=1.120683352532843, module: camillalib::biquad
Dec 06 07:33:27.236 DEBG a1=-1.9970792635018544 a2=0.997083522637329 b0=1.0003363256093734 b1=-1.9970781698672664 b2=0.9967482906625434, module: camillalib::biquad
Dec 06 07:33:27.237 DEBG a1=-1.8268466708656201 a2=0.8406873220519451 b0=1.3035982344030141 b1=-2.410440935749532 b2=1.120683352532843, module: camillalib::biquad
Dec 06 07:33:27.238 DEBG a1=-1.9970792635018544 a2=0.997083522637329 b0=1.0003363256093734 b1=-1.9970781698672664 b2=0.9967482906625434, module: camillalib::biquad
Dec 06 07:33:27.239 DEBG a1=-1.8268466708656201 a2=0.8406873220519451 b0=1.3035982344030141 b1=-2.410440935749532 b2=1.120683352532843, module: camillalib::biquad
Dec 06 07:33:27.240 DEBG a1=-1.9970792635018544 a2=0.997083522637329 b0=1.0003363256093734 b1=-1.9970781698672664 b2=0.9967482906625434, module: camillalib::biquad
Dec 06 07:33:27.241 DEBG a1=-1.8268466708656201 a2=0.8406873220519451 b0=1.3035982344030141 b1=-2.410440935749532 b2=1.120683352532843, module: camillalib::biquad
Dec 06 07:33:27.242 DEBG a1=-1.9970792635018544 a2=0.997083522637329 b0=1.0003363256093734 b1=-1.9970781698672664 b2=0.9967482906625434, module: camillalib::biquad
Dec 06 07:33:27.242 DEBG a1=-1.8268466708656201 a2=0.8406873220519451 b0=1.3035982344030141 b1=-2.410440935749532 b2=1.120683352532843, module: camillalib::biquad
Dec 06 07:33:27.246 DEBG a1=-1.9970792635018544 a2=0.997083522637329 b0=1.0003363256093734 b1=-1.9970781698672664 b2=0.9967482906625434, module: camillalib::biquad
Dec 06 07:33:27.279 DEBG a1=-1.8253551280560973 a2=0.8394263131104951 b0=1.3475234730816652 b1=-2.4934014752960407 b2=1.1599491872687735, module: camillalib::biquad
Dec 06 07:33:27.280 DEBG a1=-1.9971168500844894 a2=0.997121000382547 b0=1.0003785561779217 b1=-1.9971156173816063 b2=0.9967436769075084, module: camillalib::biquad
Dec 06 07:33:27.281 DEBG a1=-1.8253551280560973 a2=0.8394263131104951 b0=1.3475234730816652 b1=-2.4934014752960407 b2=1.1599491872687735, module: camillalib::biquad
Dec 06 07:33:27.282 DEBG a1=-1.9971168500844894 a2=0.997121000382547 b0=1.0003785561779217 b1=-1.9971156173816063 b2=0.9967436769075084, module: camillalib::biquad
Dec 06 07:33:27.283 DEBG a1=-1.8253551280560973 a2=0.8394263131104951 b0=1.3475234730816652 b1=-2.4934014752960407 b2=1.1599491872687735, module: camillalib::biquad
Dec 06 07:33:27.283 DEBG a1=-1.9971168500844894 a2=0.997121000382547 b0=1.0003785561779217 b1=-1.9971156173816063 b2=0.9967436769075084, module: camillalib::biquad
Dec 06 07:33:27.284 DEBG a1=-1.8253551280560973 a2=0.8394263131104951 b0=1.3475234730816652 b1=-2.4934014752960407 b2=1.1599491872687735, module: camillalib::biquad
Dec 06 07:33:27.285 DEBG a1=-1.9971168500844894 a2=0.997121000382547 b0=1.0003785561779217 b1=-1.9971156173816063 b2=0.9967436769075084, module: camillalib::biquad
Dec 06 07:33:27.286 DEBG a1=-1.8253551280560973 a2=0.8394263131104951 b0=1.3475234730816652 b1=-2.4934014752960407 b2=1.1599491872687735, module: camillalib::biquad
Dec 06 07:33:27.287 DEBG a1=-1.9971168500844894 a2=0.997121000382547 b0=1.0003785561779217 b1=-1.9971156173816063 b2=0.9967436769075084, module: camillalib::biquad
Dec 06 07:33:27.321 DEBG a1=-1.8238509129038687 a2=0.8381563776489928 b0=1.3929272195795088 b1=-2.579197870021237 b2=1.2005761151868521, module: camillalib::biquad
Dec 06 07:33:27.321 DEBG a1=-1.9971539527378375 a2=0.9971579969793843 b0=1.0004208517836266 b1=-1.9971525801353769 b2=0.996738517798218, module: camillalib::biquad
Dec 06 07:33:27.322 DEBG a1=-1.8238509129038687 a2=0.8381563776489928 b0=1.3929272195795088 b1=-2.579197870021237 b2=1.2005761151868521, module: camillalib::biquad
Dec 06 07:33:27.322 DEBG a1=-1.9971539527378375 a2=0.9971579969793843 b0=1.0004208517836266 b1=-1.9971525801353769 b2=0.996738517798218, module: camillalib::biquad
