That looks better but without more details, I'm not sure what you did. You shouldn't have to modify from the original values unless there is another problem.
I agree but I was unable to find the original driver transistors, so I had to use substitutes. I used the JBL BP1200.1 circuit as a reference. My amp had R202 as 510 ohms. i changed to 910 ohm as per the JBL diagram.
Across the positive and negative rectifiers. From ground to the center leg of the rectifiers i get no voltage reading but on the outer legs there is 35v present.
