Building a symmetrical PSU B1 buffer
Done. (Almost...)
Today I finished my B1. The wire, attenuator and sinks still need attention but it is good enough to be put in production.
It sounds very good (no break-in time yet) in he sense that the music was still very detailed. If it changed anything I will never know as I removed the selector switch and attenuator from my tube-amp and I do not plan to put it back. I just needed a pre for my coming F5 and Tubelab SE.
Thank you very much for the circuit, pcb and support!!
Jeroen
you want improvement ?
wire all signal routes with decent wire - 0,25mm dia , and less
I'm using Cu enameled with silver , 0,25mm dia , and there is always positive result - comparing to even Silver wire but with bigger dia
Got mine working, no case yet. Relays are different because could not find the Omrons close, but they work fine.
The DC offsets are -2.1mV and 0mV when the relay goes on, and they drift to 0.7mV and -0.7mV slowly, takes few minutes. Maybe need to do some changes to get them lower.
Under a mV in a few mins is a very fine result.
Ok, I will try that.
I see PartsConnexion only has 28AWG silver, but I love the cotton tubing to go with it. 😀
I suggest... Go for thinner wire in any material is way more important than the material it self.
Thinner copper wire will sound better than thicker silver wire... even for speaker cables. Crazy? Try it!
Nice thin wire IMO: Farnell Export
And always use solid core wire for signal and speaker cables... or better... use foil!
Thank you. I tried clicking on a number of links on that page other than "Franell Export" and none of those others work. Clicking on "Farnell Export" in the upper right hand corner and then clicking on the link again was the only combination that worked for me.
I'm using Cu enameled with silver , 0,25mm dia , and there is always positive result - comparing to even Silver wire but with bigger dia -- ZenMod
By "Cu enameled with silver" do you mean "silver plated wire" and not "enameled wire" as in the stuff used to wind coils/transformers?!
If so, with what insulation, none, cotton, ptfe ?
How critical are the strings of leds? I'm measuring 1.94v & 1.98v in the bunch of 64 I sorted (with my m3 semiconductor analyzer).
Critical no, preferable yes. So to meet the prototype Iccs and Vout. You will just get a little more current and Vout. It may have a sweeter tone with 1.8V Leds or it may not in your system. Nothing terrible.
Ok, I got my leds installed. I powered it up without any inputs or outputs attached to it. I noticed the leds on the bottom lit up and then faded - but the power led stayed lit. (I guess that's a good sign, lol)
Is there anything I should be looking out for - voltages, etc, at certain points?