Dec 06 07:33:27.323 DEBG a1=-1.8238509129038687 a2=0.8381563776489928 b0=1.3929272195795088 b1=-2.579197870021237 b2=1.2005761151868521, module: camillalib::biquad
Dec 06 07:33:27.323 DEBG a1=-1.9971539527378375 a2=0.9971579969793843 b0=1.0004208517836266 b1=-1.9971525801353769 b2=0.996738517798218, module: camillalib::biquad
Dec 06 07:33:27.324 DEBG a1=-1.8238509129038687 a2=0.8381563776489928 b0=1.3929272195795088 b1=-2.579197870021237 b2=1.2005761151868521, module: camillalib::biquad
Dec 06 07:33:27.324 DEBG a1=-1.9971539527378375 a2=0.9971579969793843 b0=1.0004208517836266 b1=-1.9971525801353769 b2=0.996738517798218, module: camillalib::biquad
Dec 06 07:33:27.325 DEBG a1=-1.8238509129038687 a2=0.8381563776489928 b0=1.3929272195795088 b1=-2.579197870021237 b2=1.2005761151868521, module: camillalib::biquad
Dec 06 07:33:27.325 DEBG a1=-1.9971539527378375 a2=0.9971579969793843 b0=1.0004208517836266 b1=-1.9971525801353769 b2=0.996738517798218, module: camillalib::biquad
Dec 06 07:33:28.439 DEBG Current buffer level: 8161.6765957446805, corrected capture rate: 100.00080729166667%, module: camillalib::audiodevice
Dec 06 07:33:28.439 DEBG Playback buffer level: 8161.6765957446805, signal rms: [-63.288425, -63.288425, -70.92276, -1000.0, -1000.0, -1000.0, -60.288425, -60.288425], module: camillalib::alsadevice
Dec 06 07:33:28.440 DEBG SetSpeed message received, module: camilladsp
Dec 06 07:33:38.465 DEBG Current buffer level: 8118.885106382979, corrected capture rate: 100.00192708333333%, module: camillalib::audiodevice
Dec 06 07:33:38.466 DEBG Playback buffer level: 8118.885106382979, signal rms: [-62.460854, -62.460854, -86.2536, -1000.0, -1000.0, -1000.0, -59.46085, -59.46085], module: camillalib::alsadevice
Dec 06 07:33:38.467 DEBG SetSpeed message received, module: camilladsp
Dec 06 07:33:48.489 DEBG Current buffer level: 8101.574468085107, corrected capture rate: 100.00236979166665%, module: camillalib::audiodevice
Dec 06 07:33:48.489 DEBG Playback buffer level: 8101.574468085107, signal rms: [-60.740166, -60.740166, -80.39853, -1000.0, -1000.0, -1000.0, -57.74017, -57.74017], module: camillalib::alsadevice
Dec 06 07:33:48.490 DEBG SetSpeed message received, module: camilladsp
Dec 06 07:33:58.517 DEBG Current buffer level: 8176.991489361702, corrected capture rate: 100.00041666666665%, module: camillalib::audiodevice
Dec 06 07:33:58.517 DEBG Playback buffer level: 8176.991489361702, signal rms: [-90.19825, -90.19825, -85.230194, -1000.0, -1000.0, -1000.0, -87.19826, -87.19826], module: camillalib::alsadevice
Dec 06 07:33:58.518 DEBG SetSpeed message received, module: camilladsp
thread 'AlsaPlayback' panicked at 'called `Result::unwrap()` on an `Err` value: Error("snd_pcm_state", UnsupportedOperation)', /cargo/registry/src/github.com-1ecc6299db9ec823/alsa-0.5.0/src/pcm.rs:159:75
Dec 06 07:34:04.782 INFO Playback thread has already stopped., module: camillalib::processing
^Cthread 'main' panicked at 'called `Result::unwrap()` on an `Err` value: Any { .. }Dec 06 07:34:31.258', src/bin.rs :247:DEBG38
Exit requested..., module: camilladsp
ubuntu@ubuntu:/usr/local/etc/camilladsp/logs$ sudo systemctl status camilladsp
○ camilladsp.service - CamillaDSP Daemon
Loaded: loaded (/etc/systemd/system/camilladsp.service; enabled; vendor preset: enabled)
Active: inactive (dead) since Mon 2021-12-06 07:31:25 UTC; 3min 17s ago
Process: 3456 ExecStart=/usr/local/bin/camilladsp -a0.0.0.0 -p5000 -g-30 --logfile /usr/local/etc/camilladsp/logs/log.txt -ldebug /usr/local/etc/camilladsp/config192XO.yml (code=killed, si>
Main PID: 3456 (code=killed, signal=TERM)
CPU: 36min 24.322s
Dec 05 16:27:11 ubuntu systemd[1]: Started CamillaDSP Daemon.
