Building with the Soekris dam1121
2,2 nF. Wanted a little lower than stock 1,5nF for -3dB at 165 khz.
10 nF -> 26k... isn't that a little low - but it will work!?
Of course :D Phase shift could play a role already with this low low pass. In terms of tube stuff. Possible :D
I have to do the soldering still and will remove it without replacement.
I know you said that your amp does not like HF but do we actually know what Frequenz could come out of the dam1121 and would it really audibly “hurt” your amp?
I’m designing a small pcb for connecting 4 dam1121. Lets see how that goes :D
Yes, I know. May try removing them over the weekend. Do you have an 1121?
If you go back a few pages you’ll find my dual mono dam1121 setup with p2p wired tube buffer and TVC.
I haven’t done the mod myself yet because I want to upgrade the hole system with stacked dual mono so 2 dam1121 per mono side in parallel and 2 TVCs one before and one after the buffer (and adding dc heater) and that is being developed - some PCBs an Arduino to control everything and a Raspberry displaying roon. So this will take place when I open the existing DAC to rearrange.
