I have a CD6 bought in or around 2000. It has been stored for years as it had a sound issue in that there is very little low frequency output. This player has both single ended and balnaced outputs, both exhibit the same problem. This player has as it's Dac a first version Dacmagic Dac inside. I think I need to check the opamps on the Dac board and also the voltage regulators to check they are functioning properly. Are there other areas that I should be checking e.g Caps or other components?
I repaired my original Dac Magic Mk 2 some time ago, I don't remember the symptoms but a general recap worked wonders, I didn't have to change any silicon. Probably not what's inside your CD player but my later DacMagic which upsamples, sounds even better, but its more modern, mostly surface mount, I've not fancied working on that yet. This might be useful: http://audiopurist.pl/en/mods-en/cambridge-audio-dacmagic-100-modification-eng/
Lack of LF can only really be caused by either a degraded cap directly in the signal path but therein lies a conundrum... if both left and right channels are affected then that is unlikely.
Only three things come to mind.
1/ You have a phase inversion on one channel somewhere in the entire path from source to speaker causing apparent lack of bass.
2/ The DAC has been modified and an unsuitable/incorrect choice of parts has been used.
3/ The DAC is AC coupled at the output and you are loading it to heavily with what ever you have it connected to. That would take some doing but stranger things have happened.
It can not be an opamp causing this.
Ideally you should play a frequency sweep test tone and monitor the output on a scope and see what the response looks like.
Thanks Mooly. The CD player appears not to have been modified and is untouched by me. I got it from an open box sale at Richer Sounds. In what way could it be overloaded? I do not have any problems with other players.
Both channels are affected wiht either single ended or balanced. I was given a Velleman hand held oscilloscope many years ago but have never bothered to try to use it which is really not good enough I know. I know that I should at least have a go at using it and if you have any "idiots guide" info that might assist I would be very grateful. I have looked for same online but I could be reading Swahili (other languages are available) as it seems somewaht incomprehensible.
If an output coupling cap were to low in value for the impedance it works into. For example a 10uF cap working into 1k loading would be -3db down at around 160HzIn what way could it be overloaded?
The scope simply measures voltage but instead of giving a number on a display it traces the voltage out over time.Both channels are affected wiht either single ended or balanced. I was given a Velleman hand held oscilloscope many years ago but have never bothered to try to use it which is really not good enough I know.
You need a simple test tone to begin with such as 1kHz tone to get the idea of what it does. Attached is a Mono MP3 File that plays for 30 seconds and goes from 10Hz to 10kHz. If you play the file on something suitable and look at the output on the scope you should begin to make sense of what happens and what the scope shows. You can use the scope to look at the output from the amp playing the tone and see what really happens.
The scope should show something like this and the amplitude (from top to bottom) should be constant.
If you post details of the scope (model etc) we can talk you through getting it to work.
Thanks for that. I will burn the test tone to a CD and play it after I have found the correct scope setting to record the results.
https://cdn.velleman.eu/downloads/0/user/manual_hps40_10-uk.pdf
Thanks for the link 🙂
The important settings are these:
The input sensitivity determines how far the trace moves up and down for a given input voltage. At this stage you just want something in the right ballpark such as 2 volts per/division. The Timebase set how long the 'spot' tracing the waveform out takes to move across the screen.
A 1kHz sine takes 1ms (1 millisecond) for 1 cycle and so a setting of say 1ms/division would trace out 10 cycles if the screen has 10 divisions on the horizontal axis.
The frequency sweep will look a bit like this but my file has the frequency increasing smoothly rather than in jumps like this one. Notice how the amplitude (top to bottom) remains the same. That is what you want to see.
I would recommend that to begin with you set the scope input to AC coupling and use the X1 setting on the probe.
- Digital Source
- Cambridge CD6 sound issues