Dec 05 16:29:05 ubuntu camilladsp[3456]: thread 'AlsaPlayback' panicked at 'called `Result::unwrap()` on an `Err` value: Error("snd_pcm_state", UnsupportedOperation)', /cargo/registry/src/gith>
Dec 05 16:29:05 ubuntu camilladsp[3456]: note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
Dec 06 07:31:25 ubuntu systemd[1]: Stopping CamillaDSP Daemon...
Dec 06 07:31:25 ubuntu systemd[1]: camilladsp.service: Deactivated successfully.
Dec 06 07:31:25 ubuntu systemd[1]: Stopped CamillaDSP Daemon.
Dec 06 07:31:25 ubuntu systemd[1]: camilladsp.service: Consumed 36min 24.322s CPU time.
Code:
ubuntu@ubuntu:~$ /usr/local/bin/camilladsp -a0.0.0.0 -p5000 -g-30 -ldebug /usr/local/etc/camilladsp/config192XO.yml
Dec 06 08:07:17.581 DEBG Read config file Some("/usr/local/etc/camilladsp/config192XO.yml"), module: camilladsp
Dec 06 08:07:17.582 DEBG Config is valid, module: camilladsp
Dec 06 08:07:17.583 DEBG Start websocket server on 0.0.0.0:5000, module: camillalib::socketserver
Dec 06 08:07:17.583 DEBG Wait for config, module: camilladsp
Dec 06 08:07:17.583 DEBG Config ready, module: camilladsp
Dec 06 08:07:17.584 DEBG Build new pipeline, module: camillalib::filters
Dec 06 08:07:17.584 DEBG Using channels [true, true], module: camilladsp
Dec 06 08:07:17.584 DEBG Build from config, module: camillalib::filters
Dec 06 08:07:17.585 DEBG Buffer frames 16384, module: camillalib::alsadevice
Dec 06 08:07:17.585 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.9981505111904521 b1=-1.9963010223809041 b2=0.9981505111904521, module: camillalib::biquad
Dec 06 08:07:17.585 DEBG a1=-1.838334102564905 a2=0.8504587169940455 b0=1 b1=-1.838334102564905 b2=0.8504587169940455, module: camillalib::biquad
Dec 06 08:07:17.586 DEBG a1=-1.9967604006840272 a2=0.996765639706586 b0=1 b1=-1.9967604006840272 b2=0.996765639706586, module: camillalib::biquad
Dec 06 08:07:17.586 DEBG Build from config, module: camillalib::filters
Dec 06 08:07:17.587 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.9981505111904521 b1=-1.9963010223809041 b2=0.9981505111904521, module: camillalib::biquad
Dec 06 08:07:17.587 DEBG a1=-1.838334102564905 a2=0.8504587169940455 b0=1 b1=-1.838334102564905 b2=0.8504587169940455, module: camillalib::biquad
Dec 06 08:07:17.588 DEBG a1=-1.9967604006840272 a2=0.996765639706586 b0=1 b1=-1.9967604006840272 b2=0.996765639706586, module: camillalib::biquad
Dec 06 08:07:17.588 DEBG Build from config, module: camillalib::filters
Dec 06 08:07:17.588 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.0000017103058908716714 b1=0.0000034206117817433428 b2=0.0000017103058908716714, module: camillalib::biquad
Dec 06 08:07:17.589 DEBG Building delay filter 'sub-align' with delay 528 samples, module: camillalib::basicfilters
Dec 06 08:07:17.589 DEBG a1=-1.838334102564905 a2=0.8504587169940455 b0=1 b1=-1.838334102564905 b2=0.8504587169940455, module: camillalib::biquad
Dec 06 08:07:17.589 DEBG a1=-1.9967604006840272 a2=0.996765639706586 b0=1 b1=-1.9967604006840272 b2=0.996765639706586, module: camillalib::biquad
Dec 06 08:07:17.590 DEBG Build from config, module: camillalib::filters
Dec 06 08:07:17.590 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.9981505111904521 b1=-1.9963010223809041 b2=0.9981505111904521, module: camillalib::biquad
Dec 06 08:07:17.591 DEBG a1=-1.838334102564905 a2=0.8504587169940455 b0=1 b1=-1.838334102564905 b2=0.8504587169940455, module: camillalib::biquad
