Which stuff is the good stuff? They have a price for 5/8" and 3/4" stranded woven bamboo plywood, what are you actually looking for?
If buy bamboo plywood from factory in China, Minimum Order Quantity is 5 Cubic Meters, price at US$1,100 - 1,500/Cubic Meter.
My math might be wrong but that works out to about $65~$90 for a sheet of 20mm thick bamboo plywood at 4' x 8' per sheet. That doesn't seem to be too bad.
How many sheets per order as minimum?
4' = 122ish cm
8' = 243ish cm
So each sheet is 2.96 meters square, so 5 cubic meters means 1.68m tall stack of 4' x 8' sheets of bamboo plywood. So in theory a 1680mm tall stack gets you 84 sheets at 20mm thickness. Adjust the number of sheets by the thickness of the material, or by changing the dimension of the sheets you order.
Hopefully my sleep deprived math isn't wrong. I based the pricing upon that minimum order and your price range.
$1,100 per cubic meter = $5,500 / 84 = $65.50 per sheet
$1,500 per cubic meter = $7,500 / 84 = $89.30 per sheet
Again, if the thickness is different or overall sheet dimensions are different that will impact your cost per sheet. But I guess that works as a rough guide.
8' = 243ish cm
To figure the price at the local lumber shop, add shipping from China, distrib markup, shipping to the dealer, dealer markup.
dave
The new cabinets made with Finland WISA birch plywood arrived.
The small bass reflex cabinet was designed by Mark. 18mm birch plywood was used for front panel and other panels used 12mm birch plywood. The dimension of cabinet is 154Wx190Dx284Hmm.
Tony,
They look nice!
Will this be available at Fotan or TuenMun?
This suits on my computer desk. : )
Mark L
They look nice!
Mark L
Be care for the cone which is easy to be damaged.
- More Vendors...
- Twin Audio
- Cabinets made with Finland Birch Plywood
