i dont beleave it was bild.
something simular was bild with lab 15 i believe,but i dont remember what tread it was
would be intresting tho.
i stil have the drawing somewhere.
Where were the HR inputs for this?
I saw a few different input pages from your EPA to Xoc1's and Djim's. Just want to simulate the correct one for drivers. Most likely use a BC 18" or 18 Sound
Did this ever get built?
I completely forgot about this design drawing.
Not seeing the image....
Well thats just great. I dont know how to use Akabak. But hopefully I can figure out the HR inputs or just have others input the drivers and post simulations.
Thanks again epa.
Thanks again epa.
images are hosted by me ,free to view for everyone(also non members)Not seeing the image....
you should be able to see them.
ive modelled severall cabs like that.Well thats just great. I dont know how to use Akabak. But hopefully I can figure out the HR inputs or just have others input the drivers and post simulations.
Thanks again epa.
this one is simpler to bild,rectangular
best is to choose the driver,then the size,f3 and then model it from scrath.
Never built a design like this before. So I guess I could just start with the 21" since I have it already. F3 would be 30hz to stay with this thread. Now using the 21" might get large so not sure.
I am guessing maybe 450-500liters.
Do the 45 degree angle pieces not attached to the perpendicular sides or are they?
Hard to tell from the picture. I was just thinking how I would build this. I have a Alpine 15SWS sitting around also that can be used. BUT I was thinking that the 21" could be used also and probably much better for SPL. Then I can just buy wood and go from there.😀
The more I look at this build the more fun it looks like building.
Could you upload them to the DIYAudio site by using the "manage attachments" option when creating a message? That way, once the site is accessible to someone, the images will also be accessible.
Will have to find which EPA posted HR input post it was but I just tried my driver(21SW152) in HR and it looks great.
This was close to maximum SPL out of this cabinet. Was curious how much a pair could get to 140db at 30hz. 😀 Single cabinet does about 133db so another cab is pretty darn close. 24hz 3rd order Hpass.
Now that I rethink it do I need to find the post that S1-S4 = for the symmetrical design?
The last design I posted is clearly a TH with expanding horn path.
Will wait to hear from others now before posting anymore.😕
chrapladm, so this box looks better than the Othorn. Does your design use 2 drivers in a single cab?
This is not my design, but NO the EPA TH does not do better tan the Othorn.
Before Hpass the Othorn has a db or two more than the EPA TH. BUT I am not after the very last drop of SPL. SO while the othorn does amazingly well I just REALLY like the post 795 design. And I dont have the HR inputs for that design. I did find the Akabak inputs for EPA's design that was very similar but not sure how to input those parameters into HR. Also not sure if Xoc1 changed anything either.
SO between a few members here the drawing changed ever so slightly. I am not sure what is even going on to figure it out. Most drawings I can see and input into HR. Not sure about the CAD drawing.
SO the design in post #796 was a TH made to be flat to 30hz with four cabs.(using an 18") The Othorn does beat it by 1db but EPA's horn was designed for an 18".
SO hopefully some of the guys will be available for an update on the above drawing. Once I can simulate and put things on paper I will start building.
Sorry for the babble. I love the look of this design and the SPL is almost the same as the Othorn. Othorn is probably an easier build. BUT I like being different. 😀
s1/s2 is 830
s3 is 1440
s4 is 1567
s5 is 1740
s6 is 2036
this what i measured
for an 18"driver so vtc ~10000 incl spacers for excursion
but al of these can be changed
i cant find the akabak files for this specific design.
i found this 21" design wich is semi sym ,with a large troat chamber.
s3 is 1440
s4 is 1567
s5 is 1740
s6 is 2036
- Subwoofers
- C/E/X PA Flat to 30 (FT30) PA TH Awesomeness