Dec 06 08:07:17.591 DEBG a1=-1.9967604006840272 a2=0.996765639706586 b0=1 b1=-1.9967604006840272 b2=0.996765639706586, module: camillalib::biquad
Dec 06 08:07:17.592 DEBG Build from config, module: camillalib::filters
Dec 06 08:07:17.592 DEBG a1=-1.9962976017691223 a2=0.9963044429926857 b0=0.9981505111904521 b1=-1.9963010223809041 b2=0.9981505111904521, module: camillalib::biquad
Dec 06 08:07:17.593 DEBG a1=-1.838334102564905 a2=0.8504587169940455 b0=1 b1=-1.838334102564905 b2=0.8504587169940455, module: camillalib::biquad
Dec 06 08:07:17.593 DEBG a1=-1.9967604006840272 a2=0.996765639706586 b0=1 b1=-1.9967604006840272 b2=0.996765639706586, module: camillalib::biquad
Dec 06 08:07:17.593 DEBG build filters, waiting to start processing loop, module: camillalib::processing
Dec 06 08:07:17.593 DEBG Playback: supported channels, min: 8, max: 8, list: [8], module: camillalib::alsadevice
Dec 06 08:07:17.594 DEBG Playback: setting channels to 8, module: camillalib::alsadevice
Dec 06 08:07:17.594 DEBG Playback: supported samplerates: Discrete([44100, 48000, 88200, 96000, 176400, 192000]), module: camillalib::alsadevice
Dec 06 08:07:17.594 DEBG Playback: setting rate to 192000, module: camillalib::alsadevice
Dec 06 08:07:17.594 DEBG Playback: supported sample formats: [S32LE], module: camillalib::alsadevice
Dec 06 08:07:17.595 DEBG Playback: setting format to S32LE, module: camillalib::alsadevice
Dec 06 08:07:17.595 DEBG Capture: supported channels, min: 1, max: 32, list: [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32], module: camillalib::alsadevice
Dec 06 08:07:17.595 DEBG Capture: setting channels to 2, module: camillalib::alsadevice
Dec 06 08:07:17.596 DEBG Capture: supported samplerates: Range(8000, 192000), module: camillalib::alsadevice
Dec 06 08:07:17.596 DEBG Capture: setting rate to 192000, module: camillalib::alsadevice
Dec 06 08:07:17.596 DEBG Capture: supported sample formats: [S16LE, S24LE, S24LE3, S32LE, FLOAT32LE], module: camillalib::alsadevice
Dec 06 08:07:17.596 DEBG Capture: setting format to S32LE, module: camillalib::alsadevice
Dec 06 08:07:17.597 DEBG Opening audio device "hw:CARD=Loopback,DEV=0" with parameters: HwParams { channels: Ok(2), rate: "Ok(192000) Hz", format: Ok(S32LE), access: Ok(RWInterleaved), period_size: "Ok(4096) frames", buffer_size: "Ok(32768) frames" }, SwParams(avail_min: Ok(4096) frames, start_threshold: Ok(0) frames, stop_threshold: Ok(32768) frames), module: camillalib::alsadevice
Dec 06 08:07:17.597 DEBG Audio device "hw:CARD=Loopback,DEV=0" successfully opened, module: camillalib::alsadevice
Dec 06 08:07:17.597 DEBG Capture thread ready to start, module: camilladsp
Dec 06 08:07:17.598 DEBG Opening audio device "hw:CARD=Pro53791076,DEV=0" with parameters: HwParams { channels: Ok(8), rate: "Ok(192000) Hz", format: Ok(S32LE), access: Ok(RWInterleaved), period_size: "Ok(2048) frames", buffer_size: "Ok(16384) frames" }, SwParams(avail_min: Ok(2048) frames, start_threshold: Ok(6144) frames, stop_threshold: Ok(16384) frames), module: camillalib::alsadevice
Dec 06 08:07:17.598 DEBG Audio device "hw:CARD=Pro53791076,DEV=0" successfully opened, module: camillalib::alsadevice
Dec 06 08:07:17.598 DEBG Playback thread ready to start, module: camilladsp
Dec 06 08:07:17.599 DEBG Both capture and playback ready, release barrier, module: camilladsp
Dec 06 08:07:17.599 DEBG Supervisor loop starts now!, module: camilladsp
Dec 06 08:07:17.599 DEBG Processing loop starts now!, module: camillalib::processing
