I'm little confused in what kind of transformer secondaries are required for powering BIII via Placid HD? At TPA website it's 9+9, but Placid accepts only one 9VAC line input, if I'm not mistake. So, other secondary is not used?
Oh man, I left out the artist's palette on mine. Is that why the music lacks color?
Yeah, I knew I should have cleaned off the (wife's) desk first...🙄
You only need a single secondary. We sell a dual secondary tranformer for flexibility across products. You can use the two secondaries in parallel for increased current output.
No - cleaning our wive's desks!Taking over our wive's desks?
Thanks for reply Brian! The last regarding transformer, 9VAC shall be under full load or in stand by without any load?
Can you publish a schematic for 4-Channel S/PDIF (or AES-EBU) Input Module?
Read more carefully: 'Twisted Pear Audio is on vacation until 23-Oct-2011. (All items are out of stock until we return.)'Placid HD and Placid bipolar also no stock
Russ,
Can Sidecar board be stacked on top of SPDIF-4 module without using ribbon cable? Thanks.
George
George
Russ,
George
Yes. The screw holes line up. You can use a pin header to connect them, or you could mate them directly and solder the pads together even...
Yes it can. You would just need to get a couple of headers for that.
you might also want to adjust standoff lengths.
As Brian also said you could simply solder short wires in the holes with the boards lined up.
Would you happen to have a suitable order numbers for such connectors?Yes it can. You would just need to get a couple of headers for that.
There are a billion different types of board-to-board connectors.
Nic
Something like this would work just fine:
15-44-5820 Molex Headers & Wire Housings
Then just a 2 x 10 2.54mm pitch standard male pin header for the other side.
Received BIII kit yestarday. Thank you Brian!
Already broke a lock of 20-pin input connector.🙁
Russ
Can you advice how to install leds on Placid and BIII, they have no keys on its bodies?
To which BIII DIN pins connect MCLK, LRCK1, LRCK2, SCLK1, SCLK2 as TTL PCM source? Is GND required, I2S has no such line?
Transformer secondary 9VAC shall be under load?
Jumpers for BIII are zero ohm smd resistors in a reel? Are there no jumpers included for ADDR, reset?
I received two 100nF C4 caps with Placid kit by a mistake or it's required somewhere?
Regards.
Russ
Regards.
Russ
They do, they are just small. Google "LED" and then refer to the markings on the PCB.
You need to read the integration guide. Then get back to me.
Cheers!
Russ
Perfect timing! Thanks for this information guys. I had it mocked up on the bench considering something like that. Am I correct to assume that it would work both ways? Mux to Sidecar and Sidecar to BIII?
- More Vendors...
- Twisted Pear
- Buffalo III - flexibility without compromise.
