Bybee Fraud Protection
Why would you shield a block of acrylic..... How can a piece of foil be an active component....
Its felt it says so on the web site, the rest is concentrated bull s*** suspended in epoxy. I cannot believe people are falling for this and trying to justify its existence. All I can say is its an utter disgrace, a total fraud and this and similar products negate any real improvements in audio reproduction as they distract from reality and give the hobby a bad name...
Oh and he is now supposedly a Quantum physicist.....
As mentioned in the link below this joke goes even further and is in some good company, namely the following high tech devices....
Stein Music Harmonizers.
Shakti Hollographs.
Stillpoints Apertures.
So a challenge to all you believers/supporters of this farcical stuff, provide some evidence or even a write up that has come from a respectable source... that discounts most audio based sources.
Acetone, tolulene, petrol will dissolve acrylic.
Does the acrylic upper sheet appear to contain other ingredients/inclusions or is the foil the only active component ?.
Is the 'felt' normal felt or perhaps shielding cloth ?.
Dan.
Why do you presume the foil (or any of the other materials for that matter) is active? I don't think it does anything but capitalize on vulnerable customer's expectation bias. My presumption is that the DESIGNED purpose is nothing more than pocket money extraction.
Mike
Look for the little antenna out one side. That is how Jack Bybee has them in his listening room.
Nothing about antennas implied here...
blend of materials and technology that resonate with the air molecules in the listening area, enabling the
transmission of sound without the usual time misalignment of high frequencies.
Admit it John you're laughing your $$$ off too. 😉
Search for crystals
I will try to dissolve the acrylic. It may take some time since I need to buy the paint thinner and I forgot to do it last weekend (makes note to do something stupid 🙂).
Hopefully they can be seen. Since the "case" is only 1/4" thick, I've got a bad feeling.
Does anyone know if acrylic blocks electro-magnetic waves?
Look CLOSELY at the diagram given in the Bybee blurb. See the antenna?
I saw the little tails hanging down (not on the side), and the document clearly states "The Room Neutralizer antenna can be positioned in any direction".
My question is, since the device and the antenna do not seem to actually do anything, who cares what direction the antenna is pointing?
Just accept, don't question, the truth is out there...
We have to accept that these type of products work by belief and we mere mortals unadorned by Midas ears and systems way to cheap to hear the benefits have to scoff and scorn and vent our jealousy by mocking such technological marvels... And a bargain at only $2000 per pack of 8.
Bybee Technologies | Power and Room Products
Of course they are approved, though my comment was probably not appreciated🙂
BYBEE QUANTUM SIGNAL ENHANCER
Align the antennas with any Ley lines in your vicinity, this allows the best signal pick up from these mystical energy highways improving the effect. I inadvertently misaligned my set and invoked a demon in my listening room, but a couple of rounds of Bybee bullets came to the rescue.
I bought a JC-2 clone from China and it measures really great, basically I am measuring my test setup. All this is brought about by an amazingly elegant connection between just 6 transistors.
Are you the same person as the brilliant guy who designed this little marvel?