Dec 06 08:07:17.600 DEBG Starting captureloop, module: camillalib::alsadevice
Dec 06 08:07:17.600 DEBG Starting playback loop, module: camillalib::alsadevice
Dec 06 08:07:17.600 INFO Capture device supports rate adjust, module: camillalib::alsadevice
Dec 06 08:07:17.601 DEBG Starting capture, module: camillalib::alsadevice
Dec 06 08:07:17.654 INFO Starting playback from Prepared state, module: camillalib::alsadevice
Dec 06 08:07:27.634 DEBG Current buffer level: 9287.2, corrected capture rate: 99.971484375%, module: camillalib::audiodevice
Dec 06 08:07:27.635 DEBG SetSpeed message received, module: camilladsp
Dec 06 08:07:27.635 DEBG Playback buffer level: 9287.2, signal rms: [-1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0, -1000.0], module: camillalib::alsadevice
Dec 06 08:07:37.666 DEBG Current buffer level: 9024.868085106384, corrected capture rate: 99.97833333333334%, module: camillalib::audiodevice
Dec 06 08:07:37.667 DEBG Playback buffer level: 9024.868085106384, signal rms: [-56.581455, -56.581455, -84.5878, -1000.0, -1000.0, -1000.0, -53.58146, -53.58146], module: camillalib::alsadevice
Dec 06 08:07:37.668 DEBG SetSpeed message received, module: camilladsp
Dec 06 08:07:47.262 INFO Playback thread has already stopped., module: camillalib::processing
^Cthread 'main' panicked at 'called `Result::unwrap()` on an `Err` value: Any { .. }Dec 06 08:08:23.723', src/bin.rs :247DEBG:38
Code:
ubuntu@ubuntu:~$ cat /usr/local/etc/camilladsp/config192XO.yml
devices:
samplerate: 192000
chunksize: 8192
enable_rate_adjust: true
capture:
type: Alsa
channels: 2
device: "hw:CARD=Loopback,DEV=0"
format: S32LE
playback:
type: Alsa
channels: 8
device: "hw:CARD=Pro53791076,DEV=0"
format: S32LE
mixers:
to8chan:
channels:
in: 2
out: 8
mapping:
- dest: 6
sources:
- channel: 0
gain: 0
inverted: false
- dest: 7
sources:
- channel: 1
gain: 0
inverted: false
- dest: 2
sources:
- channel: 0
gain: 0
inverted: false
- dest: 2
sources:
- channel: 1
gain: 0
inverted: false
- dest: 0
sources:
- channel: 0
gain: 0
inverted: false
- dest: 1
sources:
- channel: 1
gain: 0
inverted: false
filters:
vol:
type: Loudness
parameters:
ramp_time: 200.0
reference_level: -30.0
high_boost: 10.0
low_boost: 15.0
gain-pre:
type: Gain
parameters:
gain: -30.0
inverted: false
gain-post:
type: Gain
parameters:
gain: 27.0
inverted: false
gain-sub:
type: Gain
parameters:
gain: 3.0
inverted: false
gain-orange:
type: Gain
parameters:
gain: -3.0
inverted: false
main-highpass:
type: BiquadCombo
parameters:
type: LinkwitzRileyHighpass
freq: 80
order: 4
sub-lowpass:
type: BiquadCombo
parameters:
type: LinkwitzRileyLowpass
freq: 80
order: 4
sub-align:
type: Delay
parameters:
delay: 2.75
unit: ms
subsample: false
conv-l:
type: Conv
parameters:
type: Wav
filename: /usr/local/etc/camilladsp/MLP192.wav
channel: 0
conv-r:
type: Conv
parameters:
type: Wav
channel: 1
conv-ls:
type: Conv
parameters:
type: Wav
channel: 2
conv-rs:
type: Conv
parameters:
type: Wav
channel: 3
pipeline:
- type: Mixer
- type: Filter
channel: 6
names:
- main-highpass
- gain-pre
- gain-post
- vol
- type: Filter
channel: 7
names:
- main-highpass
- gain-pre
- gain-post
- vol
- type: Filter
channel: 2
names:
- sub-lowpass
- gain-sub
- sub-align
- gain-pre
- gain-post
- vol
- type: Filter
channel: 0
names:
- main-highpass
- gain-orange
- gain-pre
- gain-post
- vol
- type: Filter
channel: 1
names:
- main-highpass
- gain-orange
- gain-pre
- gain-post
- vol
You also asked for this:
Code:
