Hi
I am trying to fix my Azur 840E Preamp from Cambridge audio. Some of the resistors are damaged and needs to be replaced. Problem is that they are burnt so bad that the color code is no longer visible.
Therefore I was wondering if anybody on this forum have the scematics or the service manual for this preamp?
Any help is appreciated
ohmsweetohm
ohmsweetohm
Hi ohmsweetohm,
please send me SM for 840E, my preamp is broken, thanks a lot.
my private mail is zoran.ivacic@gmail.com
Hello!
I am too searching service manual for 840E and 851E
If anybody have,then please share and send it to my email: audimees@gmail.com
Hello!
I am searching service manual for Cambridge 840E pre-amplifier.
I need to replace the encoder.
Please share it
ryzhenko1975@gmail.com
Please share it
Hey. I wanted to ask you to send me a service manual for Cambridge Audio Azur 840E. I have two faults, the encoder when rotating to the right reduces the volume abruptly and Vice versa. Also, sometimes the signal in the left channel disappears, but if you rotate the encoder, then for a split second the signal is restored with each new step, but then again disappears.
I would like to ask if it is possible to send me a service manual on Azur 840E to the address AlexGeForce@gmail.com
Thanks so much
Thanks so much
Hello,
Would you please send me a service manual for the Cambridge Audio 840E? I'm having some trouble with the volume encoder.
If possible please e-mail to epascaru@yahoo.com.
Many thanks.
Edi
Many thanks.
Edi
- Analog Line Level
- Cambridge audio Azur 840E Schematic, Service Manual
