cables from power supply to tube mono blocks
I recently finished making the umbilical cable for my phono stage and used these. The construction quality is excellent and it has top notch cable isolation, stress protection and locking. I found it fiddly to construct with and you need to allow yourself plenty of time for pausing and problem solving - whatever you do don't rush it. The solder buckets are quite close together and clumsy amateurs like me will struggle 🙂 Once soldered though, a neat rubber grommet with individual holes for the cables slides over the solder buckets and ensures complete isolation.
Not cheap, but high quality in my opinion. How many times are you going to build an offboard power supply ? My opinion is to do it right.
62LC-16F12-10SN(771) | Amphenol 62LC Series, 10 Pole Cable Mount Connector Plug, 12 Shell Size, Female Contacts, Bayonet Mating | Amphenol
Nice Looking plug, I assume they have a chassis mount mate. Seems like Amphenol has quite a few options.
thanks for the information.
I have a few of these if you're willing to take a chance. They look similar but I can't find any manufacturer or markings. So I don't know the electrical ratings.
Nice looking connectors. The most important feature for safety is the mate first/break last contacts, to avoid arcing. Are these solder type connectors? What type of cable do you use with these?
Hello - Do you know if these connectors are "pre-earth first-mate last-break contacts", they are the nicest looking connectors I've looked at.
Rick
Hi Jack,
Ah - yes. But in those days you were allowed to lose a few hobbyists a year to accidents like that!
They had metal covers so you could use them as a plug, or a socket. They did work very well. One important note to pay attention to, the live contacts were always the female end!
-Chris
I had a 16kv neon transformer jump out and bite me on the arm many years ago. It was a week and a half before I got the feeling back in my arm. That transformer had a metal case and arched from the case to my arm, about 3 inches. It's like keeping a black mamba as a pet.
Hi Rick,
Since you should never be mating live equipment, the common, or ground connection shouldn't matter. You can cause damage by plugging in a cable like this charged or live. So you are always going to have a discharge (bleeder) resistor on any HT line. That's to make your stuff safe to plug in after some period of time.
I'm bringing this up simply because it's easy to forget to plug in a power supply, and the tendency is to connect it as soon as you remember it isn't. You have to give the supply a chance to discharge before doing this.
-Chris
Hi Rick,
-Chris
Hi Chris - No it's likely that I will connect the power cable to the mono-blocks and assuming it all works I'll leave it connected until something breaks. The filaments have a slow start circuit and the B+ wont engage until the filaments are heated. Thanks for the advices.
Rick