ubuntu@ubuntu:~$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Loopback [Loopback], device 0: Loopback PCM [Loopback PCM]
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 0: Loopback [Loopback], device 1: Loopback PCM [Loopback PCM]
Subdevices: 7/8
card 1: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 8/8
card 2: Pro53791076 [ADI-2 Pro (53791076)], device 0: USB Audio [USB Audio]
Subdevices: 1/1
ubuntu@ubuntu:~$ arecord -l
**** List of CAPTURE Hardware Devices ****
Subdevices: 8/8
Subdevices: 8/8
Subdevices: 1/1
Except I can now see that the error report is not abbreviatedI think the error reported in the status report I shared previously that @phofman highlighted is all that the logs show as far as I can see:
Code:thread 'AlsaPlayback' panicked at 'called `Result::unwrap()` on an `Err` value: Error("snd_pcm_state", UnsupportedOperation)', /cargo/registry/src/github.com-1ecc6299db9ec823/alsa-0.5.0/src/pcm.rs:159:75 note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace Dec 06 07:34:04.782 INFO Playback thread has already stopped., module: camillalib::processing ^Cthread 'main' panicked at 'called `Result::unwrap()` on an `Err` value: Any { .. }Dec 06 07:34:31.258', src/bin.rs :247:DEBG38 Exit requested..., module: camilladsp
Yes it's the same stuff, but the published 0.6.3 was built before that patch made it into a new release of the alsa crate. It doesn't fix the problem though, just gives a more detailed panic message.Maybe still some issue around the code you patched in the alsa crate? Thanks!
johnanon: It looks like you are hitting an Alsa bug where the state call returns an invalid state. This triggers a panic that kills the playback thread, and camilladsp gets stuck.
Can you try the 1.0.0 preview? It will still panic, but should exit properly when that happens.
Fantastic! Yes, v1.0.0-alpha4 stops CamillaDSP gracefully despite the ALSA crash.
I'll now re-enable the systemd and udev options and hopefully all will be well. Many thanks.
Code:
2021-12-06 12:13:52.936433 INFO [src/processing.rs:29] Playback thread has already stopped.
2021-12-06 12:13:52.971496 INFO [src/alsadevice.rs:681] Processing thread has already stopped.
2021-12-06 12:13:52.972186 WARN [src/bin.rs:421] Capture, Playback and Processing threads have exited
2021-12-06 12:13:52.972641 DEBUG [src/bin.rs:902] Restarting with new config
2021-12-06 12:13:52.972952 DEBUG [src/bin.rs:844] Wait for config
2021-12-06 12:13:52.973259 DEBUG [src/bin.rs:847] No config and not in wait mode, exiting!
This is probably a very dumb question but is there any advantage to compiling CamillaDSP vs using a pre-built binary? I run CamillaDSP on aarch64 based systems, I assume the pre-built binary has Neon enabled?
Michael
Michael
I use CM4 with pre-built aarch64 binaries for a few weeks and I am very pleased. Load of the camilladsp process is approx 26% on 3-way with IIR crossover filters, delays, EQs at 96kHz . I left the cpu fan off (approx 45C). Thanks to phofman it runs as USB Gadget with rate adjust reliably in Linux and Windows. Absolutely stable, no drops, no pops, no crackling.
(if you have USB sound card, you would need RPi4)
The prebuilt aarch64 binary has neon enabled yes. Compiling yourself should not give any speed advantage. It's only worth doing if you want to build a customized version, for example with 32-bit float calculations.
Awesome, thank you so much!
Michael
- PC Based
- CamillaDSP - Cross-platform IIR and FIR engine for crossovers, room correction etc
