Buffalo DAC (ESS Sabre 9008)
caps
I have been tweaking my design and it's certainly worthwhile to try several types of filter caps. My design isn't the Buffalo, but I can hear differences between caps in my design. You guys should try several and pick out the one you like best. You will find some are good... and some will suck the life out of your music.
Here are some that I have tried and confirm they sound good.
Panasonic ECQ-P(Z) polypropylene film caps at DigiKey.
http://dkc3.digikey.com/PDF/T083/P1686.pdf
WIMA FKP2 at Mouser.
http://www.mouser.com/catalog/636/835.pdf
There are lots of very expensive caps at some audiophile web sites, and I haven't tried many of them, and I'nm not sure they are worth the expense.
The Panasonic ECQ-P(Z) is being discontinued at DigiKey and I don't know what Panny is going to replace it with.
If anyone likes another type, please post it. 😀
"I have some of the "teddyreg" regulator boards…"
woodturner-fran, please email me – as a new member here, I'm under moderation and cannot email anyone. I'm interested in such boards.
"When my current stock of Panasonics run out, I will be switching the kits over to Wima FKP."
Brian, to what module are you referring to and where in the circuit?
Joshua_G said:
"I have some of the "teddyreg" regulator boards�quot;
woodturner-fran, please email me �as a new member here, I'm under moderation and cannot email anyone. I'm interested in such boards.
I don't know how you guys know about FKP2 0.01uf .
I have used them for digital section and got good results.
they are high resolution and with extended highs.
In the mean time, the sound is not too tight as some other square CAPs.
However, it's only applicable for High speed applications.
They are totally useless in analog section except for filter.
